path: root/include/linux/ata.h
2013-10-27libata: Add some missing command descriptionsRobert Hancock
Add some missing command enumerations from the ATA-8 ACS-3 spec into include/linux/ata.h, and add the corresponding human-readable command descriptions in libata-eh.c. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-08-25libata: Add support for SEND/RECEIVE FPDMA QUEUEDMarc Carino
Add support for the following ATA opcodes, which are present in SATA 3.1 and T13 ATA ACS-3: SEND FPDMA QUEUED RECEIVE FPDMA QUEUED Signed-off-by: Marc Carino <marc.ceeeee@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-07-16libata: move 'struct ata_taskfile' and friends from ata.h to libata.hSergei Shtylyov
Move 'struct ata_taskfile', ata_prot_flags() and their friends from <linux/ata.h> to <linux/libata.h>. They were misplaced from the beginning, as <linux/ata.h> should cover ATA/ATAPI and related standards only -- to which the aforementioned structure and function have only remote relation. I would have moved 'enum ata_tf_protocols' closely related to 'struct ata_taskfile' but it unfortunately gets used by 'drivers/ide/ide-ioctls.c'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-04-03libata: Use integer return value for atapi_command_packet_setShan Hai
The function returns type of ATAPI drives so it should return integer value. The commit 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) since v2.6.39 changed the type of return value from int to bool, the change would cause all of the ATAPI class drives to be treated as TYPE_TAPE and the max_sectors of the drives to be set to 65535 because of the commit f8d8e5799b7(libata: increase 128 KB / cmd limit for ATAPI tape drives), for the function would return true for all ATAPI class drives and the TYPE_TAPE is defined as 0x01. Cc: stable@vger.kernel.org Signed-off-by: Shan Hai <shan.hai@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-01-14[libata] replace sata_settings with devslp_timingShane Huang
NCQ capability was used to check availability of SATA Settings page from Identify Device Data Log, which contains DevSlp timing variables. It does not work on some HDDs and leads to error messages. IDENTIFY word 78 bit 5(Hardware Feature Control) can't work either because it is only the sufficient condition of Identify Device data log, not the necessary condition. This patch replaced ata_device->sata_settings with ->devslp_timing to only save DevSlp timing variables(8 bytes), instead of the whole SATA Settings page(512 bytes). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=51881 Reported-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Shane Huang <shane.huang@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-09-13ahci: implement aggressive SATA device sleep supportShane Huang
Device Sleep is a feature as described in AHCI 1.3.1 Technical Proposal. This feature enables an HBA and SATA storage device to enter the DevSleep interface state, enabling lower power SATA-based systems. Aggressive Device Sleep enables the HBA to assert the DEVSLP signal as soon as there are no commands outstanding to the device and the port specific Device Sleep idle timer has expired. This enables autonomous entry into the DevSleep interface state without waiting for software in power sensitive systems. This patch enables Aggressive Device Sleep only if both host controller and device support it. Tested on AMD reference board together with Device Sleep supported device sample. Signed-off-by: Shane Huang <shane.huang@amd.com> Reviewed-by: Aaron Lu <aaron.lwe@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-09-13ata: define enum constants for IDENTIFY DEVICEShane Huang
Define enumeration constants for IDENTIFY DEVICE words. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-06-29libata: detect Device Attention supportLin Ming
Add a new flag ATA_DFLAG_DA to indicate that device supports "Device Attention". Acked-by: Aaron Lu <aaron.lu@amd.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-15libata: Use 'bool' return value for ata_id_XXXHannes Reinecke
Most ata_id_XXX inlines are simple tests, so we should set the return value to 'bool' here. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-14libata: Include WWN ID in inquiry VPD emulationHannes Reinecke
As per SAT-3 the WWN ID should be included in the VPD page 0x83 (device identification) emulation. Signed-off-by: Hannes Reinecke <hare@suse.de> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2010-10-21[libata] support for > 512 byte sectors (e.g. 4K Native)Grant Grundler
This change enables my x86 machine to recognize and talk to a "Native 4K" SATA device. When I started working on this, I didn't know Matthew Wilcox had posted a similar patch 2 years ago: http://git.kernel.org/?p=linux/kernel/git/willy/ata.git;a=shortlog;h=refs/heads/ata-large-sectors Gwendal Grignou pointed me at the the above code and small portions of this patch include Matthew's work. That's why Mathew is first on the "Signed-off-by:". I've NOT included his use of a bitmap to determine 512 vs Native for ATA command block size - just used a simple table. And bugs are almost certainly mine. Lastly, the patch has been tested with a native 4K 'Engineering Sample' drive provided by Hitachi GST. Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Signed-off-by: Grant Grundler <grundler@google.com> Reviewed-by: Gwendal Grignou <gwendal@google.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: prd is BMDMA specificTejun Heo
struct ata_prd and ap->prd are BMDMA specific. Add bmdma_ prefix to them and move them inside CONFIG_ATA_SFF. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-04-08libata: Fix accesses at LBA28 boundary (old bug, but nasty) (v2)Mark Lord
Most drives from Seagate, Hitachi, and possibly other brands, do not allow LBA28 access to sector number 0x0fffffff (2^28 - 1). So instead use LBA48 for such accesses. This bug could bite a lot of systems, especially when the user has taken care to align partitions to 4KB boundaries. On misaligned systems, it is less likely to be encountered, since a 4KB read would end at 0x10000000 rather than at 0x0fffffff. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-01ata: Detect Delkin Devices compact flashBen Gardner
I have a Delkin Devices compact flash card that isn't being recognized using the SATA/PATA drivers. The card is recognized and works with the deprecated ATA drivers. The error I am seeing is: ata1.00: failed to IDENTIFY (device reports invalid type, err_mask=0x0) I tracked it down to ata_id_is_cfa() in include/linux/ata.h. The Delkin card has id[0] set to 0x844a and id[83] set to 0. This isn't what the kernel expects and is probably incorrect. The simplest work-around is to add a check for 0x844a to ata_id_is_cfa(). Signed-off-by: Ben Gardner <gardner.ben@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-02-04libata: fix ata_id_logical_per_physical_sectorsChristoph Hellwig
The value we get from the low byte of the ATA_ID_SECTOR_SIZE word is not not a plain multiple, but the log of it, so fix the helper to give the correct answer. Without this we'll get an incorrect minimal I/O size in the block limits VPD page for 4k sector drives. Also change the return value of ata_id_logical_per_physical_sectors to u16 for the unlikely case of very large logical sectors. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03libata: Clarify ata_set_lba_range_entries functionMartin K. Petersen
ata_set_lba_range_entries used the variable max for two different things which was confusing. Make the function take a buffer size in bytes as argument and return the used buffer size upon completion. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03libata: Report zeroed read after TRIM and max discard sizeMartin K. Petersen
Our current TRIM payload is a single sector that can accommodate 64 * 65535 blocks being unmapped. Report this value in the Block Limits Maximum Unmap LBA count field. If a storage device supports TRIM and the DRAT and RZAT bits are set, report TPRZ=1 in Read Capacity(16). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03libata: add translation for SCSI WRITE SAME (aka TRIM support)Christoph Hellwig
Add support for the ATA TRIM command in libata. We translate a WRITE SAME 16 command with the unmap bit set into an ATA TRIM command and export enough information in READ CAPACITY 16 and the block limits EVPD page so that the new SCSI layer discard support will driver this for us. Note that I hardcode the WRITE_SAME_16 opcode for now as the patch to introduce the symbolic is not in 2.6.32 yet but only in the SCSI tree - as soon as it is merged we can fix it up to properly use the symbolic name. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06libata: implement more acpi filtering optionsTejun Heo
Currently libata-acpi can only filter DIPM among SATA feature enables via _GTF. This patch adds the capability to filter out FPDMA non-zero offset, in-order guarantee and auto-activation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06libata: cosmetic updatesTejun Heo
We're about to add more SATA_* and ATA_ACPI_FILTER_* constants. Reformat them in preparation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01libata: add command name parsing for error outputRobert Hancock
This patch improve libata's output for error/notification messages to allow easier comprehension and debugging: When ATAPI commands issued through the SCSI layer fail, use SCSI functions to print the CDB in human-readable form instead of just dumping out the CDB in hex. Print out the name of the failed command (as defined by the ATA specification) in error handling output along with the raw register contents. When reporting status of ACPI taskfile commands executed on resume, also output the names of the commands being executed (or not) in readable form. Since the extra data for printing command names increases kernel size slightly, a config option has been added to allow disabling command name output (as well as some of the error register parsing) for those highly sensitive to kernel text size. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01[libata] add DMA setup FIS auto-activate featureShaohua Li
Hopefully results in fewer on-the-wire FIS's and no breakage. We'll see! Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-15ata: add ata_id_pio_need_iordy() helper (v2)Bartlomiej Zolnierkiewicz
v2: Minor fixes per Sergei's review. Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-15libata: Media rotation rate and form factor heuristicsMartin K. Petersen
This patch provides new heuristics for parsing both the form factor and media rotation rate ATA IDENFITY words. The reported ATA version must be 7 or greater and the device must return values defined as valid in the standard. Only then are the characteristics reported to SCSI via the VPD B1 page. This seems like a reasonable compromise to me considering that we have been shipping several kernel releases that key off the rotation rate bit without any version checking whatsoever. With no complaints so far. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-06ata: Add TRIM infrastructureMatthew Wilcox
This is common code shared between the IDE and libata implementations Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-26Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (35 commits) [libata] Improve timeout handling [libata] Drain data on errors pata_sc1200: Activate secondary channel pata_artop: Serializing support [libata] ahci: correct enclosure LED state save [libata] More robust parsing for IDENTIFY DEVICE multi_count field sata_mv: fix LED blinking for SoC+NCQ sata_mv: optimize IRQ coalescing for 8-port chips sata_mv: implement IRQ coalescing (v2) sata_mv: cosmetic preparations for IRQ coalescing pata-rb532-cf: platform_get_irq() fix ignored failure pata_efar: fix *dma_mask pata_radisys: fix mwdma_mask to exclude mwdma0 [libata] convert drivers to use ata.h mode mask defines include/linux/ata.h: add some more transfer masks ahci: Blacklist HP Compaq 6720s that spins off disks during ACPI power off [libata] sata_mv: Implement direct FIS transmission via mv_qc_issue_fis(). [libata] Export ata_pio_queue_task() so that it can be used from sata_mv. [libata] sata_mv: Add a new mv_sff_check_status() function to sata_mv. [libata] sata_mv: Tighten up interrupt masking in mv_qc_issue() ...
2009-03-24include/linux/ata.h: add some more transfer masksErik Inge Bolsø
Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24ide: remove broken EXABYTENEST supportBartlomiej Zolnierkiewicz
do_identify() marks EXABYTENEST device as non-present and frees drive->id so enable_nest() has absolutely no chance of working. The code was like this since at least 2.6.12-rc2 and nobody has noticed so just remove broken EXABYTENEST support. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-05ata: add CFA specific identify data wordsSergei Shtylyov
Declare CFA specific identify data words 162 and 163 for future use. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> [bart: update patch summary/description] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-02ide/libata: fix ata_id_is_cfa() (take 4)Sergei Shtylyov
When checking for the CFA feature set support, ata_id_is_cfa() tests bit 2 in word 82 of the identify data instead the word 83; it also checks the ATA/PI version support in the word 80 (which the CompactFlash specifications have as reserved), this having no slightest chance to work on the modern CF cards that don't have 0x848A in the word 0... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-10ide: lba_capacity_is_ok() -> ata_id_is_lba_capacity_ok()Bartlomiej Zolnierkiewicz
Rename lba_capacity_is_ok() to ata_id_is_lba_capacity_ok() and move it to <linux/ata.h> (remove needless parens while at it). Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: ide_id_to_hd_driveid() -> ata_id_to_hd_driveid()Bartlomiej Zolnierkiewicz
Rename ide_id_to_hd_driveid() to ata_id_to_hd_driveid() and move it to <linux/ata.h>. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: ide_id_has_flush_cache_ext() -> ata_id_flush_ext_enabled()Bartlomiej Zolnierkiewicz
* Add ata_id_flush_ext_enabled() inline helper to <linux/ata.h>. * ide_id_has_flush_cache_ext() -> ata_id_flush_ext_enabled() The latter one also checks if the command is marked as supported in word 83 and validity of words 83 & 86. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: ide_id_has_flush_cache() -> ata_id_flush_enabled()Bartlomiej Zolnierkiewicz
* Add ata_id_flush_enabled() inline helper to <linux/ata.h>. * ide_id_has_flush_cache() -> ata_id_flush_enabled() The latter one also checks if the command is marked as supported in word 83 and validity of words 83 & 86. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: idedisk_supports_lba48() -> ata_id_lba48_enabled()Bartlomiej Zolnierkiewicz
* Add ata_id_lba48_enabled() inline helper to <linux/ata.h>. * idedisk_supports_lba48() -> ata_id_lba48_enabled() The latter one also checks validity of words 83 & 86. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: ide_dev_is_sata() -> ata_id_is_sata()Bartlomiej Zolnierkiewicz
* Use optimized ATA version check from Sergei in ata_id_is_sata(). * ide_dev_is_sata() -> ata_id_is_sata() Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10Merge branch 'for-2.6.28' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.28' of git://git.kernel.dk/linux-2.6-block: (132 commits) doc/cdrom: Trvial documentation error, file not present block_dev: fix kernel-doc in new functions block: add some comments around the bio read-write flags block: mark bio_split_pool static block: Find bio sector offset given idx and offset block: gendisk integrity wrapper block: Switch blk_integrity_compare from bdev to gendisk block: Fix double put in blk_integrity_unregister block: Introduce integrity data ownership flag block: revert part of d7533ad0e132f92e75c1b2eb7c26387b25a583c1 bio.h: Remove unused conditional code block: remove end_{queued|dequeued}_request() block: change elevator to use __blk_end_request() gdrom: change to use __blk_end_request() memstick: change to use __blk_end_request() virtio_blk: change to use __blk_end_request() blktrace: use BLKTRACE_BDEV_SIZE as the name size for setup structure block: add lld busy state exporting interface block: Fix blk_start_queueing() to not kick a stopped queue include blktrace_api.h in headers_install ...
2008-10-09libata: set queue SSD flag for SSD devicesJens Axboe
SSD devices should give an RPM setting of 1 in word 217 of the ID page. If we see such a device, tell the block layer about it. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-09-29[libata] Introduce ata_id_has_unload()Elias Oltmanns
Add a function to check an ATA device's id for head unload support as specified in ATA-7. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-13[libata] LBA28/LBA48 off-by-one bug in ata.hTaisuke Yamada
I recently bought 3 HGST P7K500-series 500GB SATA drives and had trouble accessing the block right on the LBA28-LBA48 border. Here's how it fails (same for all 3 drives): # dd if=/dev/sdc bs=512 count=1 skip=268435455 > /dev/null dd: reading `/dev/sdc': Input/output error 0+0 records in 0+0 records out 0 bytes (0 B) copied, 0.288033 seconds, 0.0 kB/s # dmesg ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 ata1.00: BMDMA stat 0x25 ata1.00: cmd c8/00:08:f8:ff:ff/00:00:00:00:00/ef tag 0 dma 4096 in res 51/04:08:f8:ff:ff/00:00:00:00:00/ef Emask 0x1 (device error) ata1.00: status: { DRDY ERR } ata1.00: error: { ABRT } ata1.00: configured for UDMA/33 ata1: EH complete ... After some investigations, it turned out this seems to be caused by misinterpretation of the ATA specification on LBA28 access. Following part is the code in question: === include/linux/ata.h === static inline int lba_28_ok(u64 block, u32 n_block) { /* check the ending block number */ return ((block + n_block - 1) < ((u64)1 << 28)) && (n_block <= 256); } HGST drive (sometimes) fails with LBA28 access of {block = 0xfffffff, n_block = 1}, and this behavior seems to be comformant. Other drives, including other HGST drives are not that strict, through. >From the ATA specification: (http://www.t13.org/Documents/UploadedDocuments/project/d1410r3b-ATA-ATAPI-6.pdf) 8.15.29 Word (61:60): Total number of user addressable sectors This field contains a value that is one greater than the total number of user addressable sectors (see 6.2). The maximum value that shall be placed in this field is 0FFFFFFFh. So the driver shouldn't use the value of 0xfffffff for LBA28 request as this exceeds maximum user addressable sector. The logical maximum value for LBA28 is 0xffffffe. The obvious fix is to cut "- 1" part, and the patch attached just do that. I've been using the patched kernel for about a month now, and the same fix is also floating on the net for some time. So I believe this fix works reliably. Just FYI, many Windows/Intel platform users also seems to be struck by this, and HGST has issued a note pointing to Intel ICH8/9 driver. "28-bit LBA command is being used to access LBAs 29-bits in length" http://www.hitachigst.com/hddt/knowtree.nsf/cffe836ed7c12018862565b000530c74/b531b8bce8745fb78825740f00580e23 Also, *BSDs seems to have similar fix included sometime around ~2004, through I have not checked out exact portion of the code. Signed-off-by: Taisuke Yamada <tai@rakugaki.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-18ata: add missing ATA_* definesBartlomiej Zolnierkiewicz
Add missing ATA_* defines to <linux/ata.h>. Also add ATAPI_{LFS,EOM,ILI,IO,CODE} defines while at it. Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-18ata: add missing ATA_CMD_* definesBartlomiej Zolnierkiewicz
Add missing ATA_CMD_* defines to <linux/ata.h>. Also add ATA_EXABYTE_ENABLE_NEST, SETFEATURES_AAM_* and ATA_SMART_* defines while at it. Partially based on earlier work by Chris Wedgwood. Acked-by: Chris Wedgwood <cw@f00f.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-18ata: add missing ATA_ID_* defines (take 2)Bartlomiej Zolnierkiewicz
Add missing ATA_ID_* defines and update {ata,atapi}_*() inlines accordingly. The currently unused defines are needed for the forthcoming drivers/ide/ changes. v2: Add ATA_ID_SPG. Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-24libata: automatically use DMADIR if drive/bridge requires itTejun Heo
Back in 2.6.17-rc2, a libata module parameter was added for atapi_dmadir. That's nice, but most SATA devices which need it will tell us about it in their IDENTIFY PACKET response, as bit-15 of word-62 of the returned data (as per ATA7, ATA8 specifications). So for those which specify it, we should automatically use the DMADIR bit. Otherwise, disc writing will fail by default on many SATA-ATAPI drives. This patch adds ATA_DFLAG_DMADIR and make ata_dev_configure() set it if atapi_dmadir is set or identify data indicates DMADIR is necessary. atapi_xlat() is converted to check ATA_DFLAG_DMADIR before setting DMADIR. Original patch is from Mark Lord. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata annotations and fixesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: rename ATA_PROT_ATAPI_* to ATAPI_PROT_*Tejun Heo
ATA_PROT_ATAPI_* are ugly and naming schemes between ATA_PROT_* and ATA_PROT_ATAPI_* are inconsistent causing confusion. Rename them to ATAPI_PROT_* and make them consistent with ATA counterpart. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-23libata: add ATA_CBL_PATA_IGNTejun Heo
ATA_CBL_PATA_UNK indicates that the cable type can't be determined from the host side and might be either 80c or 40c. libata applies drive or other generic limit in this case. However, there are controllers where both host and drive side detections are misimplemented and the driver has to rely solely on private method - peeking BIOS or ACPI configuration or using some other private mechanism. This patch adds ATA_CBL_PATA_IGN which tells libata to ignore the cable type completely and just let the LLD determine the transfer mode via host transfer mode masks and ->mode_filter(). Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: implement protocol testsTejun Heo
Implement protocol tests - ata_is_atapi(), ata_is_nodata(), ata_is_pio(), ata_is_dma(), ata_is_ncq() and ata_is_data() and use them to replace is_atapi_taskfile() and hard coded protocol tests. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-23libata: Disable ATA8-ACS proposed Trusted Computing features by defaultAlan Cox
Historically word 48 in the identify data was used to mean 32bit I/O was supported for VLB IDE etc. ATA8 reassigns this word to the Trusted Computing Group, where it is used for TCG features. This means that an ATA8 TCG drive is going to trigger 32bit I/O on some systems which will be funny. Anyway we need to sort this out ready for ATA8 so: - Reorder the ata.h header a bit so the ata_version function occurs early in it - Make dword_io check the ATA version - Add an ATA8 version checking TCG presence test While we are at it the current drafts have a flaw where it may not be possible to disable TCG features at boot (and opt out of the trusted model) as TCG intends because it relies on presence of a different optional feature (DCS). Handle this in software by refusing the TCG commands if libata.allow_tpm is not set. (We must make it possible as some environments such as proprietary VDR devices will doubtless want to use it to lock up content) Finally as with CPRM print a warning so that the user knows they may not be able to full access and use the device. Signed-off-by: Alan Cox <alan@redhat.com>
2008-01-15libata: correct handling of TSS DVDAlan Cox
Devices that misreport the validity bit for word 93 look like SATA. If they are on the blacklist then we must not test for SATA but assume 40 wire in the 40 wire case (The TSSCorp reports 80 wire on SATA it seems!) Signed-off-by: Alan Cox <alan@redhat.com> Cc: Tejun Heo <htejun@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
