It's unused, everyone is using the _unlocked variant only.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Rob Clark <robdclark@gmail.com>
Signed-off-by: Dave Airlie <airlied@gmail.com>
drm_gem_object_init() and drm_gem_private_object_init() do exactly the
same (except for shmem alloc) so make the first use the latter to reduce
code duplication.
Also drop the return code from drm_gem_private_object_init(). It seems
unlikely that we will extend it any time soon so no reason to keep it
around. This simplifies code paths in drivers, too.
Last but not least, fix gma500 to call drm_gem_object_release() before
freeing objects that were allocated via drm_gem_private_object_init().
That isn't actually necessary for now, but might be in the future.
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Acked-by: Rob Clark <robdclark@gmail.com>
Only ever re-cleared in drm_setup, otherwise completely unused.
There's no other caller from driver code, so we can fold this in.
Again totally unused, so just remove them.
Again completely unused, so just remove it.
Completely unused, so just remove them.
Only ever assigned in the context code for real, with no readers
anywhere. Remove it.
No one ever waits on this waitqueue, so the wake_up call is wasted.
Remove it all.
It doesn't do anything, so kill the code.
git://people.freedesktop.org/~danvet/drm-intel into drm-next
Highlights:
- follow-up refactoring after the shared dpll rework that landed in 3.11
- oddball prep cleanups from Ben for ppgtt
- encoder->get_config state tracking infrastructure from Jesse
- used by the experimental fastboot support from Jesse (disabled by
default)
- make the error state file official and add it to our sysfs interface
(Mika)
- drm_mm prep changes from Ben, prepares to embedd the drm_mm_node (which
will be used by the vma rework later on)
- interrupt handling rework, follow up cleanups to the VECS enabling, hpd
storm handling and fifo underrun reporting.
- Big pile of smaller cleanups, code improvements and related stuff.
* tag 'drm-intel-next-2013-07-12' of git://people.freedesktop.org/~danvet/drm-intel: (72 commits)
drm/i915: clear DPLL reg when disabling i9xx dplls
drm/i915: Fix up cpt pixel multiplier enable sequence
drm/i915: clean up vlv ->pre_pll_enable and pll enable sequence
drm/i915: move error state to own compilation unit
drm/i915: Don't attempt to read an unitialized stack value
drm/i915: Use for_each_pipe() when possible
drm/i915: don't enable PM_VEBOX_CS_ERROR_INTERRUPT
drm/i915: unify ring irq refcounts (again)
drm/i915: kill dev_priv->rps.lock
drm/i915: queue work outside spinlock in hsw_pm_irq_handler
drm/i915: streamline hsw_pm_irq_handler
drm/i915: irq handlers don't need interrupt-safe spinlocks
drm/i915: kill lpt pch transcoder->crtc mapping code for fifo underruns
drm/i915: improve GEN7_ERR_INT clearing for fifo underrun reporting
drm/i915: improve SERR_INT clearing for fifo underrun reporting
drm/i915: extract ibx_display_interrupt_update
drm/i915: remove unused members from drm_i915_private
drm/i915: don't frob mm.suspended when not using ums
drm/i915: Fix VLV DP RBR/HDMI/DAC PLL LPF coefficients
drm/i915: WARN if the bios reserved range is bigger than stolen size
drivers/gpu/drm/i915/i915_gem.c
With the previous patch we no longer actually create a node, we simply
find the correct hole and occupy it. This very well could have been
squashed with the last patch, but since I already had David's review, I
figured it's easiest to keep it distinct.
Also update the users in i915. Conveniently this is the only user of the
interface.
CC: David Airlie <airlied@linux.ie>
CC: <dri-devel@lists.freedesktop.org>
Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
Acked-by: David Airlie <airlied@linux.ie>
For an upcoming patch where we introduce the i915 VMA, it's ideal to
have the drm_mm_node as part of the VMA struct (ie. it's pre-allocated).
Part of the conversion to VMAs is to kill off obj->gtt_space. Doing this
will break a bunch of code, but amongst them are 2 callers of
drm_mm_create_block(), both related to stolen memory.
It also allows us to embed the drm_mm_node into the object currently
which provides a nice transition over to the new code.
v2: Reordered to do before ripping out obj->gtt_offset.
Some minor cleanups made available because of reordering.
v3: s/continue/break on failed stolen node allocation (David)
Set obj->gtt_space on failed node allocation (David)
Only unref stolen (fix double free) on failed create_stolen (David)
Free node, and NULL it in failed create_stolen (David)
Add back accidentally removed newline (David)
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
We can use prime helpers instead.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Instead of using the dma_buf functionality for GEM CMA, we can use prime
helpers if we can provide low-level hook functions for GEM CMA.
This adds to call low-level mmap() from prime helpers.
drm/i915 is the only user of the color allocation handling and
switched to insert_node a while ago. So we can ditch this.
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
There is no reason to return "int" as this function never fails.
Furthermore, several drivers (ast, sis) already depend on this.
This reverts commit 160954b7bca43da7cd3cfbce310e6df919a8216e.
This was rearming the workqueue with a 0 timeout, causing
a WARN_ON, and possible loop.
Daniel writes:
"I've looked a bit into this and I think we need to have a separate
work struct for recovering these lost hotplug events since the
continuous self-rearming case is a real risk (e.g. if a connector
flip-flops all the time). At least I don't see a sane way to block out
re-arming with the current code in a simple way. So reverting the
offender seems like the right thing and I'll go back to the drawing
board for 3.12."
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Makes lockdep a lot more useful.
Now that the code is compatible in semantics, flip the switch.
Use ww_mutex instead of the homegrown implementation.
ww_mutex uses -EDEADLK to signal that the caller has to back off,
and -EALREADY to indicate this buffer is already held by the caller.
ttm used -EAGAIN and -EDEADLK for those, respectively. So some changes
were needed to handle this correctly.
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
This commit converts the source of the val_seq counter to
the ww_mutex api. The reservation objects are converted later,
because there is still a lockdep splat in nouveau that has to
resolved first.
into drm-next
This is the pull request for radeon for 3.11. Highlights include:
- Support for CIK (Sea Islands) asics: 3D, compute, UVD
- DPM (Dynamic Power Management) support for 6xx-SI
- ASPM support for 6xx-SI
- Assorted bug fixes
* 'drm-next-3.11' of git://people.freedesktop.org/~agd5f/linux: (168 commits)
drm/radeon/SI: fix TDP adjustment in set_power_state
drm/radeon/NI: fix TDP adjustment in set_power_state
drm/radeon: fix endian issues in atombios dpm code
drm/radeon/dpm: fix UVD clock setting on SI
drm/radeon/dpm: fix UVD clock setting on cayman
drm/radeon/dpm: add support for setting UVD clock on rv6xx
drm/radeon/dpm: add support for setting UVD clock on rs780
drm/radeon: fix typo in ni_print_power_state
drm/radeon: fix typo in cik_select_se_sh()
drm/radeon/si: fix typo in function name
drm/radeon/dpm: fix typo in setting uvd clock
drm/radeon/dpm: add dpm_set_power_state failure output (si)
add dpm_set_power_state failure output (7xx-ni)
drm/radeon/dpm: add dpm_set_power_state failure output (7xx-ni)
drm/radeon/dpm: add dpm_enable failure output (si)
drm/radeon/dpm: add dpm_enable failure output (7xx-ni)
drm/radeon/kms: add dpm support for SI (v7)
drm/radeon: switch SI to use radeon_ucode.h
drm/radeon: add SI to r600_is_internal_thermal_sensor()
drm/radeon/dpm/rs780: properly catch errors in dpm setup
Last 3.11 feature pull. I have a few odds bits and pieces and fixes in my
queue, I'll sort them out later on to see what's for 3.11-fixes and what's
for 3.12. But nothing to hold this here up imo.
Highlights:
- more hangcheck work from Mika and Chris to prepare for arb robustness
- trickle feed fixes from Ville
- first parts of the shared pch pll rework, with some basic hw state
readout and cross-checking (this shuts up the confused pch pll refcount
WARN that Linus just recently forwarded)
- Haswell audio power well support from Wang Xingchao (alsa bits acked by
Takashi)
- some cleanups and asserts sprinkling around the plane/gamma enabling
sequence from Ville
- more gtt refactoring from Ben
- clear up the adjusted->mode vs. pixel clock vs. port clock confusion
- 30bpp support, this time for real hopefully
* tag 'drm-intel-next-2013-06-18' of git://people.freedesktop.org/~danvet/drm-intel: (97 commits)
drm/i915: remove a superflous semi-colon
drm/i915: Kill useless "Enable panel fitter" comments
drm/i915: Remove extra "ring" from error message
drm/i915: simplify the reduced clock handling for pch plls
drm/i915: stop killing pfit on i9xx
drm/i915: explicitly set up PIPECONF (and gamma table) on haswell
drm/i915: set up PIPECONF explicitly for i9xx/vlv platforms
drm/i915: set up PIPECONF explicitly on ilk-ivb
drm/i915: find guilty batch buffer on ring resets
drm/i915: store ring hangcheck action
drm/i915: add batch bo to i915_add_request()
drm/i915: change i915_add_request to macro
drm/i915: add i915_gem_context_get_hang_stats()
drm/i915: add struct i915_ctx_hang_stats
drm/i915: Try harder to disable trickle feed on VLV
drm/i915: fix up pch pll enabling for pixel multipliers
drm/i915: hw state readout and cross-checking for shared dplls
drm/i915: WARN on lack of shared dpll
drm/i915: split up intel_modeset_check_state
drm/i915: extract readout_hw_state from setup_hw_state
drivers/gpu/drm/i915/intel_display.c
drivers/gpu/drm/i915/intel_fb.c
drivers/gpu/drm/i915/intel_sdvo.c
Required for certain driver calculations. Code
was written by Christian König and ported to the
drm by me.
v2: fix 64 bit divides
v3: fix 64 bit for real (math64.h)
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
So it looks like for virtual hw cursors on QXL we need to inform
the "hw" device what the cursor hotspot parameters are. This
makes sense if you think the host has to draw the cursor and interpret
clicks from it. However the current modesetting interface doesn't support
passing the hotspot information from userspace.
This implements a new cursor ioctl, that takes the hotspot info as well,
userspace can try calling the new interface and if it gets -ENOSYS it means
its on an older kernel and can just fallback.
There's a race window (small for hpd, 10s large for polled outputs)
where userspace could sneak in with an unrelated connnector probe
ioctl call and eat the hotplug event (since neither the hpd nor the
poll code see a state change).
To avoid this, check whether the connector state changes in all other
->detect calls (in the current helper code that's only probe_single)
and if that's the case, fire off a hotplug event. Note that we can't
directly call the hotplug event handler, since that expects that no
locks are held (due to reentrancy with the fb code to update the kms
console).
Also, this requires that drivers using the probe_single helper
function set up the poll work. All current drivers do that already,
and with the reworked hpd handling there'll be no downside to
unconditionally setting up the poll work any more.
Drivers are allowed (actually have to) disable unrelated crtcs in
their ->set_config callback (when we steal all the connectors from
that crtc). If they do that they'll clear crtc->fb to NULL.
Which results in a refcount leak, since the drm core is keeping track
of that reference.
To fix this track the old fb of all crtcs and adjust references for
all of them. Of course, since we only hold an additional reference for
the fb for the current crtc we need to increase refcounts before we
drop the old one.
This approach has the benefit that it inches us a bit closer to an
atomic modeset world, where we want to update the config of all crtcs
in one step.
This regression has been introduce in the framebuffer refcount
conversion, specifically in
commit b0d1232589df5575c5971224ac4cb30e7e525884
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Tue Dec 11 01:07:12 2012 +0100
drm: refcounting for crtc framebuffers
Reported-by: Russell King <linux@arm.linux.org.uk>
Cc: stable@vger.kernel.org
There's a bunch of unused members inside drm_plane, bloating the size of
the structure needlessly. Eliminate them.
v2: Remove all of it from kernel-doc too
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
drm_plane_force_disable() will forcibly disable the plane even if user
had previously requested the plane to be enabled.
This can be used to force planes to be off when restoring the fbdev
mode.
The code was simply pulled from drm_framebuffer_remove(), which now
calls the new function as well.
v2: Check plane->fb in drm_plane_force_disable(), drop bogus comment
about disabling crtc
Daniel writes:
Another round of drm-intel-next for 3.11. Highlights:
- Haswell IPS support (Paulo Zanoni)
- VECS support on Haswell (Ben Widawsky, Xiang Haihao, ...)
- Haswell watermark fixes (Paulo Zanoni)
- "Make the gun bigger again" multithread fence fix from Chris.
- i915_error_state finnally no longer fails with -ENOMEM! Big thanks to
Mika for tackling this.
- vlv sideband locking fixes from Jani
- Hangcheck prep work for arb_robustness support (Mika&Chris)
- edp vs cpu port confusion clean-up from Imre
- pile of smaller fixes and cleanups all over.
* tag 'drm-intel-next-2013-06-01' of git://people.freedesktop.org/~danvet/drm-intel: (70 commits)
drm/i915: add i915_ips_status debugfs entry
drm/i915: add enable_ips module option
drm/i915: implement IPS feature
drm/i915: fix up the edp power well check
drm/i915: add I915_PARAM_HAS_VEBOX to i915_getparam
drm/i915: add I915_EXEC_VEBOX to i915_gem_do_execbuffer()
drm/i915: add VEBOX into debugfs
drm/i915: Enable vebox interrupts
drm/i915: vebox interrupt get/put
drm/i915: consolidate interrupt naming scheme
drm/i915: Convert irq_refounct to struct
drm/i915: make PM interrupt writes non-destructive
drm/i915: Add PM regs to pre/post install
drm/i915: Create an ivybridge_irq_preinstall
drm/i915: Create a more generic pm handler for hsw+
drm/i915: add support for 5/6 data buffer partitioning on Haswell
drm/i915: properly set HSW WM_LP watermarks
drm/i915: properly set HSW WM_PIPE registers
drm/i915: fix pch_nop support
drm/i915: Vebox ringbuffer init
GEM CMA PRIME support from Laurent.
* 'drm/next' of git://linuxtv.org/pinchartl/fbdev:
drm: GEM CMA: Add DRM PRIME support
drm: GEM CMA: Split object mapping into GEM mapping and CMA mapping
drm: GEM CMA: Split object creation into object alloc and DMA memory alloc
drm/omap: Use drm_gem_mmap_obj() to implement dma-buf mmap
drm/gem: Split drm_gem_mmap() into object search and object mapping
The structures and strings involved with various pretty-print functions
aren't meant to be modified, so make them all const. The exception is
drm_connector_enum_list which does get modified in drm_connector_init().
While at it move the drm_get_connector_status_name() prototype from
drmP.h to drm_crtc.h where it belongs.
Rather than just printing the pixel format as a hex number, decode the
fourcc into human readable form, and also decode the LE vs. BE flag.
Keep printing the raw hex number too in case it contains non-printable
characters.
Some examples what the new drm_get_format_name() produces:
DRM_FORMAT_XRGB8888: "XR24 little-endian (0x34325258)"
DRM_FORMAT_YUYV: "YUYV little-endian (0x56595559)"
DRM_FORMAT_RGB565|DRM_FORMAT_BIG_ENDIAN: "RG16 big-endian (0xb6314752)"
Unprintable characters: "D??? big-endian (0xff7f0244)"
v2: Fix patch author
Prevents buffers from being pinned forever.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
The drm_gem_mmap() function first finds the GEM object to be mapped
based on the fake mmap offset and then maps the object. Split the object
mapping code into a standalone drm_gem_mmap_obj() function that can be
used to implement dma-buf mmap() operations.
Haswell Display audio depends on power well in graphic side, it should
request power well before use it and release power well after use.
I915 will not shutdown power well if it detects audio is using.
This patch protects display audio crash for Intel Haswell C3 stepping board.
Signed-off-by: Wang Xingchao <xingchao.wang@linux.intel.com>
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Reviewed-by: Damien Lespiau <damien.lespiau@intel.com>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
There are no users left in drivers/gpu.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
This replaces drm_mtrr_{add,del} with arch_phys_wc_{add,del}. The
interface is simplified (because the base and size parameters to
drm_mtrr_del never did anything), and it no longer adds MTRRs on
systems that don't need them.
Daniel writes:
Highlights (copy-pasted from my testing cycle mails):
- fbc support for Haswell (Rodrigo)
- streamlined workaround comments, including an igt tool to grep for
them (Damien)
- sdvo and TV out cleanups, including a fixup for sdvo multifunction devices
- refactor our eDP mess a bit (Imre)
- don't register the hdmi connector on haswell when desktop eDP is present
- vlv support is no longer preliminary!
- more vlv fixes from Jesse for stolen and dpll handling
- more flexible power well checking infrastructure from Paulo
- a few gtt patches from Ben
- a bit of OCD cleanups for transcoder #defines and an assorted pile
of smaller things.
- fixes for the gmch modeset sequence
- a bit of OCD around plane/pipe usage (Ville)
- vlv turbo support (Jesse)
- tons of vlv modeset fixes (Jesse et al.)
- vlv pte write fixes (Kenneth Graunke)
- hpd filtering to avoid costly probes on unaffected outputs (Egbert Eich)
- intel dev_info cleanups and refactorings (Damien)
- vlv rc6 support (Jesse)
- random pile of fixes around non-24bpp modes handling
- asle/opregion cleanups and locking fixes (Jani)
- dp dpll refactoring
- improvements for reduced_clock computation on g4x/ilk+
- pfit state refactored to use pipe_config (Jesse)
- lots more computed modeset state moved to pipe_config, including readout
and cross-check support
- fdi auto-dithering for ivb B/C links, using the neat pipe_config
improvements
- drm_rect helpers plus sprite clipping fixes (Ville)
- hw context refcounting (Mika + Ben)
* tag 'drm-intel-next-2013-05-20-merged' of git://people.freedesktop.org/~danvet/drm-intel: (155 commits)
drm/i915: add support for dvo Chrontel 7010B
drm/i915: Use pipe config state to control gmch pfit enable/disable
drm/i915: Use pipe_config state to disable ilk+ pfit
drm/i915: panel fitter hw state readout&check support
drm/i915: implement WADPOClockGatingDisable for LPT
drm/i915: Add missing platform tags to FBC workaround comments
drm/i915: rip out an unused lvds_reg variable
drm/i915: Compute WR PLL dividers dynamically
drm/i915: HSW FBC WaFbcDisableDpfcClockGating
drm/i915: HSW FBC WaFbcAsynchFlipDisableFbcQueue
drm/i915: Enable FBC at Haswell.
drm/i915: IVB FBC WaFbcDisableDpfcClockGating
drm/i915: IVB FBC WaFbcAsynchFlipDisableFbcQueue
drm/i915: Add support for FBC on Ivybridge.
drm/i915: Organize VBT stuff inside drm_i915_private
drm/i915: make SDVO TV-out work for multifunction devices
drm/i915: rip out now unused is_foo tracking from crtc code
drm/i915: rip out TV-out lore ...
drm/i915: drop TVclock special casing on ilk+
drm/i915: move sdvo TV clock computation to intel_sdvo.c
The 'struct' keyword was missing so struct drm_rect documentation never
ended up in the generated docs.
Also move the drm_rect documentations to a new section alognside the
various helper functions and add a short description about the intended
purpose of drm_rect.
v2: Move to new section and add general description
git://people.freedesktop.org/~airlied/linux
Pull radeon sun/hainan support from Dave Airlie:
"Since I know its outside the merge window, but since this is new hw I
thought I'd try and provoke the new hw exception, it just fills in the
blanks in the driver for the new AMD sun and hainan chipsets."
* 'drm-radeon-sun-hainan' of git://people.freedesktop.org/~airlied/linux:
drm/radeon: add Hainan pci ids
drm/radeon: add golden register settings for Hainan (v2)
drm/radeon: sun/hainan chips do not have UVD (v2)
drm/radeon: track which asics have UVD
drm/radeon: radeon-asic updates for Hainan
drm/radeon: fill in ucode loading support for Hainan
drm/radeon: don't touch DCE or VGA regs on Hainan (v3)
drm/radeon: fill in GPU init for Hainan (v2)
drm/radeon: add chip family for Hainan
Backmerge Linux 3.10-rc2 since the various (rather trivial) conflicts
grew a bit out of hand. intel_dp.c has the only real functional
conflict since the logic changed while dev_priv->edp.bpp was moved
around.
Also squash in a whitespace fixup from Ben Widawsky for
i915_gem_gtt.c, git seems to do something pretty strange in there
(which I don't fully understand tbh).
drivers/gpu/drm/i915/i915_reg.h
drivers/gpu/drm/i915/intel_dp.c
Reviewed-by: Christian König <christian.koenig@amd.com>
Pull drm fixes from Dave Airlie:
"Fix for radeon nomodeset regression, old radeon interface cliprects
fix, 2 qxl crasher fixes, and a couple of minor cleanups.
I may have a new AMD hw support branch next week, its one of those
doesn't affect anything existing just adds new support, I'll see how
it shapes up and I might ask you to take it, just thought I'd warn in
advance."
* 'drm-next' of git://people.freedesktop.org/~airlied/linux:
drm/radeon: restore nomodeset operation (v2)
qxl: fix bug with object eviction and update area
drm/qxl: drop active_user_framebuffer as its unneeded
qxl: drop unused variable.
drm/qxl: fix ioport interactions for kernel submitted commands.
drm: remove unused wrapper macros
drm/radeon: check incoming cliprects pointer
"Just a few straggling fixes I hoovered up, and an intel fixes pull
from Daniel which fixes some regressions, and some mgag200 fixes from
Matrox."
drm/mgag200: Fix framebuffer base address programming
drm/mgag200: Convert counter delays to jiffies
drm/mgag200: Fix writes into MGA1064_PIX_CLK_CTL register
drm/mgag200: Don't change unrelated registers during modeset
drm: Only print a debug message when the polled connector has changed
drm: Make the HPD status updates debug logs more readable
drm: Use names of ioctls in debug traces
drm: Remove pointless '-' characters from drm_fb_helper documentation
drm: Add kernel-doc for drm_fb_helper_funcs->initial_config
drm: refactor call to request_module
drm: Don't prune modes loudly when a connector is disconnected
drm: Add missing break in the command line mode parsing code
drm/i915: clear the stolen fb before resuming
Revert "drm/i915: Calculate correct stolen size for GEN7+"
drm/i915: hsw: fix link training for eDP on port-A
Revert "drm/i915: revert eDP bpp clamping code changes"
drm: don't check modeset locks in panic handler
drm/i915: Fix pipe enabled mask for pipe C in WM calculations
drm/mm: fix dump table BUG
drm/i915: Always normalize return timeout for wait_timeout_ioctl
