commit 9fa68f620041be04720d0cbfb1bd3ddfc6310b24 upstream.
Currently, almost none of the keyed hash algorithms check whether a key
has been set before proceeding. Some algorithms are okay with this and
will effectively just use a key of all 0's or some other bogus default.
However, others will severely break, as demonstrated using
"hmac(sha3-512-generic)", the unkeyed use of which causes a kernel crash
via a (potentially exploitable) stack buffer overflow.
A while ago, this problem was solved for AF_ALG by pairing each hash
transform with a 'has_key' bool. However, there are still other places
in the kernel where userspace can specify an arbitrary hash algorithm by
name, and the kernel uses it as unkeyed hash without checking whether it
is really unkeyed. Examples of this include:
- KEYCTL_DH_COMPUTE, via the KDF extension
- dm-verity
- dm-crypt, via the ESSIV support
- dm-integrity, via the "internal hash" mode with no key given
- drbd (Distributed Replicated Block Device)
This bug is especially bad for KEYCTL_DH_COMPUTE as that requires no
privileges to call.
Fix the bug for all users by adding a flag CRYPTO_TFM_NEED_KEY to the
->crt_flags of each hash transform that indicates whether the transform
still needs to be keyed or not. Then, make the hash init, import, and
digest functions return -ENOKEY if the key is still needed.
The new flag also replaces the 'has_key' bool which algif_hash was
previously using, thereby simplifying the algif_hash implementation.
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: stable@vger.kernel.org
commit a16e772e664b9a261424107784804cffc8894977 upstream.
Since Poly1305 requires a nonce per invocation, the Linux kernel
implementations of Poly1305 don't use the crypto API's keying mechanism
and instead expect the key and nonce as the first 32 bytes of the data.
But ->setkey() is still defined as a stub returning an error code. This
prevents Poly1305 from being used through AF_ALG and will also break it
completely once we start enforcing that all crypto API users (not just
AF_ALG) call ->setkey() if present.
Fix it by removing crypto_poly1305_setkey(), leaving ->setkey as NULL.
commit cd6ed77ad5d223dc6299fb58f62e0f5267f7e2ba upstream.
Templates that use an shash spawn can use crypto_shash_alg_has_setkey()
to determine whether the underlying algorithm requires a key or not.
But there was no corresponding function for ahash spawns. Add it.
Note that the new function actually has to support both shash and ahash
algorithms, since the ahash API can be used with either.
commit 9abffc6f2efe46c3564c04312e52e07622d40e51 upstream.
mcryptd_enqueue_request() grabs the per-CPU queue struct and protects
access to it with disabled preemption. Then it schedules a worker on the
same CPU. The worker in mcryptd_queue_worker() guards access to the same
per-CPU variable with disabled preemption.
If we take CPU-hotplug into account then it is possible that between
queue_work_on() and the actual invocation of the worker the CPU goes
down and the worker will be scheduled on _another_ CPU. And here the
preempt_disable() protection does not work anymore. The easiest thing is
to add a spin_lock() to guard access to the list.
Another detail: mcryptd_queue_worker() is not processing more than
MCRYPTD_BATCH invocation in a row. If there are still items left, then
it will invoke queue_work() to proceed with more later. *I* would
suggest to simply drop that check because it does not use a system
workqueue and the workqueue is already marked as "CPU_INTENSIVE". And if
preemption is required then the scheduler should do it.
However if queue_work() is used then the work item is marked as CPU
unbound. That means it will try to run on the local CPU but it may run
on another CPU as well. Especially with CONFIG_DEBUG_WQ_FORCE_RR_CPU=y.
Again, the preempt_disable() won't work here but lock which was
introduced will help.
In order to keep work-item on the local CPU (and avoid RR) I changed it
to queue_work_on().
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit af3ff8045bbf3e32f1a448542e73abb4c8ceb6f1 upstream.
Because the HMAC template didn't check that its underlying hash
algorithm is unkeyed, trying to use "hmac(hmac(sha3-512-generic))"
through AF_ALG or through KEYCTL_DH_COMPUTE resulted in the inner HMAC
being used without having been keyed, resulting in sha3_update() being
called without sha3_init(), causing a stack buffer overflow.
This is a very old bug, but it seems to have only started causing real
problems when SHA-3 support was added (requires CONFIG_CRYPTO_SHA3)
because the innermost hash's state is ->import()ed from a zeroed buffer,
and it just so happens that other hash algorithms are fine with that,
but SHA-3 is not. However, there could be arch or hardware-dependent
hash algorithms also affected; I couldn't test everything.
Fix the bug by introducing a function crypto_shash_alg_has_setkey()
which tests whether a shash algorithm is keyed. Then update the HMAC
template to require that its underlying hash algorithm is unkeyed.
Here is a reproducer:
#include <linux/if_alg.h>
#include <sys/socket.h>
int main()
int algfd;
struct sockaddr_alg addr = {
.salg_type = "hash",
.salg_name = "hmac(hmac(sha3-512-generic))",
char key[4096] = { 0 };
algfd = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(algfd, (const struct sockaddr *)&addr, sizeof(addr));
setsockopt(algfd, SOL_ALG, ALG_SET_KEY, key, sizeof(key));
Here was the KASAN report from syzbot:
BUG: KASAN: stack-out-of-bounds in memcpy include/linux/string.h:341 [inline]
BUG: KASAN: stack-out-of-bounds in sha3_update+0xdf/0x2e0 crypto/sha3_generic.c:161
Write of size 4096 at addr ffff8801cca07c40 by task syzkaller076574/3044
CPU: 1 PID: 3044 Comm: syzkaller076574 Not tainted 4.14.0-mm1+ #25
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
check_memory_region_inline mm/kasan/kasan.c:260 [inline]
check_memory_region+0x137/0x190 mm/kasan/kasan.c:267
memcpy+0x37/0x50 mm/kasan/kasan.c:303
crypto_shash_update+0xcb/0x220 crypto/shash.c:109
shash_finup_unaligned+0x2a/0x60 crypto/shash.c:151
crypto_shash_finup+0xc4/0x120 crypto/shash.c:165
hmac_finup+0x182/0x330 crypto/hmac.c:152
shash_digest_unaligned+0x9e/0xd0 crypto/shash.c:172
crypto_shash_digest+0xc4/0x120 crypto/shash.c:186
hmac_setkey+0x36a/0x690 crypto/hmac.c:66
crypto_shash_setkey+0xad/0x190 crypto/shash.c:64
shash_async_setkey+0x47/0x60 crypto/shash.c:207
crypto_ahash_setkey+0xaf/0x180 crypto/ahash.c:200
hash_setkey+0x40/0x90 crypto/algif_hash.c:446
alg_setkey crypto/af_alg.c:221 [inline]
alg_setsockopt+0x2a1/0x350 crypto/af_alg.c:254
SYSC_setsockopt net/socket.c:1851 [inline]
SyS_setsockopt+0x189/0x360 net/socket.c:1830
entry_SYSCALL_64_fastpath+0x1f/0x96
commit ef0579b64e93188710d48667cb5e014926af9f1b upstream.
The ahash API modifies the request's callback function in order
to clean up after itself in some corner cases (unaligned final
and missing finup).
When the request is complete ahash will restore the original
callback and everything is fine. However, when the request gets
an EBUSY on a full queue, an EINPROGRESS callback is made while
the request is still ongoing.
In this case the ahash API will incorrectly call its own callback.
This patch fixes the problem by creating a temporary request
object on the stack which is used to relay EINPROGRESS back to
the original completion function.
This patch also adds code to preserve the original flags value.
Fixes: ab6bf4e5e5e4 ("crypto: hash - Fix the pointer voodoo in...")
Reported-by: Sabrina Dubroca <sd@queasysnail.net>
Tested-by: Sabrina Dubroca <sd@queasysnail.net>
When using SGs, only heap memory (memory that is valid as per
virt_addr_valid) is allowed to be referenced. The CTR DRBG used to
reference the caller-provided memory directly in an SG. In case the
caller provided stack memory pointers, the SG mapping is not considered
to be valid. In some cases, this would even cause a paging fault.
The change adds a new scratch buffer that is used unconditionally to
catch the cases where the caller-provided buffer is not suitable for
use in an SG. The crypto operation of the CTR DRBG produces its output
with that scratch buffer and finally copies the content of the
scratch buffer to the caller's buffer.
The scratch buffer is allocated during allocation time of the CTR DRBG
as its access is protected with the DRBG mutex.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
Merge the crypto tree to pull in vmx ghash fix.
Move common values and types used by ghash-generic to a new header file
so drivers can directly use ghash-generic as a fallback implementation.
Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module")
Signed-off-by: Marcelo Cerri <marcelo.cerri@canonical.com>
The current crypto engine allow only ablkcipher_request to be enqueued.
Thus denying any use of it for hardware that also handle hash algo.
This patch modify the API for allowing to enqueue ciphers and hash.
Since omap-aes/omap-des are the only users, this patch also convert them
to the new cryptoengine API.
Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com>
This patch move the whole crypto engine API to its own header
crypto/engine.h.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull random driver updates from Ted Ts'o:
"A number of improvements for the /dev/random driver; the most
important is the use of a ChaCha20-based CRNG for /dev/urandom, which
is faster, more efficient, and easier to make scalable for
silly/abusive userspace programs that want to read from /dev/urandom
in a tight loop on NUMA systems.
This set of patches also improves entropy gathering on VM's running on
Microsoft Azure, and will take advantage of a hw random number
generator (if present) to initialize the /dev/urandom pool"
(It turns out that the random tree hadn't been in linux-next this time
around, because it had been dropped earlier as being too quiet. Oh
well).
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random:
random: strengthen input validation for RNDADDTOENTCNT
random: add backtracking protection to the CRNG
random: make /dev/urandom scalable for silly userspace programs
random: replace non-blocking pool with a Chacha20-based CRNG
random: properly align get_random_int_hash
random: add interrupt callback to VMBus IRQ handler
random: print a warning for the first ten uninitialized random users
random: initialize the non-blocking pool via add_hwgenerator_randomness()
This patch adds a missing comment for the base parameter in struct
skcipher_alg.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
This patch inlines the functions scatterwalk_start, scatterwalk_map
and scatterwalk_done as they're all tiny and mostly used by the block
cipher walker.
When hard preemption is enabled there is no need to explicitly
call crypto_yield. This patch eliminates it if that is the case.
This patch removes the now unused scatterwalk_bytes_sglen. Anyone
using this out-of-tree should switch over to sg_nents_for_len.
This patch removes the old crypto_grab_skcipher helper and replaces
it with crypto_grab_skcipher2.
As this is the final entry point into givcipher this patch also
removes all traces of the top-level givcipher interface, including
all implicit IV generators such as chainiv.
The bottom-level givcipher interface remains until the drivers
using it are converted.
The default null blkcipher is no longer used and can now be removed.
The blkcipher null object is no longer used and can now be removed.
This patch adds an skcipher null object alongside the existing
null blkcipher so that IV generators using it can switch over
to skcipher.
This patch adds a chunk size parameter to aead algorithms, just
like the chunk size for skcipher algorithms.
However, unlike skcipher we do not currently export this to AEAD
users. It is only meant to be used by AEAD implementors for now.
Current the default null skcipher is actually a crypto_blkcipher.
This patch creates a synchronous crypto_skcipher version of the
null cipher which unfortunately has to settle for the name skcipher2.
This patch allows skcipher algorithms and instances to be created
and registered with the crypto API. They are accessible through
the top-level skcipher interface, along with ablkcipher/blkcipher
algorithms and instances.
This patch also introduces a new parameter called chunk size
which is meant for ciphers such as CTR and CTS which ostensibly
can handle arbitrary lengths, but still behave like block ciphers
in that you can only process a partial block at the very end.
For these ciphers the block size will continue to be set to 1
as it is now while the chunk size will be set to the underlying
block size.
When parsing a private key, store all non-optional fields. These
are required for enabling CRT mode for decrypt and verify
Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com>
The CRNG is faster, and we don't pretend to track entropy usage in the
CRNG any more.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
This patch adds the helper crypto_inst_setname because the current
helper crypto_alloc_instance2 is no longer useful given that we
now look up the algorithm after we allocate the instance object.
* Implement ECDH under kpp API
* Provide ECC software support for curve P-192 and
P-256.
* Add kpp test for ECDH with data generated by OpenSSL
* Implement MPI based Diffie-Hellman under kpp API
* Test provided uses data generad by OpenSSL
Add key-agreement protocol primitives (kpp) API which allows to
implement primitives required by protocols such as DH and ECDH.
The API is composed mainly by the following functions
* set_secret() - It allows the user to set his secret, also
referred to as his private key, along with the parameters
known to both parties involved in the key-agreement session.
* generate_public_key() - It generates the public key to be sent to
the other counterpart involved in the key-agreement session. The
function has to be called after set_params() and set_secret()
* generate_secret() - It generates the shared secret for the session
Other functions such as init() and exit() are provided for allowing
cryptographic hardware to be inizialized properly before use
Herbert wants the sha1-mb algorithm to have an async implementation:
https://lkml.org/lkml/2016/4/5/286.
Currently, sha1-mb uses an async interface for the outer algorithm
and a sync interface for the inner algorithm. This patch introduces
a async interface for even the inner algorithm.
Signed-off-by: Megha Dey <megha.dey@linux.intel.com>
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
This patch adds helpers to check whether a given tfm is currently
queued. This is meant to be used by ablk_helper and similar
entities to ensure that no reordering is introduced because of
requests queued in cryptd with respect to requests being processed
in softirq context.
The per-cpu queue length limit is also increased to 1000 in line
with network limits.
This patch adds the implementation of SHA3 algorithm
in software and it's based on original implementation
pushed in patch https://lwn.net/Articles/518415/ with
additional changes to match the padding rules specified
in SHA-3 specification.
Signed-off-by: Raveendra Padasalagi <raveendra.padasalagi@broadcom.com>
Return the raw key with no other processing so that the caller
can copy it or MPI parse it, etc.
The scope is to have only one ANS.1 parser for all RSA
implementations.
Update the RSA software implementation so that it does
the MPI conversion on top.
Signed-off-by: Tudor Ambarus <tudor-dan.ambarus@nxp.com>
Hardware cipher implementation may require aligned buffers. All buffers
that potentially are processed with a cipher are now aligned.
The CTR DRBG derives its random data from the CTR that is encrypted with
AES.
This patch now changes the CTR DRBG implementation such that the
CTR AES mode is employed. This allows the use of steamlined CTR AES
implementation such as ctr-aes-aesni.
Unfortunately there are the following subtile changes we need to apply
when using the CTR AES mode:
- the CTR mode increments the counter after the cipher operation, but
the CTR DRBG requires the increment before the cipher op. Hence, the
crypto_inc is applied to the counter (drbg->V) once it is
recalculated.
- the CTR mode wants to encrypt data, but the CTR DRBG is interested in
the encrypted counter only. The full CTR mode is the XOR of the
encrypted counter with the plaintext data. To access the encrypted
counter, the patch uses a NULL data vector as plaintext to be
"encrypted".
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- A new LSM, "LoadPin", from Kees Cook is added, which allows forcing
of modules and firmware to be loaded from a specific device (this
is from ChromeOS, where the device as a whole is verified
cryptographically via dm-verity).
This is disabled by default but can be configured to be enabled by
default (don't do this if you don't know what you're doing).
- Keys: allow authentication data to be stored in an asymmetric key.
Lots of general fixes and updates.
- SELinux: add restrictions for loading of kernel modules via
finit_module(). Distinguish non-init user namespace capability
checks. Apply execstack check on thread stacks"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (48 commits)
LSM: LoadPin: provide enablement CONFIG
Yama: use atomic allocations when reporting
seccomp: Fix comment typo
ima: add support for creating files using the mknodat syscall
ima: fix ima_inode_post_setattr
vfs: forbid write access when reading a file into memory
fs: fix over-zealous use of "const"
selinux: apply execstack check on thread stacks
selinux: distinguish non-init user namespace capability checks
LSM: LoadPin for kernel file loading restrictions
fs: define a string representation of the kernel_read_file_id enumeration
Yama: consolidate error reporting
string_helpers: add kstrdup_quotable_file
string_helpers: add kstrdup_quotable_cmdline
selinux: check ss_initialized before revalidating an inode label
selinux: delay inode label lookup as long as possible
selinux: don't revalidate an inode's label when explicitly setting it
selinux: Change bool variable name to index.
KEYS: Add KEYCTL_DH_COMPUTE command
Signed-off-by: Eric Biggers <ebiggers3@gmail.com>
Move the point at which a key is determined to be trustworthy to
__key_link() so that we use the contents of the keyring being linked in to
to determine whether the key being linked in is trusted or not.
What is 'trusted' then becomes a matter of what's in the keyring.
Currently, the test is done when the key is parsed, but given that at that
point we can only sensibly refer to the contents of the system trusted
keyring, we can only use that as the basis for working out the
trustworthiness of a new key.
With this change, a trusted keyring is a set of keys that once the
trusted-only flag is set cannot be added to except by verification through
one of the contained keys.
Further, adding a key into a trusted keyring, whilst it might grant
trustworthiness in the context of that keyring, does not automatically
grant trustworthiness in the context of a second keyring to which it could
be secondarily linked.
To accomplish this, the authentication data associated with the key source
must now be retained. For an X.509 cert, this means the contents of the
AuthorityKeyIdentifier and the signature data.
If system keyrings are disabled then restrict_link_by_builtin_trusted()
resolves to restrict_link_reject(). The integrity digital signature code
still works correctly with this as it was previously using
KEY_FLAG_TRUSTED_ONLY, which doesn't permit anything to be added if there
is no system keyring against which trust can be determined.
Move x509_request_asymmetric_key() to asymmetric_type.c so that it can be
generalised.
Make the determination of the trustworthiness of a key dependent on whether
a key that can verify it is present in the supplied ring of trusted keys
rather than whether or not the verifying key has KEY_FLAG_TRUSTED set.
verify_pkcs7_signature() will return -ENOKEY if the PKCS#7 message trust
chain cannot be verified.
Generalise system_verify_data() to provide access to internal content
through a callback. This allows all the PKCS#7 stuff to be hidden inside
this function and removed from the PE file parser and the PKCS#7 test key.
If external content is not required, NULL should be passed as data to the
function. If the callback is not required, that can be set to NULL.
The function is now called verify_pkcs7_signature() to contrast with
verify_pefile_signature() and the definitions of both have been moved into
linux/verification.h along with the key_being_used_for enum.
Add key identifier pointers to public_key_signature struct so that they can
be used to retain the identifier of the key to be used to verify the
signature in both PKCS#7 and X.509.
Allow authentication data to be stored in an asymmetric key in the 4th
element of the key payload and provide a way for it to be destroyed.
For the public key subtype, this will be a public_key_signature struct.
Pull security layer updates from James Morris:
"There are a bunch of fixes to the TPM, IMA, and Keys code, with minor
fixes scattered across the subsystem.
IMA now requires signed policy, and that policy is also now measured
and appraised"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (67 commits)
X.509: Make algo identifiers text instead of enum
akcipher: Move the RSA DER encoding check to the crypto layer
crypto: Add hash param to pkcs1pad
sign-file: fix build with CMS support disabled
MAINTAINERS: update tpmdd urls
MODSIGN: linux/string.h should be #included to get memcpy()
certs: Fix misaligned data in extra certificate list
X.509: Handle midnight alternative notation in GeneralizedTime
X.509: Support leap seconds
Handle ISO 8601 leap seconds and encodings of midnight in mktime64()
X.509: Fix leap year handling again
PKCS#7: fix unitialized boolean 'want'
firmware: change kernel read fail to dev_dbg()
KEYS: Use the symbol value for list size, updated by scripts/insert-sys-cert
KEYS: Reserve an extra certificate symbol for inserting without recompiling
modsign: hide openssl output in silent builds
tpm_tis: fix build warning with tpm_tis_resume
ima: require signed IMA policy
ima: measure and appraise the IMA policy itself
ima: load policy using path
Make the identifier public key and digest algorithm fields text instead of
enum.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Move the RSA EMSA-PKCS1-v1_5 encoding from the asymmetric-key public_key
subtype to the rsa crypto module's pkcs1pad template. This means that the
public_key subtype no longer has any dependencies on public key type.
To make this work, the following changes have been made:
(1) The rsa pkcs1pad template is now used for RSA keys. This strips off the
padding and returns just the message hash.
(2) In a previous patch, the pkcs1pad template gained an optional second
parameter that, if given, specifies the hash used. We now give this,
and pkcs1pad checks the encoded message E(M) for the EMSA-PKCS1-v1_5
encoding and verifies that the correct digest OID is present.
(3) The crypto driver in crypto/asymmetric_keys/rsa.c is now reduced to
something that doesn't care about what the encryption actually does
and and has been merged into public_key.c.
(4) CONFIG_PUBLIC_KEY_ALGO_RSA is gone. Module signing must set
CONFIG_CRYPTO_RSA=y instead.
Thoughts:
(*) Should the encoding style (eg. raw, EMSA-PKCS1-v1_5) also be passed to
the padding template? Should there be multiple padding templates
registered that share most of the code?
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
After digsig_asymmetric.c is converted the MPIs can be now
safely removed from the public_key_signature structure.
The associated data handling with the kernel crypto API has been
updated. This needs to be reflected in the documentation.
Reference the new akcipher API calls in the kernel crypto API DocBook.
Also, fix the comments in the akcipher.h file: double dashes do not look
good in the DocBook; fix a typo.
The patch centralizes the XTS key check logic into the service function
xts_check_key which is invoked from the different XTS implementations.
With this, the XTS implementations in ARM, ARM64, PPC and S390 have now
a sanity check for the XTS keys similar to the other arches.
In addition, this service function received a check to ensure that the
key != the tweak key which is mandated by FIPS 140-2 IG A.9. As the
check is not present in the standards defining XTS, it is only enforced
in FIPS mode of the kernel.
