path: root/include/asm-xtensa/tlb.h
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-27[XTENSA] Add support for cache-aliasingChris Zankel
Add support for processors that have cache-aliasing issues, such as the Stretch S5000 processor. Cache-aliasing means that the size of the cache (for one way) is larger than the page size, thus, a page can end up in several places in cache depending on the virtual to physical translation. The method used here is to map a user page temporarily through the auto-refill way 0 and of of the DTLB. We probably will want to revisit this issue and use a better approach with kmap/kunmap. Signed-off-by: Chris Zankel <chris@zankel.net>
2005-06-24[PATCH] xtensa: Architecture support for Tensilica Xtensa Part 6Chris Zankel
The attached patches provides part 6 of an architecture implementation for the Tensilica Xtensa CPU series. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
