path: root/include/asm-x86_64
2007-04-25[NET]: Adding SO_TIMESTAMPNS / SCM_TIMESTAMPNS supportEric Dumazet
Now that network timestamps use ktime_t infrastructure, we can add a new SOL_SOCKET sockopt SO_TIMESTAMPNS. This command is similar to SO_TIMESTAMP, but permits transmission of a 'timespec struct' instead of a 'timeval struct' control message. (nanosecond resolution instead of microsecond) Control message is labelled SCM_TIMESTAMPNS instead of SCM_TIMESTAMP A socket cannot mix SO_TIMESTAMP and SO_TIMESTAMPNS : the two modes are mutually exclusive. sock_recv_timestamp() became too big to be fully inlined so I added a __sock_recv_timestamp() helper function. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: linux-arch@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Introduce SIOCGSTAMPNS ioctl to get timestamps with nanosec resolutionEric Dumazet
Now network timestamps use ktime_t infrastructure, we can add a new ioctl() SIOCGSTAMPNS command to get timestamps in 'struct timespec'. User programs can thus access to nanosecond resolution. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-29[PATCH] x86_64 irq: Fix comments after changing IRQ0_VECTOR from 0x20 to 0x30Yinghai Lu
Signed-off-by: Yinghai Lu <yinghai.lu@amd.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-23x86-64: add "local_apic_timer_c2_ok" here tooLinus Torvalds
Needed for any architecture that claims ARCH_APICTIMER_STOPS_ON_C3, not just i386. I'm hoping Thomas will clean this up a bit later.. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] x86-64: fix section mismatch warningsSam Ravnborg
Fix the following section mismatch warnings on x86_64: (build using defconfig) WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.text:mtrr_bp_init from .text between 'identify_cpu' (at offset 0x65eb) and 'IRQ0x20_interrupt' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data: from .text between 'finish_e820_parsing' (at offset 0x7dc2) and 'early_panic' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.text:e820_print_map from .text between 'finish_e820_parsing' (at offset 0x7de1) and 'early_panic' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:num_processors from .text between 'acpi_unmap_lsapic' (at offset 0xc88f) and 'acpi_register_ioapic' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:disabled_cpus from .text between 'MP_processor_info' (at offset 0x11f35) and 'mp_register_lapic' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:num_processors from .text between 'MP_processor_info' (at offset 0x11f6e) and 'mp_register_lapic' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:num_processors from .text between 'MP_processor_info' (at offset 0x11f93) and 'mp_register_lapic' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:fix_aperture from .text between 'gart_parse_options' (at offset 0x15517) and 'iommu_full' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:fix_aperture from .text between 'gart_parse_options' (at offset 0x1552c) and 'iommu_full' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:iommu_aperture_allowed from .text between 'gart_parse_options' (at offset 0x1553d) and 'iommu_full' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:iommu_aperture_allowed from .text between 'gart_parse_options' (at offset 0x15552) and 'iommu_full' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:iommu_aperture_allowed from .text between 'gart_parse_options' (at offset 0x15561) and 'iommu_full' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:iommu_aperture_allowed from .text between 'gart_parse_options' (at offset 0x15577) and 'iommu_full' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:fallback_aper_force from .text between 'gart_parse_options' (at offset 0x1558a) and 'iommu_full' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:fallback_aper_order from .text between 'gart_parse_options' (at offset 0x155bf) and 'iommu_full' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:timer_over_8254 from .text between 'ati_bugs' (at offset 0x16344) and 'via_bugs' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:timer_over_8254 from .text between 'ati_bugs' (at offset 0x16356) and 'via_bugs' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:iommu_aperture_allowed from .text between 'via_bugs' (at offset 0x16380) and 'nvidia_bugs' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:iommu_aperture_disabled from .text between 'via_bugs' (at offset 0x16397) and 'nvidia_bugs' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:acpi_use_timer_override from .text between 'nvidia_bugs' (at offset 0x163a7) and 'arch_unregister_cpu' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.text:nvidia_hpet_check from .text between 'nvidia_bugs' (at offset 0x163b1) and 'arch_unregister_cpu' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data: from .text between 'nvidia_bugs' (at offset 0x163be) and 'arch_unregister_cpu' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data: from .text between 'nvidia_bugs' (at offset 0x163d1) and 'arch_unregister_cpu' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.data:acpi_skip_timer_override from .text between 'nvidia_bugs' (at offset 0x163e1) and 'arch_unregister_cpu' WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.text:quirk_intel_irqbalance from .text between 'intel_bugs' (at offset 0x1633c) and 'ati_bugs' But adds: WARNING: arch/x86_64/kernel/built-in.o - Section mismatch: reference to .init.text:get_mtrr_state from .text between 'mtrr_bp_init' (at offset 0xb887) and 'ipi_handler' The warnings does not show up during a normal build due to kbuild failing to check for section mismatch in vmlinux. To see these warnings run: scripts/mod/modpost arch/x86_64/kernel/built-in.o kbuild will be fixed but the 'noise-level' had to be decresed first. There remains a few section mismatch warnigns for x86_64 for areas where I did not feel confident. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andi Kleen <ak@suse.de>
2007-03-14Disable NMI watchdog by default properlyLinus Torvalds
This reverts commit 6ebf622b2577c50b1f496bd6a5e8739e55ae7b1c and replaces it with one that actually works. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-14[PATCH] kill bogus casts in amd64 uaccess.hAl Viro
2007-03-06Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] kexec: Use EFI_LOADER_DATA for ELF core header [IA64] permon use-after-free fix [IA64] sync compat getdents [IA64] always build arch/ia64/lib/xor.o [IA64] Remove stack hard limit on ia64 [IA64] point saved_max_pfn to the max_pfn of the entire system Revert "[IA64] swiotlb abstraction (e.g. for Xen)"
2007-03-06Revert "[IA64] swiotlb abstraction (e.g. for Xen)"Tony Luck
This reverts commit 51099005ab8e09d68a13fea8d55bc739c1040ca6.
2007-03-06[PATCH] i386: make x86_64 tsc header require i386 rather than vice-versaAndres Salomon
Prior to commit 95492e4646e5de8b43d9a7908d6177fb737b61f0 ([PATCH] x86: rewrite SMP TSC sync code), the headers in asm-i386 did not really require anything in include/asm-x86_64. This means that distributions such as fedora did not include asm-x86_64 in kernel-devel headers for i386. Ingo's commit changed that, and broke things. This is easy enough to hack around in package builds by just including asm-x86_64 on i386, but that's kind of annoying. If anything, x86_64 should depend upon i386, not the other way around. This patch changes it so that asm-x86_64/tsc.h includes asm-i386/tsc.h, rather than vice-versa. Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] disable NMI watchdog by defaultIngo Molnar
there's a new NMI watchdog related problem: KVM crashes on certain bzImages because ... we enable the NMI watchdog by default (even if the user does not ask for it) , and no other OS on this planet does that so KVM doesnt have emulation for that yet. So KVM injects a #GP, which crashes the Linux guest: general protection fault: 0000 [#1] PREEMPT SMP Modules linked in: CPU: 0 EIP: 0060:[<c011a8ae>] Not tainted VLI EFLAGS: 00000246 (2.6.20-rc5-rt0 #3) EIP is at setup_apic_nmi_watchdog+0x26d/0x3d3 and no, i did /not/ request an nmi_watchdog on the boot command line! Solution: turn off that darn thing! It's a debug tool, not a 'make life harder' tool!! with this patch the KVM guest boots up just fine. And with this my laptop (Lenovo T60) also stopped its sporadic hard hanging (sometimes in acpi_init(), sometimes later during bootup, sometimes much later during actual use) as well. It hung with both nmi_watchdog=1 and nmi_watchdog=2, so it's generally the fact of NMI injection that is causing problems, not the NMI watchdog variant, nor any particular bootup code. [ NMI breaks on some systems, esp in combination with SMM -Arjan ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] clocksource init adjustments (fix bug #7426)john stultz
This patch resolves the issue found here: http://bugme.osdl.org/show_bug.cgi?id=7426 The basic summary is: Currently we register most of i386/x86_64 clocksources at module_init time. Then we enable clocksource selection at late_initcall time. This causes some problems for drivers that use gettimeofday for init calibration routines (specifically the es1968 driver in this case), where durring module_init, the only clocksource available is the low-res jiffies clocksource. This may cause slight calibration errors, due to the small sampling time used. It should be noted that drivers that require fine grained time may not function on architectures that do not have better then jiffies resolution timekeeping (there are a few). However, this does not discount the reasonable need for such fine-grained timekeeping at init time. Thus the solution here is to register clocksources earlier (ideally when the hardware is being initialized), and then we enable clocksource selection at fs_initcall (before device_initcall). This patch should probably get some testing time in -mm, since clocksource selection is one of the most important issues for correct timekeeping, and I've only been able to test this on a few of my own boxes. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] sched: remove SMT niceCon Kolivas
Remove the SMT-nice feature which idles sibling cpus on SMT cpus to facilitiate nice working properly where cpu power is shared. The idling of cpus in the presence of runnable tasks is considered too fragile, easy to break with outside code, and the complexity of managing this system if an architecture comes along with many logical cores sharing cpu power will be unworkable. Remove the associated per_cpu_gain variable in sched_domains used only by this code. Also: The reason is that with dynticks enabled, this code breaks without yet further tweaks so dynticks brought on the rapid demise of this code. So either we tweak this code or kill it off entirely. It was Ingo's preference to kill it off. Either way this needs to happen for 2.6.21 since dynticks has gone in. Signed-off-by: Con Kolivas <kernel@kolivas.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] io_apic.h needs apicdef.hJean Delvare
A -mm patch caused: In file included from drivers/pci/quirks.c:532: include/asm/io_apic.h:61: error: "MAX_IO_APICS" undeclared here (not in a function) So let's include the needed header. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-26Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] constify some data tables. [CPUFREQ] constify cpufreq_driver where possible. {rd,wr}msr_on_cpu SMP=n optimization [CPUFREQ] cpufreq_ondemand.c: don't use _WORK_NAR rdmsr_on_cpu, wrmsr_on_cpu [CPUFREQ] Revert default on deprecated config X86_SPEEDSTEP_CENTRINO_ACPI
2007-02-26[PATCH] x86_64 irq: Safely cleanup an irq after moving it.Eric W. Biederman
The problem: After moving an interrupt when is it safe to teardown the data structures for receiving the interrupt at the old location? With a normal pci device it is possible to issue a read to a device to flush all posted writes. This does not work for the oldest ioapics because they are on a 3-wire apic bus which is a completely different data path. For some more modern ioapics when everything is using front side bus delivery you can flush interrupts by simply issuing a read to the ioapic. For other modern ioapics emperical testing has shown that this does not work. So it appears the only reliable way to know the last of the irqs from an ioapic have been received from before the ioapic was reprogrammed is to received the first irq from the ioapic from after it was reprogrammed. Once we know the last irq message has been received from an ioapic into a local apic we then need to know that irq message has been processed through the local apics. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-26[PATCH] x86_64 irq: Add constants for the reserved IRQ vectors.Eric W. Biederman
For the ISA irqs we reserve 16 vectors. This patch adds constants for those vectors and modifies the code to use them. Making the code a little clearer and making it possible to move these vectors in the future. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20{rd,wr}msr_on_cpu SMP=n optimizationAdrian Bunk
Let's save a few bytes in the CONFIG_SMP=n case. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-20rdmsr_on_cpu, wrmsr_on_cpuAlexey Dobriyan
There was OpenVZ specific bug rendering some cpufreq drivers unusable on SMP. In short, when cpufreq code thinks it confined itself to needed cpu by means of set_cpus_allowed() to execute rdmsr, some "virtual cpu" feature can migrate process to anywhere. This triggers bugons and does wrong things in general. This got fixed by introducing rdmsr_on_cpu and wrmsr_on_cpu executing rdmsr and wrmsr on given physical cpu by means of smp_call_function_single(). Dave Jones mentioned cpufreq might be not only user of rdmsr_on_cpu() and wrmsr_on_cpu(), so I'm putting them into arch/{i386,x86_64}/lib/ . Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-16[PATCH] time: x86_64: re-enable vsyscall support for x86_64john stultz
Cleanup and re-enable vsyscall gettimeofday using the generic clocksource infrastructure. [akpm@osdl.org: cleanup] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@muc.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] time: x86_64: convert x86_64 to use GENERIC_TIMEjohn stultz
This patch converts x86_64 to use the GENERIC_TIME infrastructure and adds clocksource structures for both TSC and HPET (ACPI PM is shared w/ i386). [akpm@osdl.org: fix printk timestamps] [akpm@osdl.org: fix printk ckeanups] [akpm@osdl.org: hpet build fix] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@muc.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] time: x86_64: split x86_64/kernel/time.c upjohn stultz
In preparation for the x86_64 generic time conversion, this patch splits out TSC and HPET related code from arch/x86_64/kernel/time.c into respective hpet.c and tsc.c files. [akpm@osdl.org: fix printk timestamps] [akpm@osdl.org: cleanup] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@muc.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] time: x86_64: hpet_address cleanupjohn stultz
In preparation for supporting generic timekeeping, this patch cleans up x86-64's use of vxtime.hpet_address, changing it to just hpet_address as is also used in i386. This is necessary since the vxtime structure will be going away. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@muc.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] x86: rewrite SMP TSC sync codeIngo Molnar
make the TSC synchronization code more robust, and unify it between x86_64 and i386. The biggest change is the removal of the 'fix up TSCs' code on x86_64 and i386, in some rare cases it was /causing/ time-warps on SMP systems. The new code only checks for TSC asynchronity - and if it can prove a time-warp (if it can observe the TSC going backwards when going from one CPU to another within a critical section), then the TSC clock-source is turned off. The TSC synchronization-checking code also got moved into a separate file. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13[PATCH] x86-64: Remove mk_pte_phys()Andi Kleen
- Convert last user to pfn_pte - Remove mk_pte_phys Suggested by Jan Beulich Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-13[PATCH] x86-64: Fix wrong gcc check in bitops.hAndi Kleen
gcc 5.0 will likely not have the constraint problem Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-13[PATCH] x86-64: update IO-APIC dest field to 8-bit for xAPICBenjamin Romer
On the Unisys ES7000/ONE system, we encountered a problem where performing a kexec reboot or dump on any cell other than cell 0 causes the system timer to stop working, resulting in a hang during timer calibration in the new kernel. We traced the problem to one line of code in disable_IO_APIC(), which needs to restore the timer's IO-APIC configuration before rebooting. The code is currently using the 4-bit physical destination field, rather than using the 8-bit logical destination field, and it cuts off the upper 4 bits of the timer's APIC ID. If we change this to use the logical destination field, the timer works and we can kexec on the upper cells. This was tested on two different cells (0 and 2) in an ES7000/ONE system. For reference, the relevant Intel xAPIC spec is kept at ftp://download.intel.com/design/chipsets/e8501/datashts/30962001.pdf, specifically on page 334. Signed-off-by: Benjamin M Romer <benjamin.romer@unisys.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-02-13[PATCH] x86-64: define dma noncoherent API functionsJeff Garzik
x86-64 is missing these: Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-13[PATCH] x86-64: Fix preprocessor conditionJosef 'Jeff' Sipek
Old code was legal standard C, but apparently not sparse-C. Signed-off-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-13[PATCH] x86-64: remove get_pmd()Jan Beulich
Function is dead. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-13[PATCH] x86-64: Allow to run a program when a machine check event is detectedAndi Kleen
When a machine check event is detected (including a AMD RevF threshold overflow event) allow to run a "trigger" program. This allows user space to react to such events sooner. The trigger is configured using a new trigger entry in the machinecheck sysfs interface. It is currently shared between all CPUs. I also fixed the AMD threshold handler to run the machine check polling code immediately to actually log any events that might have caused the threshold interrupt. Also added some documentation for the mce sysfs interface. Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-13[PATCH] x86-64: Remove fastcall references in x86_64 codeGlauber de Oliveira Costa
Unlike x86, x86_64 already passes arguments in registers. The use of regparm attribute makes no difference in produced code, and the use of fastcall just bloats the code. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2007-02-13[PATCH] x86-64: Fix fake numa for x86_64 machines with big IO holeRohit Seth
This patch resolves the issue of running with numa=fake=X on kernel command line on x86_64 machines that have big IO hole. While calculating the size of each node now we look at the total hole size in that range. Previously there were nodes that only had IO holes in them causing kernel boot problems. We now use the NODE_MIN_SIZE (64MB) as the minimum size of memory that any node must have. We reduce the number of allocated nodes if the number of nodes specified on kernel command line results in any node getting memory smaller than NODE_MIN_SIZE. This change allows the extra memory to be incremented in NODE_MIN_SIZE granule and uniformly distribute among as many nodes (called big nodes) as possible. [akpm@osdl.org: build fix] Signed-off-by: David Rientjes <reintjes@google.com> Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: Rohit Seth <rohitseth@google.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2007-02-13[PATCH] x86-64: get rid of ARCH_HAVE_XTIME_LOCKEric Dumazet
ARCH_HAVE_XTIME_LOCK is used by x86_64 arch . This arch needs to place a read only copy of xtime_lock into vsyscall page. This read only copy is named __xtime_lock, and xtime_lock is defined in arch/x86_64/kernel/vmlinux.lds.S as an alias. So the declaration of xtime_lock in kernel/timer.c was guarded by ARCH_HAVE_XTIME_LOCK define, defined to true on x86_64. We can get same result with _attribute__((weak)) in the declaration. linker should do the job. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2007-02-13[PATCH] x86-64: Allocate the NUMA hash function nodemap dynamicallyAmul Shah
Remove the statically allocated memory to NUMA node hash map in favor of a dynamically allocated memory to node hash map (it is cache aligned). This patch has the nice side effect in that it allows the hash map to grow for systems with large amounts of memory (256GB - 1TB), but suffer from having small PCI space tacked onto the boot node (which is somewhere between 192MB to 512MB on the ES7000). Signed-off-by: Amul Shah <amul.shah@unisys.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Cc: Rohit Seth <rohitseth@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2007-02-13[PATCH] x86-64: Add __copy_from_user_nocacheAndi Kleen
This does user copies in fs write() into the page cache with write combining. This pushes the destination out of the CPU's cache, but allows higher bandwidth in some case. The theory is that the page cache data is usually not touched by the CPU again and it's better to not pollute the cache with it. Also it is a little faster. Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-12[PATCH] x86_64: 2048-byte command lineAlon Bar-Lev
Current implementation allows the kernel to receive up to 255 characters from the bootloader. While the boot protocol allows greater buffers to be sent. In current environment, the command-line is used in order to specify many values, including suspend/resume, module arguments, splash, initramfs and more. 255 characters are not enough anymore. After edd issue was fixed, and dynammic kernel command-line patch was accepted, we can extend the COMMAND_LINE_SIZE without runtime memory requirements. Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Dynamic kernel command-line: x86_64Alon Bar-Lev
1. Rename saved_command_line into boot_command_line. 2. Set command_line as __initdata. Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] fix sparse warnings from {asm,net}/checksum.hTilman Schmidt
Rename the variable "sum" in the __range_ok macros to avoid name collisions causing lots of "symbol shadows an earlier one" warnings by sparse. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Andi Kleen <ak@suse.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] consolidate line discipline number definitionsTilman Schmidt
The line discipline numbers N_* are currently defined for each architecture individually, but (except for a seeming mistake) identically, in asm/termios.h. There is no obvious reason why these numbers should be architecture specific, nor any apparent relationship with the termios structure. The total number of these, NR_LDISCS, is defined in linux/tty.h anyway. So I propose the following patch which moves the definitions of the individual line disciplines to linux/tty.h too. Three of these numbers (N_MASC, N_PROFIBUS_FDL, and N_SMSBLOCK) are unused in the current kernel, but the patch still keeps the complete set in case there are plans to use them yet. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] x86_64 ia32 vDSO: use install_special_mappingRoland McGrath
This patch uses install_special_mapping for the ia32 vDSO setup, consolidating duplicated code. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] kill eth_io_copy_and_sum()Al Viro
On all targets that sucker boils down to memcpy_fromio(sbk->data, from, len). The function name is highly misguiding (it _never_ does any checksums), the last argument is just a noise and simply expanding the call to memcpy_fromio() gives shorter and more readable source. For a lot of reasons it has almost no remaining users, so it's better to just outright kill it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (140 commits) ACPICA: reduce table header messages to fit within 80 columns asus-laptop: merge with ACPICA table update ACPI: bay: Convert ACPI Bay driver to be compatible with sysfs update. ACPI: bay: new driver is EXPERIMENTAL ACPI: bay: make drive_bays static ACPI: bay: make bay a platform driver ACPI: bay: remove prototype procfs code ACPI: bay: delete unused variable ACPI: bay: new driver adding removable drive bay support ACPI: dock: check if parent is on dock ACPICA: fix gcc build warnings Altix: Add ACPI SSDT PCI device support (hotplug) Altix: ACPI SSDT PCI device support ACPICA: reduce conflicts with Altix patch series ACPI_NUMA: fix HP IA64 simulator issue with extended memory domain ACPI: fix HP RX2600 IA64 boot ACPI: build fix for IBM x440 - CONFIG_X86_SUMMIT ACPICA: Update version to 20070126 ACPICA: Fix for incorrect parameter passed to AcpiTbDeleteTable during table load. ACPICA: Update copyright to 2007. ...
2007-02-06Pull test into release branchLen Brown
2007-02-05[IA64] swiotlb abstraction (e.g. for Xen)Jan Beulich
Add abstraction so that the file can be used by environments other than IA64 and EM64T, namely for Xen. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] swiotlb bug fixesJan Beulich
This patch fixes - marking I-cache clean of pages DMAed to now only done for IA64 - broken multiple inclusion in include/asm-x86_64/swiotlb.h - missing call to mark_clean in swiotlb_sync_sg() - a (perhaps only theoretical) issue in swiotlb_dma_supported() when io_tlb_end is exactly at the end of memory Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-03[PATCH] x86-64: define dma noncoherent API functionsJeff Garzik
x86-64 is missing these: Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-02ACPICA: Allow ACPI id to be u32 instead of u8.Alexey Starikovskiy
Allow ACPI id to be u32 instead of u8. Requires drop of conversion tables with the acpiid as index. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: minimal patch to integrate new tables into LinuxAlexey Starikovskiy
2007-01-25[PATCH] x86_64: fix put_user for 64-bit constantRoland McGrath
On x86-64, a put_user call using a 64-bit pointer and a constant value that is > 0xffffffff will produce code that doesn't assemble. This patch fixes the asm construct to use the Z constraint for 32-bit constants. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
