path: root/include/asm-x86_64/dwarf2.h
2006-01-11[PATCH] x86_64: Separate CONFIG_UNWIND_INFO from CONFIG_DEBUG_INFOJan Beulich
As a follow-up to the introduction of CONFIG_UNWIND_INFO, this separates the generation of frame unwind information for x86-64 from that of full debug information. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] x86_64: More CFI fixes for 32bit entry codeJan Beulich
Frame unwind information was still incorrect for ia32_ptregs_common (sorry, my fault), and could be improved for some of the other entry points. Signed-Off-By: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] x86-64: Fix CFI informationJan Beulich
Being the foundation for reliable stack unwinding, this fixes CFI unwind annotations in many low-level x86_64 routines, plus a config option (available to all architectures, and also present in the previously sent patch adding such annotations to i386 code) to enable them separatly rather than only along with adding full debug information. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
