path: root/include/asm-x86
2008-08-01Merge branch 'kvm-updates-2.6.27' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates-2.6.27' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: KVM: s390: Fix kvm on IBM System z10 KVM: Advertise synchronized mmu support to userspace KVM: Synchronize guest physical memory map to host virtual memory map KVM: Allow browsing memslots with mmu_lock KVM: Allow reading aliases with mmu_lock
2008-07-29generic, x86: fix add iommu_num_pages helper functionFUJITA Tomonori
This IOMMU helper function doesn't work for some architectures: http://marc.info/?l=linux-kernel&m=121699304403202&w=2 It also breaks POWER and SPARC builds: http://marc.info/?l=linux-kernel&m=121730388001890&w=2 Currently, only x86 IOMMUs use this so let's move it to x86 for now. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-29KVM: Synchronize guest physical memory map to host virtual memory mapAndrea Arcangeli
Synchronize changes to host virtual addresses which are part of a KVM memory slot to the KVM shadow mmu. This allows pte operations like swapping, page migration, and madvise() to transparently work with KVM. Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-29Merge branch 'linus' into core/generic-dma-coherentIngo Molnar
Conflicts: arch/x86/Kconfig Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-27KVM: SVM: allow enabling/disabling NPT by reloading only the architecture moduleJoerg Roedel
If NPT is enabled after loading both KVM modules on AMD and it should be disabled, both KVM modules must be reloaded. If only the architecture module is reloaded the behavior is undefined. With this patch it is possible to disable NPT only by reloading the kvm_amd module. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-26[PATCH] kill altrootAl Viro
long overdue... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, AMD IOMMU: include amd_iommu_last_bdf in device initialization x86: fix IBM Summit based systems' phys_cpu_present_map on 32-bit kernels x86, RDC321x: remove gpio.h complications x86, RDC321x: add to mach-default crashdump: fix undefined reference to `elfcorehdr_addr' flag parameters: fix compile error of sys_epoll_create1
2008-07-26x86: lockless get_user_pages_fast()Nick Piggin
Implement get_user_pages_fast without locking in the fastpath on x86. Do an optimistic lockless pagetable walk, without taking mmap_sem or any page table locks or even mmap_sem. Page table existence is guaranteed by turning interrupts off (combined with the fact that we're always looking up the current mm, means we can do the lockless page table walk within the constraints of the TLB shootdown design). Basically we can do this lockless pagetable walk in a similar manner to the way the CPU's pagetable walker does not have to take any locks to find present ptes. This patch (combined with the subsequent ones to convert direct IO to use it) was found to give about 10% performance improvement on a 2 socket 8 core Intel Xeon system running an OLTP workload on DB2 v9.5 "To test the effects of the patch, an OLTP workload was run on an IBM x3850 M2 server with 2 processors (quad-core Intel Xeon processors at 2.93 GHz) using IBM DB2 v9.5 running Linux 2.6.24rc7 kernel. Comparing runs with and without the patch resulted in an overall performance benefit of ~9.8%. Correspondingly, oprofiles showed that samples from __up_read and __down_read routines that is seen during thread contention for system resources was reduced from 2.8% down to .05%. Monitoring the /proc/vmstat output from the patched run showed that the counter for fast_gup contained a very high number while the fast_gup_slow value was zero." (fast_gup is the old name for get_user_pages_fast, fast_gup_slow is a counter we had for the number of times the slowpath was invoked). The main reason for the improvement is that DB2 has multiple threads each issuing direct-IO. Direct-IO uses get_user_pages, and thus the threads contend the mmap_sem cacheline, and can also contend on page table locks. I would anticipate larger performance gains on larger systems, however I think DB2 uses an adaptive mix of threads and processes, so it could be that thread contention remains pretty constant as machine size increases. In which case, we stuck with "only" a 10% gain. The downside of using get_user_pages_fast is that if there is not a pte with the correct permissions for the access, we end up falling back to get_user_pages and so the get_user_pages_fast is a bit of extra work. However this should not be the common case in most performance critical code. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: Kconfig fix] [akpm@linux-foundation.org: Makefile fix/cleanup] [akpm@linux-foundation.org: warning fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26x86: implement pte_specialNick Piggin
Implement the pte_special bit for x86. This is required to support lockless get_user_pages, because we need to know whether or not we can refcount a particular page given only its pte (and no vma). [hugh@veritas.com: fix a BUG] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26kexec jumpHuang Ying
This patch provides an enhancement to kexec/kdump. It implements the following features: - Backup/restore memory used by the original kernel before/after kexec. - Save/restore CPU state before/after kexec. The features of this patch can be used as a general method to call program in physical mode (paging turning off). This can be used to call BIOS code under Linux. kexec-tools needs to be patched to support kexec jump. The patches and the precompiled kexec can be download from the following URL: source: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-src_git_kh10.tar.bz2 patches: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-patches_git_kh10.tar.bz2 binary: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec_git_kh10 Usage example of calling some physical mode code and return: 1. Compile and install patched kernel with following options selected: CONFIG_X86_32=y CONFIG_KEXEC=y CONFIG_PM=y CONFIG_KEXEC_JUMP=y 2. Build patched kexec-tool or download the pre-built one. 3. Build some physical mode executable named such as "phy_mode" 4. Boot kernel compiled in step 1. 5. Load physical mode executable with /sbin/kexec. The shell command line can be as follow: /sbin/kexec --load-preserve-context --args-none phy_mode 6. Call physical mode executable with following shell command line: /sbin/kexec -e Implementation point: To support jumping without reserving memory. One shadow backup page (source page) is allocated for each page used by kexeced code image (destination page). When do kexec_load, the image of kexeced code is loaded into source pages, and before executing, the destination pages and the source pages are swapped, so the contents of destination pages are backupped. Before jumping to the kexeced code image and after jumping back to the original kernel, the destination pages and the source pages are swapped too. C ABI (calling convention) is used as communication protocol between kernel and called code. A flag named KEXEC_PRESERVE_CONTEXT for sys_kexec_load is added to indicate that the loaded kernel image is used for jumping back. Now, only the i386 architecture is supported. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26x86 calgary: fix handling of devices that aren't behind the CalgaryAlexis Bruemmer
The calgary code can give drivers addresses above 4GB which is very bad for hardware that is only 32bit DMA addressable. With this patch, the calgary code sets the global dma_ops to swiotlb or nommu properly, and the dma_ops of devices behind the Calgary/CalIOC2 to calgary_dma_ops. So the calgary code can handle devices safely that aren't behind the Calgary/CalIOC2. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alexis Bruemmer <alexisb@us.ibm.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26x86: fix IBM Summit based systems' phys_cpu_present_map on 32-bit kernelsChris McDermott
x86 kernels on IBM Summit based systems will only online 1 CPU because the phys_cpu_present_map is not set up correctly. Patch below applied to 2.6.26-git10. Signed-off-by: Chris McDermott <lcm@linux.vnet.ibm.com> Tested-by: Tim Pepper <lnxninga@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-26x86, RDC321x: remove gpio.h complicationsIngo Molnar
Remove the include/asm-x86/gpio.h specials, just use the generic version. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-25Merge git://git.infradead.org/~dwmw2/random-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/random-2.6: remove dummy asm/kvm.h files firmware: create firmware binaries during 'make modules'.
2008-07-25remove dummy asm/kvm.h filesAdrian Bunk
This patch removes the dummy asm/kvm.h files on architectures not (yet) supporting KVM and uses the same conditional headers installation as already used for a.out.h . Also removed are superfluous install rules in the s390 and x86 Kbuild files (they are already in Kbuild.asm). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25include/asm/ptrace.h userspace headers cleanupAdrian Bunk
This patch contains the following cleanups for the asm/ptrace.h userspace headers: - include/asm-generic/Kbuild.asm already lists ptrace.h, remove the superfluous listings in the Kbuild files of the following architectures: - cris - frv - powerpc - x86 - don't expose function prototypes and macros to userspace: - arm - blackfin - cris - mn10300 - parisc - remove #ifdef CONFIG_'s around #define's: - blackfin - m68knommu - sh: AFAIK __SH5__ should work in both kernel and userspace, no need to leak CONFIG_SUPERH64 to userspace - xtensa: cosmetical change to remove empty #ifndef __ASSEMBLY__ #else #endif from the userspace headers Not changed by this patch is the fact that the following architectures have a different struct pt_regs depending on CONFIG_ variables: - h8300 - m68knommu - mips This does not work in userspace. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Grant Grundler <grundler@parisc-linux.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Chris Zankel <chris@zankel.net> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpiolib: allow user-selectionMichael Buesch
This patch adds functionality to the gpio-lib subsystem to make it possible to enable the gpio-lib code even if the architecture code didn't request to get it built in. The archtitecture code does still need to implement the gpiolib accessor functions in its asm/gpio.h file. This patch adds the implementations for x86 and PPC. With these changes it is possible to run generic GPIO expansion cards on every architecture that implements the trivial wrapper functions. Support for more architectures can easily be added. Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jean Delvare <khali@linux-fr.org> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25clean up duplicated alloc/free_thread_infoFUJITA Tomonori
We duplicate alloc/free_thread_info defines on many platforms (the majority uses __get_free_pages/free_pages). This patch defines common defines and removes these duplicated defines. __HAVE_ARCH_THREAD_INFO_ALLOCATOR is introduced for platforms that do something different. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24x86-64: Clean up 'save/restore_i387()' usageLinus Torvalds
Suresh Siddha wants to fix a possible FPU leakage in error conditions, but the fact that save/restore_i387() are inlines in a header file makes that harder to do than necessary. So start off with an obvious cleanup. This just moves the x86-64 version of save/restore_i387() out of the header file, and moves it to the only file that it is actually used in: arch/x86/kernel/signal_64.c. So exposing it in a header file was wrong to begin with. [ Side note: I'd like to fix up some of the games we play with the 32-bit version of these functions too, but that's a separate matter. The 32-bit versions are shared - under different names at that! - by both the native x86-32 code and the x86-64 32-bit compatibility code ] Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (76 commits) ide: use proper printk() KERN_* levels in ide-probe.c ide: fix for EATA SCSI HBA in ATA emulating mode ide: remove stale comments from drivers/ide/Makefile ide: enable local IRQs in all handlers for TASKFILE_NO_DATA data phase ide-scsi: remove kmalloced struct request ht6560b: remove old history ht6560b: update email address ide-cd: fix oops when using growisofs gayle: release resources on ide_host_add() failure palm_bk3710: add UltraDMA/100 support ide: trivial sparse annotations ide: ide-tape.c sparse annotations and unaligned access removal ide: drop 'name' parameter from ->init_chipset method ide: prefix messages from IDE PCI host drivers by driver name it821x: remove DECLARE_ITE_DEV() macro it8213: remove DECLARE_ITE_DEV() macro ide: include PCI device name in messages from IDE PCI host drivers ide: remove <asm/ide.h> for some archs ide-generic: remove ide_default_{io_base,irq}() inlines (take 3) ide-generic: is no longer needed on ppc32 ...
2008-07-24ide: remove <asm/ide.h> for some archsBartlomiej Zolnierkiewicz
* Remove <linux/irq.h> include from <asm-ia64.h> (<linux/ide.h> includes <linux/interrupt.h> which is enough). * Remove <asm/ide.h> for alpha/blackfin/h8300/ia64/m32r/sh/x86/xtensa (this leaves us with arm/frv/m68k/mips/mn10300/parisc/powerpc/sparc[64]). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide-generic: remove ide_default_{io_base,irq}() inlines (take 3)Bartlomiej Zolnierkiewicz
Replace ide_default_{io_base,irq}() inlines by legacy_{bases,irqs}[]. v2: Add missing zero-ing of hws[] (caught during testing by Borislav Petkov). v3: Fix zero-oing of hws[] for _real_ this time. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: define MAX_HWIFS in <linux/ide.h>Bartlomiej Zolnierkiewicz
* Now that ide_hwif_t instances are allocated dynamically the difference between MAX_HWIFS == 2 and MAX_HWIFS == 10 is ~100 bytes (x86-32) so use MAX_HWIFS == 10 on all archs except these ones that use MAX_HWIFS == 1. * Define MAX_HWIFS in <linux/ide.h> instead of <asm/ide.h>. [ Please note that avr32/cris/v850 have no <asm/ide.h> and alpha/ia64/sh always define CONFIG_IDE_MAX_HWIFS. ] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide-generic: remove "no_pci_devices()" quirk from ide_default_io_base()Bartlomiej Zolnierkiewicz
Since the decision to probe for ISA ide2-6 is now left to the user "no_pci_devices()" quirk is no longer needed and may be removed. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: fix header export, asm-x86/processor-flags.h, CONFIG_* leaks x86: BUILD_IRQ say .text to avoid .data.percpu xen: don't use sysret for sysexit32 x86: call early_cpu_init at the same point
2008-07-24Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Remove __DECLARE_SEMAPHORE_GENERIC Remove asm/semaphore.h Remove use of asm/semaphore.h Add missing semaphore.h includes Remove mention of semaphores from kernel-locking
2008-07-24flag parameters add-on: remove epoll_create size paramUlrich Drepper
Remove the size parameter from the new epoll_create syscall and renames the syscall itself. The updated test program follows. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <time.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_epoll_create2 # ifdef __x86_64__ # define __NR_epoll_create2 291 # elif defined __i386__ # define __NR_epoll_create2 329 # else # error "need __NR_epoll_create2" # endif #endif #define EPOLL_CLOEXEC O_CLOEXEC int main (void) { int fd = syscall (__NR_epoll_create2, 0); if (fd == -1) { puts ("epoll_create2(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("epoll_create2(0) set close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_epoll_create2, EPOLL_CLOEXEC); if (fd == -1) { puts ("epoll_create2(EPOLL_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("epoll_create2(EPOLL_CLOEXEC) set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: inotify_initUlrich Drepper
This patch introduces the new syscall inotify_init1 (note: the 1 stands for the one parameter the syscall takes, as opposed to no parameter before). The values accepted for this parameter are function-specific and defined in the inotify.h header. Here the values must match the O_* flags, though. In this patch CLOEXEC support is introduced. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_inotify_init1 # ifdef __x86_64__ # define __NR_inotify_init1 294 # elif defined __i386__ # define __NR_inotify_init1 332 # else # error "need __NR_inotify_init1" # endif #endif #define IN_CLOEXEC O_CLOEXEC int main (void) { int fd; fd = syscall (__NR_inotify_init1, 0); if (fd == -1) { puts ("inotify_init1(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("inotify_init1(0) set close-on-exit"); return 1; } close (fd); fd = syscall (__NR_inotify_init1, IN_CLOEXEC); if (fd == -1) { puts ("inotify_init1(IN_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("inotify_init1(O_CLOEXEC) does not set close-on-exit"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [akpm@linux-foundation.org: add sys_ni stub] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: pipeUlrich Drepper
This patch introduces the new syscall pipe2 which is like pipe but it also takes an additional parameter which takes a flag value. This patch implements the handling of O_CLOEXEC for the flag. I did not add support for the new syscall for the architectures which have a special sys_pipe implementation. I think the maintainers of those archs have the chance to go with the unified implementation but that's up to them. The implementation introduces do_pipe_flags. I did that instead of changing all callers of do_pipe because some of the callers are written in assembler. I would probably screw up changing the assembly code. To avoid breaking code do_pipe is now a small wrapper around do_pipe_flags. Once all callers are changed over to do_pipe_flags the old do_pipe function can be removed. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_pipe2 # ifdef __x86_64__ # define __NR_pipe2 293 # elif defined __i386__ # define __NR_pipe2 331 # else # error "need __NR_pipe2" # endif #endif int main (void) { int fd[2]; if (syscall (__NR_pipe2, fd, 0) != 0) { puts ("pipe2(0) failed"); return 1; } for (int i = 0; i < 2; ++i) { int coe = fcntl (fd[i], F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { printf ("pipe2(0) set close-on-exit for fd[%d]\n", i); return 1; } } close (fd[0]); close (fd[1]); if (syscall (__NR_pipe2, fd, O_CLOEXEC) != 0) { puts ("pipe2(O_CLOEXEC) failed"); return 1; } for (int i = 0; i < 2; ++i) { int coe = fcntl (fd[i], F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { printf ("pipe2(O_CLOEXEC) does not set close-on-exit for fd[%d]\n", i); return 1; } } close (fd[0]); close (fd[1]); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: dup2Ulrich Drepper
This patch adds the new dup3 syscall. It extends the old dup2 syscall by one parameter which is meant to hold a flag value. Support for the O_CLOEXEC flag is added in this patch. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <time.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_dup3 # ifdef __x86_64__ # define __NR_dup3 292 # elif defined __i386__ # define __NR_dup3 330 # else # error "need __NR_dup3" # endif #endif int main (void) { int fd = syscall (__NR_dup3, 1, 4, 0); if (fd == -1) { puts ("dup3(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("dup3(0) set close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_dup3, 1, 4, O_CLOEXEC); if (fd == -1) { puts ("dup3(O_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("dup3(O_CLOEXEC) set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: epoll_createUlrich Drepper
This patch adds the new epoll_create2 syscall. It extends the old epoll_create syscall by one parameter which is meant to hold a flag value. In this patch the only flag support is EPOLL_CLOEXEC which causes the close-on-exec flag for the returned file descriptor to be set. A new name EPOLL_CLOEXEC is introduced which in this implementation must have the same value as O_CLOEXEC. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <time.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_epoll_create2 # ifdef __x86_64__ # define __NR_epoll_create2 291 # elif defined __i386__ # define __NR_epoll_create2 329 # else # error "need __NR_epoll_create2" # endif #endif #define EPOLL_CLOEXEC O_CLOEXEC int main (void) { int fd = syscall (__NR_epoll_create2, 1, 0); if (fd == -1) { puts ("epoll_create2(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("epoll_create2(0) set close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_epoll_create2, 1, EPOLL_CLOEXEC); if (fd == -1) { puts ("epoll_create2(EPOLL_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("epoll_create2(EPOLL_CLOEXEC) set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: eventfdUlrich Drepper
This patch adds the new eventfd2 syscall. It extends the old eventfd syscall by one parameter which is meant to hold a flag value. In this patch the only flag support is EFD_CLOEXEC which causes the close-on-exec flag for the returned file descriptor to be set. A new name EFD_CLOEXEC is introduced which in this implementation must have the same value as O_CLOEXEC. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_eventfd2 # ifdef __x86_64__ # define __NR_eventfd2 290 # elif defined __i386__ # define __NR_eventfd2 328 # else # error "need __NR_eventfd2" # endif #endif #define EFD_CLOEXEC O_CLOEXEC int main (void) { int fd = syscall (__NR_eventfd2, 1, 0); if (fd == -1) { puts ("eventfd2(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("eventfd2(0) sets close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_eventfd2, 1, EFD_CLOEXEC); if (fd == -1) { puts ("eventfd2(EFD_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("eventfd2(EFD_CLOEXEC) does not set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [akpm@linux-foundation.org: add sys_ni stub] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: signalfdUlrich Drepper
This patch adds the new signalfd4 syscall. It extends the old signalfd syscall by one parameter which is meant to hold a flag value. In this patch the only flag support is SFD_CLOEXEC which causes the close-on-exec flag for the returned file descriptor to be set. A new name SFD_CLOEXEC is introduced which in this implementation must have the same value as O_CLOEXEC. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <signal.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_signalfd4 # ifdef __x86_64__ # define __NR_signalfd4 289 # elif defined __i386__ # define __NR_signalfd4 327 # else # error "need __NR_signalfd4" # endif #endif #define SFD_CLOEXEC O_CLOEXEC int main (void) { sigset_t ss; sigemptyset (&ss); sigaddset (&ss, SIGUSR1); int fd = syscall (__NR_signalfd4, -1, &ss, 8, 0); if (fd == -1) { puts ("signalfd4(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("signalfd4(0) set close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_signalfd4, -1, &ss, 8, SFD_CLOEXEC); if (fd == -1) { puts ("signalfd4(SFD_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("signalfd4(SFD_CLOEXEC) does not set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [akpm@linux-foundation.org: add sys_ni stub] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: pacceptUlrich Drepper
This patch is by far the most complex in the series. It adds a new syscall paccept. This syscall differs from accept in that it adds (at the userlevel) two additional parameters: - a signal mask - a flags value The flags parameter can be used to set flag like SOCK_CLOEXEC. This is imlpemented here as well. Some people argued that this is a property which should be inherited from the file desriptor for the server but this is against POSIX. Additionally, we really want the signal mask parameter as well (similar to pselect, ppoll, etc). So an interface change in inevitable. The flag value is the same as for socket and socketpair. I think diverging here will only create confusion. Similar to the filesystem interfaces where the use of the O_* constants differs, it is acceptable here. The signal mask is handled as for pselect etc. The mask is temporarily installed for the thread and removed before the call returns. I modeled the code after pselect. If there is a problem it's likely also in pselect. For architectures which use socketcall I maintained this interface instead of adding a system call. The symmetry shouldn't be broken. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <errno.h> #include <fcntl.h> #include <pthread.h> #include <signal.h> #include <stdio.h> #include <unistd.h> #include <netinet/in.h> #include <sys/socket.h> #include <sys/syscall.h> #ifndef __NR_paccept # ifdef __x86_64__ # define __NR_paccept 288 # elif defined __i386__ # define SYS_PACCEPT 18 # define USE_SOCKETCALL 1 # else # error "need __NR_paccept" # endif #endif #ifdef USE_SOCKETCALL # define paccept(fd, addr, addrlen, mask, flags) \ ({ long args[6] = { \ (long) fd, (long) addr, (long) addrlen, (long) mask, 8, (long) flags }; \ syscall (__NR_socketcall, SYS_PACCEPT, args); }) #else # define paccept(fd, addr, addrlen, mask, flags) \ syscall (__NR_paccept, fd, addr, addrlen, mask, 8, flags) #endif #define PORT 57392 #define SOCK_CLOEXEC O_CLOEXEC static pthread_barrier_t b; static void * tf (void *arg) { pthread_barrier_wait (&b); int s = socket (AF_INET, SOCK_STREAM, 0); struct sockaddr_in sin; sin.sin_family = AF_INET; sin.sin_addr.s_addr = htonl (INADDR_LOOPBACK); sin.sin_port = htons (PORT); connect (s, (const struct sockaddr *) &sin, sizeof (sin)); close (s); pthread_barrier_wait (&b); s = socket (AF_INET, SOCK_STREAM, 0); sin.sin_port = htons (PORT); connect (s, (const struct sockaddr *) &sin, sizeof (sin)); close (s); pthread_barrier_wait (&b); pthread_barrier_wait (&b); sleep (2); pthread_kill ((pthread_t) arg, SIGUSR1); return NULL; } static void handler (int s) { } int main (void) { pthread_barrier_init (&b, NULL, 2); struct sockaddr_in sin; pthread_t th; if (pthread_create (&th, NULL, tf, (void *) pthread_self ()) != 0) { puts ("pthread_create failed"); return 1; } int s = socket (AF_INET, SOCK_STREAM, 0); int reuse = 1; setsockopt (s, SOL_SOCKET, SO_REUSEADDR, &reuse, sizeof (reuse)); sin.sin_family = AF_INET; sin.sin_addr.s_addr = htonl (INADDR_LOOPBACK); sin.sin_port = htons (PORT); bind (s, (struct sockaddr *) &sin, sizeof (sin)); listen (s, SOMAXCONN); pthread_barrier_wait (&b); int s2 = paccept (s, NULL, 0, NULL, 0); if (s2 < 0) { puts ("paccept(0) failed"); return 1; } int coe = fcntl (s2, F_GETFD); if (coe & FD_CLOEXEC) { puts ("paccept(0) set close-on-exec-flag"); return 1; } close (s2); pthread_barrier_wait (&b); s2 = paccept (s, NULL, 0, NULL, SOCK_CLOEXEC); if (s2 < 0) { puts ("paccept(SOCK_CLOEXEC) failed"); return 1; } coe = fcntl (s2, F_GETFD); if ((coe & FD_CLOEXEC) == 0) { puts ("paccept(SOCK_CLOEXEC) does not set close-on-exec flag"); return 1; } close (s2); pthread_barrier_wait (&b); struct sigaction sa; sa.sa_handler = handler; sa.sa_flags = 0; sigemptyset (&sa.sa_mask); sigaction (SIGUSR1, &sa, NULL); sigset_t ss; pthread_sigmask (SIG_SETMASK, NULL, &ss); sigaddset (&ss, SIGUSR1); pthread_sigmask (SIG_SETMASK, &ss, NULL); sigdelset (&ss, SIGUSR1); alarm (4); pthread_barrier_wait (&b); errno = 0 ; s2 = paccept (s, NULL, 0, &ss, 0); if (s2 != -1 || errno != EINTR) { puts ("paccept did not fail with EINTR"); return 1; } close (s); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [akpm@linux-foundation.org: make it compile] [akpm@linux-foundation.org: add sys_ni stub] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Roland McGrath <roland@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24x86: add hugepagesz option on 64-bitAndi Kleen
Add an hugepagesz=... option similar to IA64, PPC etc. to x86-64. This finally allows to select GB pages for hugetlbfs in x86 now that all the infrastructure is in place. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: modular state for hugetlb page sizeAndi Kleen
The goal of this patchset is to support multiple hugetlb page sizes. This is achieved by introducing a new struct hstate structure, which encapsulates the important hugetlb state and constants (eg. huge page size, number of huge pages currently allocated, etc). The hstate structure is then passed around the code which requires these fields, they will do the right thing regardless of the exact hstate they are operating on. This patch adds the hstate structure, with a single global instance of it (default_hstate), and does the basic work of converting hugetlb to use the hstate. Future patches will add more hstate structures to allow for different hugetlbfs mounts to have different page sizes. [akpm@linux-foundation.org: coding-style fixes] Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: remove double indirection on tlb parameter to free_pgd_range() & CoJan Beulich
The double indirection here is not needed anywhere and hence (at least) confusing. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24access_process_vm device memory infrastructureRik van Riel
In order to be able to debug things like the X server and programs using the PPC Cell SPUs, the debugger needs to be able to access device memory through ptrace and /proc/pid/mem. This patch: Add the generic_access_phys access function and put the hooks in place to allow access_process_vm to access device or PPC Cell SPU memory. [riel@redhat.com: Add documentation for the vm_ops->access function] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Benjamin Herrensmidt <benh@kernel.crashing.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Hugh Dickins <hugh@veritas.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Remove asm/semaphore.hMatthew Wilcox
All users have now been converted to linux/semaphore.h and we don't need to keep these files around any longer. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-07-24x86: fix header export, asm-x86/processor-flags.h, CONFIG_* leaksVegard Nossum
Apparently, commit 6330a30a76c1e62d4b4ec238368957f8febf9113 Author: Vegard Nossum <vegard.nossum@gmail.com> Date: Wed May 28 09:46:19 2008 +0200 x86: break mutual header inclusion introduced some CONFIG names to processor-flags.h, which was exported in commit 6093015db2bd9e70cf20cdd23be1a50733baafdd Author: Ingo Molnar <mingo@elte.hu> Date: Sun Mar 30 11:45:23 2008 +0200 x86: cleanup replace most vm86 flags with flags from processor-flags.h, fix Fix it by wrapping the CONFIG parts in __KERNEL__. Reported-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Cc: Adrian Bunk <bunk@kernel.org> Cc: Olaf Hering <olaf@aepfle.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-23Merge branch 'sched/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: hrtick_enabled() should use cpu_active() sched, x86: clean up hrtick implementation sched: fix build error, provide partition_sched_domains() unconditionally sched: fix warning in inc_rt_tasks() to not declare variable 'rq' if it's not needed cpu hotplug: Make cpu_active_map synchronization dependency clear cpu hotplug, sched: Introduce cpu_active_map and redo sched domain managment (take 2) sched: rework of "prioritize non-migratable tasks over migratable ones" sched: reduce stack size in isolated_cpu_setup() Revert parts of "ftrace: do not trace scheduler functions" Fixed up conflicts in include/asm-x86/thread_info.h (due to the TIF_SINGLESTEP unification vs TIF_HRTICK_RESCHED removal) and kernel/sched_fair.c (due to cpu_active_map vs for_each_cpu_mask_nr() introduction).
2008-07-23Merge branch 'cpus4096-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits) NR_CPUS: Replace NR_CPUS in speedstep-centrino.c cpumask: Provide a generic set of CPUMASK_ALLOC macros, FIXUP NR_CPUS: Replace NR_CPUS in cpufreq userspace routines NR_CPUS: Replace per_cpu(..., smp_processor_id()) with __get_cpu_var NR_CPUS: Replace NR_CPUS in arch/x86/kernel/genapic_flat_64.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/genx2apic_uv_x.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/cpu/proc.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/cpu/mcheck/mce_64.c cpumask: Optimize cpumask_of_cpu in lib/smp_processor_id.c, fix cpumask: Use optimized CPUMASK_ALLOC macros in the centrino_target cpumask: Provide a generic set of CPUMASK_ALLOC macros cpumask: Optimize cpumask_of_cpu in lib/smp_processor_id.c cpumask: Optimize cpumask_of_cpu in kernel/time/tick-common.c cpumask: Optimize cpumask_of_cpu in drivers/misc/sgi-xp/xpc_main.c cpumask: Optimize cpumask_of_cpu in arch/x86/kernel/ldt.c cpumask: Optimize cpumask_of_cpu in arch/x86/kernel/io_apic_64.c cpumask: Replace cpumask_of_cpu with cpumask_of_cpu_ptr Revert "cpumask: introduce new APIs" cpumask: make for_each_cpu_mask a bit smaller net: Pass reference to cpumask variable in net/sunrpc/svc.c ... Fix up trivial conflicts in drivers/cpufreq/cpufreq.c manually
2008-07-22x86: add PTE_FLAGS_MASKJeremy Fitzhardinge
PTE_PFN_MASK was getting lonely, so I made it a friend. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-22x86: rename PTE_MASK to PTE_PFN_MASKJeremy Fitzhardinge
Rusty, in his peevish way, complained that macros defining constants should have a name which somewhat accurately reflects the actual purpose of the constant. Aside from the fact that PTE_MASK gives no clue as to what's actually being masked, and is misleadingly similar to the functionally entirely different PMD_MASK, PUD_MASK and PGD_MASK, I don't really see what the problem is. But if this patch silences the incessent noise, then it will have achieved its goal (TODO: write test-case). Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-22x86: fix pte_flags() to only return flags, fix lguest (updated)Rusty Russell
(Jeremy said: rusty: use PTE_MASK rusty: use PTE_MASK rusty: use PTE_MASK When I asked: jsgf: does that include the NX flag? He responded eloquently: rusty: use PTE_MASK rusty: use PTE_MASK yes, it's the official constant of masking flags out of ptes ) Change a15af1c9ea2750a9ff01e51615c45950bad8221b 'x86/paravirt: add pte_flags to just get pte flags' removed lguest's private pte_flags() in favor of a generic one. Unfortunately, the generic one doesn't filter out the non-flags bits: this results in lguest creating corrupt shadow page tables and blowing up host memory. Since noone is supposed to use the pfn part of pte_flags(), it seems safest to always do the filtering. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-and-morning-tea-spilled-by: Ingo Molnar <mingo@elte.hu>
2008-07-21x86: convert Dprintk to pr_debugThomas Gleixner
There are a couple of places where (P)Dprintk is used which is an old compile time enabled printk wrapper. Convert it to the generic pr_debug(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-21Merge branch 'linus' into cpus4096-for-linusIngo Molnar
Conflicts: net/sunrpc/svc.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-21Merge branch 'x86/paravirt-spinlocks' into x86/for-linusIngo Molnar
