path: root/include/asm-x86/trampoline.h
2008-07-22x86: consolidate header guardsVegard Nossum
This patch is the result of an automatic script that consolidates the format of all the headers in include/asm-x86/. The format: 1. No leading underscore. Names with leading underscores are reserved. 2. Pathname components are separated by two underscores. So we can distinguish between mm_types.h and mm/types.h. 3. Everything except letters and numbers are turned into single underscores. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2008-04-17x86: move suspend wakeup code to CPavel Machek
Move wakeup code to .c, so that video mode setting code can be shared between boot and wakeup. Remove nasty assembly code in 64-bit case by re-using trampoline code. Stack setup was fixed to clear high 16bits of %esp, maybe that fixes some machines. .c code sharing and morse code was done H. Peter Anvin, Sam Ravnborg reviewed kbuild related stuff, and it seems okay to him. Rafael did some cleanups. [rjw: * Made the patch stop breaking compilation on x86-32 * Added arch/x86/kernel/acpi/sleep.h * Got rid of compiler warnings in arch/x86/kernel/acpi/sleep.c * Fixed 32-bit compilation on x86-64 systems * Added include/asm-x86/trampoline.h and fixed the non-SMP compilation on 64-bit x86 * Removed arch/x86/kernel/acpi/sleep_32.c which was not used * Fixed some breakage caused by the integration of smpboot.c done under us in the meantime] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
