path: root/include/asm-x86/Kbuild
2008-04-17x86: cleanup replace most vm86 flags with flags from processor-flags.h, fixIngo Molnar
- fix build error - fix CONFIG_HEADERS_CHECK error Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-06Really unexport asm/page.hDavid Woodhouse
Commit ed7b1889da256977574663689b598d88950bbd23 removed page.h from include/asm-generic/Kbuild so that it shouldn't get exported. However, it was redundantly listed in asm-mn10300/Kbuild and asm-x86/Kbuild too. Remove those as well, so it really stops being exported on those architectures. Also remove the redundant listing of ptrace.h and termios.h from mn10300. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Unexport asm/user.h and linux/user.hKirill A. Shutemov
Do not export asm/user.h and linux/user.h during make headers_install. Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30KVM: Export include/asm-x86/kvm.hAvi Kivity
Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30x86: page.h: move things back to their own filesJeremy Fitzhardinge
# HG changeset patch # User Jeremy Fitzhardinge <jeremy@xensource.com> # Date 1199321648 28800 # Node ID 22f6a5902285b58bfc1fbbd9e183498c9017bd78 # Parent bba9287641ff90e836d090d80b5c0a846aab7162 x86: page.h: move things back to their own files Oops, asm/page.h has turned into an #ifdef hellhole. Move 32/64-specific things back to their own headers to make it somewhat comprehensible... Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86 vDSO: ia32 vsyscall removalRoland McGrath
This removes all the old vsyscall code from arch/x86/ia32/ that is no longer used because arch/x86/vdso/ code has replaced it. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-23x86: merge setup_32/64.hThomas Gleixner
2007-10-23x86: merge signal_32/64.hThomas Gleixner
2007-10-23x86: merge sigcontext_32/64.hThomas Gleixner
2007-10-23x86: merge msr_32/64.hThomas Gleixner
2007-10-23x86: merge mttr_32/64.hThomas Gleixner
2007-10-23x86: merge statfs_32/64.hThomas Gleixner
2007-10-23x86: merge stat_32/64.hThomas Gleixner
2007-10-23x86: merge shmbuf_32/64.hThomas Gleixner
2007-10-23x86: merge ptrace_32/64.hThomas Gleixner
2007-10-23x86: merge msgbuf_32/64.hThomas Gleixner
2007-10-23x86: merge elf_32/64.hThomas Gleixner
2007-10-23x86: merge byteorder_32/64.hThomas Gleixner
2007-10-23x86: unify a.out{,_32,_64}.hChris Snook
Unify x86 a.out_32.h and a.out_64.h [ tglx: Kbuild fixup ] Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-23Make asm-x86/bootparam.h includable from userspace.Rusty Russell
To actually write a bootloader (or, say, the lguest launcher) currently requires duplication of these structures. Making them includable from userspace is much nicer. We merge the common userspace-required definitions of e820_32/64.h into e820.h for export. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-17x86: unify include/asm/debugreg_32/64.hThomas Gleixner
Almost identical except for the extra DR_LEN_8 and the different DR_CONTROL_RESERVED defines. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Conflicts: include/asm-x86/Kbuild
2007-10-17x86: unify include/asm/types_32/64.hThomas Gleixner
Mostly the same. Make the few exceptions conditional. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Conflicts: include/asm-x86/types_32.h
2007-10-17x86: unify include/asm/siginfo_32/64.hThomas Gleixner
Same file, except for the 64bit PREAMBLE_SIZE define. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17x86: unify include/asm/mman_32/64.hThomas Gleixner
Same file, except for the extra 64bit MAP_32BIT define, which does not hurt for 32 bit compiles. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17x86: unify include/asm/ioctls_32/64.hThomas Gleixner
Same file, except for whitespace and comment formatting. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17x86: unify include/asm/auxvec_32/64.hThomas Gleixner
Same file, except for whitespace, comment formatting and the AT_SYSINFO define for 32bit Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17x86: unify some more trivial include/asm-x86/ 32/64 variantsThomas Gleixner
Scripted unification. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17x86: merge some trivially mergeable headersRoland Dreier
Merge errno.h, resource.h, rtc.h, sections.h, serial.h and sockios.h, where i386 and x86_64 have no or only trivial comment/include guard differences. Build tested on both 32-bit and 64-bit, and booted on 64-bit. [tglx: fixup Kbuild as well] Signed-off-by: Roland Dreier <roland@digitalvampire.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17x86: trivial header mergesBrian Gerst
Merge 32/64-bit headers that simply redirect to asm-generic [tglx: fixup Kbuild as well] Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17x86: unify include/asm/ldt_32/64.hThomas Gleixner
The additional struct member of user_desc can be made conditional for 64 bit compiles. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-17x86: unify include/asm/ptrace-abi_32/64.hThomas Gleixner
Aside of the register defines the content can be shared. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-16[x86] remove uses of magic macros for boot_params accessH. Peter Anvin
Instead of using magic macros for boot_params access, simply use the boot_params structure. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
