path: root/include/asm-sparc
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-24[SPARC]: __NR_sys removalOGAWA Hirofumi
__NR_sys_sync_file_range part was lost somewhere... [glibc is already checking __NR_sync_file_range] Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-19[SPARC]: __NR_sys_splice --> __NR_spliceDavid S. Miller
2006-04-14[SPARC]: Hook up sys_tee() into syscall tables.David S. Miller
2006-04-11[PATCH] sparc32 vga supportAndrew Morton
sparc32 lacks vga.h, so lots of fbdev drivers won't compile. There are no sparc32 systems with PCI slots, so it's a bit moot. The patch gives sparc32 a copy of the sparc64 vga.h. It fixes sparc32 allmodconfig without mucking up fbdev Kconfig and gives us wider compile coverage. Cc: "Antonino A. Daplas" <adaplas@pol.net> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[SPARC]: Wire up sys_sync_file_range() into syscall tables.David S. Miller
2006-03-31[SPARC]: Wire up sys_splice() into the syscall tables.David S. Miller
2006-03-27[PATCH] unify pfn_to_page: sparc pfn_to_pageKAMEZAWA Hiroyuki
sparc can use generic funcs. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: sparc: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove __ffs() - remove sched_find_first_bit() - remove ffs() - remove generic_fls() - remove generic_fls64() - remove generic_hweight{32,16,8}() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: use non atomic operations for minix_*_bit() and ext2_*_bit()Akinobu Mita
Bitmap functions for the minix filesystem and the ext2 filesystem except ext2_set_bit_atomic() and ext2_clear_bit_atomic() do not require the atomic guarantees. But these are defined by using atomic bit operations on several architectures. (cris, frv, h8300, ia64, m32r, m68k, m68knommu, mips, s390, sh, sh64, sparc, sparc64, v850, and xtensa) This patch switches to non atomic bit operation. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC]: Try to start getting SMP back into shape.
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[SPARC]: Try to start getting SMP back into shape.Bob Breuer
Todo items: - IRQ_INPROGRESS flag - use sparc64 irq buckets, or generic irq_desc? - sun4d - re-indent large chunks of sun4m_smp.c - some places assume sequential cpu numbering (i.e. 0,1 instead of 0,2) Last I checked (with 2.6.14), random programs segfault with dual HyperSPARC. And with SuperSPARC II's, it seems stable but will eventually die from a write lock error (wrong lock owner or something). I haven't tried the HyperSPARC + highmem combination recently, so that may still be a problem. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-22[SPARC]: Respect vm_page_prot in io_remap_page_range().David S. Miller
Make sure the callers do a pgprot_noncached() on vma->vm_page_prot. Pointed out by Hugh Dickens. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC]: Fixup SO_PEERSEC value on 32-bit sparc.David S. Miller
Sparc64 and Sparc32 have to have identical socket call numbering in order to handle compat layer stuff properly. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC]: Kill off these __put_user_ret things.David S. Miller
They are bogus and haven't been referenced in years. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Recognize "virtual-console" as input and output console device.David S. Miller
2006-03-20[SPARC]: Clean up idprom header files.David S. Miller
Delete unused macros, and use fixed sized types in sparc32 header. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-15[PATCH] add asm-generic/mman.hMichael S. Tsirkin
Make new MADV_REMOVE, MADV_DONTFORK, MADV_DOFORK consistent across all arches. The idea is to make it possible to use them portably even before distros include them in libc headers. Move common flags to asm-generic/mman.h Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] madvise MADV_DONTFORK/MADV_DOFORKMichael S. Tsirkin
Currently, copy-on-write may change the physical address of a page even if the user requested that the page is pinned in memory (either by mlock or by get_user_pages). This happens if the process forks meanwhile, and the parent writes to that page. As a result, the page is orphaned: in case of get_user_pages, the application will never see any data hardware DMA's into this page after the COW. In case of mlock'd memory, the parent is not getting the realtime/security benefits of mlock. In particular, this affects the Infiniband modules which do DMA from and into user pages all the time. This patch adds madvise options to control whether memory range is inherited across fork. Useful e.g. for when hardware is doing DMA from/into these pages. Could also be useful to an application wanting to speed up its forks by cutting large areas out of consideration. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Acked-by: Hugh Dickins <hugh@veritas.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-12[SPARC]: sys_newfstatat --> sys_fstatat64David S. Miller
2006-02-07[SPARC]: Wire up sys_unshare().David S. Miller
Also, the Solaris syscall table is sized differrently, and does not go beyond entry 255, so trim off the excess entries. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-19[SPARC]: Add support for *at(), ppoll, and pselect syscalls.David S. Miller
This also includes by necessity _TIF_RESTORE_SIGMASK support, which actually resulted in a lot of cleanups. The sparc signal handling code is quite a mess and I should clean it up some day. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18[SPARC]: sparc32 needs PROMDEV_{I,O}RSC defines too.David S. Miller
2006-01-12[PATCH] death of get_thread_info/put_thread_infoAl Viro
{get,put}_thread_info() were introduced in 2.5.4 and never had been called by anything in the tree. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] sparc: task_thread_info()Al Viro
2006-01-12[PATCH] sched: add cacheflush() asmIngo Molnar
Add per-arch sched_cacheflush() which is a write-back cacheflush used by the migration-cost calibration code at bootup time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, add default include/asm-*/mutex.h filesArjan van de Ven
add the per-arch mutex.h files for the remaining architectures. We default to asm-generic/mutex-dec.h, because that performs quite well on most arches. Arches that do not have atomic decrement/increment instructions should switch to mutex-xchg.h instead. Arches can also provide their own implementation for the mutex fastpath primitives. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] mutex subsystem, add atomic_xchg() to all archesIngo Molnar
add atomic_xchg() to all the architectures. Needed by the new mutex code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-08[PATCH] consolidate asm/futex.hJeff Dike
Most of the architectures have the same asm/futex.h. This consolidates them into asm-generic, with the arches including it from their own asm/futex.h. In the case of UML, this reverts the old broken futex.h and goes back to using the same one as almost everyone else. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Kill L1_CACHE_SHIFT_MAXRavikiran G Thirumalai
Kill L1_CACHE_SHIFT from all arches. Since L1_CACHE_SHIFT_MAX is not used anymore with the introduction of INTERNODE_CACHE, kill L1_CACHE_SHIFT_MAX. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] atomic_long_t & include/asm-generic/atomic.h V2Christoph Lameter
Several counters already have the need to use 64 atomic variables on 64 bit platforms (see mm_counter_t in sched.h). We have to do ugly ifdefs to fall back to 32 bit atomic on 32 bit platforms. The VM statistics patch that I am working on will also make more extensive use of atomic64. This patch introduces a new type atomic_long_t by providing definitions in asm-generic/atomic.h that works similar to the c "long" type. Its 32 bits on 32 bit platforms and 64 bits on 64 bit platforms. Also cleans up the determination of the mm_counter_t in sched.h. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] madvise(MADV_REMOVE): remove pages from tmpfs shm backing storeBadari Pulavarty
Here is the patch to implement madvise(MADV_REMOVE) - which frees up a given range of pages & its associated backing store. Current implementation supports only shmfs/tmpfs and other filesystems return -ENOSYS. "Some app allocates large tmpfs files, then when some task quits and some client disconnect, some memory can be released. However the only way to release tmpfs-swap is to MADV_REMOVE". - Andrea Arcangeli Databases want to use this feature to drop a section of their bufferpool (shared memory segments) - without writing back to disk/swap space. This feature is also useful for supporting hot-plug memory on UML. Concerns raised by Andrew Morton: - "We have no plan for holepunching! If we _do_ have such a plan (or might in the future) then what would the API look like? I think sys_holepunch(fd, start, len), so we should start out with that." - Using madvise is very weird, because people will ask "why do I need to mmap my file before I can stick a hole in it?" - None of the other madvise operations call into the filesystem in this manner. A broad question is: is this capability an MM operation or a filesytem operation? truncate, for example, is a filesystem operation which sometimes has MM side-effects. madvise is an mm operation and with this patch, it gains FS side-effects, only they're really, really significant ones." Comments: - Andrea suggested the fs operation too but then it's more efficient to have it as a mm operation with fs side effects, because they don't immediatly know fd and physical offset of the range. It's possible to fixup in userland and to use the fs operation but it's more expensive, the vmas are already in the kernel and we can use them. Short term plan & Future Direction: - We seem to need this interface only for shmfs/tmpfs files in the short term. We have to add hooks into the filesystem for correctness and completeness. This is what this patch does. - In the future, plan is to support both fs and mmap apis also. This also involves (other) filesystem specific functions to be implemented. - Current patch doesn't support VM_NONLINEAR - which can be addressed in the future. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Andrea Arcangeli <andrea@suse.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[FLS64]: generic versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-15[PATCH] sun4c_memerr_reg __iomem annotationsAl Viro
2005-12-15[PATCH] fix iomem annotations in sparc32 pcic codeAl Viro
2005-11-13[PATCH] atomic: inc_not_zeroNick Piggin
Introduce an atomic_inc_not_zero operation. Make this a special case of atomic_add_unless because lockless pagecache actually wants atomic_inc_not_negativeone due to its offset refcount. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] atomic: cmpxchgNick Piggin
Introduce an atomic_cmpxchg operation. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[SPARC]: remove vuid_event.hChristoph Hellwig
I don't know if we ever implemented this, but the only user in any 2.6 tree are the compat ioctls. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[SPARC]: remove kbio.hChristoph Hellwig
The old keyboard driver is gone in 2.6, so the only user left are the compat ioctls. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[SPARC]: remove audioio.hChristoph Hellwig
The old sound drivers are gone in 2.6, so the only user left are the compat ioctls. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[SPARC]: remove duplicate TIOCPKT_ definitionsStephen Rothwell
The TIOCPKT_ macros are defined by all other architectures in asm/ioctls.h and so does sparc and sparc64, so reomve the duplicates in asm/termios.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] semaphore: Remove __MUTEX_INITIALIZER()Arthur Othieno
__MUTEX_INITIALIZER() has no users, and equates to the more commonly used DECLARE_MUTEX(), thus making it pretty much redundant. Remove it for good. Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] vm: remove unused/broken page_pte[_prot] macrosTejun Heo
This patch removes page_pte_prot and page_pte macros from all architectures. Some architectures define both, some only page_pte (broken) and others none. These macros are not used anywhere. page_pte_prot(page, prot) is identical to mk_pte(page, prot) and page_pte(page) is identical to page_pte_prot(page, __pgprot(0)). * The following architectures define both page_pte_prot and page_pte arm, arm26, ia64, sh64, sparc, sparc64 * The following architectures define only page_pte (broken) frv, i386, m32r, mips, sh, x86-64 * All other architectures define neither Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] remove some more check_region stuffJeff Garzik
Removed some more references to check_region(). I checked these changes into the 'checkreg' branch of rsync://rsync.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6.git The only valid references remaining are in: drivers/scsi/advansys.c drivers/scsi/BusLogic.c drivers/cdrom/sbpcd.c sound/oss/pss.c Remove last vestiges of ide_check_region() drivers/char/specialix: trim trailing whitespace drivers/char/specialix: eliminate use of check_region() Remove outdated and unused references to check_region() [sound oss] remove check_region() usage from cs4232, wavfront [netdrvr eepro] trim trailing whitespace [netdrvr eepro] remove check_region() usage Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: dma-mapping (simple cases)Al Viro
2005-10-05[PATCH] fix the breakage in sparc headersAl Viro
If we switch extern inline to static inline, we'd better switch the pre-declarations we use to say that these puppies have __attribute_const__ on them. Otherwise we get extern declaration followed by static inline one. Which makes gcc unhappy, and for a good reason... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-03[SPARC]: "extern inline" doesn't make much sense.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC]: Declare paging_init() in asm/pgtable.hDavid S. Miller
