path: root/include/asm-sparc64
2008-05-25sparc64: global_reg_snapshot is not for userspaceAdrian Bunk
global_reg_snapshot shouldn't be visible in our userspace headers. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc64: Add global register dumping facility.David S. Miller
When a cpu really is stuck in the kernel, it can be often impossible to figure out which cpu is stuck where. The worst case is when the stuck cpu has interrupts disabled. Therefore, implement a global cpu state capture that uses SMP message interrupts which are not disabled by the normal IRQ enable/disable APIs of the kernel. As long as we can get a sysrq 'y' to the kernel, we can get a dump. Even if the console interrupt cpu is wedged, we can trigger it from userspace using /proc/sysrq-trigger The output is made compact so that this facility is more useful on high cpu count systems, which is where this facility will likely find itself the most useful :) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12sparc64: Use a TS_RESTORE_SIGMASKDavid S. Miller
This mirrors x86 changeset 5a8da0ea82db6fa9737041381079fd16f25dcce2 ("signals: x86 TS_RESTORE_SIGMASK") on sparc64. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12sparc: Fix mremap address range validation.David S. Miller
Just like mmap, we need to validate address ranges regardless of MAP_FIXED. sparc{,64}_mmap_check()'s flag argument is unused, remove. Based upon a report and preliminary patch by Jan Lieskovsky <jlieskov@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-11sparc: Fix debugger syscall restart interactions.David S. Miller
So, forever, we've had this ptrace_signal_deliver implementation which tries to handle all of the nasties that can occur when the debugger looks at a process about to take a signal. It's meant to address all of these issues inside of the kernel so that the debugger need not be mindful of such things. Problem is, this doesn't work. The idea was that we should do the syscall restart business first, so that the debugger captures that state. Otherwise, if the debugger for example saves the child's state, makes the child execute something else, then restores the saved state, we won't handle the syscall restart properly because we lose the "we're in a syscall" state. The code here worked for most cases, but if the debugger actually passes the signal through to the child unaltered, it's possible that we would do a syscall restart when we shouldn't have. In particular this breaks the case of debugging a process under a gdb which is being debugged by yet another gdb. gdb uses sigsuspend to wait for SIGCHLD of the inferior, but if gdb itself is being debugged by a top-level gdb we get a ptrace_stop(). The top-level gdb does a PTRACE_CONT with SIGCHLD to let the inferior gdb see the signal. But ptrace_signal_deliver() assumed the debugger would cancel out the signal and therefore did a syscall restart, because the return error was ERESTARTNOHAND. Fix this by simply making ptrace_signal_deliver() a nop, and providing a way for the debugger to control system call restarting properly: 1) Report a "in syscall" software bit in regs->{tstate,psr}. It is set early on in trap entry to a system call and is fully visible to the debugger via ptrace() and regsets. 2) Test this bit right before doing a syscall restart. We have to do a final recheck right after get_signal_to_deliver() in case the debugger cleared the bit during ptrace_stop(). 3) Clear the bit in trap return so we don't accidently try to set that bit in the real register. As a result we also get a ptrace_{is,clear}_syscall() for sparc32 just like sparc64 has. M68K has this same exact bug, and is now the only other user of the ptrace_signal_deliver hook. It needs to be fixed in the same exact way as sparc. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-11sparc: Fix ptrace() detach.David S. Miller
Forever we had a PTRACE_SUNOS_DETACH which was unconditionally recognized, regardless of the personality of the process. Unfortunately, this value is what ended up in the GLIBC sys/ptrace.h header file on sparc as PTRACE_DETACH and PT_DETACH. So continue to recognize this old value. Luckily, it doesn't conflict with anything we actually care about. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02sparc64: types: use <asm-generic/int-*.h> for the sparc64 architectureH. Peter Anvin
This modifies <asm-sparc64/types.h> to use the <asm-generic/int-*.h> generic include files. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Acked-by: David S. Miller <davem@davemloft.net>
2008-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: remove duplicated include sparc: Add kgdb support. kgdbts: Sparc needs sstep emulation. sparc32: Kill smp_message_pass() and related code. sparc64: Kill PIL_RESERVED, unused. sparc64: Split entry.S up into seperate files.
2008-04-30asm-*/futex.h should include linux/uaccess.hJeff Dike
Lots of asm-*/futex.h call pagefault_enable and pagefault_disable, which are declared in linux/uaccess.h, without including linux/uaccess.h. They all include asm/uaccess.h, so this patch replaces asm/uaccess.h with linux/uaccess.h. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: Move arches to use common unaligned accessHarvey Harrison
Unaligned access is ok for the following arches: cris, m68k, mn10300, powerpc, s390, x86 Arches that use the memmove implementation for native endian, and the byteshifting for the opposite endianness. h8300, m32r, xtensa Packed struct for native endian, byteshifting for other endian: alpha, blackfin, ia64, parisc, sparc, sparc64, mips, sh m86knommu is generic_be for Coldfire, otherwise unaligned access is ok. frv, arm chooses endianness based on compiler settings, uses the byteshifting versions. Remove the unaligned trap handler from frv as it is now unused. v850 is le, uses the byteshifting versions for both be and le. Remove the now unused asm-generic implementation. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29sparc: Add kgdb support.David S. Miller
Current limitations: 1) On SMP single stepping has some fundamental issues, shared with other sw single-step architectures such as mips and arm. 2) On 32-bit sparc we don't support SMP kgdb yet. That requires some reworking of the IPI mechanisms and infrastructure on that platform. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: video drivers: add facility level sparc: tcx.c make tcx_init and tcx_exit static sparc: ffb.c make ffb_init and ffb_exit static sparc: cg14.c make cg14_init and cg15_exit static sparc: bw2.c fix bw2_exit sparc64: Fix accidental syscall restart on child return from clone/fork/vfork. sparc64: Clean up handling of pt_regs trap type encoding. sparc: Remove old style signal frame support. sparc64: Kill bogus RT_ALIGNEDSZ macro from signal.c sparc: sunzilog.c remove unused argument sparc: fix drivers/video/tcx.c warning sparc64: Kill unused local ISA bus layer. input: Rewrite sparcspkr device probing. sparc64: Do not ignore 'pmu' device ranges. sparc64: Kill ISA_FLOPPY_WORKS code. sparc64: Kill CONFIG_SPARC32_COMPAT sparc64: Cleanups and corrections for arch/sparc64/Kconfig sparc64: Fix wedged irq regression.
2008-04-28hugetlbfs: common code update for s390Gerald Schaefer
Huge ptes have a special type on s390 and cannot be handled with the standard pte functions in certain cases, e.g. because of a different location of the invalid bit. This patch adds some new architecture- specific functions to hugetlb common code, as a prerequisite for the s390 large page support. This won't affect other architectures in functionality, but I need to add some new dummy inline functions to the headers. Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28hugetlbfs: add missing TLB flush to hugetlb_cow()Gerald Schaefer
A cow break on a hugetlbfs page with page_count > 1 will set a new pte with set_huge_pte_at(), w/o any tlb flush operation. The old pte will remain in the tlb and subsequent write access to the page will result in a page fault loop, for as long as it may take until the tlb is flushed from somewhere else. This patch introduces an architecture-specific huge_ptep_clear_flush() function, which is called before the the set_huge_pte_at() in hugetlb_cow(). ATTENTION: This is just a nop on all architectures for now, the s390 implementation will come with our large page patch later. Other architectures should define their own huge_ptep_clear_flush() if needed. Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28hugetlbfs: architecture header cleanupGerald Schaefer
This patch moves all architecture functions for hugetlb to architecture header files (include/asm-foo/hugetlb.h) and converts all macros to inline functions. It also removes (!) ARCH_HAS_HUGEPAGE_ONLY_RANGE, ARCH_HAS_HUGETLB_FREE_PGD_RANGE, ARCH_HAS_PREPARE_HUGEPAGE_RANGE, ARCH_HAS_SETCLEAR_HUGE_PTE and ARCH_HAS_HUGETLB_PREFAULT_HOOK. Getting rid of the ARCH_HAS_xxx #ifdef and macro fugliness should increase readability and maintainability, at the price of some code duplication. An asm-generic common part would have reduced the loc, but we would end up with new ARCH_HAS_xxx defines eventually. Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28sparc64: Kill PIL_RESERVED, unused.David S. Miller
2008-04-27sparc64: Clean up handling of pt_regs trap type encoding.David S. Miller
If we use this from more than one place, it's better to have helpers instead of twiddling magic constants all over. Add pt_regs_trap_type(), pt_regs_clear_trap_type(), and pt_regs_is_syscall(). Use them in do_signal(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27sparc: Remove old style signal frame support.David S. Miller
Back around the same time we were bootstrapping the first 32-bit sparc Linux kernel with a SunOS userland, we made the signal frame match that of SunOS. By the time we even started putting together a native Linux userland for 32-bit Sparc we realized this layout wasn't sufficient for Linux's needs. Therefore we changed the layout, yet kept support for the old style signal frame layout in there. The detection mechanism is that we had sys_sigaction() start passing in a negative signal number to indicate "new style signal frames please". Anyways, no binaries exist in the world that use the old stuff. In fact, I bet Jakub Jelinek and myself are the only two people who ever had such binaries to be honest. So let's get rid of this stuff. I added an assertion using WARN_ON_ONCE() that makes sure 32-bit applications are passing in that negative signal number still. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-26sparc64: Kill unused local ISA bus layer.David S. Miller
No more drivers use this, and therefore it can die. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-26sparc64: Kill ISA_FLOPPY_WORKS code.David S. Miller
This never was enabled, I could never get it working, and if anyone wants to try and get it's very easy to reference this code in the history. It's the only thing referencing the silly ISA device layer in the sparc64 tree. OF device layer infrastructure is what should be used for these things. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-26generic: implement __fls on all 64-bit archsAlexander van Heukelum
Implement __fls on all 64-bit archs: alpha has an implementation of fls64. Added __fls(x) = fls64(x) - 1. ia64 has fls, but not __fls. Added __fls based on code of fls. mips and powerpc have __ilog2, which is the same as __fls. Added __fls = __ilog2. parisc, s390, sh and sparc64: Include generic __fls. x86_64 already has __fls. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-24[SPARC64]: %l6 trap return handling no longer necessary.David S. Miller
Now that we indicate the "restart system call" in the trap type field of pt_regs->magic, we don't need to set the %l6 boolean in all of the trap return paths. And we therefore don't need to pass it to do_notify_resume(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-23[SPARC64]: Store magic cookie and trap type in pt_regs.David S. Miller
This sets us up for several simplifications and facilities: 1) The magic cookie lets us identify trap frames more accurately in stack backtraces. 2) The trap type lets us simplify all of the "are we in a syscall" state management and checks. 3) We can now see if a task off the cpu is sleeping in a system call or not. In fact, we can see what trap it is sleeping in whatever the type. The utrace guys will use this. Based upon some discussions with Roland McGrath. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-23[SPARC64]: Add NUMA support.David S. Miller
Currently there is only code to parse NUMA attributes on sun4v/niagara systems, but later on we will add such parsing for older systems. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-23[SPARC64]: NUMA device infrastructure.David S. Miller
Record and propagate NUMA information for devices. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-23[SPARC64]: Remove unused asm-sparc64/numnodes.hDavid S. Miller
This is handled with config options now. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-23[SPARC64]: Decrease SECTION_SIZE_BITS to 30.David S. Miller
We'll need this to handle NUMA properly on some systems. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC]: Remove SunOS and Solaris binary support.
2008-04-21Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits) [POWERPC] Fix compile breakage for 64-bit UP configs [POWERPC] Define copy_siginfo_from_user32 [POWERPC] Add compat handler for PTRACE_GETSIGINFO [POWERPC] i2c: Fix build breakage introduced by OF helpers [POWERPC] Optimize fls64() on 64-bit processors [POWERPC] irqtrace support for 64-bit powerpc [POWERPC] Stacktrace support for lockdep [POWERPC] Move stackframe definitions to common header [POWERPC] Fix device-tree locking vs. interrupts [POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const [POWERPC] Remove unused __max_memory variable [POWERPC] Simplify xics direct/lpar irq_host setup [POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ() [POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade() [POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c [POWERPC] Use asm-generic/bitops/find.h in bitops.h [POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup [POWERPC] 85xx: Fix the size of qe muram for MPC8568E [POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier. [POWERPC] 86xx: mark functions static, other minor cleanups ...
2008-04-21[SPARC]: Remove SunOS and Solaris binary support.David S. Miller
As per Documentation/feature-removal-schedule.txt Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (58 commits) ide: remove ide_init_default_irq() macro ide: move default IDE ports setup to ide_generic host driver ide: remove obsoleted "idex=noprobe" kernel parameter (take 2) ide: remove needless hwif->irq check from ide_hwif_configure() ide: init hwif->{io_ports,irq} explicitly in legacy VLB host drivers ide: limit legacy VLB host drivers to alpha, x86 and mips cmd640: init hwif->{io_ports,irq} explicitly cmd640: cleanup setup_device_ptrs() ide: add ide-4drives host driver (take 3) ide: remove ppc ifdef from init_ide_data() ide: remove ide_default_io_ctl() macro ide: remove CONFIG_IDE_ARCH_OBSOLETE_INIT ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2) ppc/pmac: remove no longer needed IDE quirk ppc: don't include <linux/ide.h> ppc: remove ppc_ide_md ppc/pplus: remove ppc_ide_md.ide_init_hwif hook ppc/sandpoint: remove ppc_ide_md hooks ppc/lopec: remove ppc_ide_md hooks ppc/mpc8xx: remove ppc_ide_md hooks ...
2008-04-18ide: remove ide_default_io_ctl() macroBartlomiej Zolnierkiewicz
It is always == '((base) + 0x206)' if CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=y and it is not needed otherwise (arm, blackfin, parisc, ppc64, sh, sparc[64]). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-14Merge branch 'linux-2.6'Paul Mackerras
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Define TASK_SIZE_OF() [SPARC64]: flush_ptrace_access() needs preemption disable. [SPARC64]: Update defconfig. [SPARC64]: Fix allnoconfig build, ptrace.c missing CONFIG_COMPAT checks. [SPARC64]: Fix __get_cpu_var in preemption-enabled area. [SPARC64]: Fix sparse warnings in arch/sparc64/kernel/signal.c [SPARC64]: Fix most sparse warnings in arch/sparc64/kernel/sys_sparc.c [SPARC64]: Fix sparse warnings in arch/sparc64/kernel/time.c [SPARC64]: Fix sparse warnings in arch/sparc64/kernel/ptrace.c [SPARC64]: Fix sparse warnings in arch/sparc64/kernel/irq.c [SPARC64]: Fix sparse warnings in arch/sparc64/kernel/iommu.c [SPARC64]: Fix sparse errors in arch/sparc64/kernel/traps.c [SPARC64]: Fix sparse warnings in arch/sparc64/kernel/{cpu,setup}.c [SPARC64]: Adjust {TLBTEMP,TSBMAP}_BASE. [SPARC64]: Make save_stack_trace() more efficient.
2008-03-26[SPARC64]: Define TASK_SIZE_OF()David S. Miller
This make "cat /proc/${PID}/pagemap" more efficient for 32-bit tasks. Based upon a report by Mariusz Kozlowski. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[SPARC64]: Fix sparse warnings in arch/sparc64/kernel/time.cDavid S. Miller
2008-03-26[SPARC64]: Fix sparse warnings in arch/sparc64/kernel/irq.cDavid S. Miller
2008-03-26[SPARC64]: Fix sparse errors in arch/sparc64/kernel/traps.cDavid S. Miller
Add 'UL' markers to DCU_* macros. Declare C functions called from assembler in entry.h Declare C functions called from within the sparc64 arch code in include/asm-sparc64/*.h headers as appropriate. Remove unused routines in traps.c Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[SPARC64]: Fix sparse warnings in arch/sparc64/kernel/{cpu,setup}.cDavid S. Miller
We create a local header file entry.h, under arch/sparc64/kernel/, that we can use to declare routines either defined in assembler or only invoked from assembler. As well as other data objects which are private to the inner sparc64 kernel arch code. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[SPARC64]: Adjust {TLBTEMP,TSBMAP}_BASE.David S. Miller
Move them further from the main kernel image area to facilitate larger kernel sizes. Adjust comments to match. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26Merge branch 'linux-2.6'Paul Mackerras
2008-03-24[SPARC64]: Make save_stack_trace() more efficient.David S. Miller
Doing a 'flushw' every stack trace capture creates so much overhead that it makes lockdep next to unusable. We only care about the frame pointer chain and the function caller program counters, so flush those by hand to the stack frame. This is significantly more efficient than a 'flushw' because: 1) We only save 16 bytes per active register window to the stack. 2) This doesn't push the entire register window context of the current call chain out of the cpu, forcing register window fill traps as we return back down. Note that we can't use 'restore' and 'save' instructions to move around the register windows because that wouldn't work on Niagara processors. They optimize 'save' into a new register window by simply clearing out the registers instead of pulling them in from the on-chip register window backing store. Based upon a report by Tom Callaway. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: exec PT_DTRACE [SPARC64]: Use shorter list_splice_init() for brevity. [SPARC64]: Remove most limitations to kernel image size.
2008-03-21[SPARC64]: Remove most limitations to kernel image size.David S. Miller
Currently kernel images are limited to 8MB in size, and this causes problems especially when enabling features that take up a lot of kernel image space such as lockdep. The code now will align the kernel image size up to 4MB and map that many locked TLB entries. So, the only practical limitation is the number of available locked TLB entries which is 16 on Cheetah and 64 on pre-Cheetah sparc64 cpus. Niagara cpus don't actually have hw locked TLB entry support. Rather, the hypervisor transparently provides support for "locked" TLB entries since it runs with physical addressing and does the initial TLB miss processing. Fully utilizing this change requires some help from SILO, a patch for which will be submitted to the maintainer. Essentially, SILO will only currently map up to 8MB for the kernel image and that needs to be increased. Note that neither this patch nor the SILO bits will help with network booting. The openfirmware code will only map up to a certain amount of kernel image during a network boot and there isn't much we can to about that other than to implemented a layered network booting facility. Solaris has this, and calls it "wanboot" and we may implement something similar at some point. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Fix atomic backoff limit.
2008-03-19[SPARC64]: Fix atomic backoff limit.David S. Miller
4096 will not fit into the immediate field of a compare instruction, in fact it will end up being -4096 causing the check to fail every time and thus disabling backoff. Signed-off-by: David S. Miller <davem@davemloft.net>
