path: root/include/asm-sparc/system.h
2007-10-13[SPARC32]: Add irqflags.h to sparc32 and use it from generic code.Robert Reif
Added asm-sparc/irqflags.h and moved irq related code from system.h to it. Renamed local_irq functions to raw_local_irq in irq.c. Modified system.h to include linux/irqflags.h which includes asm/irqflags.h. Added TRACE_IRQFLAGS_SUPPORT to Kconfig.debug. This is the first step in adding IRQ-flags state tracing as outlined in Documentation/irqflags-tracing.txt. These changes should be harmless because they just move things around and rename them. The next step is making the lowlevel entry code modifications which to be honest are beyond my capabilities at this point. Boot tested on an ss20 running an SMP kernel. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-19[PATCH] sched: sched_cacheflush is now unusedRalf Baechle
Since Ingo's recent scheduler rewrite which was merged as commit 0437e109e1841607f2988891eaa36c531c6aa6ac sched_cacheflush is unused. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-05-14[SPARC32]: asm/system.h needs asm/smp.hDavid S. Miller
To get hard_smp_processor_id() even on UP builds. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-08Remove tas()Jeff Dike
tas() has no users, so get rid of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: <linux-arch@vger.kernel.org> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-14[PATCH] remove set_wmb - arch removalSteven Rostedt
set_wmb should not be used in the kernel because it just confuses the code more and has no benefit. Since it is not currently used in the kernel this patch removes it so that new code does not include it. All archs define set_wmb(var, value) to do { var = value; wmb(); } while(0) except ia64 and sparc which use a mb() instead. But this is still moot since it is not used anyway. Hasn't been tested on any archs but x86 and x86_64 (and only compiled tested) Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-12[PATCH] sparc: task_thread_info()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] sched: add cacheflush() asmIngo Molnar
Add per-arch sched_cacheflush() which is a write-back cacheflush used by the migration-cost calibration code at bootup time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-03[SPARC]: "extern inline" doesn't make much sense.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SPARC]: remove use of asm/segment.hKumar Gala
Removed sparc architecture specific users of asm/segment.h and asm-sparc/segment.h itself Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-25[PATCH] sched: cleanup context switch lockingNick Piggin
Instead of requiring architecture code to interact with the scheduler's locking implementation, provide a couple of defines that can be used by the architecture to request runqueue unlocked context switches, and ask for interrupts to be enabled over the context switch. Also replaces the "switch_lock" used by these architectures with an oncpu flag (note, not a potentially slow bitflag). This eliminates one bus locked memory operation when context switching, and simplifies the task_running function. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
