path: root/include/asm-sh/termbits.h
2007-07-10lots-of-architectures: enable arbitary speed tty supportAlan Cox
Add the termios2 structure ready for enabling on most platforms. One or two like Sparc are plain weird so have been left alone. Most can use the same structure as ktermios for termios2 (ie the newer ioctl uses the structure matching the current kernel structure) Signed-off-by: Alan Cox <alan@redhat.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] tty: preparatory structures for termios revampAlan Cox
In order to sort out our struct termios and add proper speed control we need to separate the kernel and user termios structures. Glibc is fine but the other libraries rely on the kernel exported struct termios and we need to extend this without breaking the ABI/API To do so we add a struct ktermios which is the kernel view of a termios structure and overlaps the struct termios with extra fields on the end for now. (That limitation will go away in later patches). Some platforms (eg alpha) planned ahead and thus use the same struct for both, others did not. This just adds the structures but does not use them, it seems a sensible splitting point for bisect if there are compile failures (not that I expect them) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
