path: root/include/asm-s390/setup.h
2006-02-11[PATCH] s390: add #ifdef __KERNEL__ to asm-s390/setup.hHeiko Carstens
Based on a patch from Maximilian Attems <maks@sternwelten.at> . Nothing in asm-s390/setup.h is of interest for user space. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] s390: export ipl device parametersHeiko Carstens
Sysfs interface to export ipl device parameters. Dependent on the ipl type the interface will look like this: - ccw ipl: /sys/firmware/ipl/device /ipl_type - fcp ipl: /sys/firmware/ipl/binary_parameter /bootprog /br_lba /device /ipl_type /lun /scp_data /wwpn - otherwise (unknown that is): /sys/firmware/ipl/ipl_type Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
