path: root/include/asm-ppc/machdep.h
2006-03-28[PATCH] powerpc: Kill _machine and hard-coded platform numbersBenjamin Herrenschmidt
This removes statically assigned platform numbers and reworks the powerpc platform probe code to use a better mechanism. With this, board support files can simply declare a new machine type with a macro, and implement a probe() function that uses the flattened device-tree to detect if they apply for a given machine. We now have a machine_is() macro that replaces the comparisons of _machine with the various PLATFORM_* constants. This commit also changes various drivers to use the new macro instead of looking at _machine. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-28ppc: Remove CHRP, POWER3 and POWER4 support from arch/ppcPaul Mackerras
32-bit CHRP machines are now supported only in arch/powerpc, as are all 64-bit PowerPC processors. This means that we don't use Open Firmware on any platform in arch/ppc any more. This makes PReP support a single-platform option like every other platform support option in arch/ppc now, thus CONFIG_PPC_MULTIPLATFORM is gone from arch/ppc. CONFIG_PPC_PREP is the option that selects PReP support and is generally what has replaced CONFIG_PPC_MULTIPLATFORM within arch/ppc. _machine is all but dead now, being #defined to 0. Updated Makefiles, comments and Kconfig options generally to reflect these changes. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27powerpc: Unify the 32 and 64 bit idle loopsPaul Mackerras
This unifies the 32-bit (ARCH=ppc and ARCH=powerpc) and 64-bit idle loops. It brings over the concept of having a ppc_md.power_save function from 32-bit to ARCH=powerpc, which lets us get rid of native_idle(). With this we will also be able to simplify the idle handling for pSeries and cell. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-20[PATCH] powerpc: remove duplicate exportsOlaf Hering
A few symbols are exported twice, remove them from ppc_ksyms.c Remove users of sys_ctrler in arch/ppc/ WARNING: vmlinux: duplicate symbol '__delay' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol '__up' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol '__down' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol '__down_interruptible' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'sys_ctrler' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strncat' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strncmp' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strchr' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strrchr' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strnlen' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strpbrk' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'memscan' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strstr' previous definition was in vmlinux Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Unify udbg (#2)Benjamin Herrenschmidt
This patch unifies udbg for both ppc32 and ppc64 when building the merged achitecture. xmon now has a single "back end". The powermac udbg stuff gets enriched with some ADB capabilities and btext output. In addition, the early_init callback is now called on ppc32 as well, approx. in the same order as ppc64 regarding device-tree manipulations. The init sequences of ppc32 and ppc64 are getting closer, I'll unify them in a later patch. For now, you can force udbg to the scc using "sccdbg" or to btext using "btextdbg" on powermacs. I'll implement a cleaner way of forcing udbg output to something else than the autodetected OF output device in a later patch. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-29[PATCH] ppc: make phys_mem_access_prot() work with pfns instead of addressesRoland Dreier
Change the phys_mem_access_prot() function to take a pfn instead of an address. This allows mmap64() to work on /dev/mem for addresses above 4G on 32-bit architectures. We start with a pfn in mmap_mem(), so there's no need to convert to an address; in fact, it's actively bad, since the conversion can overflow when the address is above 4G. Similarly fix the ppc32 page_is_ram() function to avoid a conversion to an address by directly comparing to max_pfn. Working with max_pfn instead of high_memory fixes page_is_ram() to give the right answer for highmem pages. Signed-off-by: Roland Dreier <rolandd@cisco.com> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-20powerpc/ppc/ppc64: Various compile fixes.Paul Mackerras
This declares powersave_nap in system.h and makes it an int everywhere, fixes typos for the maple platform, fixes a couple of places where I missed removing the last two arguments from a message_pass function, and makes ppc64 consistent with ppc32 in the type of the pci_bridge.cfg_data field. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-06-25[PATCH] kexec: kexec ppc supportEric W. Biederman
I have tweaked this patch slightly to handle an empty list of pages to relocate passed to relocate_new_kernel. And I have added ppc_md.machine_crash_shutdown. To keep up with the changes in the generic kexec infrastructure. From: Albert Herranz <albert_herranz@yahoo.es> The following patch adds support for kexec on the ppc32 platform. Non-OpenFirmware based platforms are likely to work directly without additional changes on the kernel side. The kexec-tools userland package may need to be slightly updated, though. For OpenFirmware based machines, additional work is still needed on the kernel side before kexec support is ready. Benjamin Herrenschmidt is kindly working on that part. In order for a ppc platform to use the kexec kernel services it must implement some ppc_md hooks. Otherwise, kexec will be explicitly disabled, as suggested by benh. There are 3+1 new ppc_md hooks that a platform supporting kexec may implement. Two of them are mandatory for kexec to work. See include/asm-ppc/machdep.h for details. - machine_kexec_prepare(image) This function is called to make any arrangements to the image before it is loaded. This hook _MUST_ be provided by a platform in order to activate kexec support for that platform. Otherwise, the platform is considered to not support kexec and the kexec_load system call will fail (that makes all existing platforms by default non-kexec'able). - machine_kexec_cleanup(image) This function is called to make any cleanups on image after the loaded image data it is freed. This hook is optional. A platform may or may not provide this hook. - machine_kexec(image) This function is called to perform the _actual_ kexec. This hook _MUST_ be provided by a platform in order to activate kexec support for that platform. If a platform provides machine_kexec_prepare but forgets to provide machine_kexec, a kexec will fall back to a reboot. A ready-to-use machine_kexec_simple() generic function is provided to, hopefully, simplify kexec adoption for embedded platforms. A platform may call this function from its specific machine_kexec hook, like this: void myplatform_kexec(struct kimage *image) { machine_kexec_simple(image); } - machine_shutdown() This function is called to perform any machine specific shutdowns, not already done by drivers. This hook is optional. A platform may or may not provide this hook. An example (trimmed) platform specific module for a platform supporting kexec through the existing machine_kexec_simple follows: /* ... */ #ifdef CONFIG_KEXEC int myplatform_kexec_prepare(struct kimage *image) { /* here, we can place additional preparations */ return 0; /* yes, we support kexec */ } void myplatform_kexec(struct kimage *image) { machine_kexec_simple(image); } #endif /* CONFIG_KEXEC */ /* ... */ void __init platform_init(unsigned long r3, unsigned long r4, unsigned long r5, unsigned long r6, unsigned long r7) { /* ... */ #ifdef CONFIG_KEXEC ppc_md.machine_kexec_prepare = myplatform_kexec_prepare; ppc_md.machine_kexec = myplatform_kexec; #endif /* CONFIG_KEXEC */ /* ... */ } The kexec ppc kernel support has been heavily tested on the GameCube Linux port, and, as reported in the fastboot mailing list, it has been tested too on a Moto 82xx ppc by Rick Richardson. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
