Add an of_find_property function that returns a struct property
given a property name. Then change the get_property function to
use that routine internally.
Signed-off-by: Dave Boutcher <sleddog@us.ibm.com>
Add support for updating and removing device tree
properties. Since we hand out pointers to properties with gay
abandon, we can't just free the property storage. Instead we
move deleted, or the old copy of an updated property, to a
"dead properties" list.
Also note, its not feasable to kref device tree properties.
we call get_property() all over the kernel in a wild variety
of contexts.
One consequence of this change is that we now take a
read_lock(&devtree_lock) when doing get_property().
Adds a few more hypervisor call constants.
Fix up delete/modify conflict of arch/ppc/kernel/process.c by hand (it's
gone, gone, gone).
{get,put}_thread_info() were introduced in 2.5.4 and never
had been called by anything in the tree.
This is the latest version of the scheduler cache-hot-auto-tune patch.
The first problem was that detection time scaled with O(N^2), which is
unacceptable on larger SMP and NUMA systems. To solve this:
- I've added a 'domain distance' function, which is used to cache
measurement results. Each distance is only measured once. This means
that e.g. on NUMA distances of 0, 1 and 2 might be measured, on HT
distances 0 and 1, and on SMP distance 0 is measured. The code walks
the domain tree to determine the distance, so it automatically follows
whatever hierarchy an architecture sets up. This cuts down on the boot
time significantly and removes the O(N^2) limit. The only assumption
is that migration costs can be expressed as a function of domain
distance - this covers the overwhelming majority of existing systems,
and is a good guess even for more assymetric systems.
[ People hacking systems that have assymetries that break this
assumption (e.g. different CPU speeds) should experiment a bit with
the cpu_distance() function. Adding a ->migration_distance factor to
the domain structure would be one possible solution - but lets first
see the problem systems, if they exist at all. Lets not overdesign. ]
Another problem was that only a single cache-size was used for measuring
the cost of migration, and most architectures didnt set that variable
up. Furthermore, a single cache-size does not fit NUMA hierarchies with
L3 caches and does not fit HT setups, where different CPUs will often
have different 'effective cache sizes'. To solve this problem:
- Instead of relying on a single cache-size provided by the platform and
sticking to it, the code now auto-detects the 'effective migration
cost' between two measured CPUs, via iterating through a wide range of
cachesizes. The code searches for the maximum migration cost, which
occurs when the working set of the test-workload falls just below the
'effective cache size'. I.e. real-life optimized search is done for
the maximum migration cost, between two real CPUs.
This, amongst other things, has the positive effect hat if e.g. two
CPUs share a L2/L3 cache, a different (and accurate) migration cost
will be found than between two CPUs on the same system that dont share
any caches.
(The reliable measurement of migration costs is tricky - see the source
for details.)
Furthermore i've added various boot-time options to override/tune
migration behavior.
Firstly, there's a blanket override for autodetection:
migration_cost=1000,2000,3000
will override the depth 0/1/2 values with 1msec/2msec/3msec values.
Secondly, there's a global factor that can be used to increase (or
decrease) the autodetected values:
migration_factor=120
will increase the autodetected values by 20%. This option is useful to
tune things in a workload-dependent way - e.g. if a workload is
cache-insensitive then CPU utilization can be maximized by specifying
migration_factor=0.
I've tested the autodetection code quite extensively on x86, on 3
P3/Xeon/2MB, and the autodetected values look pretty good:
Dual Celeron (128K L2 cache):
migration cost matrix (max_cache_size: 131072, cpu: 467 MHz):
[00] [01]
[00]: - 1.7(1)
[01]: 1.7(1) -
cacheflush times [2]: 0.0 (0) 1.7 (1784008)
Here the slow memory subsystem dominates system performance, and even
though caches are small, the migration cost is 1.7 msecs.
Dual HT P4 (512K L2 cache):
migration cost matrix (max_cache_size: 524288, cpu: 2379 MHz):
[00] [01] [02] [03]
[00]: - 0.4(1) 0.0(0) 0.4(1)
[01]: 0.4(1) - 0.4(1) 0.0(0)
[02]: 0.0(0) 0.4(1) - 0.4(1)
[03]: 0.4(1) 0.0(0) 0.4(1) -
cacheflush times [2]: 0.0 (33900) 0.4 (448514)
Here it can be seen that there is no migration cost between two HT
siblings (CPU#0/2 and CPU#1/3 are separate physical CPUs). A fast memory
system makes inter-physical-CPU migration pretty cheap: 0.4 msecs.
8-way P3/Xeon [2MB L2 cache]:
migration cost matrix (max_cache_size: 2097152, cpu: 700 MHz):
[00] [01] [02] [03] [04] [05] [06] [07]
[00]: - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[01]: 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[02]: 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[03]: 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[04]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1)
[05]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1)
[06]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1)
[07]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) -
cacheflush times [2]: 0.0 (0) 19.2 (19281756)
This one has huge caches and a relatively slow memory subsystem - so the
migration cost is 19 msecs.
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
Cc: <wilder@us.ibm.com>
Signed-off-by: John Hawkes <hawkes@sgi.com>
Add per-arch sched_cacheflush() which is a write-back cacheflush used by
the migration-cost calibration code at bootup time.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
pcibios_claim_one_bus is not needed on iSeries and phbs_remap_io can be
mode static.
There was a function declared for CONFIG_PSERIES which no longer exists
and the two function declarations for CONFIG_ISERIES have been moved
into an include file in platforms/iseries since they are defined and
used only there.
This reverts part of "ppc64 iSeries: allow build with no PCI"
(145d01e4287b8cbf50f87c3283e33bf5c84e8468) which affected generic code
and applies a fix in the arch specific code.
Commit "partly merge iseries do_IRQ"
(5fee9b3b39eb55c7e3619a3b36ceeabffeb8f144) introduced iSeries_get_irq
which was only available if CONFIG_PCI is set.
Mainly just removing file names from the comments.
Also does some comment cleanups and removal of unnecessary
variables.
Heikki Lindholm pointed out that there was a potential race with the
lazy CPU state (FP, VR, EVR) stuff if preempt is enabled. The race
is that in the process of restoring FP state on sigreturn, the task
gets preempted by a user task that wants to use the FPU. It will take
an FP unavailable exception, which will write the current FPU state
to the thread_struct, overwriting the values which sigreturn has
stored. Note that this can only happen on UP since we don't implement
lazy CPU state on SMP.
The fix is to flush the lazy CPU state before updating the
thread_struct. To do this we re-use the flush_lazy_cpu_state()
function from process.c.
PPC32 is still using asm-generic/4level-fixup.h, but asm-powerpc/page.h
was defining pud_t and pgd_t. Depending on the order in which files
got included, this could result in a compilation error. Tweak the ifdef
so that page.h doesn't try to define pud_t on ppc32 (which uses 2-level
page tables).
The current ppc64 per cpu data implementation is quite slow. eg:
lhz 11,18(13) /* smp_processor_id() */
ld 9,.LC63-.LCTOC1(30) /* per_cpu__variable_name */
ld 8,.LC61-.LCTOC1(30) /* __per_cpu_offset */
sldi 11,11,3 /* form index into __per_cpu_offset */
mr 10,9
ldx 9,11,8 /* __per_cpu_offset[smp_processor_id()] */
ldx 0,10,9 /* load per cpu data */
5 loads for something that is supposed to be fast, pretty awful. One
reason for the large number of loads is that we have to synthesize 2
64bit constants (per_cpu__variable_name and __per_cpu_offset).
By putting __per_cpu_offset into the paca we can avoid the 2 loads
associated with it:
ld 11,56(13) /* paca->data_offset */
ld 9,.LC59-.LCTOC1(30) /* per_cpu__variable_name */
ldx 0,9,11 /* load per cpu data
Longer term we can should be able to do even better than 3 loads.
If per_cpu__variable_name wasnt a 64bit constant and paca->data_offset
was in a register we could cut it down to one load. A suggestion from
Rusty is to use gcc's __thread extension here. In order to do this we
would need to free up r13 (the __thread register and where the paca
currently is). So far Ive had a few unsuccessful attempts at doing that :)
The patch also allocates per cpu memory node local on NUMA machines.
This patch from Rusty has been sitting in my queue _forever_ but stalled
when I hit the compiler bug. Sorry about that.
Finally I also only allocate per cpu data for possible cpus, which comes
straight out of the x86-64 port. On a pseries kernel (with NR_CPUS == 128)
and 4 possible cpus we see some nice gains:
total used free shared buffers cached
Mem: 4012228 212860 3799368 0 0 162424
Mem: 4016200 212984 3803216 0 0 162424
A saving of 3.75MB. Quite nice for smaller machines. Note: we now have
to be careful of per cpu users that touch data for !possible cpus.
At this stage it might be worth making the NUMA and possible cpu
optimisations generic, but per cpu init is done so early we have to be
careful that all architectures have their possible map setup correctly.
This stops parport from accessing nonexistent parallel ports.
Signed-off-by: Michael Neuling <mikey@neuling.org>
This patch adds Kconfig entries to control the early debugging options,
currently in setup_64.c.
Doing this via Kconfig rather than #defines means you can have one source tree,
which is buildable for multiple platforms - and you can enable the correct
early debug option for each platform via .config.
I made udbg_early_init() a static inline because otherwise GCC is to daft to
optimise it away when debugging is off.
Now that we have udbg_init_rtas() we can make call_rtas_display_status* static.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Header included twice.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
The following patch (against 2.6.15-rc5-mm3) fixes a kprobes build break
due to changes introduced in the kprobe locking in 2.6.15-rc5-mm3. In
addition, the patch reverts back the open-coding of kprobe_mutex.
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Acked-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Currently arch_remove_kprobes() is only implemented/required for x86_64 and
powerpc. All other architecture like IA64, i386 and sparc64 implementes a
dummy function which is being called from arch independent kprobes.c file.
This patch removes the dummy functions and replaces it with
#define arch_remove_kprobe(p, s) do { } while(0)
Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
The arch specific kprobes.h files never gets included when CONFIG_KPROBES is
turned off. Hence check for CONFIG_KPROBES is not appropriate here in this
arch specific kprobes.h files.
Also the below defined function kprobes_exception_notify() is not needed when
CONFIG_KPROBES is off.
Compile tested for both CONFIG_KPROBES=y and N.
Kernel/kprobes.c defines get_insn_slot() and free_insn_slot() which are
currently required _only_ for x86_64 and powerpc (which has no-exec support).
FYI, get{free}_insn_slot() functions manages the memory page which is mapped
as executable, required for instruction emulation.
This patch moves those two functions under __ARCH_WANT_KPROBES_INSN_SLOT and
defines __ARCH_WANT_KPROBES_INSN_SLOT in arch specific kprobes.h file.
crash_setup_regs() is an architecture dependent function which is called in
architecture independent section. So every architecture supporting kexec
should at least provide a dummy definition of crash_setup_regs() even if
crash dumping is not implemented yet, to avoid build failures.
Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com>
- In case of system crash, current state of cpu registers is saved in memory
in elf note format. So far memory for storing elf notes was being allocated
statically for NR_CPUS.
- This patch introduces dynamic allocation of memory for storing elf notes.
It uses alloc_percpu() interface. This should lead to better memory usage.
- Introduced based on Andi Kleen's and Eric W. Biederman's suggestions.
- This patch also moves memory allocation for elf notes from architecture
dependent portion to architecture independent portion. Now crash_notes is
architecture independent. The whole idea is that size of memory to be
allocated per cpu (MAX_NOTE_BYTES) can be architecture dependent and
allocation of this memory can be architecture independent.
The previous change by Kumar Gala in this area led to legacy_serial.c
and udbg_16550.c being built as modules when CONFIG_SERIAL_8250=m.
Fix this by introducing a new symbol, CONFIG_PPC_UDBG_16550, to
control whether these files get built, and arrange for it to be selected
for those platforms that need it.
241-eeh-save-bars-earlier.patch
Save the PCI device bars *before* any PCI probing is done.
Signed-off-by: Linas Vepstas <linas@austin.ibm.com>
(cherry picked from 76c902b919098860f3d4e125f847abcc4cb1782a commit)
238-eeh-stop-if-reset_failed.patch
If the firmware is unable to reset the PCI slot for some reason, then
don't attempt any further recovery steps after that point. Instead,
mark the device as permanently failed.
(cherry picked from e06b942521eb2cdaf232726f45a820d5837acb12 commit)
234-eeh-find-pe.patch
The find_device_pe() routine is duplicated in two files. Remove one of
the two copies, declare the other extern.
(cherry picked from 48408e708282d4d0269136ff27ea5acbd9410b5a commit)
26-eeh-partition-endpoint.patch
New versions of firmware introduce a new method by which the
"partitionable endpoint" (the point at which the pci bus is cut)
should be located. This code adds the support for this (mandatory)
new feature.
(cherry picked from 9fcfb5d35b5294659f9299aa9cae6fd16325c07e commit)
25-pci-address-cache.patch
The core EEH file is rather large. This patch splits out a self-contained
chunk of it into its own file. This is the chunk that performes the
caching and lookup of pci devices based on the i/o addresses of thier
resoures. This code is almos architecture-independent and could be
used by any system that wanted to find a pci device based only on
the i/o address used by the device.
(cherry picked from b0b291d59906d4a9a89ed9e34d9fd684c7188924 commit)
Various PCI bus errors can be signaled by newer PCI controllers. The
core error recovery routines are architecture dependent. This patch adds
a recovery infrastructure for the PPC64 pSeries systems.
(cherry picked from e8ca11b460c4c9c7fa6b529be221529ebd770e38 commit)
add the per-arch mutex.h files for the remaining architectures.
We default to asm-generic/mutex-dec.h, because that performs
quite well on most arches. Arches that do not have atomic
decrement/increment instructions should switch to mutex-xchg.h
instead. Arches can also provide their own implementation for
the mutex fastpath primitives.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
add atomic_xchg() to all the architectures. Needed by the new mutex code.
My recent changes to oprofile broke it when built as a module. Fix it by
using an enum instead of a function pointer. This way we still retain
the oprofile configuration in the cputable.
This is the platform function interpreter itself along with the backends
for UniN/U3/U4, mac-io, GPIOs and i2c. It adds the ability to execute
those do-platform-* scripts in the device-tree (at least for most
devices for which a backend is provided). This should replace the clock
spreading hacks properly. It might also have an impact on all sort of
machines since some of the scripts marked "at init" will now be executed
on boot (or some other on sleep/wakeup), those will possibly do things
that the kernel didn't do at all, like setting some values into some i2c
devices (changing thermal sensor calibration or conversion rate) etc...
Thus regression testing is MUCH welcome. Also loook for errors in dmesg.
That's also why I've left rather verbose debugging enabled in this
version of the patch.
(I do expect some Windtunnel G4s to show some errors as they have an i2c
clock chip on the PMU bus that uses some primitives that the i2c backend
doesn't implement yet. I really need users that have one of those
machine to come back to me so we can get that done right, though the
errors themselves should be harmless, I suspect the machine might not
run at full speed).
This is the continuation of the previous patch. This one removes the old
PowerMac i2c drivers (i2c-keywest and i2c-pmac-smu) and replaces them
both with a single stub driver that uses the new PowerMac low i2c layer.
Now that i2c-keywest is gone, the low-i2c code is extended to support
interrupt driver transfers. All i2c busses now appear as platform
devices. Compatibility with existing drivers should be maintained as the
i2c bus names have been kept identical, except for the SMU bus but in
that later case, all users has been fixed.
With that patch added, matching a device node to an i2c_adapter becomes
trivial.
This is the first part of a rework of the PowerMac i2c code. It
completely reworks the "low_i2c" layer. It is now more flexible,
supports KeyWest, SMU and PMU i2c busses, and provides functions to
match device nodes to i2c busses and adapters.
This patch also extends & fix some bugs in the SMU driver related to i2c
support and removes the clock spreading hacks from the pmac feature code
rather than adapting them to the new API since they'll be replaced by
the platform function code completely in patch 3/5
For far, all SPU triggered interrupts always end up on
the first SMT thread, which is a bad solution.
This patch implements setting the affinity to the
CPU that was running last when entering execution on
an SPU. This should result in a significant reduction
in IPI calls and better cache locality for SPE thread
specific data.
Signed-off-by: Arnd Bergmann <arndb@de.ibm.com>
The size of the local store is architecture defined
and independent from the page size, so it should
not be defined in terms of pages in the first place.
This mistake broke a few places when building for
64kb pages.
In a hypervisor based setup, direct access to the first
priviledged register space can typically not be allowed
to the kernel and has to be implemented through hypervisor
calls.
As suggested by Masato Noguchi, let's abstract the register
access trough a number of function calls. Since there is
currently no public specification of actual hypervisor
calls to implement this, I only provide a place that
makes it easier to hook into.
Cc: Masato Noguchi <Masato.Noguchi@jp.sony.com>
Cc: Geoff Levand <geoff.levand@am.sony.com>
checking bits manually might not be synchonized with
the use of set_bit/clear_bit. Make sure we always use
the correct bitops by removing the unnecessary
identifiers.
This patch enables support for pause(0) power management state
for the Cell Broadband Processor, which is import for power efficient
operation. The pervasive infrastructure will in the future enable
us to introduce more functionality specific to the Cell's
pervasive unit.
Undefined symbols (eeh_add_device_tree_early and eeh_remove_bus_device)
when EEH is not enabled. This small patch will fix this.
Acked-by: Linas Vepstas <linas@austin.ibm.com>
