path: root/include/asm-powerpc/topology.h
2006-01-09[PATCH] powerpc: sanitize header files for user space includesArnd Bergmann
include/asm-ppc/ had #ifdef __KERNEL__ in all header files that are not meant for use by user space, include/asm-powerpc does not have this yet. This patch gets us a lot closer there. There are a few cases where I was not sure, so I left them out. I have verified that no CONFIG_* symbols are used outside of __KERNEL__ any more and that there are no obvious compile errors when including any of the headers in user space libraries. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] ppc64: Add NUMA cpu summary at bootAnton Blanchard
We used to print a NUMA cpu summary at boot before the hotplug cpu code was added. This has been useful for catching machine configuration as well as firmware bugs in the past. This patch restores that functionality. An example of the output is: Node 0 CPUs: 0-7 Node 1 CPUs: 8-15 Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-18[PATCH] powerpc: Fix typo in topology.hMichael Ellerman
The fix to topology.h (5cfccd7f132432dd4705444a44b51d12ef88a85f) seems to have a typeo, struct sched_domain has an idle_idx member but not an idle_id member. I assume this is the fix. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-17[PATCH] powerpc: Fix database regression due to scheduler changesNick Piggin
PowerPC's NUMA domain doesn't currently set up some of the newer sched-domains parameters. Brian Twichell <tbrian@us.ibm.com> discovered and diagnosed a 1.5% OLTP database regression on a 4 core POWER5 system that was due to the use of NUMA scheduling on ppc64. This patch applies some saneish values to the parameters, in line with other architectures. This solves the regression. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-11[PATCH] ppc64: Convert NUMA to sparsemem (3)Anton Blanchard
Convert to sparsemem and remove all the discontigmem code in the process. This has a few advantages: - The old numa_memory_lookup_table can go away - All the arch specific discontigmem magic can go away We also remove the triple pass of memory properties and instead create a list of per node extents that we iterate through. A final cleanup would be to change our lmb code to store extents per node, then we can reuse that information in the numa code. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-11[PATCH] ppc64: prep for NUMA sparsemem rework 2Anton Blanchard
Remove ppc64 specific version of nr_cpus_node and use the generic one provided. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-09[PATCH] powerpc: Merge a few more include filesjdl@freescale.com
Merge a few asm-ppc and asm-ppc64 header files. Note: the merge of setup.h intentionally does not carry forward the m68k cruft. That means this patch continues to break the already broken amiga on the ppc32. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
