path: root/include/asm-powerpc/mpc85xx.h
2006-09-21POWERPC: Add support for the mpc8560 eval boardVitaly Bordug
This makes the 8560 evaluation board fully supported under arch/powerpc, as the first board with CPM2 SoC peripherals. The brand new devicetree nodes are introduced (intending to be a subset of the QuiccEngine-equipped models, with dts sources placed into the kernel according to the new convention. Assuming all the preceding stuff applied (PAL+fs_enet related+ CPM_UART update), the both TSEC eth ,FCC Eths, and both SCC UARTs are working. The relevant drivers are still capable to drive users in ppc, which was verified with 8272ADS (SCC uart+FCC eth). This is also verified on mpc8540 and actually make it work (PCI stuff working as well) Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
