path: root/include/asm-parisc/tlbflush.h
2007-02-18Revert "[PARISC] Optimize TLB flush on SMP systems"Kyle McMartin
This reverts commit 592ac93a607109e0643da6c23ae07ac749e973b1 which causes SMP machines with maxcpus > 1 to fail to boot...
2007-02-17[PARISC] Clean up the cache and tlb headersRandolph Chung
No changes in functionality. Signed-off-by: Randolph Chung <tausq@debian.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] Optimize TLB flush on SMP systemsRandolph Chung
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-10[PARISC] Make local cache flushes take a void *Matthew Wilcox
Make flush_data_cache_local, flush_instruction_cache_local and flush_tlb_all_local take a void * so they don't have to be cast when using on_each_cpu(). This becomes a problem when on_each_cpu is a macro (as it is in current -mm). Also move the prototype of flush_tlb_all_local into tlbflush.h and remove its declaration from .c files. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Always spinlock tlb flush operations to ensure preempt safetyMatthew Wilcox
Since taking a spinlock disables preempt, and we need to spinlock tlb flush on SMP for N class, we might as well just spinlock on uniprocessor machines too. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-29[PATCH] mm: flush_tlb_range outside ptlockHugh Dickins
There was one small but very significant change in the previous patch: mprotect's flush_tlb_range fell outside the page_table_lock: as it is in 2.4, but that doesn't prove it safe in 2.6. On some architectures flush_tlb_range comes to the same as flush_tlb_mm, which has always been called from outside page_table_lock in dup_mmap, and is so proved safe. Others required a deeper audit: I could find no reliance on page_table_lock in any; but in ia64 and parisc found some code which looks a bit as if it might want preemption disabled. That won't do any actual harm, so pending a decision from the maintainers, disable preemption there. Remove comments on page_table_lock from flush_tlb_mm, flush_tlb_range and flush_tlb_page entries in cachetlb.txt: they were rather misleading (what generic code does is different from what usually happens), the rules are now changing, and it's not yet clear where we'll end up (will the generic tlb_flush_mmu happen always under lock? never under lock? or sometimes under and sometimes not?). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-21[PARISC] Move pa_tlb_lock to tlb_flush.hGrant Grundler
move pa_tlb_lock and it's primary consumers to tlb_flush.h Future step will be to move spinlock_t definition out of system.h. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Make sure use of RFI conforms to PA 2.0 and 1.1 arch docsGrant Grundler
2.6.12-rc4-pa3 : first pass at making sure use of RFI conforms to PA 2.0 arch pages F-4 and F-5, PA 1.1 Arch page 3-19 and 3-20. The discussion revolves around all the rules for clearing PSW Q-bit. The hard part is meeting all the rules for "relied upon translation". .align directive is used to guarantee the critical sequence ends more than 8 instructions (32 bytes) from the end of page. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
