path: root/include/asm-parisc/mmu_context.h
2008-10-10parisc: move include/asm-parisc to arch/parisc/include/asmKyle McMartin
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86: PARAVIRT: add hooks to intercept mm creation and destructionJeremy Fitzhardinge
Add hooks to allow a paravirt implementation to track the lifetime of an mm. Paravirtualization requires three hooks, but only two are needed in common code. They are: arch_dup_mmap, which is called when a new mmap is created at fork arch_exit_mmap, which is called when the last process reference to an mm is dropped, which typically happens on exit and exec. The third hook is activate_mm, which is called from the arch-specific activate_mm() macro/function, and so doesn't need stub versions for other architectures. It's called when an mm is first used. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: linux-arch@vger.kernel.org Cc: James Bottomley <James.Bottomley@SteelEye.com> Acked-by: Ingo Molnar <mingo@elte.hu>
