path: root/include/asm-parisc/irq.h
2008-10-10parisc: move include/asm-parisc to arch/parisc/include/asmKyle McMartin
2006-10-04[PARISC] Allow nested interruptsJames Bottomley
Our prior mode of operation didn't allow nested interrupts because it makes the interrupt code much simpler. However, nested interrupts are better for latency. This code uses the EIEM register to simulate level interrupts and thus achieve nesting. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Fix up parisc irq handling for genirq changesKyle McMartin
Clean up enough to get things compiling again in the interim. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-29[PATCH] genirq: cleanup: turn ARCH_HAS_IRQ_PER_CPU into CONFIG_IRQ_PER_CPUIngo Molnar
Cleanup: change ARCH_HAS_IRQ_PER_CPU into a Kconfig method. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-11-17[PARISC] Add IRQ affinitiesJames Bottomley
This really only adds them for the machines I can check SMP on, which is CPU interrupts and IOSAPIC (so not any of the GSC based machines). With this patch, irqbalanced can be used to maintain irq balancing. Unfortunately, irqbalanced is a bit x86 centric, so it doesn't do an incredibly good job, but it does work. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-07[PATCH] CHECK_IRQ_PER_CPU() to avoid dead code in __do_IRQ()Karsten Wiese
IRQ_PER_CPU is not used by all architectures. This patch introduces the macros ARCH_HAS_IRQ_PER_CPU and CHECK_IRQ_PER_CPU() to avoid the generation of dead code in __do_IRQ(). ARCH_HAS_IRQ_PER_CPU is defined by architectures using IRQ_PER_CPU in their include/asm_ARCH/irq.h file. Through grepping the tree I found the following architectures currently use IRQ_PER_CPU: cris, ia64, ppc, ppc64 and parisc. Signed-off-by: Karsten Wiese <annabellesgarden@yahoo.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
