path: root/include/asm-mips
2007-07-31Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (50 commits) [MIPS] Add smp_call_function_single() [MIPS] thread_info.h: kmalloc + memset conversion to kzalloc [MIPS] Kexec: Fix several 64-bit bugs. [MIPS] Kexec: Fix several warnings. [MIPS] DDB5477: Remove support [MIPS] Fulong: Remove unneeded header file [MIPS] Cobalt: Enable UART on RaQ1 [MIPS] Remove unused GROUP_TOSHIBA_NAMES [MIPS] remove some duplicate includes [MIPS] Oprofile: Fix rm9000 performance counter handler [MIPS] Use -Werror on subdirectories which build cleanly. [MIPS] Yosemite: Fix warning. [MIPS] PMON: Fix cpustart declaration. [MIPS] Yosemite: Only build ll_ht_smp_irq_handler() if HYPERTRANSPORT. [MIPS] Yosemite: Fix build error due to undeclared titan_mailbox_irq(). [MIPS] Yosemite: Don't declare titan_mailbox_irq() as asmlinkage. [MIPS] Yosemite: Fix warnings in i2c-yoesmite by deleting the unused code. [MIPS] Delete unused arch/mips/gt64120/common/ [MIPS] Fix build warning in unaligned load/store emulator. [MIPS] IP32: Don't ignore request_irq's return value. ...
2007-07-31remove tx3912fbYoichi Yuasa
Remove tx3912fb. Nino has already removed. It is no longer needed. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31remove unused TIF_NOTIFY_RESUME flagStephane Eranian
Remove unused TIF_NOTIFY_RESUME flag for all processor architectures. The flag was not used excecpt on IA-64 where the patch replaces it with TIF_PERFMON_WORK. Signed-off-by: stephane eranian <eranian@hpl.hp.com> Cc: <linux-arch@vger.kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31[MIPS] thread_info.h: kmalloc + memset conversion to kzallocMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] DDB5477: Remove supportYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Remove unused GROUP_TOSHIBA_NAMESYoichi Yuasa
2007-07-31[MIPS] PMON: Fix cpustart declaration.Ralf Baechle
This now matches how cpustart is actually being invoked from Linux. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Remove Momentum Ocelot support.Ralf Baechle
2007-07-31[MIPS] Add missing declaration for mips_ihb().Ralf Baechle
2007-07-31[MIPS] MTI: Add CoreFPGA4 ID.Chris Dearman
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] MT: Enable coexistence of AP/SP with VSMP and SMTC.Ralf Baechle
2007-07-31[MIPS] Wire up the fallocate syscall.Ralf Baechle
2007-07-31[MIPS] Fixup secure computing stuff.Ralf Baechle
2007-07-31[MIPS] tx49xx: Add mach specific headersAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] rbtx4927: Fix -Werror-implicit-function-declaration build error.Atsushi Nemoto
2007-07-26include/asm-:mips add missing edac h fileDoug Thompson
EDAC has a foundation to perform software memory scrubbing, but it requires a per architecture (atomic_scrub) function for performing an atomic update operation. Under X86, this is done with a lock: add [addr],0 in the file asm-x86/edac.h This patch provides the MIPS arch with that atomic function, atomic_scrub() in asm-mips/edac.h Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24[MIPS] Whitespace cleanup.Ralf Baechle
2007-07-20[MIPS] User stack pointer randomisationFranck Bui-Huu
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-20[MIPS] Remove unused include/asm-mips/gfx.hYoichi Yuasa
2007-07-20[MIPS] Remove unused include/asm-mips/ds1216.hYoichi Yuasa
2007-07-20[MIPS] Make support for weakly ordered LL/SC a config option.Ralf Baechle
None of weakly ordered processor supported in tree need this but it seems like this could change ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-20[MIPS] Disable UserLocal runtime detection on platforms which never have it.Ralf Baechle
2007-07-20[MIPS] Disable MT runtime detection on platforms which never support MT.Ralf Baechle
2007-07-19[PATCH] sched: sched_cacheflush is now unusedRalf Baechle
Since Ingo's recent scheduler rewrite which was merged as commit 0437e109e1841607f2988891eaa36c531c6aa6ac sched_cacheflush is unused. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-19arch: personality independent stack topPeter Zijlstra
New arch macro STACK_TOP_MAX it gives the larges valid stack address for the architecture in question. It differs from STACK_TOP in that it will not distinguish between personalities but will always return the largest possible address. This is used to create the initial stack on execve, which we will move down to the proper location once the binfmt code has figured out where that is. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ollie Wild <aaw@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18zs: move to the serial subsystemMaciej W. Rozycki
This is a reimplementation of the zs driver for the serial subsystem. Any resemblance to the old driver is purely coincidential. ;-) I do hope I got the handling of modem lines right -- better do not tackle me about the issue unless you feel too good... Any users of the old driver: please note the numbers of the serial lines have now been swapped, i.e. ttyS0 <-> ttyS1 and ttyS2 <-> ttyS3. It has to do with the modem lines mentioned above; basically the port A in a given chip has to be initialised before the port B if you want to use the latter as the serial console (which is usually the case), as operations on modem lines of the serial line associated with the port B access both ports (see the comment at the top of the driver for the details of wiring used). Please update your scripts. This is also the reason each SCC now requests an IRQ once only (as seen in "/proc/interrupts") -- the handler takes care of both ports at once as the line associated with the port B has to take status update interrupts from both ports (and yet the line of the port A takes its own for itself too). The old driver never got it right... Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fbdev: detect primary display deviceAntonino A. Daplas
Add function helper, fb_is_primary_device(). Given struct fb_info, it will return a nonzero value if the device is the primary display. Currently, only the i386 is supported where the function checks for the IORESOURCE_ROM_SHADOW flag. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fbdev: move arch-specific bits to their respective subdirectoriesAntonino A. Daplas
Move arch-specific bits of fb_mmap() to their respective subdirectories [bob.picco@hp.com: efi_range_is_wc is referenced but not declared] [bunk@stusta.de: fix include/asm-m68k/fb.h] Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17sb1250-duart.c: SB1250 DUART serial supportMaciej W. Rozycki
This is a driver for the SB1250 DUART, a dual serial port implementation included in the Broadcom family of SOCs descending from the SiByte SB1250 MIPS64 chip multiprocessor. It is a new implementation replacing the old-fashioned driver currently present in the linux-mips.org tree. It supports all the usual features one would expect from a(n asynchronous) serial driver, including modem line control (as far as hardware supports it -- there is edge detection logic missing from the DCD and RI lines and the driver does not implement polling of these lines at the moment), the serial console, BREAK transmission and reception, including the magic SysRq. The receive FIFO threshold is not maintained though. The driver was tested with a SWARM board which uses a BCM1250 SOC (which is dual MIPS64 CMP) and has both ports of the single DUART implemented wired externally. Both were tested. Testing included using the ports as terminal lines at 1200bps (which is the ports minimum), 115200bps and a couple of random speeds inbetween. The modem lines were verified to operate correctly. No testing was performed with a use as a network interface, like with SLIP or PPP. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Introduce compat_u64 and compat_s64 typesArnd Bergmann
One common problem with 32 bit system call and ioctl emulation is the different alignment rules between i386 and 64 bit machines. A number of drivers work around this by marking the compat structures as 'attribute((packed))', which is not the right solution because it breaks all the non-x86 architectures that want to use the same compat code. Hopefully, this patch improves the situation, it introduces two new types, compat_u64 and compat_s64. These are defined on all architectures to have the same size and alignment as the 32 bit version of u64 and s64. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Andi Kleen <ak@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Vasily Tarasov <vtaras@openvz.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16page table handling cleanupJan Beulich
Kill pte_rdprotect(), pte_exprotect(), pte_mkread(), pte_mkexec(), pte_read(), pte_exec(), and pte_user() except where arch-specific code is making use of them. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-13[MIPS] Workaround for a sparse warning in include/asm-mips/mach-tx4927/ioremap.hAtsushi Nemoto
include2/asm/mach-tx49xx/ioremap.h:39:52: warning: cast truncates bits from constant value (fff000000 becomes ff000000) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-13[MIPS] Workaround for a sparse warning in include/asm-mips/compat.hAtsushi Nemoto
Cast to a __user pointer via "unsigned long" to get rid of this warning: include2/asm/compat.h:135:10: warning: cast adds address space to expression (<asn:1>) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (34 commits) PCI: Only build PCI syscalls on architectures that want them PCI: limit pci_get_bus_and_slot to domain 0 PCI: hotplug: acpiphp: avoid acpiphp "cannot get bridge info" PCI hotplug failure PCI: hotplug: acpiphp: remove hot plug parameter write to PCI host bridge PCI: hotplug: acpiphp: fix slot poweroff problem on systems without _PS3 PCI: hotplug: pciehp: wait for 1 second after power off slot PCI: pci_set_power_state(): check for PM capabilities earlier PCI: cpci_hotplug: Convert to use the kthread API PCI: add pci_try_set_mwi PCI: pcie: remove SPIN_LOCK_UNLOCKED PCI: ROUND_UP macro cleanup in drivers/pci PCI: remove pci_dac_dma_... APIs PCI: pci-x-pci-express-read-control-interfaces cleanups PCI: Fix typo in include/linux/pci.h PCI: pci_ids, remove double or more empty lines PCI: pci_ids, add atheros and 3com_2 vendors PCI: pci_ids, reorder some entries PCI: i386: traps, change VENDOR to DEVICE PCI: ATM: lanai, change VENDOR to DEVICE PCI: Change all drivers to use pci_device->revision ...
2007-07-12[MIPS] Don't use genrtc.Ralf Baechle
The only pseudo-legitimate MIPS user of genrtc was a systems that doesn't have an RTC in hardware at all. At this point faking one is a little pointless ...
2007-07-12[MIPS] SMTC: Interrupt mask backstop hackKevin D. Kissell
To support multiple TC microthreads acting as "CPUs" within a VPE, VPE-wide interrupt mask bits must be specially manipulated during interrupt handling. To support legacy drivers and interrupt controller management code, SMTC has a "backstop" to track and if necessary restore the interrupt mask. This has some performance impact on interrupt service overhead. Disable it only if you know what you are doing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-12[MIPS] Separate platform_device registration for VR41xx GPIOYoichi Yuasa
2007-07-12[MIPS] separate platform_device registration for VR41xx serial interfaceYoichi Yuasa
2007-07-12[MIPS] Cleanup tlbdebug.hAtsushi Nemoto
Also include tlbdebug.h in dump_tlb.c and r3k_dump_tlb.c. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-12[MIPS] Change names of local variables to silence sparse (part 2)Atsushi Nemoto
This patch is an workaround for these sparse warnings: include2/asm/mmu_context.h:172:2: warning: symbol 'flags' shadows an earlier one include2/asm/mmu_context.h:133:16: originally declared here include2/asm/mmu_context.h:232:2: warning: symbol 'flags' shadows an earlier one include2/asm/mmu_context.h:203:16: originally declared here include2/asm/mmu_context.h:277:3: warning: symbol 'flags' shadows an earlier one include2/asm/mmu_context.h:250:16: originally declared here Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-12[MIPS] Workaround for a sparse warning in include/asm-mips/io.hAtsushi Nemoto
CKSEG1ADDR() returns unsigned int value on 32bit kernel. Cast it to unsigned long to get rid of this warning: include2/asm/io.h:215:12: warning: cast adds address space to expression (<asn:2>) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-11PCI: remove pci_dac_dma_... APIsJan Beulich
Based on replies to a respective query, remove the pci_dac_dma_...() APIs (except for pci_dac_dma_supported() on Alpha, where this function is used in non-DAC PCI DMA code). Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <ak@suse.de> Cc: Jesse Barnes <jesse.barnes@intel.com> Cc: Christoph Hellwig <hch@infradead.org> Acked-by: David Miller <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: Use a weak symbol for the empty version of pcibios_add_platform_entries()Michael Ellerman
I'm not sure if this is going to fly, weak symbols work on the compilers I'm using, but whether they work for all of the affected architectures I can't say. I've cc'ed as many arch maintainers/lists as I could find. But assuming they do, we can use a weak empty definition of pcibios_add_platform_entries() to avoid having an empty definition on every arch. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-10lots-of-architectures: enable arbitary speed tty supportAlan Cox
Add the termios2 structure ready for enabling on most platforms. One or two like Sparc are plain weird so have been left alone. Most can use the same structure as ktermios for termios2 (ie the newer ioctl uses the structure matching the current kernel structure) Signed-off-by: Alan Cox <alan@redhat.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[MIPS] WRPPMC: Fix build.Ralf Baechle
Using another systems defines is a safe way to get your code broken by accident when that system is removed. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Change names of local variables to silence sparseAtsushi Nemoto
This patch is an workaround for these sparse warnings: linux/include/linux/calc64.h:25:17: warning: symbol '__quot' shadows an earlier one linux/include/linux/calc64.h:25:17: originally declared here linux/include/linux/calc64.h:25:17: warning: symbol '__mod' shadows an earlier one linux/include/linux/calc64.h:25:17: originally declared here Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Non-FPAFF: Fix warning.Ralf Baechle
2007-07-10[MIPS] Delete Ocelot 3 support.Ralf Baechle
2007-07-10[MIPS] remove LASAT Networks platforms supportYoichi Yuasa
2007-07-10[MIPS] Early check for SMTC kernel on non-MT processorChris Dearman
