path: root/include/asm-mips
2005-11-07Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
2005-11-07Redefine outs[wl] for ide_outs[wl].Atsushi Nemoto
Add missing bits to fix D-cache aliasing problem in the PIO IDE driver. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-07Delete duplicate definitions.Ralf Baechle
This reverts 8f91ed6c2fec8cb746e4dc86a79247162b4c5a7a. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-07Define MAX_UDELAY_MSAtsushi Nemoto
If HZ was 1000, mdelay(2) cause overflow on multiplication in __udelay. We should define MAX_UDELAY_MS properly to prevent this. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-07Use rtc_lock to protect RTC operationsAtsushi Nemoto
Many RTC routines were not protected against each other, so there are potential races, for example, ntp-update against /dev/rtc. This patch fixes them using rtc_lock. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-07Remove mips_rtc_lockAtsushi Nemoto
The mips_rtc_lock is no longer needed because RTC operations should be protected already by other mechanism. (rtc_lock, local_irq_save, etc.) Also, locking whole rtc_get_time/rtc_set_time should be avoided while some RTC routines might take very long time (a few seconds). Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-07Add .gitignore files for MIPS.Ralf Baechle
2005-11-07O2 parport definitionsIlya A. Volynets-Evenbakh
2005-11-07Add spaces to MODULE_PROC_FAMILY values.Ralf Baechle
Only a cosmetic fix to make the output of modinfo look readable. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-07Turn rtlx upside down.Ralf Baechle
o Coding style o Race condition on open o Switch to dynamic major o Header file cleanup Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] semaphore: Remove __MUTEX_INITIALIZER()Arthur Othieno
__MUTEX_INITIALIZER() has no users, and equates to the more commonly used DECLARE_MUTEX(), thus making it pretty much redundant. Remove it for good. Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] vm: remove unused/broken page_pte[_prot] macrosTejun Heo
This patch removes page_pte_prot and page_pte macros from all architectures. Some architectures define both, some only page_pte (broken) and others none. These macros are not used anywhere. page_pte_prot(page, prot) is identical to mk_pte(page, prot) and page_pte(page) is identical to page_pte_prot(page, __pgprot(0)). * The following architectures define both page_pte_prot and page_pte arm, arm26, ia64, sh64, sparc, sparc64 * The following architectures define only page_pte (broken) frv, i386, m32r, mips, sh, x86-64 * All other architectures define neither Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] unify sys_ptrace prototypeChristoph Hellwig
Make sure we always return, as all syscalls should. Also move the common prototype to <linux/syscalls.h> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29BCM1480 HT supportAndrew Isaacson
PCI support code for PLX 7250 PCI-X tunnel on BCM91480B BigSur board. Signed-Off-By: Andy Isaacson <adi@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Support for BigSur board.Andrew Isaacson
2005-10-29Add support for SB1A CPU.Andrew Isaacson
2005-10-29Sibyte header cleanupAndrew Isaacson
Update sibyte headers to match Broadcom internal copies: - comment cleanup and updates - fix LittleSur part number to match the board silkscreen Signed-Off-By: Andy Isaacson <adi@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29BCM1480 headersAndrew Isaacson
Add header files for BCM1480/1280/1455/1255 family of chips, and update sb1250 headers which are shared by BCM1480 family. Signed-Off-By: Andy Isaacson <adi@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> diff --git a/include/asm-mips/sibyte/bcm1480_int.h b/include/asm-mips/sibyte/bcm1480_int.h new file mode 100644
2005-10-29Make UL what should be UL.Ralf Baechle
2005-10-29Don't print file name and line in die and die_if_kernel.Ralf Baechle
2005-10-29Define EOWNERDEAD and ENOTRECOVERABLE.Ralf Baechle
2005-10-29More configcheck fixes.Ralf Baechle
2005-10-292.6.14-rc1 updates for MIPS compat types.Ralf Baechle
2005-10-29Complete the fcntl.h cleanup.Ralf Baechle
2005-10-29Cleanup Sibyte Kconfig a bit further.Ralf Baechle
2005-10-29Fix weirdness in <asm/bug.h>Ralf Baechle
2005-10-29Fixup a few lose ends in explicit support for MIPS R1/R2.Ralf Baechle
2005-10-29Provide 64-bit address space definitions for the Sibyte SB1 CPU core.Ralf Baechle
2005-10-29Cleanup the mess in cpu_cache_init.Ralf Baechle
2005-10-29Use R4000 TLB routines for SB1 also.Ralf Baechle
2005-10-29Fix ARCH_KMALLOC_MINALIGN values on MIPSRalf Baechle
2005-10-29Support for MIPSsim, the cycle accurate MIPS simulator.Ralf Baechle
2005-10-29Revise MIPS 64-bit ptrace interfaceDaniel Jacobowitz
Change the N32 debugging ABI to something more sane, and add support for o32 and n32 debuggers to trace n64 programs. Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Glue again after removal of BUILD_BUG().Ralf Baechle
2005-10-29SMP on Malta needs to define ARCH_HAS_IRQ_PER_CPU since 2.6.14-rc1.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> diff --git a/include/asm-mips/mach-mips/irq.h b/include/asm-mips/mach-mips/irq.h new file mode 100644
2005-10-29Add SOCK_DCCP definition for MIPS also.Ralf Baechle
2005-10-29The type of sum in csum_tcpudp_nofold is "unsigned int", so when we assignRalf Baechle
to it in an asm() block, and we're running on a system with 64-bit registers, it is vitally important that we sign extend it correctly before returning to C. Otherwise the stray high bits will be preserved into csum_fold, and on the SB-1 processor, 32-bit arithmetic on a non sign-extended register will yield surprising results. This caused incorrect checksums in some UDP packets for NFS root. The problem was mild when using a 10.0.1.x IP address, but severe when using 192.168.1.x. Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Kernel gpio/2 routines that will be used by some drivers.Pete Popov
2005-10-29Updated pcmcia driver with pb1200 and db1200 support.Pete Popov
Updated db1200_defconfig so pcmcia is enabled by default. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Reorder & reformat a bit.Ralf Baechle
2005-10-29The values for SO_SNDBUFFORCE / SO_RCVBUFFORCE were already taken ...Ralf Baechle
2005-10-29Futexes for MIPS, for the time being only the R10000_LLSC_WAR version.Ralf Baechle
2005-10-29Define pcibus_to_node() for IP27.Ralf Baechle
2005-10-29Cleaned up AMD Au1200 IDE driver:Pete Popov
- converted to platform bus - removed pci dependencies - removed virt_to_phys/phys_to_virt calls System now can root off of a disk. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> diff --git a/Documentation/mips/AU1xxx_IDE.README b/Documentation/mips/AU1xxx_IDE.README new file mode 100644
2005-10-29Delete the SABLE_RTL case.Ralf Baechle
2005-10-29Provide MODULE_ARCH_VERMAGIC for MIPS.Ralf Baechle
2005-10-29Move MIPS Technologies processor IDs to where they belong.Maciej W. Rozycki
2005-10-29Move genrtc.c's functions into <asm/rtc.h>Ralf Baechle
2005-10-29Define some more common ip22 CPU features.Thiemo Seufer
Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
