path: root/include/asm-mips/dec
2008-07-15[MIPS] DECstation: Document more MB ASIC register bitsMaciej W. Rozycki
Document a few more register bits provided by the MB ASIC used on R4000SC (KN04) and R4400SC (KN05) CPU daughtercards with the DECstation. Reverse-engineered and not documented anywhere else to the best of my knowledge. Bit names appended to the last underscore the same as reported by the firmware in register dumps. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] add DECstation I/O ASIC clocksourceYoichi Yuasa
Add DECstation I/O ASIC clocksource Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-18zs: move to the serial subsystemMaciej W. Rozycki
This is a reimplementation of the zs driver for the serial subsystem. Any resemblance to the old driver is purely coincidential. ;-) I do hope I got the handling of modem lines right -- better do not tackle me about the issue unless you feel too good... Any users of the old driver: please note the numbers of the serial lines have now been swapped, i.e. ttyS0 <-> ttyS1 and ttyS2 <-> ttyS3. It has to do with the modem lines mentioned above; basically the port A in a given chip has to be initialised before the port B if you want to use the latter as the serial console (which is usually the case), as operations on modem lines of the serial line associated with the port B access both ports (see the comment at the top of the driver for the details of wiring used). Please update your scripts. This is also the reason each SCC now requests an IRQ once only (as seen in "/proc/interrupts") -- the handler takes care of both ports at once as the line associated with the port B has to take status update interrupts from both ports (and yet the line of the port A takes its own for itself too). The old driver never got it right... Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[TC] TURBOchannel support for the DECstationMaciej W. Rozycki
This is the platform-specific part of TURBOchannel bus support for the DECstation. It implements determining whether the bus is actually there, getting bus parameters, IRQ assignments for devices and protected accesses to possibly unoccupied slots that may trigger bus error exceptions. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-09[TC] MIPS: TURBOchannel update to the driver modelMaciej W. Rozycki
This is a set of changes to convert support for the TURBOchannel bus to the driver model. It implements the usual set of calls similar to what other bus drivers have: tc_register_driver(), tc_unregister_driver(), etc. All the platform-specific bits have been removed and headers from asm-mips/dec/ have been merged into linux/tc.h, which should be included by drivers. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] Define MIPS_CPU_IRQ_BASE in generic headerAtsushi Nemoto
The irq_base for {mips,rm7k,rm9k}_cpu_irq_init() are constant on all platforms and are same value on most platforms (0 or 16, depends on CONFIG_I8259). Define them in asm-mips/mach-generic/irq.h and make them customizable. This will save a few cycle on each CPU interrupt. A good side effect is removing some dependencies to MALTA in generic SMTC code. Although MIPS_CPU_IRQ_BASE is customizable, this patch changes irq mappings on DDB5477, EMMA2RH and MIPS_SIM, since really customizing them might cause some header dependency problem and there seems no good reason to customize it. So currently only VR41XX is using custom MIPS_CPU_IRQ_BASE value, which is 0 regardless of CONFIG_I8259. Testing this patch on those platforms is greatly appreciated. Thank you. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] IRQ cleanupsAtsushi Nemoto
This is a big irq cleanup patch. * Use set_irq_chip() to register irq_chip. * Initialize .mask, .unmask, .mask_ack field. Functions for these method are already exist in most case. * Do not initialize .startup, .shutdown, .enable, .disable fields if default routines provided by irq_chip_set_defaults() were suitable. * Remove redundant irq_desc initializations. * Remove unnecessary local_irq_save/local_irq_restore, spin_lock. With this cleanup, it would be easy to switch to slightly lightwait irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ(). Though whole this patch is quite large, changes in each irq_chip are not quite simple. Please review and test on your platform. Thanks. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] DEC: pt_regs fixes for buserror handlersRalf Baechle
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-10-29Use physical addresses at the interface level, letting drivers remapMaciej W. Rozycki
them as appropriate. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29System-specific handling of bus errors for DECstation variationsMaciej W. Rozycki
supporting parity errors only for memory (Pmax/3min/Maxine). Fixes for resources decoded by the KN04/KN05 MB ASIC. Additional clean-ups for the ECC handler. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29GCC 4.0.0 broke `attribute(("alias"))' -- resort to an assembly variant.Maciej W. Rozycki
2005-10-29Deal with the bloody KSEG vs CKSEG horror...Maciej W. Rozycki
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
