path: root/include/asm-mips/cacheflush.h
2008-04-07[MIPS] Handle aliases in vmalloc correctly.Ralf Baechle
flush_cache_vmap / flush_cache_vunmap were calling flush_cache_all which - having been deprecated - turned into a nop ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-03-12[MIPS] Fix loads of section missmatchesRalf Baechle
2007-04-27[MIPS] Remove unused argument from kunmap_coherent().Ralf Baechle
2007-03-24[MIPS] Implement flush_anon_page().Ralf Baechle
2006-12-13[PATCH] Optimize D-cache alias handling on forkRalf Baechle
Virtually index, physically tagged cache architectures can get away without cache flushing when forking. This patch adds a new cache flushing function flush_cache_dup_mm(struct mm_struct *) which for the moment I've implemented to do the same thing on all architectures except on MIPS where it's a no-op. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-21[MIPS] Fix aliasing bug in copy_to_user_page / copy_from_user_pageRalf Baechle
The current implementation uses a sequence of a cacheflush and a copy. This is racy in case of a multithreaded debuggee and renders GDB virtually unusable. Aside this fixes a performance hog rendering access to /proc/cmdline very slow and resulting in a enough cache stalls for the 34K AP/SP programming model to make the bare metal code on the non-Linux VPE miss RT deadlines. The main part of this patch was originally written by Ralf Baechle; Atushi Nemoto did the the debugging. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-01[MIPS] Remove __flush_icache_pageAtsushi Nemoto
__flash_icache_page is unused, so kill it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Retire flush_icache_page from mm use.Ralf Baechle
On the 34K the redundant cache operations were causing excessive stalls resulting in realtime code running on the second VPE missing its deadline. For all other platforms this patch is just a significant performance improvment as illustrated by below benchmark numbers. Processor, Processes - times in microseconds - smaller is better ------------------------------------------------------------------------------ Host OS Mhz null null open slct sig sig fork exec sh call I/O stat clos TCP inst hndl proc proc proc --------- ------------- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- 25Kf 2.6.18-rc4 533 0.49 1.16 7.57 33.4 30.5 1.34 12.4 5497 17.K 54.K 25Kf 2.6.18-rc4-p 533 0.49 1.16 6.68 23.0 30.7 1.36 8.55 5030 16.K 48.K 4Kc 2.6.18-rc4 80 4.21 15.0 131. 289. 261. 16.5 258. 18.K 70.K 227K 4Kc 2.6.18-rc4-p 80 4.34 13.1 128. 285. 262. 18.2 258. 12.K 52.K 176K 34Kc 2.6.18-rc4 40 5.01 14.0 61.6 90.0 477. 17.9 94.7 29.K 108K 342K 34Kc 2.6.18-rc4-p 40 4.98 13.9 61.2 89.7 475. 17.6 93.7 8758 44.K 158K BCM1480 2.6.18-rc4 700 0.28 0.60 3.68 5.92 16.0 0.78 5.08 931. 3163 15.K BCM1480 2.6.18-rc4-p 700 0.28 0.61 3.65 5.85 16.0 0.79 5.20 395. 1464 8385 TX49-16K 2.6.18-rc3 197 0.73 2.41 19.0 37.8 82.9 2.94 17.5 4438 14.K 56.K TX49-16K 2.6.18-rc3-p 197 0.73 2.40 19.9 36.3 82.9 2.94 23.4 2577 9103 38.K TX49-32K 2.6.18-rc3 396 0.36 1.19 6.80 11.8 41.0 1.46 8.17 2738 8465 32.K TX49-32K 2.6.18-rc3-p 396 0.36 1.19 6.82 10.2 41.0 1.46 8.18 1330 4638 18.K Original patch by me with enhancements by Atsushi Nemoto. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
2006-04-19[MIPS] Handle IDE PIO cache aliases on SMP.Ralf Baechle
2006-02-07[MIPS] Remove wrong __user tags.Atsushi Nemoto
This fixes sparse warnings 'dereference of noderef expression'. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Better interface to run uncached cache setup code.Thiemo Seufer
Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Reformat; cosmetic cleanups.Ralf Baechle
2005-10-29Sparseify MIPS.Ralf Baechle
2005-10-29Fix ptrace aliasing issue in copy_from_user_page / copy_to_user_page.Ralf Baechle
