path: root/include/asm-m68k/poll.h
2009-01-16m68k,m68knommu: merge header filesSam Ravnborg
Merge header files for m68k and m68knommu to the single location: arch/m68k/include/asm The majority of this patch was the result of the script that is included in the changelog below. The script was originally written by Arnd Bergman and exten by me to cover a few more files. When the header files differed the script uses the following: The original m68k file is named <file>_mm.h [mm for memory manager] The m68knommu file is named <file>_no.h [no for no memory manager] The files uses the following include guard: This include gaurd works as the m68knommu toolchain set the __uClinux__ symbol - so this should work in userspace too. Merging the header files for m68k and m68knommu exposes the (unexpected?) ABI differences thus it is easier to actually identify these and thus to fix them. The commit has been build tested with both a m68k and a m68knommu toolchain - with success. The commit has also been tested with "make headers_check" and this patch fixes make headers_check for m68knommu. The script used: TARGET=arch/m68k/include/asm SOURCE=arch/m68knommu/include/asm INCLUDE="cachectl.h errno.h fcntl.h hwtest.h ioctls.h ipcbuf.h \ linkage.h math-emu.h md.h mman.h movs.h msgbuf.h openprom.h \ oplib.h poll.h posix_types.h resource.h rtc.h sembuf.h shmbuf.h \ shm.h shmparam.h socket.h sockios.h spinlock.h statfs.h stat.h \ termbits.h termios.h tlb.h types.h user.h" EQUAL="auxvec.h cputime.h device.h emergency-restart.h futex.h \ ioctl.h irq_regs.h kdebug.h local.h mutex.h percpu.h \ sections.h topology.h" NOMUUFILES="anchor.h bootstd.h coldfire.h commproc.h dbg.h \ elia.h flat.h m5206sim.h m520xsim.h m523xsim.h m5249sim.h \ m5272sim.h m527xsim.h m528xsim.h m5307sim.h m532xsim.h \ m5407sim.h m68360_enet.h m68360.h m68360_pram.h m68360_quicc.h \ m68360_regs.h MC68328.h MC68332.h MC68EZ328.h MC68VZ328.h \ mcfcache.h mcfdma.h mcfmbus.h mcfne.h mcfpci.h mcfpit.h \ mcfsim.h mcfsmc.h mcftimer.h mcfuart.h mcfwdebug.h \ nettel.h quicc_simple.h smp.h" FILES="atomic.h bitops.h bootinfo.h bug.h bugs.h byteorder.h cache.h \ cacheflush.h checksum.h current.h delay.h div64.h \ dma-mapping.h dma.h elf.h entry.h fb.h fpu.h hardirq.h hw_irq.h io.h \ irq.h kmap_types.h machdep.h mc146818rtc.h mmu.h mmu_context.h \ module.h page.h page_offset.h param.h pci.h pgalloc.h \ pgtable.h processor.h ptrace.h scatterlist.h segment.h \ setup.h sigcontext.h siginfo.h signal.h string.h system.h swab.h \ thread_info.h timex.h tlbflush.h traps.h uaccess.h ucontext.h \ unaligned.h unistd.h" mergefile() { BASE=${1%.h} git mv ${SOURCE}/$1 ${TARGET}/${BASE}_no.h git mv ${TARGET}/$1 ${TARGET}/${BASE}_mm.h cat << EOF > ${TARGET}/$1 EOF git add ${TARGET}/$1 } set -e mkdir -p ${TARGET} git mv include/asm-m68k/* ${TARGET} rmdir include/asm-m68k git rm ${SOURCE}/Kbuild for F in $INCLUDE $EQUAL; do git rm ${SOURCE}/$F done for F in $NOMUUFILES; do git mv ${SOURCE}/$F ${TARGET}/$F done for F in $FILES ; do mergefile $F done rmdir arch/m68knommu/include/asm rmdir arch/m68knommu/include Cc: Arnd Bergmann <arnd@arndb.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2007-05-11Consolidate asm/poll.hStephen Rothwell
These files are almost all the same. This patch could be made even simpler if we don't mind POLLREMOVE turning up in a few architectures that didn't have it previously (which should be OK as POLLREMOVE is not used anywhere in the current tree). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
