path: root/include/asm-m32r
2006-09-26[PATCH] Standardize pxx_page macrosDave McCracken
One of the changes necessary for shared page tables is to standardize the pxx_page macros. pte_page and pmd_page have always returned the struct page associated with their entry, while pte_page_kernel and pmd_page_kernel have returned the kernel virtual address. pud_page and pgd_page, on the other hand, return the kernel virtual address. Shared page tables needs pud_page and pgd_page to return the actual page structures. There are very few actual users of these functions, so it is simple to standardize their usage. Since this is basic cleanup, I am submitting these changes as a standalone patch. Per Hugh Dickins' comments about it, I am also changing the pxx_page_kernel macros to pxx_page_vaddr to clarify their meaning. Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-21Fix 'make headers_check' on m32rDavid Woodhouse
> asm-m32r/page.h requires asm-generic/memory_model.h, which does not exist > asm-m32r/ptrace.h requires asm/m32r.h, which does not exist > asm-m32r/signal.h requires linux/linkage.h, which does not exist > asm-m32r/unistd.h requires asm/syscall.h, which does not exist > asm-m32r/user.h requires asm/processor.h, which does not exist Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-07-14[PATCH] remove set_wmb - arch removalSteven Rostedt
set_wmb should not be used in the kernel because it just confuses the code more and has no benefit. Since it is not currently used in the kernel this patch removes it so that new code does not include it. All archs define set_wmb(var, value) to do { var = value; wmb(); } while(0) except ia64 and sparc which use a mb() instead. But this is still moot since it is not used anyway. Hasn't been tested on any archs but x86 and x86_64 (and only compiled tested) Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-04Merge git://git.infradead.org/hdrinstall-2.6Linus Torvalds
* git://git.infradead.org/hdrinstall-2.6: Remove export of include/linux/isdn/tpam.h Remove <linux/i2c-id.h> and <linux/i2c-algo-ite.h> from userspace export Restrict headers exported to userspace for SPARC and SPARC64 Add empty Kbuild files for 'make headers_install' in remaining arches. Add Kbuild file for Alpha 'make headers_install' Add Kbuild file for SPARC 'make headers_install' Add Kbuild file for IA64 'make headers_install' Add Kbuild file for S390 'make headers_install' Add Kbuild file for i386 'make headers_install' Add Kbuild file for x86_64 'make headers_install' Add Kbuild file for PowerPC 'make headers_install' Add generic Kbuild files for 'make headers_install' Basic implementation of 'make headers_check' Basic implementation of 'make headers_install'
2006-07-03[PATCH] sched: cleanup, remove task_t, convert to struct task_structIngo Molnar
cleanup: remove task_t and convert all the uses to struct task_struct. I introduced it for the scheduler anno and it was a mistake. Conversion was mostly scripted, the result was reviewed and all secondary whitespace and style impact (if any) was fixed up by hand. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: M32R: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[AF_UNIX]: Datagram getpeersecCatherine Zhang
This patch implements an API whereby an application can determine the label of its peer's Unix datagram sockets via the auxiliary data mechanism of recvmsg. Patch purpose: This patch enables a security-aware application to retrieve the security context of the peer of a Unix datagram socket. The application can then use this security context to determine the security context for processing on behalf of the peer who sent the packet. Patch design and implementation: The design and implementation is very similar to the UDP case for INET sockets. Basically we build upon the existing Unix domain socket API for retrieving user credentials. Linux offers the API for obtaining user credentials via ancillary messages (i.e., out of band/control messages that are bundled together with a normal message). To retrieve the security context, the application first indicates to the kernel such desire by setting the SO_PASSSEC option via getsockopt. Then the application retrieves the security context using the auxiliary data mechanism. An example server application for Unix datagram socket should look like this: toggle = 1; toggle_len = sizeof(toggle); setsockopt(sockfd, SOL_SOCKET, SO_PASSSEC, &toggle, &toggle_len); recvmsg(sockfd, &msg_hdr, 0); if (msg_hdr.msg_controllen > sizeof(struct cmsghdr)) { cmsg_hdr = CMSG_FIRSTHDR(&msg_hdr); if (cmsg_hdr->cmsg_len <= CMSG_LEN(sizeof(scontext)) && cmsg_hdr->cmsg_level == SOL_SOCKET && cmsg_hdr->cmsg_type == SCM_SECURITY) { memcpy(&scontext, CMSG_DATA(cmsg_hdr), sizeof(scontext)); } } sock_setsockopt is enhanced with a new socket option SOCK_PASSSEC to allow a server socket to receive security context of the peer. Testing: We have tested the patch by setting up Unix datagram client and server applications. We verified that the server can retrieve the security context using the auxiliary data mechanism of recvmsg. Signed-off-by: Catherine Zhang <cxzhang@watson.ibm.com> Acked-by: Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[PATCH] genirq: add ->retrigger() irq op to consolidate hw_irq_resend()Ingo Molnar
Add ->retrigger() irq op to consolidate hw_irq_resend() implementations. (Most architectures had it defined to NOP anyway.) NOTE: ia64 needs testing. i386 and x86_64 tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-22[PATCH] vgacon: make VGA_MAP_MEM take size, remove extra useBjorn Helgaas
VGA_MAP_MEM translates to ioremap() on some architectures. It makes sense to do this to vga_vram_base, because we're going to access memory between vga_vram_base and vga_vram_end. But it doesn't really make sense to map starting at vga_vram_end, because we aren't going to access memory starting there. On ia64, which always has to be different, ioremapping vga_vram_end gives you something completely incompatible with ioremapped vga_vram_start, so vga_vram_size ends up being nonsense. As a bonus, we often know the size up front, so we can use ioremap() correctly, rather than giving it a zero size. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-18Add empty Kbuild files for 'make headers_install' in remaining arches.David Woodhouse
These include nothing more than the basic set of files listed in asm-generic/Kbuild.asm. Any extra arch-specific files will need to be added. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-04-29Remove unneeded _syscallX macros from user view in asm-*/unistd.hDavid Woodhouse
These aren't needed by glibc or klibc, and they're broken in some cases anyway. The uClibc folks are apparently switching over to stop using them too (now that we agreed that they should be dropped, at least). Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-19[PATCH] m32r: update switch_to macro for tuningHirokazu Takata
- Remove unnecessary push/pop's of the switch_to() macro for performance tuning. - Cosmetic updates: change __inline__ to inline, etc. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: NIIBE Yutaka <gniibe@fsij.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] m32r: mappi3 reboot supportHirokazu Takata
Here is a patch to support a reboot function for M3A-2170(Mappi-III) evaluation board. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] m32r: update include/asm-m32r/semaphore.hHirokazu Takata
This patch updates include/asm-m32r/semaphore.h for good readability and maintainability. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] m32r: Fix pt_regs for !COFNIG_ISA_DSP_LEVEL2 targetHirokazu Takata
This modification is required to fix debugging function for m32r targets with !CONFIG_ISA_DSP_LEVEL2, by unifying 'struct pt_regs' and 'struct sigcontext' size for all M32R ISA. Some m32r processor core with !CONFIG_ISA_DSP_LEVEL2 configuration has only single accumulator a0 (ex. VDEC2 core, M32102 core, etc.), the others with CONFIG_ISA_DSP_LEVEL2 has two accumulators, a0 and a1. This means there are two variations of thread context. So far, we reduced and changed stackframe size at a syscall for their context size. However, this causes a problem that a GDB for processors with CONFIG_ISA_DSP_LEVEL2 cannot be used for processors with !CONFIG_ISA_DSP_LEVEL2. From the viewpoint of GDB support, we should reduce such variation of stackframe size for simplicity. In this patch, dummy members are added to 'struct pt_regs' and 'struct sigcontext' to adjust their size for !CONFIG_ISA_DSP_LEVEL2. This modification is also a one step for a GDB update in future. Currently, on the m32r, GDB can access process's context by using ptrace functions in a simple way of register by register access. By unifying stackframe size, we have a possibility to make use of ptrace functions of not only a single register access but also block register access, PTRACE_{GETREGS,PUTREGS}. However, for this purpose, we might have to modify stackframe structure some more; for example, PSW (processor status word) register should be pre-processed before pushing to stack at a syscall, and so on. In this case, we must update carefully both kernel and GDB at a time... Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Kei Sakamoto <ksakamot@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] sys_kexec_load() naming fixupsAndrew Morton
__NR_sys_kexec_load should be __NR_kexec_load. Mainly affects users of the _syscallN() macros, and glibc is already checking for __NR_kexec_load. Cc: Ulrich Drepper <drepper@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Configurable NODES_SHIFTYasunori Goto
Current implementations define NODES_SHIFT in include/asm-xxx/numnodes.h for each arch. Its definition is sometimes configurable. Indeed, ia64 defines 5 NODES_SHIFT values in the current git tree. But it looks a bit messy. SGI-SN2(ia64) system requires 1024 nodes, and the number of nodes already has been changeable by config. Suitable node's number may be changed in the future even if it is other architecture. So, I wrote configurable node's number. This patch set defines just default value for each arch which needs multi nodes except ia64. But, it is easy to change to configurable if necessary. On ia64 the number of nodes can be already configured in generic ia64 and SN2 config. But, NODES_SHIFT is defined for DIG64 and HP'S machine too. So, I changed it so that all platforms can be configured via CONFIG_NODES_SHIFT. It would be simpler. See also: http://marc.theaimsgroup.com/?l=linux-kernel&m=114358010523896&w=2 Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jack Steiner <steiner@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Remove unused prepare_to_switch macroHirokazu Takata
Remove unused prepare_to_switch() macros. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] m32r: security fix of {get,put}_user macrosHirokazu Takata
Update {get,put}_user macros for m32r kernel. - Modify get_user to use __get_user_asm macro, instead of __get_user_x macro. - Remove arch/m32r/lib/{get,put}user.S. - Some cosmetic updates. I would like to thank NIIBE Yutaka for his reporting about the m32r kernel's security problem in {get,put}_user macros. There were no address checking for user space access in {get,put}_user macros. ;-) Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: NIIBE Yutaka <gniibe@fsij.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] m32r: Fix cpu_possible_map and cpu_present_map initialization for ↵Hirokazu Takata
SMP kernel This patch fixes a boot problem of the m32r SMP kernel 2.6.16-rc1-mm3 or later. In this patch, cpu_possible_map is statically initialized, and cpu_present_map is also copied from cpu_possible_map in smp_prepare_cpus(), because the m32r architecture has not supported CPU hotplug yet. Signed-off-by: Hayato Fujiwara <fujiwara.hayato@renesas.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] unify PFN_* macrosDave Hansen
Just about every architecture defines some macros to do operations on pfns. They're all virtually identical. This patch consolidates all of them. One minor glitch is that at least i386 uses them in a very skeletal header file. To keep away from #include dependency hell, I stuck the new definitions in a new, isolated header. Of all of the implementations, sh64 is the only one that varied by a bit. It used some masks to ensure that any sign-extension got ripped away before the arithmetic is done. This has been posted to that sh64 maintainers and the development list. Compiles on x86, x86_64, ia64 and ppc64. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] unify pfn_to_page: m32r pfn_to_pageKAMEZAWA Hiroyuki
m32r can use generic funcs. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: m32r: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove find_{next,first}{,_zero}_bit() - remove __ffs() - remove generic_fls() - remove generic_fls64() - remove sched_find_first_bit() - remove generic_ffs() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: use non atomic operations for minix_*_bit() and ext2_*_bit()Akinobu Mita
Bitmap functions for the minix filesystem and the ext2 filesystem except ext2_set_bit_atomic() and ext2_clear_bit_atomic() do not require the atomic guarantees. But these are defined by using atomic bit operations on several architectures. (cris, frv, h8300, ia64, m32r, m68k, m68knommu, mips, s390, sh, sh64, sparc, sparc64, v850, and xtensa) This patch switches to non atomic bit operation. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] m32r: fix and update for gcc-4.0Hirokazu Takata
Fix and update for gcc-4.0. - arch/m32r/kernel/signal.c: Change type of the 8th parameter of sys_rt_sigsuspend() from 'struct pt_regs' to 'struct pt_regs *'. This functions make use of the 'regs' parameter to return status value, but gcc-4.0 optimizes and removes it as a dead code. Functions, sys_sigaltstack() and sys_rt_sigreturn(), have also modified. - arch/m32r/lib/usercopy.c, include/asm-m32r/uaccess.h: Add early-clobber constraints('&') to output values of asm statements; these constraints seems to be required for gcc-4.0 register assignment. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] m32r: __cmpxchg_u32 fixHirokazu Takata
This patch fixes a bug of include/asm-m32r/system.h:__cmpxchg_u32(). static __inline__ unsigned long __cmpxchg_u32(volatile unsigned int *p, unsigned int old, unsigned int new); In __cmpxchg_u32(), the "old" value must not be changed to the previous "*p" value. But the former code modifies the previous "*p" value. A deadlock at _atomic_dec_and_lock sometimes happened due to this bug. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[PATCH] add asm-generic/mman.hMichael S. Tsirkin
Make new MADV_REMOVE, MADV_DONTFORK, MADV_DOFORK consistent across all arches. The idea is to make it possible to use them portably even before distros include them in libc headers. Move common flags to asm-generic/mman.h Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] madvise MADV_DONTFORK/MADV_DOFORKMichael S. Tsirkin
Currently, copy-on-write may change the physical address of a page even if the user requested that the page is pinned in memory (either by mlock or by get_user_pages). This happens if the process forks meanwhile, and the parent writes to that page. As a result, the page is orphaned: in case of get_user_pages, the application will never see any data hardware DMA's into this page after the COW. In case of mlock'd memory, the parent is not getting the realtime/security benefits of mlock. In particular, this affects the Infiniband modules which do DMA from and into user pages all the time. This patch adds madvise options to control whether memory range is inherited across fork. Useful e.g. for when hardware is doing DMA from/into these pages. Could also be useful to an application wanting to speed up its forks by cutting large areas out of consideration. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Acked-by: Hugh Dickins <hugh@veritas.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] death of get_thread_info/put_thread_infoAl Viro
{get,put}_thread_info() were introduced in 2.5.4 and never had been called by anything in the tree. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] m32r: task_pt_regs(), task_stack_page(), task_thread_info()Al Viro
2006-01-12[PATCH] sched: add cacheflush() asmIngo Molnar
Add per-arch sched_cacheflush() which is a write-back cacheflush used by the migration-cost calibration code at bootup time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Generic ioctl.hBrian Gerst
Most arches copied the i386 ioctl.h. Combine them into a generic header. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, add default include/asm-*/mutex.h filesArjan van de Ven
add the per-arch mutex.h files for the remaining architectures. We default to asm-generic/mutex-dec.h, because that performs quite well on most arches. Arches that do not have atomic decrement/increment instructions should switch to mutex-xchg.h instead. Arches can also provide their own implementation for the mutex fastpath primitives. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] mutex subsystem, add atomic_xchg() to all archesIngo Molnar
add atomic_xchg() to all the architectures. Needed by the new mutex code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
2006-01-08[PATCH] consolidate asm/futex.hJeff Dike
Most of the architectures have the same asm/futex.h. This consolidates them into asm-generic, with the arches including it from their own asm/futex.h. In the case of UML, this reverts the old broken futex.h and goes back to using the same one as almost everyone else. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Kill L1_CACHE_SHIFT_MAXRavikiran G Thirumalai
Kill L1_CACHE_SHIFT from all arches. Since L1_CACHE_SHIFT_MAX is not used anymore with the introduction of INTERNODE_CACHE, kill L1_CACHE_SHIFT_MAX. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Remove unnecessary icu_data_t definitionsHirokazu Takata
This patch removes unnecessary struct icu_data_t definitions of arch/m32r/kernel/setup_*.c. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Update _port2addr to use NONCACHE_OFFSETHirokazu Takata
Modify _port2addr*() routines in arch/m32r/kernel/io_*.c to use NONCACHE_OFFSET instead of hard-coding of a constant address. This modification is also required to support an M3A-ZA36 FPGA eva board in case an MMU-less synthesizable m32r core is used. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Update syscall macros for MMU-less targetsHirokazu Takata
This patch is for updating m32r's MMU-less support. Some legacy MMU-less m32r chips cannot return from a trap handler to the right-hand side 16-bit halfword code of a 32-bit instrucion code pair, because a "trap" instruction specification was expanded in M32R-II ISA. This modification forces "trap" instructions to be placed in word alignment location with a parallel "nop" code. Signed-off-by: Kazuhiro Inaoka <inaoka@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Support M32104UT target platformHirokazu Takata
This patch is for supporting a new target platform, Renesas M32104UT evaluation board. The M32104UT is an eval board based on an uT-Engine specification. This board has an MMU-less M32R family processor, M32104. http://www-wa0.personal-media.co.jp/pmc/archive/te/te_m32104_e.pdf This board is one of the most popular M32R platform, so we have ported Linux/M32R to it. Signed-off-by: Naoto Sugai <Sugai.Naoto@ak.MitsubishiElectric.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] atomic_long_t & include/asm-generic/atomic.h V2Christoph Lameter
Several counters already have the need to use 64 atomic variables on 64 bit platforms (see mm_counter_t in sched.h). We have to do ugly ifdefs to fall back to 32 bit atomic on 32 bit platforms. The VM statistics patch that I am working on will also make more extensive use of atomic64. This patch introduces a new type atomic_long_t by providing definitions in asm-generic/atomic.h that works similar to the c "long" type. Its 32 bits on 32 bit platforms and 64 bits on 64 bit platforms. Also cleans up the determination of the mm_counter_t in sched.h. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] madvise(MADV_REMOVE): remove pages from tmpfs shm backing storeBadari Pulavarty
Here is the patch to implement madvise(MADV_REMOVE) - which frees up a given range of pages & its associated backing store. Current implementation supports only shmfs/tmpfs and other filesystems return -ENOSYS. "Some app allocates large tmpfs files, then when some task quits and some client disconnect, some memory can be released. However the only way to release tmpfs-swap is to MADV_REMOVE". - Andrea Arcangeli Databases want to use this feature to drop a section of their bufferpool (shared memory segments) - without writing back to disk/swap space. This feature is also useful for supporting hot-plug memory on UML. Concerns raised by Andrew Morton: - "We have no plan for holepunching! If we _do_ have such a plan (or might in the future) then what would the API look like? I think sys_holepunch(fd, start, len), so we should start out with that." - Using madvise is very weird, because people will ask "why do I need to mmap my file before I can stick a hole in it?" - None of the other madvise operations call into the filesystem in this manner. A broad question is: is this capability an MM operation or a filesytem operation? truncate, for example, is a filesystem operation which sometimes has MM side-effects. madvise is an mm operation and with this patch, it gains FS side-effects, only they're really, really significant ones." Comments: - Andrea suggested the fs operation too but then it's more efficient to have it as a mm operation with fs side effects, because they don't immediatly know fd and physical offset of the range. It's possible to fixup in userland and to use the fs operation but it's more expensive, the vmas are already in the kernel and we can use them. Short term plan & Future Direction: - We seem to need this interface only for shmfs/tmpfs files in the short term. We have to add hooks into the filesystem for correctness and completeness. This is what this patch does. - In the future, plan is to support both fs and mmap apis also. This also involves (other) filesystem specific functions to be implemented. - Current patch doesn't support VM_NONLINEAR - which can be addressed in the future. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Andrea Arcangeli <andrea@suse.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[FLS64]: generic versionStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-28[PATCH] m32r: M3A-2170(Mappi-III) IDE supportHirokazu Takata
This patch is for supporting IDE interface for M3A-2170(Mappi-III) board. Signed-off-by: Mamoru Sakugawa <sakugawa@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] m32r: Introduce atomic_cmpxchg and atomic_inc_not_zero operationsHirokazu Takata
Introduce atomic_cmpxchg and atomic_inc_not_zero operations for m32r. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
