path: root/include/asm-m32r/uaccess.h
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-11[PATCH] m32r: security fix of {get,put}_user macrosHirokazu Takata
Update {get,put}_user macros for m32r kernel. - Modify get_user to use __get_user_asm macro, instead of __get_user_x macro. - Remove arch/m32r/lib/{get,put}user.S. - Some cosmetic updates. I would like to thank NIIBE Yutaka for his reporting about the m32r kernel's security problem in {get,put}_user macros. There were no address checking for user space access in {get,put}_user macros. ;-) Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: NIIBE Yutaka <gniibe@fsij.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] m32r: fix and update for gcc-4.0Hirokazu Takata
Fix and update for gcc-4.0. - arch/m32r/kernel/signal.c: Change type of the 8th parameter of sys_rt_sigsuspend() from 'struct pt_regs' to 'struct pt_regs *'. This functions make use of the 'regs' parameter to return status value, but gcc-4.0 optimizes and removes it as a dead code. Functions, sys_sigaltstack() and sys_rt_sigreturn(), have also modified. - arch/m32r/lib/usercopy.c, include/asm-m32r/uaccess.h: Add early-clobber constraints('&') to output values of asm statements; these constraints seems to be required for gcc-4.0 register assignment. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-26[PATCH] m32r: more basic __user annotationsAl Viro
2005-09-07[PATCH] remove verify_area(): remove verify_area() from various uaccess.h ↵Jesper Juhl
headers Remove the deprecated (and unused) verify_area() from various uaccess.h headers. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
