path: root/include/asm-m32r/m32r.h
2009-04-17m32r: move include/asm-m32r headers to arch/m32r/include/asmHirokazu Takata
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-09-03m32r: Define symbols to unify platform-dependent ICU checksHirokazu Takata
On some m32r platforms, cascaded ICUs are used. This patch is required to simplify ei_handler and consolidate platform- dependent ICU check routines. platform ICU/INT1 ICU/INT0 ICU/INT2 -------------- -------- -------- -------- m32104ut o - - m32700ut o o o opsput o o o usrv o - - (others) - - - Signed-off-by: Hitoshi Yamamoto <hitoshiy@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-06[PATCH] m32r: Update _port2addr to use NONCACHE_OFFSETHirokazu Takata
Modify _port2addr*() routines in arch/m32r/kernel/io_*.c to use NONCACHE_OFFSET instead of hard-coding of a constant address. This modification is also required to support an M3A-ZA36 FPGA eva board in case an MMU-less synthesizable m32r core is used. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Support M32104UT target platformHirokazu Takata
This patch is for supporting a new target platform, Renesas M32104UT evaluation board. The M32104UT is an eval board based on an uT-Engine specification. This board has an MMU-less M32R family processor, M32104. http://www-wa0.personal-media.co.jp/pmc/archive/te/te_m32104_e.pdf This board is one of the most popular M32R platform, so we have ported Linux/M32R to it. Signed-off-by: Naoto Sugai <Sugai.Naoto@ak.MitsubishiElectric.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] m32r: Remove include/asm-m32r/m32102peri.hHirokazu Takata
This patch removes an obsolete header file include/asm-m32r/m32102peri.h. In this header, there are some undesirable single character types, like V. And the header is almost no longer used. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] m32r: Support M3A-2170(Mappi-III) platformHirokazu Takata
This patchset is for supporting a new m32r platform, M3A-2170(Mappi-III) evaluation board. An M32R chip multiprocessor is equipped on the board. http://http://www.linux-m32r.org/eng/platform/platform.html * arch/m32r/Kconfig: Support Mappi-III platform. * arch/m32r/kernel/Makefile: ditto. * arch/m32r/kernel/io_mappi3.c: ditto. * arch/m32r/kernel/setup.c: ditto. * arch/m32r/kernel/setup_mappi3.c: ditto. * include/asm-m32r/m32102.h: ditto. * include/asm-m32r/m32r.h: ditto. * include/asm-m32r/mappi3/mappi3_pld.h: ditto. * include/asm-m32r/ide.h: CF support for Mappi-III. * arch/m32r/kernel/setup_mappi3.c: ditto. * arch/m32r/mappi3/defconfig.smp: A default config file for Mappi-III. * arch/m32r/mappi3/dot.gdbinit: A default .gdbinit file for Mappi-III. * arch/m32r/boot/compressed/m32r_sio.c: Modified for Mappi-III - At boot time, m32r-g00ff bootloader makes MMU off for Mappi-III, on the contrary it makes MMU on for Mappi-II. * arch/m32r/kernel/io_mappi2.c: Update comments. * arch/m32r/kernel/setup_mappi2.c: ditto. Signed-off-by: Mamoru Sakugawa <sakugawa@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
