path: root/include/asm-m32r/flat.h
2007-10-03Binfmt_flat: Add minimum support for the Blackfin relocationsBernd Schmidt
Add minimum support for the Blackfin relocations, since we don't have enough space in each reloc. The idea is to store a value with one relocation so that subsequent ones can access it. Actually, this patch is required for Blackfin. Currently if BINFMT_FLAT is enabled, git-tree kernel will fail to compile. Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: David McCullough <davidm@snapgear.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Miles Bader <miles.bader@necel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
