path: root/include/asm-ia64
2006-05-24Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: include/asm-powerpc/unistd.h include/asm-sparc/unistd.h include/asm-sparc64/unistd.h Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-05[IA64] remove asm-ia64/bitops.h self-inclusionJon Mason
asm-ia64/bitops.h includes itself. The #ifndef _ASM_IA64_BITOPS_H prevents this from being an issue, but it should still be removed. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6David Woodhouse
2006-04-27Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] update sn2 defconfig [IA64] Add mca recovery failure messages [IA64-SGI] fix SGI Altix tioce_reserve_m32() bug [IA64] enable dumps to capture second page of kernel stack [IA64-SGI] - Reduce overhead of reading sn_topology [IA64-SGI] - Fix discover of nearest cpu node to IO node [IA64] IOC4 config option ordering [IA64] Setup an IA64 specific reclaim distance [IA64] eliminate compile time warnings [IA64] eliminate compile time warnings [IA64-SGI] SN SAL call to inject memory errors [IA64] - Fix MAX_PXM_DOMAINS for systems with > 256 nodes [IA64] Remove unused variable in sn_sal.h [IA64] Remove redundant NULL checks before kfree [IA64] wire up compat_sys_adjtimex()
2006-04-27[IA64] enable dumps to capture second page of kernel stackCliff Wickman
In SLES10 (2.6.16) crash dumping (in my experience, LKCD) is unable to capture the second page of the 2-page task/stack allocation. This is particularly troublesome for dump analysis, as the stack traceback cannot be done. (A similar convention is probably needed throughout the kernel to make kernel multi-page allocations detectable for dumping) Multi-page kernel allocations are represented by the single page structure associated with the first page of the allocation. The page structures associated with the other pages are unintialized. If the dumper is selecting only kernel pages it has no way to identify any but the first page of the allocation. The fix is to make the task/stack allocation a compound page. Signed-off-by: Cliff Wickman <cpw@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-27[IA64-SGI] - Fix discover of nearest cpu node to IO nodeJack Steiner
Fix a bug that causes discovery of the nearest node/cpu to a TIO (IO node) to fail. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-26[PATCH] Add support for the sys_vmsplice syscallJens Axboe
sys_splice() moves data to/from pipes with a file input/output. sys_vmsplice() moves data to a pipe, with the input being a user address range instead. This uses an approach suggested by Linus, where we can hold partial ranges inside the pages[] map. Hopefully this will be useful for network receive support as well. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-21[IA64] Setup an IA64 specific reclaim distanceChristoph Lameter
RECLAIM_DISTANCE is checked on bootup against the SLIT table distances. Zone reclaim is important for system that have higher latencies but not for systems that have multiple nodes on one motherboard and therefore low latencies. We found that on motherboard latencies are typically 1 to 1.4 of local memory access speed whereas multinode systems which benefit from zone reclaim have usually more than 1.5 times the latency of a local access. Set the reclaim distance for IA64 to 1.5 times. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-20[IA64] eliminate compile time warningsSatoru Takeuchi
This patch removes following compile time warnings: drivers/pci/pci-sysfs.c: In function `pci_read_legacy_io': drivers/pci/pci-sysfs.c:257: warning: implicit declaration of function `ia64_pci_legacy_read' drivers/pci/pci-sysfs.c: In function `pci_write_legacy_io': drivers/pci/pci-sysfs.c:280: warning: implicit declaration of function `ia64_pci_legacy_write' It also fixes wrong definition of ia64_pci_legacy_write (type of `bus' is not `pci_dev', but `pci_bus'). Signed-Off-By: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-20[IA64-SGI] SN SAL call to inject memory errorsRuss Anderson
The SGI Altix SAL provides an interface for modifying the ECC on memory to create memory errors. The SAL call can be used to inject memory errors for testing MCA recovery code. Signed-off-by: Russ Anderson (rja@sgi.com) Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-20[IA64] - Fix MAX_PXM_DOMAINS for systems with > 256 nodesJack Steiner
Correctly size the PXM-related arrays for systems that have more than 256 nodes. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-20[IA64] Remove unused variable in sn_sal.hRuss Anderson
cnodeid was being set but not used. The dead code was left over from a previous version that grabbed a per node lock. Signed-off-by: Russ Anderson (rja@sgi.com) Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-11[PATCH] splice: add support for sys_tee()Jens Axboe
Basically an in-kernel implementation of tee, which uses splice and the pipe buffers as an intelligent way to pass data around by reference. Where the user space tee consumes the input and produces a stdout and file output, this syscall merely duplicates the data inside a pipe to another pipe. No data is copied, the output just grabs a reference to the input pipe data. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-11Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Prefetch mmap_sem in ia64_do_page_fault() [IA64] Failure to resume after INIT in user space [IA64] Pass more data to the MCA/INIT notify_die hooks [IA64] always map VGA framebuffer UC, even if it supports WB [IA64] fix bug in ia64 __mutex_fastpath_trylock [IA64] for_each_possible_cpu: ia64 [IA64] update HP CSR space discovery via ACPI [IA64] Wire up new syscalls {set,get}_robust_list [IA64] 'msg' may be used uninitialized in xpc_initiate_allocate() [IA64] Wire up new syscall sync_file_range()
2006-04-11[PATCH] Configurable NODES_SHIFTYasunori Goto
Current implementations define NODES_SHIFT in include/asm-xxx/numnodes.h for each arch. Its definition is sometimes configurable. Indeed, ia64 defines 5 NODES_SHIFT values in the current git tree. But it looks a bit messy. SGI-SN2(ia64) system requires 1024 nodes, and the number of nodes already has been changeable by config. Suitable node's number may be changed in the future even if it is other architecture. So, I wrote configurable node's number. This patch set defines just default value for each arch which needs multi nodes except ia64. But, it is easy to change to configurable if necessary. On ia64 the number of nodes can be already configured in generic ia64 and SN2 config. But, NODES_SHIFT is defined for DIG64 and HP'S machine too. So, I changed it so that all platforms can be configured via CONFIG_NODES_SHIFT. It would be simpler. See also: http://marc.theaimsgroup.com/?l=linux-kernel&m=114358010523896&w=2 Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jack Steiner <steiner@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-07[IA64] Pass more data to the MCA/INIT notify_die hooksKeith Owens
The MCA/INIT handlers maintain important state in the SAL to OS (sos) area and in the monarch_cpu flag. Kernel debuggers (such as KDB) need this data, and may need to adjust the monarch_cpu field so make the data available to the notify_die hooks. Define two more events for calling the functions on the notify_die chain. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-07[IA64] always map VGA framebuffer UC, even if it supports WBBjorn Helgaas
EFI on some machines, e.g., Intel Tiger, reports that the VGA framebuffer supports WB access. ioremap() prefers WB when possible, so it can work when mapping main memory. But it doesn't make sense to map a framebuffer WB, because the driver doesn't flush explicitly, so updates won't make it to the device immediately. This is due to Zou Nan hai <nanhai.zou@intel.com>. More extensive fix that adds a "size" argument coming soon. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-07[IA64] fix bug in ia64 __mutex_fastpath_trylockChen, Kenneth W
The parenthesis around "likely" used in ia64 __mutex_fastpath_trylock is incorrect, and it leads to broken mutex_trylock. Here is the patch that fixed the bug. I removed the likely altogether because there is no branch and gcc does a reasonable job at predicating the return value. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-06[IA64] update HP CSR space discovery via ACPIBjorn Helgaas
Get rid of the manual search of _CRS, in favor of acpi_get_vendor_resource() which is now provided by the ACPI CA. And fall back to searching for a consumer-only address space descriptor if no vendor-defined resource is found. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-06[IA64] Wire up new syscalls {set,get}_robust_listTony Luck
Join the dots to enable Ingo's robut futex syscalls. Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-04-04[IA64] Wire up new syscall sync_file_range()Tony Luck
Also reserve syscall numbers for {set,get}_robust_list Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-31[IA64] Avoid "u64 foo : 32;" for gcc3 vs. gcc4 compatibilityTony Luck
gcc3 thinks that a 32-bit field of a u64 type is itself a u64, so should be printed with "%ld". gcc4 thinks it needs just "%d". Make both versions happy by avoiding this construct. Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-30[IA64] Export cpu cache info by sysfsZhang, Yanmin
The patch exports 8 attributes of cpu cache info under /sys/devices/system/cpu/cpuX/cache/indexX: 1) level 2) type 3) coherency_line_size 4) ways_of_associativity 5) size 6) shared_cpu_map 7) attributes 8) number_of_sets: number_of_sets=size/ways_of_associativity/coherency_line_size. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] ioremap() should prefer WB over UC [IA64] Add __mca_table to the DISCARD list in gate.lds [IA64] Move __mca_table out of the __init section [IA64] simplify some condition checks in iosapic_check_gsi_range [IA64] correct some messages and fixes some minor things [IA64-SGI] fix for-loop in sn_hwperf_geoid_to_cnode() [IA64-SGI] sn_hwperf use of num_online_cpus() [IA64] optimize flush_tlb_range on large numa box [IA64] lazy_mmu_prot_update needs to be aware of huge pages
2006-03-30[PATCH] Introduce sys_splice() system callJens Axboe
This adds support for the sys_splice system call. Using a pipe as a transport, it can connect to files or sockets (latter as output only). From the splice.c comments: "splice": joining two ropes together by interweaving their strands. This is the "extended pipe" functionality, where a pipe is used as an arbitrary in-memory buffer. Think of a pipe as a small kernel buffer that you can use to transfer data from one end to the other. The traditional unix read/write is extended with a "splice()" operation that transfers data buffers to or from a pipe buffer. Named by Larry McVoy, original implementation from Linus, extended by Jens to support splicing to files and fixing the initial implementation bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[IA64] Add __mca_table to the DISCARD list in gate.ldsJes Sorensen
Add __mca_table to the DISCARD list for the gate.lds linker script to avoid broken linker references when linking the final vmlinux file. Also add comment to include/asm-ia64/asmmacros.h to avoid anyone else hitting this problem in the future. Credits to James Bottomley <James.Bottomley@SteelEye.com> for spotting the DISCARD list in gate.lds.S Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] ia64: add ptr_to_compat()Ingo Molnar
Add ptr_to_compat() to ia64 - needed by the robust-futex code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] unify pfn_to_page: ia64 pfn_to_pageKAMEZAWA Hiroyuki
ia64 has special config CONFIG_VIRTUAL_MEM_MAP. CONFIG_DISCONTIGMEM=y && CONFIG_VIRTUAL_MEM_MAP!=y is bug ? Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: ia64: use generic bitopsAkinobu Mita
- remove generic_fls64() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove sched_find_first_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: use non atomic operations for minix_*_bit() and ext2_*_bit()Akinobu Mita
Bitmap functions for the minix filesystem and the ext2 filesystem except ext2_set_bit_atomic() and ext2_clear_bit_atomic() do not require the atomic guarantees. But these are defined by using atomic bit operations on several architectures. (cris, frv, h8300, ia64, m32r, m68k, m68knommu, mips, s390, sh, sh64, sparc, sparc64, v850, and xtensa) This patch switches to non atomic bit operation. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EFI: keep physical table addresses in efi structureBjorn Helgaas
Almost all users of the table addresses from the EFI system table want physical addresses. So rather than doing the pa->va->pa conversion, just keep physical addresses in struct efi. This fixes a DMI bug: the efi structure contained the physical SMBIOS address on x86 but the virtual address on ia64, so dmi_scan_machine() used ioremap() on a virtual address on ia64. This is essentially the same as an earlier patch by Matt Tolentino: http://marc.theaimsgroup.com/?l=linux-kernel&m=112130292316281&w=2 except that this changes all table addresses, not just ACPI addresses. Matt's original patch was backed out because it caused MCAs on HP sx1000 systems. That problem is resolved by the ioremap() attribute checking added for ia64. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] ia64: ioremap: check EFI for valid memory attributesBjorn Helgaas
Check the EFI memory map so we can use the correct memory attributes for ioremap(). Previously, we always used uncacheable access, which blows up on some machines for regular system memory. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EFI, /dev/mem: simplify efi_mem_attribute_range()Bjorn Helgaas
Pass the size, not a pointer to the size, to efi_mem_attribute_range(). This function validates memory regions for the /dev/mem read/write/mmap paths. The pointer allows arches to reduce the size of the range, but I think that's unnecessary complexity. Simplifying it will let me use efi_mem_attribute_range() to improve the ia64 ioremap() implementation. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] ia64: use i386 dmi_scan.cMatt Domsch
Enable DMI table parsing on ia64. Andi Kleen has a patch in his x86_64 tree which enables the use of i386 dmi_scan.c on x86_64. dmi_scan.c functions are being used by the drivers/char/ipmi/ipmi_si_intf.c driver for autodetecting the ports or memory spaces where the IPMI controllers may be found. This patch adds equivalent changes for ia64 as to what is in the x86_64 tree. In addition, I reworked the DMI detection, such that on EFI-capable systems, it uses the efi.smbios pointer to find the table, rather than brute-force searching from 0xF0000. On non-EFI systems, it continues the brute-force search. My test system, an Intel S870BN4 'Tiger4', aka Dell PowerEdge 7250, with latest BIOS, does not list the IPMI controller in the ACPI namespace, nor does it have an ACPI SPMI table. Also note, currently shipping Dell x8xx EM64T servers don't have these either, so DMI is the only method for obtaining the address of the IPMI controller. Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] New IA64 core/thread detection patch [IA64] Increase max node count on SN platforms [IA64] Increase max node count on SN platforms [IA64] Increase max node count on SN platforms [IA64] Increase max node count on SN platforms [IA64] Tollhouse HP: IA64 arch changes [IA64] cleanup dig_irq_init [IA64] MCA recovery: kernel context recovery table IA64: Use early_parm to handle mvec_name and nomca [IA64] move patchlist and machvec into init section [IA64] add init declaration - nolwsys [IA64] add init declaration - gate page functions [IA64] add init declaration to memory initialization functions [IA64] add init declaration to cpu initialization functions [IA64] add __init declaration to mca functions [IA64] Ignore disabled Local SAPIC Affinity Structure in SRAT [IA64] sn_check_intr: use ia64_get_irr() [IA64] fix ia64 is_hugepage_only_range
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[IA64] New IA64 core/thread detection patchFenghua Yu
IPF SDM 2.2 changes definition of PAL_LOGICAL_TO_PHYSICAL to add proc_number=-1 to get core/thread mapping info on the running processer. Based on this change, we had better to update existing core/thread detection in IA64 kernel correspondingly. The attached patch implements this change. It simplifies detection code and eliminates potential race condition. It also runs a bit faster and has better scalability especially when cores and threads number grows up in one package. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24[IA64] Increase max node count on SN platformsJack Steiner
Node number are kept in the cpu_to_node_map which is currently defined as u8. Change to u16 to accomodate larger node numbers. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
Add support in IA64 acpi for platforms that support more than 256 nodes. Currently, ACPI is limited to 256 nodes because the proximity domain number is 8-bits. Long term, we expect to use ACPI3.0 to support >256 nodes. This patch is an interim solution that works with platforms that pass the high order bits of the proximity domain in "reserved" fields of the ACPI tables. This code is enabled ONLY on SN platforms. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
Add a configuration option to allow the maximum number of nodes to be configurable for GENERIC or SN kernels. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24[IA64] Tollhouse HP: IA64 arch changesPrarit Bhargava
arch/ia64/sn and include/asm-ia64/sn changes required to support Tollhouse system PCI hotplug, fixes the ia64_sn_sysctl_ioboard_get call, and introduces the PRF_HOTPLUG_SUPPORT feature bit. Signed-off-by: Prarit Bhargava <prarit@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24[IA64] cleanup dig_irq_initChen, Kenneth W
dig_irq_init is equivalent to machvec_noop, no need to define another empty function. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24[IA64] MCA recovery: kernel context recovery tableRuss Anderson
Memory errors encountered by user applications may surface when the CPU is running in kernel context. The current code will not attempt recovery if the MCA surfaces in kernel context (privilage mode 0). This patch adds a check for cases where the user initiated the load that surfaces in kernel interrupt code. An example is a user process lauching a load from memory and the data in memory had bad ECC. Before the bad data gets to the CPU register, and interrupt comes in. The code jumps to the IVT interrupt entry point and begins execution in kernel context. The process of saving the user registers (SAVE_REST) causes the bad data to be loaded into a CPU register, triggering the MCA. The MCA surfaces in kernel context, even though the load was initiated from user context. As suggested by David and Tony, this patch uses an exception table like approach, puting the tagged recovery addresses in a searchable table. One difference from the exception table is that MCAs do not surface in precise places (such as with a TLB miss), so instead of tagging specific instructions, address ranges are registers. A single macro is used to do the tagging, with the input parameter being the label of the starting address and the macro being the ending address. This limits clutter in the code. This patch only tags one spot, the interrupt ivt entry. Testing showed that spot to be a "heavy hitter" with MCAs surfacing while saving user registers. Other spots can be added as needed by adding a single macro. Signed-off-by: Russ Anderson (rja@sgi.com) Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24[PATCH] abstract type/size specification for assemblyJan Beulich
Provide abstraction for generating type and size information of assembly routines and data, while permitting architectures to override these defaults. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: "Russell King" <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Andi Kleen" <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s/;;/;/gAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] kill include/linux/platform.h, default_idle() cleanupAdrian Bunk
include/linux/platform.h contained nothing that was actually used except the default_idle() prototype, and is therefore removed by this patch. This patch does the following with the platform specific default_idle() functions on different architectures: - remove the unused function: - parisc - sparc64 - make the needlessly global function static: - arm - h8300 - m68k - m68knommu - s390 - v850 - x86_64 - add a prototype in asm/system.h: - cris - i386 - ia64 Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Patrick Mochel <mochel@digitalimplant.org> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] atomic: add_unless cmpxchg optimiseNick Piggin
Without branch hints, the very unlikely chance of the loop repeating due to cmpxchg failure is unrolled with gcc-4 that I have tested. Improve this for architectures with a native cas/cmpxchg. llsc archs should try to implement this natively. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Andi Kleen <ak@muc.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Move read_mostly definition to asm/cache.hKyle McMartin
Seems like needless clutter having a bunch of #if defined(CONFIG_$ARCH) in include/linux/cache.h. Move the per architecture section definition to asm/cache.h, and keep the if-not-defined dummy case in linux/cache.h to catch architectures which don't implement the section. Verified that symbols still go in .data.read_mostly on parisc, and the compile doesn't break. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
