path: root/include/asm-ia64
2008-04-30signals: ia64 renumber TIF_RESTORE_SIGMASKakpm@linux-foundation.org
TIF_RESTORE_SIGMASK no longer needs to be in the _TIF_WORK_* masks. Those low bits are scarce. Renumber TIF_RESTORE_SIGMASK to free one up. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29[IA64] Provide ACPI fixup for /proc/cpuinfo/physical_idAlex Chiang
Legacy HP ia64 platforms currently cannot provide /proc/cpuinfo/physical_id due to legacy SAL/PAL implementations. However, that physical topology information can be obtained via ACPI. Provide an interface that gives ACPI one last chance to provide physical_id for these legacy platforms. This logic only comes into play iff: - ACPI actually provides slot information for the CPU - we lack a valid socket_id Otherwise, we don't do anything. Since x86 uses the ACPI processor driver as well, we provide a nop stub function for arch_fix_phys_package_id() in asm-x86/topology.h Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-29[IA64] allocate multiple contiguous pages via uncached allocatorDean Nelson
Enable the uncached allocator to allocate multiple pages of contiguous uncached memory. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-29kernel: Move arches to use common unaligned accessHarvey Harrison
Unaligned access is ok for the following arches: cris, m68k, mn10300, powerpc, s390, x86 Arches that use the memmove implementation for native endian, and the byteshifting for the opposite endianness. h8300, m32r, xtensa Packed struct for native endian, byteshifting for other endian: alpha, blackfin, ia64, parisc, sparc, sparc64, mips, sh m86knommu is generic_be for Coldfire, otherwise unaligned access is ok. frv, arm chooses endianness based on compiler settings, uses the byteshifting versions. Remove the unaligned trap handler from frv as it is now unused. v850 is le, uses the byteshifting versions for both be and le. Remove the now unused asm-generic implementation. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29dma/ia64: update ia64 machvecs, swiotlb.cArthur Kepner
Change all ia64 machvecs to use the new dma_*map*_attrs() interfaces. Implement the old dma_*map_*() interfaces in terms of the corresponding new interfaces. For ia64/sn, make use of one dma attribute, DMA_ATTR_WRITE_BARRIER. Introduce swiotlb_*map*_attrs() functions. Signed-off-by: Arthur Kepner <akepner@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jes Sorensen <jes@sgi.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fix ia64 local_irq_save() et.al.Al Viro
psr is not a good name for local variable in macro body when it has a good chance of being the argument of said macro (actually is at least in one place) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28hugetlbfs: common code update for s390Gerald Schaefer
Huge ptes have a special type on s390 and cannot be handled with the standard pte functions in certain cases, e.g. because of a different location of the invalid bit. This patch adds some new architecture- specific functions to hugetlb common code, as a prerequisite for the s390 large page support. This won't affect other architectures in functionality, but I need to add some new dummy inline functions to the headers. Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28hugetlbfs: add missing TLB flush to hugetlb_cow()Gerald Schaefer
A cow break on a hugetlbfs page with page_count > 1 will set a new pte with set_huge_pte_at(), w/o any tlb flush operation. The old pte will remain in the tlb and subsequent write access to the page will result in a page fault loop, for as long as it may take until the tlb is flushed from somewhere else. This patch introduces an architecture-specific huge_ptep_clear_flush() function, which is called before the the set_huge_pte_at() in hugetlb_cow(). ATTENTION: This is just a nop on all architectures for now, the s390 implementation will come with our large page patch later. Other architectures should define their own huge_ptep_clear_flush() if needed. Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28hugetlbfs: architecture header cleanupGerald Schaefer
This patch moves all architecture functions for hugetlb to architecture header files (include/asm-foo/hugetlb.h) and converts all macros to inline functions. It also removes (!) ARCH_HAS_HUGEPAGE_ONLY_RANGE, ARCH_HAS_HUGETLB_FREE_PGD_RANGE, ARCH_HAS_PREPARE_HUGEPAGE_RANGE, ARCH_HAS_SETCLEAR_HUGE_PTE and ARCH_HAS_HUGETLB_PREFAULT_HOOK. Getting rid of the ARCH_HAS_xxx #ifdef and macro fugliness should increase readability and maintainability, at the price of some code duplication. An asm-generic common part would have reduced the loc, but we would end up with new ARCH_HAS_xxx defines eventually. Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27KVM: Rename VCPU_MP_STATE_* to KVM_MP_STATE_*Avi Kivity
We wish to export it to userspace, so move it into the kvm namespace. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Add header files for kvm/ia64Xiantao Zhang
Three header files are added: asm-ia64/kvm.h asm-ia64/kvm_host.h asm-ia64/kvm_para.h Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: ia64: Prepare some structure and routines for kvm useXiantao Zhang
Register structures are defined per SDM. Add three small routines for kernel: ia64_ttag, ia64_loadrs, ia64_flushrs Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-26generic: implement __fls on all 64-bit archsAlexander van Heukelum
Implement __fls on all 64-bit archs: alpha has an implementation of fls64. Added __fls(x) = fls64(x) - 1. ia64 has fls, but not __fls. Added __fls based on code of fls. mips and powerpc have __ilog2, which is the same as __fls. Added __fls = __ilog2. parisc, s390, sh and sparc64: Include generic __fls. x86_64 already has __fls. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-22[IA64] move XP and XPC to drivers/misc/sgi-xpDean Nelson
Move XPC and XPNET from arch/ia64/sn/kernel to drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-22[IA64] simplify notify hooks in mca.cHidetoshi Seto
There are many notify_die() and almost all take same style with ia64_mca_spin(). This patch defines macros and replace them all, to reduce lines and to improve readability. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-21Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Deprecate the asm/semaphore.h files in feature-removal-schedule. Convert asm/semaphore.h users to linux/semaphore.h security: Remove unnecessary inclusions of asm/semaphore.h lib: Remove unnecessary inclusions of asm/semaphore.h kernel: Remove unnecessary inclusions of asm/semaphore.h include: Remove unnecessary inclusions of asm/semaphore.h fs: Remove unnecessary inclusions of asm/semaphore.h drivers: Remove unnecessary inclusions of asm/semaphore.h net: Remove unnecessary inclusions of asm/semaphore.h arch: Remove unnecessary inclusions of asm/semaphore.h
2008-04-19sched, cpuset: customize sched domains, coreHidetoshi Seto
[rebased for sched-devel/latest] - Add a new cpuset file, having levels: sched_relax_domain_level - Modify partition_sched_domains() and build_sched_domains() to take attributes parameter passed from cpuset. - Fill newidle_idx for node domains which currently unused but might be required if sched_relax_domain_level become higher. - We can change the default level by boot option 'relax_domain_level='. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19asm-generic: add node_to_cpumask_ptr macroMike Travis
Create a simple macro to always return a pointer to the node_to_cpumask(node) value. This relies on compiler optimization to remove the extra indirection: #define node_to_cpumask_ptr(v, node) \ cpumask_t _##v = node_to_cpumask(node), *v = &_##v For those systems with a large cpumask size, then a true pointer to the array element can be used: #define node_to_cpumask_ptr(v, node) \ cpumask_t *v = &(node_to_cpumask_map[node]) A node_to_cpumask_ptr_next() macro is provided to access another node_to_cpumask value. The other change is to always include asm-generic/topology.h moving the ifdef CONFIG_NUMA to this same file. Note: there are no references to either of these new macros in this patch, only the definition. Based on 2.6.25-rc5-mm1 # alpha Cc: Richard Henderson <rth@twiddle.net> # fujitsu Cc: David Howells <dhowells@redhat.com> # ia64 Cc: Tony Luck <tony.luck@intel.com> # powerpc Cc: Paul Mackerras <paulus@samba.org> Cc: Anton Blanchard <anton@samba.org> # sparc Cc: David S. Miller <davem@davemloft.net> Cc: William L. Irwin <wli@holomorphy.com> # x86 Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-18include: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they (or some user of them) rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have to fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: (27 commits) [IA64] kdump: Add crash_save_vmcoreinfo for INIT [IA64] Fix NUMA configuration issue [IA64] Itanium Spec updates [IA64] Untangle sync_icache_dcache() page size determination [IA64] arch/ia64/kernel/: use time_* macros [IA64] remove redundant display of free swap space in show_mem() [IA64] make IOMMU respect the segment boundary limits [IA64] kprobes: kprobe-booster for ia64 [IA64] fix getpid and set_tid_address fast system calls for pid namespaces [IA64] Replace explicit jiffies tests with time_* macros. [IA64] use goto to jump out do/while_each_thread [IA64] Fix unlock ordering in smp_callin [IA64] pgd_offset() constfication. [IA64] kdump: crash.c coding style fix [IA64] kdump: add kdump_on_fatal_mca [IA64] Minimize per_cpu reservations. [IA64] Correct pernodesize calculation. [IA64] Kernel parameter for max number of concurrent global TLB purges [IA64] Multiple outstanding ptc.g instruction support [IA64] Implement smp_call_function_mask for ia64 ...
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (58 commits) ide: remove ide_init_default_irq() macro ide: move default IDE ports setup to ide_generic host driver ide: remove obsoleted "idex=noprobe" kernel parameter (take 2) ide: remove needless hwif->irq check from ide_hwif_configure() ide: init hwif->{io_ports,irq} explicitly in legacy VLB host drivers ide: limit legacy VLB host drivers to alpha, x86 and mips cmd640: init hwif->{io_ports,irq} explicitly cmd640: cleanup setup_device_ptrs() ide: add ide-4drives host driver (take 3) ide: remove ppc ifdef from init_ide_data() ide: remove ide_default_io_ctl() macro ide: remove CONFIG_IDE_ARCH_OBSOLETE_INIT ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2) ppc/pmac: remove no longer needed IDE quirk ppc: don't include <linux/ide.h> ppc: remove ppc_ide_md ppc/pplus: remove ppc_ide_md.ide_init_hwif hook ppc/sandpoint: remove ppc_ide_md hooks ppc/lopec: remove ppc_ide_md hooks ppc/mpc8xx: remove ppc_ide_md hooks ...
2008-04-18ide: remove ide_init_default_irq() macroBartlomiej Zolnierkiewicz
* Use ide_default_irq() instead of ide_init_default_irq() in ide_generic host driver (so the correct IRQ is always set regardless of CONFIG_PCI / CONFIG_BLK_DEV_IDEPCI). * Remove no longer needed ide_init_default_irq() macro. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove ide_default_io_ctl() macroBartlomiej Zolnierkiewicz
It is always == '((base) + 0x206)' if CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=y and it is not needed otherwise (arm, blackfin, parisc, ppc64, sh, sparc[64]). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2)Bartlomiej Zolnierkiewicz
* Add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS to drivers/ide/Kconfig and use it instead of defining IDE_ARCH_OBSOLETE_DEFAULTS in <arch/ide.h>. v2: * Define ide_default_irq() in ide-probe.c/ns87415.c if not already defined and drop defining ide_default_irq() for CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=n. [ Thanks to Stephen Rothwell and David Miller for noticing the problem. ] Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Miller <davem@davemloft.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Pull miscellaneous into release branchTony Luck
Conflicts: arch/ia64/kernel/mca.c
2008-04-17Pull nptcg into release branchTony Luck
Conflicts: arch/ia64/mm/tlb.c
2008-04-17Pull kvm-patches into release branchTony Luck
2008-04-17Pull percpureserve into release branchTony Luck
2008-04-17Pull regset into release branchTony Luck
2008-04-17Pull virt-cpu-accounting into release branchTony Luck
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-11[IA64] Fix NUMA configuration issueZoltan Menyhart
There is a NUMA memory configuration issue in 2.6.24: A 2-node machine of ours has got the following memory layout: Node 0: 0 - 2 Gbytes Node 0: 4 - 8 Gbytes Node 1: 8 - 16 Gbytes Node 0: 16 - 18 Gbytes "efi_memmap_init()" merges the three last ranges into one. "register_active_ranges()" is called as follows: efi_memmap_walk(register_active_ranges, NULL); i.e. once for the 4 - 18 Gbytes range. It picks up the node number from the start address, and registers all the memory for the node #0. "register_active_ranges()" should be called as follows to make sure there is no merged address range at its entry: efi_memmap_walk(filter_memory, register_active_ranges); "filter_memory()" is similar to "filter_rsvd_memory()", but the reserved memory ranges are not filtered out. Signed-off-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] Itanium Spec updatesRuss Anderson
Updates based on the "Intel® Itanium® Architecture Software Developer's Manual Specification Update October 2007". http://download.intel.com/design/itanium/specupdt/24869911.pdf Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] kprobes: kprobe-booster for ia64Masami Hiramatsu
Add kprobe-booster support on ia64. Kprobe-booster improves the performance of kprobes by eliminating single-step, where possible. Currently, kprobe-booster is implemented on x86 and x86-64. This is an ia64 port. On ia64, kprobe-booster executes a copied bundle directly, instead of single stepping. Bundles which have B or X unit and which may cause an exception (including break) are not executed directly. And also, to prevent hitting break exceptions on the copied bundle, only the hindmost kprobe is executed directly if several kprobes share a bundle and are placed in different slots. Note: set_brl_inst() is used for preparing an instruction buffer(it does not modify any active code), so it does not need any atomic operation. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: bibo,mao <bibo.mao@intel.com> Cc: Rusty Lynch <rusty.lynch@intel.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] pgd_offset() constfication.KOSAKI Motohiro
when compile 2.6.25-rc8-mm1, below warning happend. because walk_page_range pass argument as "const struct mm*", but pgd_offset() receive as "struct mm*". CC mm/pagewalk.o mm/pagewalk.c: In function 'walk_page_range': mm/pagewalk.c:111: warning: passing argument 1 of 'pgd_offset' discards qualifiers from pointer target type Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-08[IA64] Minimize per_cpu reservations.holt@sgi.com
This attached patch significantly shrinks boot memory allocation on ia64. It does this by not allocating per_cpu areas for cpus that can never exist. In the case where acpi does not have any numa node description of the cpus, I defaulted to assigning the first 32 round-robin on the known nodes.. For the !CONFIG_ACPI I used for_each_possible_cpu(). Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-04[IA64] Kernel parameter for max number of concurrent global TLB purgesFenghua Yu
The patch defines kernel parameter "nptcg=". The parameter overrides max number of concurrent global TLB purges which is reported from either PAL_VM_SUMMARY or SAL PALO. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-04[IA64] Multiple outstanding ptc.g instruction supportFenghua Yu
According to SDM2.2, Itanium supports multiple outstanding ptc.g instructions. But current kernel function ia64_global_tlb_purge() uses a spinlock to serialize ptc.g instructions issued by multiple processors. This serialization might have scalability issue on a big SMP machine where many processors could purge TLB in parallel. The patch fixes this problem by issuing multiple ptc.g instructions in ia64_global_tlb_purge(). It also adds support for the "PALO" table to get a platform view of the max number of outstanding ptc.g instructions (which may be different from the processor view found from PAL_VM_SUMMARY). PALO specification can be found at: http://www.dig64.org/home/DIG64_PALO_R1_0.pdf spinaphore implementation by Matthew Wilcox. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-03[IA64] Implement smp_call_function_mask for ia64Xiantao Zhang
This interface provides more flexible functionality for smp infrastructure ... e.g. KVM frequently needs to operate on a subset of cpus. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-03[IA64] Add API for allocating Dynamic TR resource.Xiantao Zhang
Dynamic TR resource should be managed in the uniform way. Add two interfaces for kernel: ia64_itr_entry: Allocate a (pair of) TR for caller. ia64_ptr_entry: Purge a (pair of ) TR by caller. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-12[IA64] use CORE_DUMP_USE_REGSETShaohua Li
After we have regset support, we can use CORE_DUMP_USE_REGSET. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-12[IA64] regset: 64-bit supportShaohua Li
This is the 64-bit regset implementation under IA64. Basically register read/write, which is derived from current ptrace register read/write. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-06[IA64] kprobes arch consolidation build fixHarvey Harrison
ia64 named their handler kprobes_fault_handler while all other arches used kprobe_fault_handler. Change the function definition and header declaration. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-05[IA64] remove duplicate code from arch_ptrace()Petr Tesarik
Remove all code which does exactly the same thing as ptrace_request(). Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-05[IA64] convert sys_ptrace to arch_ptracePetr Tesarik
Convert sys_ptrace() to arch_ptrace(). Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-03-04Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] fix ia64 kprobes compilation [IA64] move gcc_intrin.h from header-y to unifdef-y [IA64] workaround tiger ia64_sal_get_physical_id_info hang [IA64] move defconfig to arch/ia64/configs/ [IA64] Fix irq migration in multiple vector domain [IA64] signal(ia64_ia32): add a signal stack overflow check [IA64] signal(ia64): add a signal stack overflow check [IA64] CONFIG_SGI_SN2 - auto select NUMA and ACPI_NUMA
2008-03-04Kprobes: indicate kretprobe support in KconfigAnanth N Mavinakayanahalli
Add CONFIG_HAVE_KRETPROBES to the arch/<arch>/Kconfig file for relevant architectures with kprobes support. This facilitates easy handling of in-kernel modules (like samples/kprobes/kretprobe_example.c) that depend on kretprobes being present in the kernel. Thanks to Sam Ravnborg for helping make the patch more lean. Per Mathieu's suggestion, added CONFIG_KRETPROBES and fixed up dependencies. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04[IA64] fix ia64 kprobes compilationAdrian Bunk
This patch fixes the following compile error with a recent gcc: CC kernel/kprobes.o /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/kprobes.c:1066: error: __ksymtab_jprobe_return causes a section type conflict Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
