path: root/include/asm-i386
2006-07-14[PATCH] remove set_wmb - arch removalSteven Rostedt
set_wmb should not be used in the kernel because it just confuses the code more and has no benefit. Since it is not currently used in the kernel this patch removes it so that new code does not include it. All archs define set_wmb(var, value) to do { var = value; wmb(); } while(0) except ia64 and sparc which use a mb() instead. But this is still moot since it is not used anyway. Hasn't been tested on any archs but x86 and x86_64 (and only compiled tested) Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-13[PATCH] i386: system.h: remove extra semicolons and fix orderChuck Ebbert
include/asm-i386/system.h has trailing semicolons in some of the macros that cause legitimate code to fail compilation, so remove them. Also remove extra blank lines within one group of macros. And put stts() and clts() back together; they got separated somehow. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-09[PATCH] i386: use thread_info flags for debug regs and IO bitmapsStephane Eranian
Use thread info flags to track use of debug registers and IO bitmaps. - add TIF_DEBUG to track when debug registers are active - add TIF_IO_BITMAP to track when I/O bitmap is used - modify __switch_to() to use the new TIF flags Performance tested on Pentium II, ten runs of LMbench context switch benchmark (smaller is better:) before after avg 3.65 3.39 min 3.55 3.33 Signed-off-by: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-08i386: improve and correct inline asm memory constraintsLinus Torvalds
Use "+m" rather than a combination of "=m" and "m" for improved clarity and consistency. This also fixes some inlines that incorrectly didn't tell the compiler that they read the old value at all, potentially causing the compiler to generate bogus code. It appear that all of those potential bugs were hidden by the use of extra "volatile" specifiers on the data structures in question, though. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-04Merge git://git.infradead.org/hdrinstall-2.6Linus Torvalds
* git://git.infradead.org/hdrinstall-2.6: Remove export of include/linux/isdn/tpam.h Remove <linux/i2c-id.h> and <linux/i2c-algo-ite.h> from userspace export Restrict headers exported to userspace for SPARC and SPARC64 Add empty Kbuild files for 'make headers_install' in remaining arches. Add Kbuild file for Alpha 'make headers_install' Add Kbuild file for SPARC 'make headers_install' Add Kbuild file for IA64 'make headers_install' Add Kbuild file for S390 'make headers_install' Add Kbuild file for i386 'make headers_install' Add Kbuild file for x86_64 'make headers_install' Add Kbuild file for PowerPC 'make headers_install' Add generic Kbuild files for 'make headers_install' Basic implementation of 'make headers_check' Basic implementation of 'make headers_install'
2006-07-03[PATCH] lockdep: prove spinlock rwlock locking correctnessIngo Molnar
Use the lock validator framework to prove spinlock and rwlock locking correctness. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: prove rwsem locking correctnessIngo Molnar
Use the lock validator framework to prove rwsem locking correctness. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: irqtrace cleanup of include/asm-i386/irqflags.hIngo Molnar
Clean up the x86 irqflags.h file: - macro => inline function transformation - simplifications - style fixes Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: irqtrace subsystem, i386 supportIngo Molnar
Add irqflags-tracing support to i386. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: clean up rwsemsIngo Molnar
Clean up rwsems. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: i386: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] SMP alternatives: skip with UP kernelsGerd Hoffmann
Hide the magic in alternative.h and provide some dummy inline functions for the UP case (gcc should manage to optimize away these calls). No changes in module.c. Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[AF_UNIX]: Datagram getpeersecCatherine Zhang
This patch implements an API whereby an application can determine the label of its peer's Unix datagram sockets via the auxiliary data mechanism of recvmsg. Patch purpose: This patch enables a security-aware application to retrieve the security context of the peer of a Unix datagram socket. The application can then use this security context to determine the security context for processing on behalf of the peer who sent the packet. Patch design and implementation: The design and implementation is very similar to the UDP case for INET sockets. Basically we build upon the existing Unix domain socket API for retrieving user credentials. Linux offers the API for obtaining user credentials via ancillary messages (i.e., out of band/control messages that are bundled together with a normal message). To retrieve the security context, the application first indicates to the kernel such desire by setting the SO_PASSSEC option via getsockopt. Then the application retrieves the security context using the auxiliary data mechanism. An example server application for Unix datagram socket should look like this: toggle = 1; toggle_len = sizeof(toggle); setsockopt(sockfd, SOL_SOCKET, SO_PASSSEC, &toggle, &toggle_len); recvmsg(sockfd, &msg_hdr, 0); if (msg_hdr.msg_controllen > sizeof(struct cmsghdr)) { cmsg_hdr = CMSG_FIRSTHDR(&msg_hdr); if (cmsg_hdr->cmsg_len <= CMSG_LEN(sizeof(scontext)) && cmsg_hdr->cmsg_level == SOL_SOCKET && cmsg_hdr->cmsg_type == SCM_SECURITY) { memcpy(&scontext, CMSG_DATA(cmsg_hdr), sizeof(scontext)); } } sock_setsockopt is enhanced with a new socket option SOCK_PASSSEC to allow a server socket to receive security context of the peer. Testing: We have tested the patch by setting up Unix datagram client and server applications. We verified that the server can retrieve the security context using the auxiliary data mechanism of recvmsg. Signed-off-by: Catherine Zhang <cxzhang@watson.ibm.com> Acked-by: Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[PATCH] genirq: add ->retrigger() irq op to consolidate hw_irq_resend()Ingo Molnar
Add ->retrigger() irq op to consolidate hw_irq_resend() implementations. (Most architectures had it defined to NOP anyway.) NOTE: ia64 needs testing. i386 and x86_64 tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] fix sgivwfb compileAdrian Bunk
drivers/built-in.o: In function `sgivwfb_set_par': sgivwfb.c:(.text+0x88583): undefined reference to `sgivwfb_mem_phys' sgivwfb.c:(.text+0x88596): undefined reference to `sgivwfb_mem_phys' sgivwfb.c:(.text+0x885a8): undefined reference to `sgivwfb_mem_phys' drivers/built-in.o: In function `sgivwfb_check_var': sgivwfb.c:(.text+0x88ad0): undefined reference to `sgivwfb_mem_size' drivers/built-in.o: In function `sgivwfb_mmap': sgivwfb.c:(.text+0x88c75): undefined reference to `sgivwfb_mem_size' sgivwfb.c:(.text+0x88c7f): undefined reference to `sgivwfb_mem_phys' drivers/built-in.o: In function `sgivwfb_probe': sgivwfb.c:(.init.text+0x4060): undefined reference to `sgivwfb_mem_size' sgivwfb.c:(.init.text+0x4065): undefined reference to `sgivwfb_mem_phys' sgivwfb.c:(.init.text+0x4076): undefined reference to `sgivwfb_mem_phys' sgivwfb.c:(.init.text+0x409c): undefined reference to `sgivwfb_mem_size' sgivwfb.c:(.init.text+0x410e): undefined reference to `sgivwfb_mem_size' sgivwfb.c:(.init.text+0x4113): undefined reference to `sgivwfb_mem_phys' sgivwfb.c:(.init.text+0x4162): undefined reference to `sgivwfb_mem_size' sgivwfb.c:(.init.text+0x4168): undefined reference to `sgivwfb_mem_phys' make: *** [.tmp_vmlinux1] Error 1 Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] sched: mc/smt power savings sched policySiddha, Suresh B
sysfs entries 'sched_mc_power_savings' and 'sched_smt_power_savings' in /sys/devices/system/cpu/ control the MC/SMT power savings policy for the scheduler. Based on the values (1-enable, 0-disable) for these controls, sched groups cpu power will be determined for different domains. When power savings policy is enabled and under light load conditions, scheduler will minimize the physical packages/cpu cores carrying the load and thus conserving power(with a perf impact based on the workload characteristics... see OLS 2005 CMP kernel scheduler paper for more details..) Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Con Kolivas <kernel@kolivas.org> Cc: "Chen, Kenneth W" <kenneth.w.chen@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] vdso: randomize the i386 vDSO by moving it into a vmaIngo Molnar
Move the i386 VDSO down into a vma and thus randomize it. Besides the security implications, this feature also helps debuggers, which can COW a vma-backed VDSO just like a normal DSO and can thus do single-stepping and other debugging features. It's good for hypervisors (Xen, VMWare) too, which typically live in the same high-mapped address space as the VDSO, hence whenever the VDSO is used, they get lots of guest pagefaults and have to fix such guest accesses up - which slows things down instead of speeding things up (the primary purpose of the VDSO). There's a new CONFIG_COMPAT_VDSO (default=y) option, which provides support for older glibcs that still rely on a prelinked high-mapped VDSO. Newer distributions (using glibc 2.3.3 or later) can turn this option off. Turning it off is also recommended for security reasons: attackers cannot use the predictable high-mapped VDSO page as syscall trampoline anymore. There is a new vdso=[0|1] boot option as well, and a runtime /proc/sys/vm/vdso_enabled sysctl switch, that allows the VDSO to be turned on/off. (This version of the VDSO-randomization patch also has working ELF coredumping, the previous patch crashed in the coredumping code.) This code is a combined work of the exec-shield VDSO randomization code and Gerd Hoffmann's hypervisor-centric VDSO patch. Rusty Russell started this patch and i completed it. [akpm@osdl.org: cleanups] [akpm@osdl.org: compile fix] [akpm@osdl.org: compile fix 2] [akpm@osdl.org: compile fix 3] [akpm@osdl.org: revernt MAXMEM change] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Cc: Gerd Hoffmann <kraxel@suse.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Zachary Amsden <zach@vmware.com> Cc: Andi Kleen <ak@muc.de> Cc: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] i386: use C code for current_thread_info()Chuck Ebbert
Using C code for current_thread_info() lets the compiler optimize it. With gcc 4.0.2, kernel is smaller: text data bss dec hex filename 3645212 555556 312024 4512792 44dc18 2.6.17-rc6-nb-post/vmlinux 3647276 555556 312024 4514856 44e428 2.6.17-rc6-nb/vmlinux ------- -2064 Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] i386: move phys_proc_id and cpu_core_id to cpuinfo_x86Rohit Seth
Move the phys_core_id and cpu_core_id to cpuinfo_x86 structure. Similar patch for x86_64 is already accepted by Andi earlier this week. [akpm@osdl.org: fix warning] Signed-off-by: Rohit Seth <rohitseth@google.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] Register sysfs file for hotplugged new nodeYasunori Goto
When new node becomes enable by hot-add, new sysfs file must be created for new node. So, if new node is enabled by add_memory(), register_one_node() is called to create it. In addition, I386's arch_register_node() and a part of register_nodes() of powerpc are consolidated to register_one_node() as a generic_code(). This is tested by Tiger4(IPF) with node hot-plug emulation. Signed-off-by: Keiichiro Tokunaga <tokuanga.keiich@jp.fujitsu.com> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: typo fixes Clean up 'inline is not at beginning' warnings for usb storage Storage class should be first i386: Trivial typo fixes ixj: make ixj_set_tone_off() static spelling fixes fix paniced->panicked typos Spelling fixes for Documentation/atomic_ops.txt move acknowledgment for Mark Adler to CREDITS remove the bouncing email address of David Campbell
2006-06-26Merge branch 'x86-64'Linus Torvalds
* x86-64: (83 commits) [PATCH] x86_64: x86_64 stack usage debugging [PATCH] x86_64: (resend) x86_64 stack overflow debugging [PATCH] x86_64: msi_apic.c build fix [PATCH] x86_64: i386/x86-64 Add nmi watchdog support for new Intel CPUs [PATCH] x86_64: Avoid broadcasting NMI IPIs [PATCH] x86_64: fix apic error on bootup [PATCH] x86_64: enlarge window for stack growth [PATCH] x86_64: Minor string functions optimizations [PATCH] x86_64: Move export symbols to their C functions [PATCH] x86_64: Standardize i386/x86_64 handling of NMI_VECTOR [PATCH] x86_64: Fix modular pc speaker [PATCH] x86_64: remove sys32_ni_syscall() [PATCH] x86_64: Do not use -ffunction-sections for modules [PATCH] x86_64: Add cpu_relax to apic_wait_icr_idle [PATCH] x86_64: adjust kstack_depth_to_print default [PATCH] i386/x86-64: adjust /proc/interrupts column headings [PATCH] x86_64: Fix race in cpu_local_* on preemptible kernels [PATCH] x86_64: Fix fast check in safe_smp_processor_id [PATCH] x86_64: x86_64 setup.c - printing cmp related boottime information [PATCH] i386/x86-64/ia64: Move polling flag into thread_info_status ... Manual resolve of trivial conflict in arch/i386/kernel/Makefile
2006-06-26[PATCH] x86_64: i386/x86-64 Add nmi watchdog support for new Intel CPUsVenkatesh Pallipadi
Intel now has support for Architectural Performance Monitoring Counters ( Refer to IA-32 Intel Architecture Software Developer's Manual http://www.intel.com/design/pentium4/manuals/253669.htm ). This feature is present starting from Intel Core Duo and Intel Core Solo processors. What this means is, the performance monitoring counters and some performance monitoring events are now defined in an architectural way (using cpuid). And there will be no need to check for family/model etc for these architectural events. Below is the patch to use this performance counters in nmi watchdog driver. Patch handles both i386 and x86-64 kernels. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: Avoid broadcasting NMI IPIsKeith Owens
On some i386/x86_64 systems, sending an NMI IPI as a broadcast will reset the system. This seems to be a BIOS bug which affects machines where one or more cpus are not under OS control. It occurs on HT systems with a version of the OS that is not compiled without HT support. It also occurs when a system is booted with max_cpus=n where 2 <= n < cpus known to the BIOS. The fix is to always send NMI IPI as a mask instead of as a broadcast. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: Standardize i386/x86_64 handling of NMI_VECTORKeith Owens
x86_64 and i386 behave inconsistently when sending an IPI on vector 2 (NMI_VECTOR). Make both behave the same, so IPI 2 is sent as NMI. The crash code was abusing send_IPI_allbutself() by passing a code instead of a vector, it only worked because crash knew about the internal code of send_IPI_allbutself(). Change crash to use NMI_VECTOR instead, and remove the comment about how crash was abusing the function. This patch is a pre-requisite for fixing the problem where sending an IPI as NMI would reboot some Dell Xeon systems. I cannot fix that problem while crash continus to abuse send_IPI_allbutself(). It also removes the inconsistency between i386 and x86_64 for NMI_VECTOR. That will simplify all the RAS code that needs to bring all the cpus to a clean stop, even when one or more cpus are spinning disabled. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: Fix race in cpu_local_* on preemptible kernelsAndi Kleen
When a process changes CPUs while doing the non atomic cpu_local_* operations it might operate on the local_t of a different CPUs. Fix that by disabling preemption. Pointed out by Christopher Lameter Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] i386/x86-64/ia64: Move polling flag into thread_info_statusAndi Kleen
During some profiling I noticed that default_idle causes a lot of memory traffic. I think that is caused by the atomic operations to clear/set the polling flag in thread_info. There is actually no reason to make this atomic - only the idle thread does it to itself, other CPUs only read it. So I moved it into ti->status. Converted i386/x86-64/ia64 for now because that was the easiest way to fix ACPI which also manipulates these flags in its idle function. Cc: Nick Piggin <npiggin@novell.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] i386/x86-64: fall back to old-style call trace if no unwindingJan Beulich
If no unwinding is possible at all for a certain exception instance, fall back to the old style call trace instead of not showing any trace at all. Also, allow setting the stack trace mode at the command line. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] i386: reliable stack trace support i386 entry.SJan Beulich
To increase the usefulness of reliable stack unwinding, this adds CFI unwind annotations to many low-level i386 routines. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] i386: reliable stack trace support (i386)Jan Beulich
These are the i386-specific pieces to enable reliable stack traces. This is going to be even more useful once CFI annotations get added to he assembly code, namely to entry.S. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: nmi watchdog header cleanupDon Zickus
Misc header cleanup for nmi watchdog. Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: Clean and enhance up K8 northbridge access codeAndi Kleen
- Factor out the duplicated access/cache code into a single file * Shared between i386/x86-64. - Share flush code between AGP and IOMMU * Fix a bug: AGP didn't wait for end of flush before - Drop 8 northbridges limit and allocate dynamically - Add lock to serialize AGP and IOMMU GART flushes - Add PCI ID for next AMD northbridge - Random related cleanups The old K8 NUMA discovery code is unchanged. New systems should all use SRAT for this. Cc: "Navin Boppuri" <navin.boppuri@newisys.com> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: x86_64 version of the smp alternative patch.Gerd Hoffmann
Changes are largely identical to the i386 version: * alternative #define are moved to the new alternative.h file. * one new elf section with pointers to the lock prefixes which can be nop'ed out for non-smp. * two new elf sections simliar to the "classic" alternatives to replace SMP code with simpler UP code. * fixup headers to use alternative.h instead of defining their own LOCK / LOCK_PREFIX macros. The patch reuses the i386 version of the alternatives code to avoid code duplication. The code in alternatives.c was shuffled around a bit to reduce the number of #ifdefs needed. It also got some tweaks needed for x86_64 (vsyscall page handling) and new features (noreplacement option which was x86_64 only up to now). Debug printk's are changed from compile-time to runtime. Loosely based on a early version from Bastian Blank <waldi@debian.org> Signed-off-by: Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] i386/x86-64: Emulate CPUID4 on AMDAndi Kleen
Intel systems report the cache level data from CPUID 4 in sysfs. Add a CPUID 4 emulation for AMD CPUs to report the same information for them. This allows programs to read this information in a uniform way. The AMD way to report this is less flexible so some assumptions are hardcoded (e.g. no L3) Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Notify page fault call chainAnil S Keshavamurthy
With this patch Kprobes now registers for page fault notifications only when their is an active probe registered. Once all the active probes are unregistered their is no need to be notified of page faults and kprobes unregisters itself from the page fault notifications. Hence we will have ZERO side effects when no probes are active. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Notify page fault call chain for i386Anil S Keshavamurthy
Overloading of page fault notification with the notify_die() has performance issues(since the only interested components for page fault is kprobes and/or kdb) and hence this patch introduces the new notifier call chain exclusively for page fault notifications their by avoiding notifying unnecessary components in the do_page_fault() code path. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: i386 Conversion - part 3: Enable Generic Timekeepingjohn stultz
This converts the i386 arch to use the generic timeofday subsystem. It enabled the GENERIC_TIME option, disables the timer_opts code and other arch specific timekeeping code and reworks the delay code. While this patch enables the generic timekeeping, please note that this patch does not provide any i386 clocksource. Thus only the jiffies clocksource will be available. To get full replacements for the code being disabled here, the timeofday-clocks-i386 patch will needed. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: i386 Conversion - part 2: Rework TSC Supportjohn stultz
As part of the i386 conversion to the generic timekeeping infrastructure, this introduces a new tsc.c file. The code in this file replaces the TSC initialization, management and access code currently in timer_tsc.c (which will be removed) that we want to preserve. The code also introduces the following functionality: o tsc_khz: like cpu_khz but stores the TSC frequency on systems that do not change TSC frequency w/ CPU frequency o check/mark_tsc_unstable: accessor/modifier flag for TSC timekeeping usability o minor cleanups to calibration math. This patch also includes a one line __cpuinitdata fix from Zwane Mwaikambo. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[PATCH] Make copy_from_user_inatomic NOT zero the tail on i386NeilBrown
As described in a previous patch and documented in mm/filemap.h, copy_from_user_inatomic* shouldn't zero out the tail of the buffer after an incomplete copy. This patch implements that change for i386. For the _nocache version, a new __copy_user_intel_nocache is defined similar to copy_user_zeroio_intel_nocache, and this is ultimately used for the copy. For the regular version, __copy_from_user_ll_nozero is defined which uses __copy_user and __copy_user_intel - the later needs casts to reposition the __user annotations. If copy_from_user_atomic is given a constant length of 1, 2, or 4, then we do still zero the destintion on failure. This didn't seem worth the effort of fixing as the places where it is used really don't care. Signed-off-by: Neil Brown <neilb@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Prepare for __copy_from_user_inatomic to not zero missed bytesNeilBrown
The problem is that when we write to a file, the copy from userspace to pagecache is first done with preemption disabled, so if the source address is not immediately available the copy fails *and* *zeros* *the* *destination*. This is a problem because a concurrent read (which admittedly is an odd thing to do) might see zeros rather that was there before the write, or what was there after, or some mixture of the two (any of these being a reasonable thing to see). If the copy did fail, it will immediately be retried with preemption re-enabled so any transient problem with accessing the source won't cause an error. The first copying does not need to zero any uncopied bytes, and doing so causes the problem. It uses copy_from_user_atomic rather than copy_from_user so the simple expedient is to change copy_from_user_atomic to *not* zero out bytes on failure. The first of these two patches prepares for the change by fixing two places which assume copy_from_user_atomic does zero the tail. The two usages are very similar pieces of code which copy from a userspace iovec into one or more page-cache pages. These are changed to remove the assumption. The second patch changes __copy_from_user_inatomic* to not zero the tail. Once these are accepted, I will look at similar patches of other architectures where this is important (ppc, mips and sparc being the ones I can find). This patch: There is a problem with __copy_from_user_inatomic zeroing the tail of the buffer in the case of an error. As it is called in atomic context, the error may be transient, so it results in zeros being written where maybe they shouldn't be. In the usage in filemap, this opens a window for a well timed read to see data (zeros) which is not consistent with any ordering of reads and writes. Most cases where __copy_from_user_inatomic is called, a failure results in __copy_from_user being called immediately. As long as the latter zeros the tail, the former doesn't need to. However in *copy_from_user_iovec implementations (in both filemap and ntfs/file), it is assumed that copy_from_user_inatomic will zero the tail. This patch removes that assumption, so that after this patch it will be safe for copy_from_user_inatomic to not zero the tail. This patch also adds some commentary to filemap.h and asm-i386/uaccess.h. After this patch, all architectures that might disable preempt when kmap_atomic is called need to have their __copy_from_user_inatomic* "fixed". This includes - powerpc - i386 - mips - sparc Signed-off-by: Neil Brown <neilb@suse.de> Cc: David Howells <dhowells@redhat.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] random: remove SA_SAMPLE_RANDOM from floppy driverMatt Mackall
The floppy driver is already calling add_disk_randomness as it should, so this was redundant. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Clean up and refactor i386 sub-architecture setupJeremy Fitzhardinge
Clean up and refactor i386 sub-architecture setup. This change moves all the code from the asm-i386/mach-*/setup_arch_pre/post.h headers, into arch/i386/mach-*/setup.c. mach-*/setup_arch_pre.h is renamed to setup_arch.h, and contains only things which should be in header files. It is purely code-motion; there should be no functional changes at all. Several functions in arch/i386/kernel/setup.c needed to be made non-static so that they're visible to the code in mach-*/setup.c. asm-i386/setup.h is used to hold the prototypes for these functions. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Zachary Amsden <zach@vmware.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Christian Limpach <Christian.Limpach@cl.cam.ac.uk> Cc: Martin Bligh <mbligh@google.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Andrey Panin <pazke@donpac.ru> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (65 commits) ACPI: suppress power button event on S3 resume ACPI: resolve merge conflict between sem2mutex and processor_perflib.c ACPI: use for_each_possible_cpu() instead of for_each_cpu() ACPI: delete newly added debugging macros in processor_perflib.c ACPI: UP build fix for bugzilla-5737 Enable P-state software coordination via _PDC P-state software coordination for speedstep-centrino P-state software coordination for acpi-cpufreq P-state software coordination for ACPI core ACPI: create acpi_thermal_resume() ACPI: create acpi_fan_suspend()/acpi_fan_resume() ACPI: pass pm_message_t from acpi_device_suspend() to root_suspend() ACPI: create acpi_device_suspend()/acpi_device_resume() ACPI: replace spin_lock_irq with mutex for ec poll mode ACPI: Allow a WAN module enable/disable on a Thinkpad X60. sem2mutex: acpi, acpi_link_lock ACPI: delete unused acpi_bus_drivers_lock sem2mutex: drivers/acpi/processor_perflib.c ACPI add ia64 exports to build acpi_memhotplug as a module ACPI: asus_acpi_init(): propagate correct return value ... Manual resolve of conflicts in: arch/i386/kernel/cpu/cpufreq/acpi-cpufreq.c arch/i386/kernel/cpu/cpufreq/speedstep-centrino.c include/acpi/processor.h
2006-06-23[PATCH] x86: compile fix for asm-i386/alternatives.hKirill Smelkov
compile fix: <asm-i386/alternative.h> needs <asm/types.h> for 'u8' -- just look at struct alt_instr. My module includes <asm/bitops.h> as the first header, and as of 2.6.17 this leads to compilation errors. Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] x86: VIA C7 CPU flagsMichal Ludvig
New CPU flags for next generation of crypto engine as found in VIA C7 processors. Signed-off-by: Michal Ludvig <michal@logix.cz> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] x86: fix __range_ok constraintRoman Zippel
An immediate operand can't be the destination of the cmpl instruction, so exclude it. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Mattia Dongili <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Don't trigger full rebuild via CONFIG_X86_MCEAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Don't trigger full rebuild via CONFIG_MTRRAlexey Dobriyan
Only drm, framebuffer, mtrr parts + misc files here and there. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] arch/i386/kernel/apic.c: make modern_apic() staticAdrian Bunk
