path: root/include/asm-i386
2006-03-26[PATCH] x86: kprobes-boosterMasami Hiramatsu
Current kprobe copies the original instruction at the probe point and replaces it with a breakpoint instruction (int3). When the kernel hits the probe point, kprobe handler is invoked. And the copied instruction is single-step executed on the copied buffer (not on the original address) by kprobe. After that, the kprobe checks registers and modify it (if need) as if the instructions was executed on the original address. My proposal is based on the fact there are many instructions which do NOT require the register modification after the single-step execution. When the copied instruction is a kind of them, kprobe just jumps back to the next instruction after single-step execution. If so, why don't we execute those instructions directly? With kprobe-booster patch, kprobes will execute a copied instruction directly and (if need) jump back to original code. This direct execution is executed when the kprobe don't have both post_handler and break_handler, and the copied instruction can be executed directly. I sorted instructions which can be executed directly or not; - Call instructions are NG(can not be executed directly). We should correct the return address pushed into top of stack. - Indirect instructions except for absolute indirect-jumps are NG. Those instructions changes EIP randomly. We should check EIP and correct it. - Instructions that change EIP beyond the range of the instruction buffer are NG. - Instructions that change EIP to tail 5 bytes of the instruction buffer (it is the size of a jump instruction). We must write a jump instruction which backs to original kernel code in the instruction buffer. - Break point instruction is NG. We should not touch EIP and pass to other handlers. - Absolute direct/indirect jumps are OK.- Conditional Jumps are NG. - Halt and software-interruptions are NG. Because it will stay on the instruction buffer of kprobes. - Prefixes are NG. - Unknown/reserved opcode is NG. - Other 1 byte instructions are OK. But those instructions need a jump back code. - 2 bytes instructions are mapped sparsely. So, in this release, this patch don't boost those instructions. >From Intel's IA-32 opcode map described in IA-32 Intel Architecture Software Developer's Manual Vol.2 B, I determined that following opcodes are not boostable. - 0FH (2byte escape) - 70H - 7FH (Jump on condition) - 9AH (Call) and 9CH (Pushf) - C0H-C1H (Grp 2: includes reserved opcode) - C6H-C7H (Grp11: includes reserved opcode) - CCH-CEH (Software-interrupt) - D0H-D3H (Grp2: includes reserved opcode) - D6H (Reserved) - D8H-DFH (Coprocessor) - E0H-E3H (loop/conditional jump) - E8H (Call) - F0H-F3H (Prefixes and reserved) - F4H (Halt) - F6H-F7H (Grp3: includes reserved opcode) - FEH-FFH(Grp4,5: includes reserved opcode) Kprobe-booster checks whether target instruction can be boosted (can be executed directly) at arch_copy_kprobe() function. If the target instruction can be boosted, it clears "boostable" flag. If not, it sets "boostable" flag -1. This is disabled status. In resume_execution() function, If "boostable" flag is cleared, kprobe-booster measures the size of the target instruction and sets "boostable" flag 1. In kprobe_handler(), kprobe checks the "boostable" flag. If the flag is 1, it resets current kprobe and executes instruction buffer directly instead of single stepping. When unregistering a boosted kprobe, it calls synchronize_sched() after "int3" is removed. So we can ensure followings after the synchronize_sched() called. - interrupt handlers are finished on all CPUs. - instruction buffer is not executed on all CPUs. And we can release the boosted kprobe safely. And also, on preemptible kernel, the booster is not enabled where the kernel preemption is enabled. So, there are no preempted threads on the instruction buffer. The description of kretprobe-booster: ==================================== In the normal operation, kretprobe make a target function return to trampoline code. And a kprobe (called trampoline_probe) have been inserted at the trampoline code. When the kernel hits this kprobe, it calls kretprobe's handler and it returns to original return address. Kretprobe-booster patch removes the trampoline_probe. It allows the trampoline code to call kretprobe's handler directly instead of invoking kprobe. And tranpoline code returns to original return address. This new trampoline code stores and restores registers, so the kretprobe handler is still able to access those registers. Current kprobe has about 1.3 usec/probe(*) overhead, and kprobe-booster patch reduces it to 0.6 usec/probe(*). Also current kretprobe has about 2.0 usec/probe(*) overhead. Kprobe-booster patch reduces it to 1.3 usec/probe(*), and the combination of both kprobe-booster patch and kretprobe-booster patch reduces it to 0.9 usec/probe(*). I expect the combination of both patches can reduce half of a probing overhead. Performance numbers strongly depend on the processor model. Andrew Morton wrote: > These preempt tricks look rather nasty. Can you please describe what the > problem is, precisely? And how this code avoids it? Perhaps we can find > something cleaner. The problem is how to remove the copied instructions of the kprobe *safely* on the preemptable kernel (CONFIG_PREEMPT=y). Kprobes basically executes the following actions; (1)int3 (2)preempt_disable() (3)kprobe_prehandler() (4)copied instructioin(single step) (5)kprobe_posthandler() (6)preempt_enable() (7)return to the original code During the execution of copied instruction, preemption is disabled (from step (2) to (6)). When unregistering the probes, Kprobe waits for RCU quiescent state by using synchronize_sched() after removing int3 instruction. Thus we can ensure the copied instruction is not executed. On the other hand, kprobe-booster executes the following actions; (1)int3 (2)preempt_disable() (3)kprobe_prehandler() (4)preempt_enable() <-- this one is added by my patch (5)copied instruction(direct execution) (6)jmp back to the original code The problem is that we have no way to prevent preemption on step (5) or (6). We cannot call preempt_disable() after step (6), because there are no rooms to do that. Thus, some other processes may be preempted at step(5) or (6) on preemptable kernel. And I couldn't find the easy way to ensure that other processes' stack do *not* have the address of them. (I thought some way to do that, but those are very costly.) So currently, I simply boost the kprobe only when the probe point is already preemption disabled. > Also, the patch adds a preempt_enable() but I don't see a corresponding > preempt_disable(). Am I missing something? It is corresponding to the preempt_disable() in the top of kprobe_handler(). I copied the code of kprobe_handler() here: static int __kprobes kprobe_handler(struct pt_regs *regs) { struct kprobe *p; int ret = 0; kprobe_opcode_t *addr = NULL; unsigned long *lp; struct kprobe_ctlblk *kcb; /* * We don't want to be preempted for the entire * duration of kprobe processing */ preempt_disable(); <-- HERE kcb = get_kprobe_ctlblk(); Signed-off-by: Masami Hiramatsu <hiramatu@sdl.hitachi.co.jp> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 2TB files: add blkcnt_tTakashi Sato
Add blkcnt_t as the type of inode.i_blocks. This enables you to make the size of blkcnt_t either 4 bytes or 8 bytes on 32 bits architecture with CONFIG_LSF. - CONFIG_LSF Add new configuration parameter. - blkcnt_t On h8300, i386, mips, powerpc, s390 and sh that define sector_t, blkcnt_t is defined as u64 if CONFIG_LSF is enabled; otherwise it is defined as unsigned long. On other architectures, it is defined as unsigned long. - inode.i_blocks Change the type from sector_t to blkcnt_t. Signed-off-by: Takashi Sato <sho@tnes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 2TB files: st_blocks is invalid when calling stat64Takashi Sato
This patch series fixes the following problems on 32 bits architecture. o stat64 returns the lower 32 bits of blocks, although userland st_blocks has 64 bits, because i_blocks has only 32 bits. The ioctl with FIOQSIZE has the same problem. o As Dave Kleikamp said, making >2TB file on JFS results in writing an invalid block number to disk inode. The cause is the same as above too. o In generic quota code dquot_transfer(), the file usage is calculated from i_blocks via inode_get_bytes(). If the file is over 2TB, the change of usage is less than expected. The cause is the same as above too. o As Trond Myklebust said, statfs64's entries related to blocks are invalid on statfs64 for a network filesystem which has more than 2^32-1 blocks with CONFIG_LBD disabled. [PATCH 3/3] We made patches to fix problems that occur when handling a large filesystem and a large file. It was discussed on the mails titled "stat64 for over 2TB file returned invalid st_blocks". Signed-off-by: Takashi Sato <sho@tnes.nec.co.jp> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] x86_64: Implement early DMI scanningAndi Kleen
There are more and more cases where we need to know DMI information early to work around bugs. i386 already had early DMI scanning, but x86-64 didn't. Implement this now. This required some cleanup in the i386 code. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] kill include/linux/platform.h, default_idle() cleanupAdrian Bunk
include/linux/platform.h contained nothing that was actually used except the default_idle() prototype, and is therefore removed by this patch. This patch does the following with the platform specific default_idle() functions on different architectures: - remove the unused function: - parisc - sparc64 - make the needlessly global function static: - arm - h8300 - m68k - m68knommu - s390 - v850 - x86_64 - add a prototype in asm/system.h: - cris - i386 - ia64 Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Patrick Mochel <mochel@digitalimplant.org> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] remove ISA legacy functions: remove the helpersAl Viro
unused isa_...() helpers removed. Adrian Bunk: The asm-sh part was rediffed due to unrelated changes. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] atomic: add_unless cmpxchg optimiseNick Piggin
Without branch hints, the very unlikely chance of the loop repeating due to cmpxchg failure is unrolled with gcc-4 that I have tested. Improve this for architectures with a native cas/cmpxchg. llsc archs should try to implement this natively. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Andi Kleen <ak@muc.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Move read_mostly definition to asm/cache.hKyle McMartin
Seems like needless clutter having a bunch of #if defined(CONFIG_$ARCH) in include/linux/cache.h. Move the per architecture section definition to asm/cache.h, and keep the if-not-defined dummy case in linux/cache.h to catch architectures which don't implement the section. Verified that symbols still go in .data.read_mostly on parisc, and the compile doesn't break. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] x86: Make _syscallX() macros compile in PIC modeMarkus Gutschke
Gcc reserves %ebx when compiling position-independent-code on i386. This means, the _syscallX() macros in include/asm-i386/unistd.h will not compile. This patch is changes the existing macros to take special care to preserve %ebx. The bug can be tracked at http://bugzilla.kernel.org/show_bug.cgi?id=6204 Signed-off-by: Markus Gutschke <markus@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] i386 spinlocks: disable interrupts only if we enabled themChuck Ebbert
_raw_spin_lock_flags() is entered with interrupts disabled. If it cannot obtain a spinlock, it checks the flags that were passed and re-enables interrupts before spinning if that's how the flags are set. When the spinlock might be available, it disables interrupts (even if they are already disabled) before trying to get the lock. Change that so interrupts are only disabled if they have been enabled. This costs nine bytes of duplicated spinloop code. Fastpath before patch: jle <keep looping> not-taken conditional jump cli disable interrupts jmp <try for lock> unconditional jump Fastpath after patch, if interrupts were not enabled: jg <try for lock> taken conditional branch Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Fix the imlicit declaration of mtrr_centaur_report_mcr in ↵Jesper Juhl
arch/i386/kernel/cpu/centaur.c arch/i386/kernel/cpu/centaur.c: In function `centaur_mcr_insert': arch/i386/kernel/cpu/centaur.c:33: warning: implicit declaration of function `mtrr_centaur_report_mcr' Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] i386: fix uses of user_mode() vs. user_mode_vm()Jan Beulich
>commit 76381fee7e8feb4c22be636aa5d4765dbe4fbf9e >Author: Vincent Hanquez <vincent.hanquez@cl.cam.ac.uk> >Date: Thu Jun 23 00:08:46 2005 -0700 > > [PATCH] xen: x86_64: use more usermode macro > > Make use of the user_mode macro where it's possible. This is useful for Xen > because it will need only to redefine only the macro to a hypervisor call. I am of the opinion that the above changeset is incomplete, i.e. it missed converting some previous uses of user_mode to user_mode_vm. While most of them could be considered just cosmetical, at least the one in die_nmi doesn't appear to be. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Vincent Hanquez <vincent.hanquez@cl.cam.ac.uk> Cc: Zachary Amsden <zach@vmware.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] i386: actively synchronize vmalloc area when registering certain ↵Jan Beulich
callbacks Registering a callback handler through register_die_notifier() is obviously primarily intended for use by modules. However, the way these currently get called it is basically impossible for them to actually be used by modules, as there is, on non-PAE configurationes, a good chance (the larger the module, the better) for the system to crash as a result. This is because the callback gets invoked (a) in the page fault path before the top level page table propagation gets carried out (hence a fault to propagate the top level page table entry/entries mapping to module's code/data would nest infinitly) and (b) in the NMI path, where nested faults must absolutely not happen, since otherwise the IRET from the nested fault re-enables NMIs, potentially resulting in nested NMI occurences. Besides the modular aspect, similar problems would even arise for in- kernel consumers of the API if they touched ioremap()ed or vmalloc()ed memory inside their handlers. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] x86: early printk handling fixesStas Sergeev
The history is that -mm kernels do not work for me for a few months already. The things started from crashing somewhere after starting init, and for the last month - no boot at all, just "Uncompressing... OK, booting kernel", and silence. Early console didn't work too. With the latest releases this degraded into an infinite stream of the "Unknown interrupt or fault" messages. So today my patience ran out and I started to think how can I collect at least some info for the bug-report. Attached is the patch that allows to gather some valueable debug info on the problem by making an early console more useable. I can't properly test the patch, as the kernel still doesn't boot, so I'll explain it in details in a hope someone else can justify the intrusive changes. arch_hooks.h: added prototypes for setup_early_printk() and early_printk(). setup.c: killed wrong setup_early_printk() prototype. Moved setup_early_printk() a bit earlier, as it was not "early enough" to cover the bug I was fighting with. early_printk.c: made it to start printing from the bottom of the screen, otherwise the messages interfere with the ones of the boot-loader, so you can't read them. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Cc: Andi Kleen <ak@muc.de> Cc: Zwane Mwaikambo <zwane@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] i386: remove duplicate declaration of mp_bus_id_to_pci_busChris Wright
mp_bus_id_to_pci_bus is declared identically twice. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Compilation fix for ES7000 when no ACPI is specified in config (i386)Natalie.Protasevich@unisys.com
ES7000 platform code clean up for compilation errors and a warning. Ifdef'd the ACPI related parts in the ES7000 platform code. They were causing compile errors in certain configuration (without ACPI defined). I think this approach would be best (as opposed to Kconfig changes) since it only touches the subarch... Signed-off-by: <Natalie.Protasevich@unisys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] i386: Add a temporary to make put_user more type safeEric W. Biederman
In some code I am developing I had occasion to change the type of a variable. This made the value put_user was putting to user space wrong. But the code continued to build cleanly without errors. Introducing a temporary fixes this problem and at least with gcc-3.3.5 does not cause gcc any problems with optimizing out the temporary. gcc-4.x using SSA internally ought to be even better at optimizing out temporaries, so I don't expect a temporary to become a problem. Especially because in all correct cases the types on both sides of the assignment to the temporary are the same. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] x86: SMP alternativesGerd Hoffmann
Implement SMP alternatives, i.e. switching at runtime between different code versions for UP and SMP. The code can patch both SMP->UP and UP->SMP. The UP->SMP case is useful for CPU hotplug. With CONFIG_CPU_HOTPLUG enabled the code switches to UP at boot time and when the number of CPUs goes down to 1, and switches to SMP when the number of CPUs goes up to 2. Without CONFIG_CPU_HOTPLUG or on non-SMP-capable systems the code is patched once at boot time (if needed) and the tables are released afterwards. The changes in detail: * The current alternatives bits are moved to a separate file, the SMP alternatives code is added there. * The patch adds some new elf sections to the kernel: .smp_altinstructions like .altinstructions, also contains a list of alt_instr structs. .smp_altinstr_replacement like .altinstr_replacement, but also has some space to save original instruction before replaving it. .smp_locks list of pointers to lock prefixes which can be nop'ed out on UP. The first two are used to replace more complex instruction sequences such as spinlocks and semaphores. It would be possible to deal with the lock prefixes with that as well, but by handling them as special case the table sizes become much smaller. * The sections are page-aligned and padded up to page size, so they can be free if they are not needed. * Splitted the code to release init pages to a separate function and use it to release the elf sections if they are unused. Signed-off-by: Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] Enable mprotect on huge pagesZhang, Yanmin
2.6.16-rc3 uses hugetlb on-demand paging, but it doesn_t support hugetlb mprotect. From: David Gibson <david@gibson.dropbear.id.au> Remove a test from the mprotect() path which checks that the mprotect()ed range on a hugepage VMA is hugepage aligned (yes, really, the sense of is_aligned_hugepage_range() is the opposite of what you'd guess :-/). In fact, we don't need this test. If the given addresses match the beginning/end of a hugepage VMA they must already be suitably aligned. If they don't, then mprotect_fixup() will attempt to split the VMA. The very first test in split_vma() will check for a badly aligned address on a hugepage VMA and return -EINVAL if necessary. From: "Chen, Kenneth W" <kenneth.w.chen@intel.com> On i386 and x86-64, pte flag _PAGE_PSE collides with _PAGE_PROTNONE. The identify of hugetlb pte is lost when changing page protection via mprotect. A page fault occurs later will trigger a bug check in huge_pte_alloc(). The fix is to always make new pte a hugetlb pte and also to clean up legacy code where _PAGE_PRESENT is forced on in the pre-faulting day. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] don't call check_acpi_pci() on x86 with ACPI disabledHerbert Poetzl
check_acpi_pci() is called from arch/i386/kernel/setup.c even if CONFIG_ACPI is not defined, but the code in include/asm/acpi.h doesn't provide it in this case. Signed-off-by: Herbert Pötzl <herbert@13thfloor.at> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08[PATCH] i386: port ATI timer fix from x86_64 to i386 IIAndi Kleen
ATI chipsets tend to generate double timer interrupts for the local APIC timer when both the 8254 and the IO-APIC timer pins are enabled. This is because they route it to both and the result is anded together and the CPU ends up processing it twice. This patch changes check_timer to disable the 8254 routing for interrupt 0. I think it would be safe on all chipsets actually (i tested it on a couple and it worked everywhere) and Windows seems to do it in a similar way, but to be conservative this patch only enables this mode on ATI (and adds options to enable/disable too) Ported over from a similar x86-64 change. I reused the ACPI earlyquirk infrastructure for the ATI bridge check, but tweaked it a bit to work even without ACPI. Inspired by a patch from Chuck Ebbert, but redone. Cc: Chuck Ebbert <76306.1226@compuserve.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] x86: fix broken SMP boot sequenceJames Bottomley
Recent GDT changes broke the SMP boot sequence if the booting CPU is numbered anything other than zero. There's also a subtle source of error in that the boot time CPU now uses cpu_gdt_table (which is actually the GDT for booting CPUs in head.S). This patch fixes both problems by making GDT descriptors themselves allocated from a per_cpu area and switching to them in cpu_init(), which now means that cpu_gdt_table is exclusively used for booting CPUs again. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Cc: Zachary Amsden <zach@vmware.com> Cc: Matt Tolentino <metolent@snoqualmie.dp.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] Kprobes causes NX protection fault on i686 SMPPrasanna S Panchamukhi
Fix a problem seen on i686 machine with NX support where the instruction could not be single stepped because of NX bit set on the memory pages allocated by kprobes module. This patch provides allocation of instruction solt so that the processor can execute the instruction from that location similar to x86_64 architecture. Thanks to Bibo and Masami for testing this patch. Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] i386: fix singlestepping though a syscallChuck Ebbert
Do not mask TIF_SINGLESTEP bit in _TIF_WORK_MASK. Masking this stopped do_notify_resume() from being called when it should have been. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[PATCH] add asm-generic/mman.hMichael S. Tsirkin
Make new MADV_REMOVE, MADV_DONTFORK, MADV_DOFORK consistent across all arches. The idea is to make it possible to use them portably even before distros include them in libc headers. Move common flags to asm-generic/mman.h Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] madvise MADV_DONTFORK/MADV_DOFORKMichael S. Tsirkin
Currently, copy-on-write may change the physical address of a page even if the user requested that the page is pinned in memory (either by mlock or by get_user_pages). This happens if the process forks meanwhile, and the parent writes to that page. As a result, the page is orphaned: in case of get_user_pages, the application will never see any data hardware DMA's into this page after the COW. In case of mlock'd memory, the parent is not getting the realtime/security benefits of mlock. In particular, this affects the Infiniband modules which do DMA from and into user pages all the time. This patch adds madvise options to control whether memory range is inherited across fork. Useful e.g. for when hardware is doing DMA from/into these pages. Could also be useful to an application wanting to speed up its forks by cutting large areas out of consideration. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Acked-by: Hugh Dickins <hugh@veritas.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] fix x86 topology export in sysfs for subarchitecturesJames Bottomley
The correct way to export hyperthreading based functions is to predicate them on CONFIG_X86_HT. Without this, the topology exporting patch breaks the build on all non-PC x86 subarchitectures. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] fstatat64 supportUlrich Drepper
The *at patches introduced fstatat and, due to inusfficient research, I used the newfstat functions generally as the guideline. The result is that on 32-bit platforms we don't have all the information needed to implement fstatat64. This patch modifies the code to pass up 64-bit information if __ARCH_WANT_STAT64 is defined. I renamed the syscall entry point to make this clear. Other archs will continue to use the existing code. On x86-64 the compat code is implemented using a new sys32_ function. this is what is done for the other stat syscalls as well. This patch might break some other archs (those which define __ARCH_WANT_STAT64 and which already wired up the syscall). Yet others might need changes to accomodate the compatibility mode. I really don't want to do that work because all this stat handling is a mess (more so in glibc, but the kernel is also affected). It should be done by the arch maintainers. I'll provide some stand-alone test shortly. Those who are eager could compile glibc and run 'make check' (no installation needed). The patch below has been tested on x86 and x86-64. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] unshare system call -v5: system call registration for i386JANAK DESAI
Registers system call for the i386 architecture. Signed-off-by: Janak Desai <janak@us.ibm.com> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] Fix "value computed is not used" compile warnings with gcc-4.1Takashi Iwai
Fix gcc4.1 compile warnings "value computed is not used" with set_current_state() and set_task_state() on i386/SMP and x86-64. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] Export cpu topology in sysfsZhang, Yanmin
The patch implements cpu topology exportation by sysfs. Items (attributes) are similar to /proc/cpuinfo. 1) /sys/devices/system/cpu/cpuX/topology/physical_package_id: represent the physical package id of cpu X; 2) /sys/devices/system/cpu/cpuX/topology/core_id: represent the cpu core id to cpu X; 3) /sys/devices/system/cpu/cpuX/topology/thread_siblings: represent the thread siblings to cpu X in the same core; 4) /sys/devices/system/cpu/cpuX/topology/core_siblings: represent the thread siblings to cpu X in the same physical package; To implement it in an architecture-neutral way, a new source file, driver/base/topology.c, is to export the 5 attributes. If one architecture wants to support this feature, it just needs to implement 4 defines, typically in file include/asm-XXX/topology.h. The 4 defines are: #define topology_physical_package_id(cpu) #define topology_core_id(cpu) #define topology_thread_siblings(cpu) #define topology_core_siblings(cpu) The type of **_id is int. The type of siblings is cpumask_t. To be consistent on all architectures, the 4 attributes should have deafult values if their values are unavailable. Below is the rule. 1) physical_package_id: If cpu has no physical package id, -1 is the default value. 2) core_id: If cpu doesn't support multi-core, its core id is 0. 3) thread_siblings: Just include itself, if the cpu doesn't support HT/multi-thread. 4) core_siblings: Just include itself, if the cpu doesn't support multi-core and HT/Multi-thread. So be careful when declaring the 4 defines in include/asm-XXX/topology.h. If an attribute isn't defined on an architecture, it won't be exported. Thank Nathan, Greg, Andi, Paul and Venki. The patch provides defines for i386/x86_64/ia64. Signed-off-by: Zhang, Yanmin <yanmin.zhang@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
2006-02-01[PATCH] VMSPLIT config optionsMark Lord
Enable selection of different user/kernel VM splits for i386, including an optimized mode for 1GB physical RAM, which gives the kernel a direct (non HIGHMEM) mapping to the entire 1GB rather than just the first 896MB. There is a similarly a similarly optimized mode for machines with exactly 2GB of physical RAM. This can speed up the kernel by avoiding having to create/destroy temporary HIGHMEM mappings, and by not having to include HIGHMEM support at all on such machines. The flip side is that there's less virtual addressing left for userspace in these alternatives, and some binary-only kernel modules may misbehave unless rebuilt with the same VMSPLIT option as the main kernel image. Original idea/patch from Jens Axboe, modified based on suggestions from Linus et al. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-24[ACPI] merge 3549 4320 4485 4588 4980 5483 5651 acpica asus fops pnpacpi ↵Len Brown
branches into release Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-18[PATCH] EDAC: core EDAC support codeAlan Cox
This is a subset of the bluesmoke project core code, stripped of the NMI work which isn't ready to merge and some of the "interesting" proc functionality that needs reworking or just has no place in kernel. It requires no core kernel changes except the added scrub functions already posted. The goal is to merge further functionality only after the core code is accepted and proven in the base kernel, and only at the point the upstream extras are really ready to merge. From: doug thompson <norsk5@xmission.com> This converts EDAC to sysfs and is the final chunk neccessary before EDAC has a stable user space API and can be considered for submission into the base kernel. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: doug thompson <norsk5@xmission.com> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] EDAC: atomic scrub operationsAlan Cox
EDAC requires a way to scrub memory if an ECC error is found and the chipset does not do the work automatically. That means rewriting memory locations atomically with respect to all CPUs _and_ bus masters. That means we can't use atomic_add(foo, 0) as it gets optimised for non-SMP This adds a function to include/asm-foo/atomic.h for the platforms currently supported which implements a scrub of a mapped block. It also adjusts a few other files include order where atomic.h is included before types.h as this now causes an error as atomic_scrub uses u32. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] Add pselect/ppoll system calls on i386David Woodhouse
Add the sys_pselect6() and sys_poll() calls to the i386 syscall table. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] Handle TIF_RESTORE_SIGMASK for i386David Howells
Handle TIF_RESTORE_SIGMASK as added by David Woodhouse's patch entitled: [PATCH] 2/3 Add TIF_RESTORE_SIGMASK support for arch/powerpc [PATCH] 3/3 Generic sys_rt_sigsuspend It does the following: (1) Declares TIF_RESTORE_SIGMASK for i386. (2) Invokes it over to do_signal() when TIF_RESTORE_SIGMASK is set. (3) Makes do_signal() support TIF_RESTORE_SIGMASK, using the signal mask saved in current->saved_sigmask. (4) Discards sys_rt_sigsuspend() from the arch, using the generic one instead. (5) Makes sys_sigsuspend() save the signal mask and set TIF_RESTORE_SIGMASK rather than attempting to fudge the return registers. (6) Makes sys_sigsuspend() return -ERESTARTNOHAND rather than looping intrinsically. (7) Makes setup_frame(), setup_rt_frame() and handle_signal() return 0 or -EFAULT rather than true/false to be consistent with the rest of the kernel. Due to the fact do_signal() is then only called from one place: (8) Makes do_signal() no longer have a return value is it was just being ignored; force_sig() takes care of this. (9) Discards the old sigmask argument to do_signal() as it's no longer necessary. (10) Makes do_signal() static. (11) Marks the second argument to do_notify_resume() as unused. The unused argument should remain in the middle as the arguments are passed in as registers, and the ordering is specific in entry.S Given the way do_signal() is now no longer called from sys_{,rt_}sigsuspend(), they no longer need access to the exception frame, and so can just take arguments normally. This patch depends on sys_rt_sigsuspend patch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] vfs: *at functions: i386Ulrich Drepper
Wire up the x86 syscalls Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: remove leftover from patch revertalPaolo 'Blaisorblade' Giarrusso
I added this line to share this file with UML, but now it's no longer shared so remove this useless leftover. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] mark several functions __always_inlineIngo Molnar
Arjan van de Ven <arjan@infradead.org> Mark a number of functions as 'must inline'. The functions affected by this patch need to be inlined because they use knowledge that their arguments are constant so that most of the function optimizes away. At this point this patch does not change behavior, it's for documentation only (and for future patches in the inline series) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] death of get_thread_info/put_thread_infoAl Viro
{get,put}_thread_info() were introduced in 2.5.4 and never had been called by anything in the tree. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] i386: task_stack_page()Al Viro
2006-01-12[PATCH] i386: fix task_pt_regs()akpm@osdl.org
) From: Al Viro <viro@ftp.linux.org.uk> task_pt_regs() needs the same offset-by-8 to match copy_thread() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] i386: task_thread_info()Al Viro
2006-01-12[PATCH] scheduler cache-hot-autodetectakpm@osdl.org
) From: Ingo Molnar <mingo@elte.hu> This is the latest version of the scheduler cache-hot-auto-tune patch. The first problem was that detection time scaled with O(N^2), which is unacceptable on larger SMP and NUMA systems. To solve this: - I've added a 'domain distance' function, which is used to cache measurement results. Each distance is only measured once. This means that e.g. on NUMA distances of 0, 1 and 2 might be measured, on HT distances 0 and 1, and on SMP distance 0 is measured. The code walks the domain tree to determine the distance, so it automatically follows whatever hierarchy an architecture sets up. This cuts down on the boot time significantly and removes the O(N^2) limit. The only assumption is that migration costs can be expressed as a function of domain distance - this covers the overwhelming majority of existing systems, and is a good guess even for more assymetric systems. [ People hacking systems that have assymetries that break this assumption (e.g. different CPU speeds) should experiment a bit with the cpu_distance() function. Adding a ->migration_distance factor to the domain structure would be one possible solution - but lets first see the problem systems, if they exist at all. Lets not overdesign. ] Another problem was that only a single cache-size was used for measuring the cost of migration, and most architectures didnt set that variable up. Furthermore, a single cache-size does not fit NUMA hierarchies with L3 caches and does not fit HT setups, where different CPUs will often have different 'effective cache sizes'. To solve this problem: - Instead of relying on a single cache-size provided by the platform and sticking to it, the code now auto-detects the 'effective migration cost' between two measured CPUs, via iterating through a wide range of cachesizes. The code searches for the maximum migration cost, which occurs when the working set of the test-workload falls just below the 'effective cache size'. I.e. real-life optimized search is done for the maximum migration cost, between two real CPUs. This, amongst other things, has the positive effect hat if e.g. two CPUs share a L2/L3 cache, a different (and accurate) migration cost will be found than between two CPUs on the same system that dont share any caches. (The reliable measurement of migration costs is tricky - see the source for details.) Furthermore i've added various boot-time options to override/tune migration behavior. Firstly, there's a blanket override for autodetection: migration_cost=1000,2000,3000 will override the depth 0/1/2 values with 1msec/2msec/3msec values. Secondly, there's a global factor that can be used to increase (or decrease) the autodetected values: migration_factor=120 will increase the autodetected values by 20%. This option is useful to tune things in a workload-dependent way - e.g. if a workload is cache-insensitive then CPU utilization can be maximized by specifying migration_factor=0. I've tested the autodetection code quite extensively on x86, on 3 P3/Xeon/2MB, and the autodetected values look pretty good: Dual Celeron (128K L2 cache): --------------------- migration cost matrix (max_cache_size: 131072, cpu: 467 MHz): --------------------- [00] [01] [00]: - 1.7(1) [01]: 1.7(1) - --------------------- cacheflush times [2]: 0.0 (0) 1.7 (1784008) --------------------- Here the slow memory subsystem dominates system performance, and even though caches are small, the migration cost is 1.7 msecs. Dual HT P4 (512K L2 cache): --------------------- migration cost matrix (max_cache_size: 524288, cpu: 2379 MHz): --------------------- [00] [01] [02] [03] [00]: - 0.4(1) 0.0(0) 0.4(1) [01]: 0.4(1) - 0.4(1) 0.0(0) [02]: 0.0(0) 0.4(1) - 0.4(1) [03]: 0.4(1) 0.0(0) 0.4(1) - --------------------- cacheflush times [2]: 0.0 (33900) 0.4 (448514) --------------------- Here it can be seen that there is no migration cost between two HT siblings (CPU#0/2 and CPU#1/3 are separate physical CPUs). A fast memory system makes inter-physical-CPU migration pretty cheap: 0.4 msecs. 8-way P3/Xeon [2MB L2 cache]: --------------------- migration cost matrix (max_cache_size: 2097152, cpu: 700 MHz): --------------------- [00] [01] [02] [03] [04] [05] [06] [07] [00]: - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) [01]: 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) [02]: 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) [03]: 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) [04]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) [05]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) [06]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) [07]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - --------------------- cacheflush times [2]: 0.0 (0) 19.2 (19281756) --------------------- This one has huge caches and a relatively slow memory subsystem - so the migration cost is 19 msecs. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Cc: <wilder@us.ibm.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] sched: add cacheflush() asmIngo Molnar
Add per-arch sched_cacheflush() which is a write-back cacheflush used by the migration-cost calibration code at bootup time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] i386: Replace broken serialize_cpu in microcode driver with correct ↵Andi Kleen
sync_core Passing random input values in eax to cpuid is not a good idea because the CPU will GPF for unknown ones. Use the correct x86-64 version that exists for a longer time too. This also adds a memory barrier to prevent the optimizer from reordering. Cc: tigran@veritas.com Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] i386: make pci_map_single/pci_map_sg warn for zero length.Andi Kleen
As suggested by Linus. This catches driver bugs that could cause corruption on IOMMU architectures. Also I converted the BUGs to out_of_line_bug()s to save a bit of text space. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
