path: root/include/asm-i386/pgtable.h
2006-10-01[PATCH] paravirt: update pte hookZachary Amsden
Add a pte_update_hook which notifies about pte changes that have been made without using the set_pte / clear_pte interfaces. This allows shadow mode hypervisors which do not trap on page table access to maintain synchronized shadows. It also turns out, there was one pte update in PAE mode that wasn't using any accessor interface at all for setting NX protection. Considering it is PAE specific, and the accessor is i386 specific, I didn't want to add a generic encapsulation of this behavior yet. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] paravirt: optimize ptep establish for paeZachary Amsden
The ptep_establish macro is only used on user-level PTEs, for P->P mapping changes. Since these always happen under protection of the pagetable lock, the strong synchronization of a 64-bit cmpxchg is not needed, in fact, not even a lock prefix needs to be used. We can simply instead clear the P-bit, followed by a normal set. The write ordering is still important to avoid the possibility of the TLB snooping a partially written PTE and getting a bad mapping installed. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] paravirt: kpte flushZachary Amsden
Create a new PTE function which combines clearing a kernel PTE with the subsequent flush. This allows the two to be easily combined into a single hypercall or paravirt-op. More subtly, reverse the order of the flush for kmap_atomic. Instead of flushing on establishing a mapping, flush on clearing a mapping. This eliminates the possibility of leaving stale kmap entries which may still have valid TLB mappings. This is required for direct mode hypervisors, which need to reprotect all mappings of a given page when changing the page type from a normal page to a protected page (such as a page table or descriptor table page). But it also provides some nicer semantics for real hardware, by providing extra debug-proofing against using stale mappings, as well as ensuring that no stale mappings exist when changing the cacheability attributes of a page, which could lead to cache conflicts when two different types of mappings exist for the same page. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] paravirt: combine flush accessed dirty.patchZachary Amsden
Remove ptep_test_and_clear_{dirty|young} from i386, and instead use the dominating functions, ptep_clear_flush_{dirty|young}. This allows the TLB page flush to be contained in the same macro, and allows for an eager optimization - if reading the PTE initially returned dirty/accessed, we can assume the fact that no subsequent update to the PTE which cleared accessed / dirty has occurred, as the only way A/D bits can change without holding the page table lock is if a remote processor clears them. This eliminates an extra branch which came from the generic version of the code, as we know that no other CPU could have cleared the A/D bit, so the flush will always be needed. We still export these two defines, even though we do not actually define the macros in the i386 code: #define __HAVE_ARCH_PTEP_TEST_AND_CLEAR_YOUNG #define __HAVE_ARCH_PTEP_TEST_AND_CLEAR_DIRTY The reason for this is that the only use of these functions is within the generic clear_flush functions, and we want a strong guarantee that there are no other users of these functions, so we want to prevent the generic code from defining them for us. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (225 commits) [PATCH] Don't set calgary iommu as default y [PATCH] i386/x86-64: New Intel feature flags [PATCH] x86: Add a cumulative thermal throttle event counter. [PATCH] i386: Make the jiffies compares use the 64bit safe macros. [PATCH] x86: Refactor thermal throttle processing [PATCH] Add 64bit jiffies compares (for use with get_jiffies_64) [PATCH] Fix unwinder warning in traps.c [PATCH] x86: Allow disabling early pci scans with pci=noearly or disallowing conf1 [PATCH] x86: Move direct PCI scanning functions out of line [PATCH] i386/x86-64: Make all early PCI scans dependent on CONFIG_PCI [PATCH] Don't leak NT bit into next task [PATCH] i386/x86-64: Work around gcc bug with noreturn functions in unwinder [PATCH] Fix some broken white space in ia32_signal.c [PATCH] Initialize argument registers for 32bit signal handlers. [PATCH] Remove all traces of signal number conversion [PATCH] Don't synchronize time reading on single core AMD systems [PATCH] Remove outdated comment in x86-64 mmconfig code [PATCH] Use string instructions for Core2 copy/clear [PATCH] x86: - restore i8259A eoi status on resume [PATCH] i386: Split multi-line printk in oops output. ...
2006-09-26[PATCH] x86: trivial move of ptep_set_access_flagsRusty Russell
Move ptep_set_access_flags to be closer to the other ptep accessors, and make the indentation standard. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] x86: trivial move of __HAVE macros in i386 pagetable headersRusty Russell
Move the __HAVE_ARCH_PTEP defines to accompany the function definitions. Anything else is just a complete nightmare to track through the 2/3-level paging code, and this caused duplicate definitions to be needed (pte_same), which could have easily been taken care of with the asm-generic pgtable functions. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] Standardize pxx_page macrosDave McCracken
One of the changes necessary for shared page tables is to standardize the pxx_page macros. pte_page and pmd_page have always returned the struct page associated with their entry, while pte_page_kernel and pmd_page_kernel have returned the kernel virtual address. pud_page and pgd_page, on the other hand, return the kernel virtual address. Shared page tables needs pud_page and pgd_page to return the actual page structures. There are very few actual users of these functions, so it is simple to standardize their usage. Since this is basic cleanup, I am submitting these changes as a standalone patch. Per Hugh Dickins' comments about it, I am also changing the pxx_page_kernel macros to pxx_page_vaddr to clarify their meaning. Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] i386: Replace i386 open-coded cmdline parsing withRusty Russell
This patch replaces the open-coded early commandline parsing throughout the i386 boot code with the generic mechanism (already used by ppc, powerpc, ia64 and s390). The code was inconsistent with whether it deletes the option from the cmdline or not, meaning some of these will get passed through the environment into init. This transformation is mainly mechanical, but there are some notable parts: 1) Grammar: s/linux never set's it up/linux never sets it up/ 2) Remove hacked-in earlyprintk= option scanning. When someone actually implements CONFIG_EARLY_PRINTK, then they can use early_param(). [AK: actually it is implemented, but I'm adding the early_param it in the next x86-64 patch] 3) Move declaration of generic_apic_probe() from setup.c into asm/apic.h 4) Various parameters now moved into their appropriate files (thanks Andi). 5) All parse functions which examine arg need to check for NULL, except one where it has subtle humor value. AK: readded acpi_sci handling which was completely dropped AK: moved some more variables into acpi/boot.c Cc: len.brown@intel.com Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andi Kleen <ak@suse.de>
2006-04-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6David Woodhouse
2006-04-27[PATCH] x86/PAE: Fix pte_clear for the >4GB RAM caseZachary Amsden
Proposed fix for ptep_get_and_clear_full PAE bug. Pte_clear had the same bug, so use the same fix for both. Turns out pmd_clear had it as well, but pgds are not affected. The problem is rather intricate. Page table entries in PAE mode are 64-bits wide, but the only atomic 8-byte write operation available in 32-bit mode is cmpxchg8b, which is expensive (at least on P4), and thus avoided. But it can happen that the processor may prefetch entries into the TLB in the middle of an operation which clears a page table entry. So one must always clear the P-bit in the low word of the page table entry first when clearing it. Since the sequence *ptep = __pte(0) leaves the order of the write dependent on the compiler, it must be coded explicitly as a clear of the low word followed by a clear of the high word. Further, there must be a write memory barrier here to enforce proper ordering by the compiler (and, in the future, by the processor as well). On > 4GB memory machines, the implementation of pte_clear for PAE was clearly deficient, as it could leave virtual mappings of physical memory above 4GB aliased to memory below 4GB in the TLB. The implementation of ptep_get_and_clear_full has a similar bug, although not nearly as likely to occur, since the mappings being cleared are in the process of being destroyed, and should never be dereferenced again. But, as luck would have it, it is possible to trigger bugs even without ever dereferencing these bogus TLB mappings, even if the clear is followed fairly soon after with a TLB flush or invalidation. The problem is that memory above 4GB may now be aliased into the first 4GB of memory, and in fact, may hit a region of memory with non-memory semantics. These regions include AGP and PCI space. As such, these memory regions are not cached by the processor. This introduces the bug. The processor can speculate memory operations, including memory writes, as long as they are committed with the proper ordering. Speculating a memory write to a linear address that has a bogus TLB mapping is possible. Normally, the speculation is harmless. But for cached memory, it does leave the falsely speculated cacheline unmodified, but in a dirty state. This cache line will be eventually written back. If this cacheline happens to intersect a region of memory that is not protected by the cache coherency protocol, it can corrupt data in I/O memory, which is generally a very bad thing to do, and can cause total system failure or just plain undefined behavior. These bugs are extremely unlikely, but the severity is of such magnitude, and the fix so simple that I think fixing them immediately is justified. Also, they are nearly impossible to debug. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-22[PATCH] Enable mprotect on huge pagesZhang, Yanmin
2.6.16-rc3 uses hugetlb on-demand paging, but it doesn_t support hugetlb mprotect. From: David Gibson <david@gibson.dropbear.id.au> Remove a test from the mprotect() path which checks that the mprotect()ed range on a hugepage VMA is hugepage aligned (yes, really, the sense of is_aligned_hugepage_range() is the opposite of what you'd guess :-/). In fact, we don't need this test. If the given addresses match the beginning/end of a hugepage VMA they must already be suitably aligned. If they don't, then mprotect_fixup() will attempt to split the VMA. The very first test in split_vma() will check for a badly aligned address on a hugepage VMA and return -EINVAL if necessary. From: "Chen, Kenneth W" <kenneth.w.chen@intel.com> On i386 and x86-64, pte flag _PAGE_PSE collides with _PAGE_PROTNONE. The identify of hugetlb pte is lost when changing page protection via mprotect. A page fault occurs later will trigger a bug check in huge_pte_alloc(). The fix is to always make new pte a hugetlb pte and also to clean up legacy code where _PAGE_PRESENT is forced on in the pre-faulting day. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] vm: remove unused/broken page_pte[_prot] macrosTejun Heo
This patch removes page_pte_prot and page_pte macros from all architectures. Some architectures define both, some only page_pte (broken) and others none. These macros are not used anywhere. page_pte_prot(page, prot) is identical to mk_pte(page, prot) and page_pte(page) is identical to page_pte_prot(page, __pgprot(0)). * The following architectures define both page_pte_prot and page_pte arm, arm26, ia64, sh64, sparc, sparc64 * The following architectures define only page_pte (broken) frv, i386, m32r, mips, sh, x86-64 * All other architectures define neither Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] i386: little pgtable.h consolidation vs 2/3levelPaolo 'Blaisorblade' Giarrusso
Join together some common functions (pmd_page{,_kernel}) over 2level and 3level pages. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: pte_offset_map_lock loopsHugh Dickins
Convert those common loops using page_table_lock on the outside and pte_offset_map within to use just pte_offset_map_lock within instead. These all hold mmap_sem (some exclusively, some not), so at no level can a page table be whipped away from beneath them. But whereas pte_alloc loops tested with the "atomic" pmd_present, these loops are testing with pmd_none, which on i386 PAE tests both lower and upper halves. That's now unsafe, so add a cast into pmd_none to test only the vital lower half: we lose a little sensitivity to a corrupt middle directory, but not enough to worry about. It appears that i386 and UML were the only architectures vulnerable in this way, and pgd and pud no problem. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] feature removal of io_remap_page_range()Randy Dunlap
As written in Documentation/feature-removal-schedule.txt, remove the io_remap_page_range() kernel API. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: encapsulate copying of pgd entriesZachary Amsden
Add a clone operation for pgd updates. This helps complete the encapsulation of updates to page tables (or pages about to become page tables) into accessor functions rather than using memcpy() to duplicate them. This is both generally good for consistency and also necessary for running in a hypervisor which requires explicit updates to page table entries. The new function is: clone_pgd_range(pgd_t *dst, pgd_t *src, int count); dst - pointer to pgd range anwhere on a pgd page src - "" count - the number of pgds to copy. dst and src can be on the same page, but the range must not overlap and must not cross a page boundary. Note that I ommitted using this call to copy pgd entries into the software suspend page root, since this is not technically a live paging structure, rather it is used on resume from suspend. CC'ing Pavel in case he has any feedback on this. Thanks to Chris Wright for noticing that this could be more optimal in PAE compiles by eliminating the memset. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: ptep_clear optimizationZachary Amsden
Add a new accessor for PTEs, which passes the full hint from the mmu_gather struct; this allows architectures with hardware pagetables to optimize away atomic PTE operations when destroying an address space. Removing the locked operation should allow better pipelining of memory access in this loop. I measured an average savings of 30-35 cycles per zap_pte_range on the first 500 destructions on Pentium-M, but I believe the optimization would win more on older processors which still assert the bus lock on xchg for an exclusive cacheline. Update: I made some new measurements, and this saves exactly 26 cycles over ptep_get_and_clear on Pentium M. On P4, with a PAE kernel, this saves 180 cycles per ptep_get_and_clear, for a whopping 92160 cycles savings for a full address space destruction. pte_clear_full is not yet used, but is provided for future optimizations (in particular, when running inside of a hypervisor that queues page table updates, the full hint allows us to avoid queueing unnecessary page table update for an address space in the process of being destroyed. This is not a huge win, but it does help a bit, and sets the stage for further hypervisor optimization of the mm layer on all architectures. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Christoph Lameter <christoph@lameter.com> Cc: <linux-mm@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] hugetlb: add pte_huge() macroAdam Litke
This patch adds a macro pte_huge(pte) for i386/x86_64 which is needed by a patch later in the series. Instead of repeating (_PAGE_PRESENT | _PAGE_PSE), I've added __LARGE_PTE to i386 to match x86_64. Signed-off-by: Adam Litke <agl@us.ibm.com> Cc: <linux-mm@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: correct _PAGE_FILE commentPaolo 'Blaisorblade' Giarrusso
_PAGE_FILE does not indicate whether a file is in page / swap cache, it is set just for non-linear PTE's. Correct the comment for i386, x86_64, UML. Also clearify _PAGE_NONE. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] sparsemem memory model for i386Andy Whitcroft
Provide the architecture specific implementation for SPARSEMEM for i386 SMP and NUMA systems. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Martin Bligh <mbligh@aracnet.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] Hugepage consolidationDavid Gibson
A lot of the code in arch/*/mm/hugetlbpage.c is quite similar. This patch attempts to consolidate a lot of the code across the arch's, putting the combined version in mm/hugetlb.c. There are a couple of uglyish hacks in order to covert all the hugepage archs, but the result is a very large reduction in the total amount of code. It also means things like hugepage lazy allocation could be implemented in one place, instead of six. Tested, at least a little, on ppc64, i386 and x86_64. Notes: - this patch changes the meaning of set_huge_pte() to be more analagous to set_pte() - does SH4 need s special huge_ptep_get_and_clear()?? Acked-by: William Lee Irwin <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] misc verify_area cleanupsJesper Juhl
There were still a few comments left refering to verify_area, and two functions, verify_area_skas & verify_area_tt that just wrap corresponding access_ok_skas & access_ok_tt functions, just like verify_area does for access_ok - deprecate those. There was also a few places that still used verify_area in commented-out code, fix those up to use access_ok. After applying this one there should not be anything left but finally removing verify_area completely, which will happen after a kernel release or two. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: arch FIRST_USER_ADDRESS 0Hugh Dickins
Replace misleading definition of FIRST_USER_PGD_NR 0 by definition of FIRST_USER_ADDRESS 0 in all the MMU architectures beyond arm and arm26. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
