path: root/include/asm-i386/mutex.h
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-09-26[PATCH] i386: Remove lock section support in mutex.hAndi Kleen
Lock sections don't work the new dwarf2 unwinder This generates slightly smaller code. It adds one more taken jump to the fast path. Cc: jbeulich@novell.com Signed-off-by: Andi Kleen <ak@suse.de>
2006-03-23[PATCH] x86: SMP alternativesGerd Hoffmann
Implement SMP alternatives, i.e. switching at runtime between different code versions for UP and SMP. The code can patch both SMP->UP and UP->SMP. The UP->SMP case is useful for CPU hotplug. With CONFIG_CPU_HOTPLUG enabled the code switches to UP at boot time and when the number of CPUs goes down to 1, and switches to SMP when the number of CPUs goes up to 2. Without CONFIG_CPU_HOTPLUG or on non-SMP-capable systems the code is patched once at boot time (if needed) and the tables are released afterwards. The changes in detail: * The current alternatives bits are moved to a separate file, the SMP alternatives code is added there. * The patch adds some new elf sections to the kernel: .smp_altinstructions like .altinstructions, also contains a list of alt_instr structs. .smp_altinstr_replacement like .altinstr_replacement, but also has some space to save original instruction before replaving it. .smp_locks list of pointers to lock prefixes which can be nop'ed out on UP. The first two are used to replace more complex instruction sequences such as spinlocks and semaphores. It would be possible to deal with the lock prefixes with that as well, but by handling them as special case the table sizes become much smaller. * The sections are page-aligned and padded up to page size, so they can be free if they are not needed. * Splitted the code to release init pages to a separate function and use it to release the elf sections if they are unused. Signed-off-by: Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11Fix mutex_trylock() copy-and-paste bug (x86, x86-64, generic mutex-dec.h)Linus Torvalds
Noticed by Arjan originally on x86-64, then Ingo on x86, and finally me grepping for it in the generic version. Bad parenthesis nesting. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fix i386 mutex fastpath on FRAME_POINTER && !DEBUG_MUTEXESIngo Molnar
Call the mutex slowpath more conservatively - e.g. FRAME_POINTERS can change the calling convention, in which case a direct branch to the slowpath becomes illegal. Bug found by Hugh Dickins. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, add include/asm-i386/mutex.hArjan van de Ven
add the i386 version of mutex.h, optimized in assembly. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
