path: root/include/asm-i386/cpufeature.h
2006-01-11[PATCH] i386/x86-64: Generalize X86_FEATURE_CONSTANT_TSC flagAndi Kleen
Define it for i386 too. This is a synthetic flag that signifies that the CPU's TSC runs at a constant P state invariant frequency. Fix up the logic on x86-64/i386 to set it on all known CPUs. Use the AMD defined bit to set it on future AMD CPUs. Cc: venkatesh.pallipadi@intel.com Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] CPUID bug and inconsistency fixH. Peter Anvin
The recent support for K8 multicore was misported from x86-64 to i386, due to an unnecessary inconsistency between the CPUID code. Sure, there is are no x86-64 VIA chips yet, but it should happen eventually. This patch fixes the i386 bug as well as makes x86-64 match i386 in the handing of the CPUID array. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
