commit 6ee8630e02be6dd89926ca0fbc21af68b23dc087 upstream.
On architectures where a pgd entry may be shared between user and kernel
(e.g. ARM+LPAE), freeing page tables needs a ceiling other than 0.
This patch introduces a generic USER_PGTABLES_CEILING that arch code can
override. It is the responsibility of the arch code setting the ceiling
to ensure the complete freeing of the page tables (usually in
pgd_free()).
[catalin.marinas@arm.com: commit log; shift_arg_pages(), asm-generic/pgtables.h changes]
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side
struct sigaction declarations'.
flush_signal_handlers() needs to know whether sigaction::sa_restorer
is defined, not whether SA_RESTORER is defined. Define the
__ARCH_HAS_SA_RESTORER macro to indicate this.
commit 53a59fc67f97374758e63a9c785891ec62324c81 upstream.
Since commit e303297e6c3a ("mm: extended batches for generic
mmu_gather") we are batching pages to be freed until either
tlb_next_batch cannot allocate a new batch or we are done.
This works just fine most of the time but we can get in troubles with
non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY)
on large machines where too aggressive batching might lead to soft
lockups during process exit path (exit_mmap) because there are no
scheduling points down the free_pages_and_swap_cache path and so the
freeing can take long enough to trigger the soft lockup.
The lockup is harmless except when the system is setup to panic on
softlockup which is not that unusual.
The simplest way to work around this issue is to limit the maximum
number of batches in a single mmu_gather. 10k of collected pages should
be safe to prevent from soft lockups (we would have 2ms for one) even if
they are all freed without an explicit scheduling point.
This patch doesn't add any new explicit scheduling points because it
relies on zap_pmd_range during page tables zapping which calls
cond_resched per PMD.
The following lockup has been reported for 3.0 kernel with a huge
process (in order of hundreds gigs but I do know any more details).
BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053]
Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod
Supported: Yes
CPU 56
Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7
RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10
RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206
RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80
RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206
RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400
R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e
R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e
FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0
Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100)
Call Trace:
release_pages+0xc5/0x260
free_pages_and_swap_cache+0x9d/0xc0
tlb_flush_mmu+0x5c/0x80
tlb_finish_mmu+0xe/0x50
exit_mmap+0xbd/0x120
mmput+0x49/0x120
exit_mm+0x122/0x160
do_exit+0x17a/0x430
do_group_exit+0x3d/0xb0
get_signal_to_deliver+0x247/0x480
do_signal+0x71/0x1b0
do_notify_resume+0x98/0xb0
int_signal+0x12/0x17
DWARF2 unwinder stuck at int_signal+0x12/0x17
commit 0bce9c46bf3b15f485d82d7e81dabed6ebcc24b1 upstream.
ARM recently moved to asm-generic/mutex-xchg.h for its mutex
implementation after the previous implementation was found to be missing
some crucial memory barriers. However, this has revealed some problems
running hackbench on SMP platforms due to the way in which the
MUTEX_SPIN_ON_OWNER code operates.
The symptoms are that a bunch of hackbench tasks are left waiting on an
unlocked mutex and therefore never get woken up to claim it. This boils
down to the following sequence of events:
Task A Task B Task C Lock value
0 1
1 lock() 0
2 lock() 0
3 spin(A) 0
4 unlock() 1
5 lock() 0
6 cmpxchg(1,0) 0
7 contended() -1
8 lock() 0
9 spin(C) 0
10 unlock() 1
11 cmpxchg(1,0) 0
12 unlock() 1
At this point, the lock is unlocked, but Task B is in an uninterruptible
sleep with nobody to wake it up.
This patch fixes the problem by ensuring we put the lock into the
contended state if we fail to acquire it on the fastpath, ensuring that
any blocked waiters are woken up when the mutex is released.
Cc: Chris Mason <chris.mason@fusionio.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Link: http://lkml.kernel.org/n/tip-6e9lrw2avczr0617fzl5vqb8@git.kernel.org
commit e4eed03fd06578571c01d4f1478c874bb432c815 upstream.
In the x86 32bit PAE CONFIG_TRANSPARENT_HUGEPAGE=y case while holding the
mmap_sem for reading, cmpxchg8b cannot be used to read pmd contents under
Xen.
So instead of dealing only with "consistent" pmdvals in
pmd_none_or_trans_huge_or_clear_bad() (which would be conceptually
simpler) we let pmd_none_or_trans_huge_or_clear_bad() deal with pmdvals
where the low 32bit and high 32bit could be inconsistent (to avoid having
to use cmpxchg8b).
The only guarantee we get from pmd_read_atomic is that if the low part of
the pmd was found null, the high part will be null too (so the pmd will be
considered unstable). And if the low part of the pmd is found "stable"
later, then it means the whole pmd was read atomically (because after a
pmd is stable, neither MADV_DONTNEED nor page faults can alter it anymore,
and we read the high part after the low part).
In the 32bit PAE x86 case, it is enough to read the low part of the pmdval
atomically to declare the pmd as "stable" and that's true for THP and no
THP, furthermore in the THP case we also have a barrier() that will
prevent any inconsistent pmdvals to be cached by a later re-read of the
*pmd.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Jonathan Nieder <jrnieder@gmail.com>
Cc: Ulrich Obergfell <uobergfe@redhat.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Tested-by: Andrew Jones <drjones@redhat.com>
commit 26c191788f18129af0eb32a358cdaea0c7479626 upstream.
When holding the mmap_sem for reading, pmd_offset_map_lock should only
run on a pmd_t that has been read atomically from the pmdp pointer,
otherwise we may read only half of it leading to this crash.
PID: 11679 TASK: f06e8000 CPU: 3 COMMAND: "do_race_2_panic"
#0 [f06a9dd8] crash_kexec at c049b5ec
#1 [f06a9e2c] oops_end at c083d1c2
#2 [f06a9e40] no_context at c0433ded
#3 [f06a9e64] bad_area_nosemaphore at c043401a
#4 [f06a9e6c] __do_page_fault at c0434493
#5 [f06a9eec] do_page_fault at c083eb45
#6 [f06a9f04] error_code (via page_fault) at c083c5d5
EAX: 01fb470c EBX: fff35000 ECX: 00000003 EDX: 00000100 EBP:
00000000
DS: 007b ESI: 9e201000 ES: 007b EDI: 01fb4700 GS: 00e0
CS: 0060 EIP: c083bc14 ERR: ffffffff EFLAGS: 00010246
#7 [f06a9f38] _spin_lock at c083bc14
#8 [f06a9f44] sys_mincore at c0507b7d
#9 [f06a9fb0] system_call at c083becd
start len
EAX: ffffffda EBX: 9e200000 ECX: 00001000 EDX: 6228537f
DS: 007b ESI: 00000000 ES: 007b EDI: 003d0f00
SS: 007b ESP: 62285354 EBP: 62285388 GS: 0033
CS: 0073 EIP: 00291416 ERR: 000000da EFLAGS: 00000286
This should be a longstanding bug affecting x86 32bit PAE without THP.
Only archs with 64bit large pmd_t and 32bit unsigned long should be
affected.
With THP enabled the barrier() in pmd_none_or_trans_huge_or_clear_bad()
would partly hide the bug when the pmd transition from none to stable,
by forcing a re-read of the *pmd in pmd_offset_map_lock, but when THP is
enabled a new set of problem arises by the fact could then transition
freely in any of the none, pmd_trans_huge or pmd_trans_stable states.
So making the barrier in pmd_none_or_trans_huge_or_clear_bad()
unconditional isn't good idea and it would be a flakey solution.
This should be fully fixed by introducing a pmd_read_atomic that reads
the pmd in order with THP disabled, or by reading the pmd atomically
with cmpxchg8b with THP enabled.
Luckily this new race condition only triggers in the places that must
already be covered by pmd_none_or_trans_huge_or_clear_bad() so the fix
is localized there but this bug is not related to THP.
NOTE: this can trigger on x86 32bit systems with PAE enabled with more
than 4G of ram, otherwise the high part of the pmd will never risk to be
truncated because it would be zero at all times, in turn so hiding the
SMP race.
This bug was discovered and fully debugged by Ulrich, quote:
pmd_none_or_trans_huge_or_clear_bad() loads the content of edx and
eax.
496 static inline int pmd_none_or_trans_huge_or_clear_bad(pmd_t
*pmd)
497 {
498 /* depend on compiler for an atomic pmd read */
499 pmd_t pmdval = *pmd;
// edi = pmd pointer
0xc0507a74 <sys_mincore+548>: mov 0x8(%esp),%edi
// edx = PTE page table high address
0xc0507a84 <sys_mincore+564>: mov 0x4(%edi),%edx
// eax = PTE page table low address
0xc0507a8e <sys_mincore+574>: mov (%edi),%eax
Please note that the PMD is not read atomically. These are two "mov"
instructions where the high order bits of the PMD entry are fetched
first. Hence, the above machine code is prone to the following race.
- The PMD entry {high|low} is 0x0000000000000000.
The "mov" at 0xc0507a84 loads 0x00000000 into edx.
- A page fault (on another CPU) sneaks in between the two "mov"
instructions and instantiates the PMD.
- The PMD entry {high|low} is now 0x00000003fda38067.
The "mov" at 0xc0507a8e loads 0xfda38067 into eax.
Reported-by: Ulrich Obergfell <uobergfe@redhat.com>
<asm-generic/statfs.h> is exported to userspace, so using
BITS_PER_LONG is invalid. We need to use __BITS_PER_LONG instead.
This is kernel bugzilla 43165.
Reported-by: H.J. Lu <hjl.tools@gmail.com>
Link: http://lkml.kernel.org/r/1335465916-16965-1-git-send-email-hpa@linux.intel.com
Cc: <stable@vger.kernel.org>
For the particular issue of x32, which shares code with i386 in the
handling of compat_siginfo_t, the use of a 64-bit clock_t bumps the
sigchld structure out of alignment, which triggers a messy cascade of
padding.
This was already handled on the kernel compat side, but it needs
handling on the user space side, which uses the generic header. To
make that possible:
1. Allow __kernel_clock_t to be overridden in struct siginfo;
2. Allow there to be attributes added to struct siginfo.
Reported-by: H.J. Lu <hjl.rools@gmail.com>
Cc: Bruce J. Beare <bruce.j.beare@intel.com>
Link: http://lkml.kernel.org/r/CAMe9rOqF6Kh6-NK7oP0Fpzkd4SBAWU%2BG53hwBbSD4iA2UzyxuA@mail.gmail.com
Builds of the openrisc or1ksim_defconfig show the following:
In file included from arch/openrisc/include/generated/asm/cmpxchg.h:1:0,
from include/asm-generic/atomic.h:18,
from arch/openrisc/include/generated/asm/atomic.h:1,
from include/linux/atomic.h:4,
from include/linux/dcache.h:4,
from fs/notify/fsnotify.c:19:
include/asm-generic/cmpxchg.h: In function '__xchg':
include/asm-generic/cmpxchg.h:34:20: error: expected ')' before 'u8'
include/asm-generic/cmpxchg.h:34:20: warning: type defaults to 'int' in type name
and many more lines of similar errors. It seems specific to the or32
because most other platforms have an arch specific component that would
have already included types.h ahead of time, but the o32 does not.
Cc: Jonas Bonn <jonas@southpole.se>
Acked-by: David Howells <dhowells@redhat.com
Pull x32 support for x86-64 from Ingo Molnar:
"This tree introduces the X32 binary format and execution mode for x86:
32-bit data space binaries using 64-bit instructions and 64-bit kernel
syscalls.
This allows applications whose working set fits into a 32 bits address
space to make use of 64-bit instructions while using a 32-bit address
space with shorter pointers, more compressed data structures, etc."
Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c}
* 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits)
x32: Fix alignment fail in struct compat_siginfo
x32: Fix stupid ia32/x32 inversion in the siginfo format
x32: Add ptrace for x32
x32: Switch to a 64-bit clock_t
x32: Provide separate is_ia32_task() and is_x32_task() predicates
x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls
x86/x32: Fix the binutils auto-detect
x32: Warn and disable rather than error if binutils too old
x32: Only clear TIF_X32 flag once
x32: Make sure TS_COMPAT is cleared for x32 tasks
fs: Remove missed ->fds_bits from cessation use of fd_set structs internally
fs: Fix close_on_exec pointer in alloc_fdtable
x32: Drop non-__vdso weak symbols from the x32 VDSO
x32: Fix coding style violations in the x32 VDSO code
x32: Add x32 VDSO support
x32: Allow x32 to be configured
x32: If configured, add x32 system calls to system call tables
x32: Handle process creation
x32: Signal-related system calls
x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h>
Pull arch/tile (really asm-generic) update from Chris Metcalf:
"These are a couple of asm-generic changes that apply to tile."
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
compat: use sys_sendfile64() implementation for sendfile syscall
[PATCH v3] ipc: provide generic compat versions of IPC syscalls
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Pull module and param updates from Rusty Russell:
"I'm getting married next week, and then honeymoon until 6th May. I'll
be offline from next week, except to post the compulsory pictures if
Alex shaves her head..."
I'm sure Rusty can take time off from his honeymoon if something comes
up. And here's the explanation about head shaving:
http://baldalex.org/
in case you wondered and wanted to support another insane caper or
Rusty's involving shaving.
What *is* it with Rusty and shaving, anyway?
* git://github.com/rustyrussell/linux:
module: Remove module size limit
module: move __module_get and try_module_get() out of line.
params: <level>_initcall-like kernel parameters
module_param: remove support for bool parameters which are really int.
module: add kernel param to force disable module load
Pull GPIO changes for v3.4 from Grant Likely:
"Primarily gpio device driver changes with some minor side effects
under arch/arm and arch/x86. Also includes a few core changes such as
explicitly supporting (electrical) open source and open drain outputs
and some help for parsing gpio devicetree properties."
Fix up context conflict due to Laxman Dewangan adding sleep control for
the tps65910 driver separately for gpio's and regulators.
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits)
gpio/ep93xx: Remove unused inline function and useless pr_err message
gpio/sodaville: Mark broken due to core irqdomain migration
gpio/omap: fix redundant decoding of gpio offset
gpio/omap: fix incorrect update to context.irqenable1
gpio/omap: fix incorrect context restore logic in omap_gpio_runtime_*
gpio/omap: fix missing dataout context save in _set_gpio_dataout_reg
gpio/omap: fix _set_gpio_irqenable implementation
gpio/omap: fix trigger type to unsigned
gpio/omap: fix wakeup_en register update in _set_gpio_wakeup()
gpio: tegra: tegra_gpio_config shouldn't be __init
gpio/davinci: fix enabling unbanked GPIO IRQs
gpio/davinci: fix oops on unbanked gpio irq request
gpio/omap: Fix section warning for omap_mpuio_alloc_gc()
ARM: tegra: export tegra_gpio_{en,dis}able
gpio/gpio-stmpe: Fix the value returned by _get_value routine
Documentation/gpio.txt: Explain expected pinctrl interaction
GPIO: LPC32xx: Add output reading to GPO P3
GPIO: LPC32xx: Fix missing bit selection mask
gpio/omap: fix wakeups on level-triggered GPIOs
gpio/omap: Fix IRQ handling for SPARSE_IRQ
Delete all instances of asm/system.h as they should be redundant by this
point.
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
asm/system.h is a cause of circular dependency problems because it contains
commonly used primitive stuff like barrier definitions and uncommonly used
stuff like switch_to() that might require MMU definitions.
asm/system.h has been disintegrated by this point on all arches into the
following common segments:
(1) asm/barrier.h
Moved memory barrier definitions here.
(2) asm/cmpxchg.h
Moved xchg() and cmpxchg() here. #included in asm/atomic.h.
(3) asm/bug.h
Moved die() and similar here.
(4) asm/exec.h
Moved arch_align_stack() here.
(5) asm/elf.h
Moved AT_VECTOR_SIZE_ARCH here.
(6) asm/switch_to.h
Moved switch_to() here.
Split arch_align_stack() out from asm-generic/system.h into its own header of
asm-generic/exec.h as part of the asm/system.h disintegration.
Split the switch_to() wrapper out of asm-generic/system.h into its own
asm-generic/system.h as part of the asm/system.h disintegration.
to simplify disintegration of asm/system.h.
Create asm-generic/barrier.h and move the barrier definitions from
asm-generic/system.h to it.
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h as all arch
files that #include the former also #include the latter. See:
grep -rl asm-generic/cmpxchg-local[.]h arch/ | sort > b
grep -rl asm-generic/cmpxchg[.]h arch/ | sort > a
comm a b
This simplifies the disintegration of asm-generic/system.h for arches that
don't have their own.
<asm-generic/unistd.h> was set up to use sys_sendfile() for the 32-bit
compat API instead of sys_sendfile64(), but in fact the right thing to
do is to use sys_sendfile64() in all cases. The 32-bit sendfile64() API
in glibc uses the sendfile64 syscall, so it has to be capable of doing
full 64-bit operations. But the sys_sendfile() kernel implementation
has a MAX_NON_LFS test in it which explicitly limits the offset to 2^32.
So, we need to use the sys_sendfile64() implementation in the kernel
for this case.
Cc: <stable@kernel.org>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
This patch adds a set of macros that can be used to declare
kernel parameters to be parsed _before_ initcalls at a chosen
level are executed. We rename the now-unused "flags" field of
struct kernel_param as the level. It's signed, for when we
use this for early params as well, in future.
Linker macro collating init calls had to be modified in order
to add additional symbols between levels that are later used
by the init code to split the calls into blocks.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/bug.h> cleanup from Paul Gortmaker:
"The changes shown here are to unify linux's BUG support under the one
<linux/bug.h> file. Due to historical reasons, we have some BUG code
in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in
linux/kernel.h predates the addition of linux/bug.h, but old code in
kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h
was including <asm/bug.h> to pseudo link them.
This has caused confusion[1] and general yuck/WTF[2] reactions. Here
is an example that violates the principle of least surprise:
CC lib/string.o
lib/string.c: In function 'strlcat':
lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON'
make[2]: *** [lib/string.o] Error 1
$ grep linux/bug.h lib/string.c
#include <linux/bug.h>
We've included <linux/bug.h> for the BUG infrastructure and yet we
still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh -
very confusing for someone who is new to kernel development.
With the above in mind, the goals of this changeset are:
1) find and fix any include/*.h files that were relying on the
implicit presence of BUG code.
2) find and fix any C files that were consuming kernel.h and hence
relying on implicitly getting some/all BUG code.
3) Move the BUG related code living in kernel.h to <linux/bug.h>
4) remove the asm/bug.h from kernel.h to finally break the chain.
During development, the order was more like 3-4, build-test, 1-2. But
to ensure that git history for bisect doesn't get needless build
failures introduced, the commits have been reorderd to fix the problem
areas in advance.
[1] https://lkml.org/lkml/2012/1/3/90
[2] https://lkml.org/lkml/2012/1/17/414"
Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul
and linux-next.
* tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
kernel.h: doesn't explicitly use bug.h, so don't include it.
bug: consolidate BUILD_BUG_ON with other bug code
BUG: headers with BUG/BUG_ON etc. need linux/bug.h
bug.h: add include of it to various implicit C users
lib: fix implicit users of kernel.h for TAINT_WARN
spinlock: macroize assert_spin_locked to avoid bug.h dependency
x86: relocate get/set debugreg fcns to include/asm/debugreg.
Merge second batch of patches from Andrew Morton:
- various misc things
- core kernel changes to prctl, exit, exec, init, etc.
- kernel/watchdog.c updates
- get_maintainer
- MAINTAINERS
- the backlight driver queue
- core bitops code cleanups
- the led driver queue
- some core prio_tree work
- checkpatch udpates
- largeish crc32 update
- a new poll() feature for the v4l guys
- the rtc driver queue
- fatfs
- ptrace
- signals
- kmod/usermodehelper updates
- coredump
- procfs updates
* emailed from Andrew Morton <akpm@linux-foundation.org>: (141 commits)
seq_file: add seq_set_overflow(), seq_overflow()
proc-ns: use d_set_d_op() API to set dentry ops in proc_ns_instantiate().
procfs: speed up /proc/pid/stat, statm
procfs: add num_to_str() to speed up /proc/stat
proc: speed up /proc/stat handling
fs/proc/kcore.c: make get_sparsemem_vmemmap_info() static
coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMP
coredump: remove VM_ALWAYSDUMP flag
kmod: make __request_module() killable
kmod: introduce call_modprobe() helper
usermodehelper: ____call_usermodehelper() doesn't need do_exit()
usermodehelper: kill umh_wait, renumber UMH_* constants
usermodehelper: implement UMH_KILLABLE
usermodehelper: introduce umh_complete(sub_info)
usermodehelper: use UMH_WAIT_PROC consistently
signal: zap_pid_ns_processes: s/SEND_SIG_NOINFO/SEND_SIG_FORCED/
signal: oom_kill_task: use SEND_SIG_FORCED instead of force_sig()
signal: cosmetic, s/from_ancestor_ns/force/ in prepare_signal() paths
signal: give SEND_SIG_FORCED more power to beat SIGNAL_UNKILLABLE
Hexagon: use set_current_blocked() and block_sigmask()
Since we no longer need the VM_ALWAYSDUMP flag, let's use the freed bit
for 'VM_NODUMP' flag. The idea is is to add a new madvise() flag:
MADV_DONTDUMP, which can be set by applications to specifically request
memory regions which should not dump core.
The specific application I have in mind is qemu: we can add a flag there
that wouldn't dump all of guest memory when qemu dumps core. This flag
might also be useful for security sensitive apps that want to absolutely
make sure that parts of memory are not dumped. To clear the flag use:
MADV_DODUMP.
[akpm@linux-foundation.org: s/MADV_NODUMP/MADV_DONTDUMP/, s/MADV_CLEAR_NODUMP/MADV_DODUMP/, per Roland]
[akpm@linux-foundation.org: fix up the architectures which broke]
Signed-off-by: Jason Baron <jbaron@redhat.com>
Acked-by: Roland McGrath <roland@hack.frob.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Avi Kivity <avi@redhat.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Due to the alignment of following variables, these typically consume
more than just the single byte that 'bool' requires, and as there are a
few hundred instances, the cache pollution (not so much the waste of
memory) sums up. Put these variables into their own section, outside of
any half way frequently used memory range.
Do the same also to the __warned variable of rcu_lockdep_assert().
(Don't, however, include the ones used by printk_once() and alike, as
they can potentially be hot.)
Signed-off-by: Jan Beulich <jbeulich@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
Pull PCI changes (including maintainer change) from Jesse Barnes:
"This pull has some good cleanups from Bjorn and Yinghai, as well as
some more code from Yinghai to better handle resource re-allocation
when enabled.
There's also a new initcall_debug feature from Arjan which will print
out quirk timing information to help identify slow quirks for fixing
or refinement (Yinghai sent in a few patches to do just that once the
new debug code landed).
Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas.
He's been a core PCI and Linux contributor for some time now, and has
kindly volunteered to take over. I just don't feel I have the time
for PCI review and work that it deserves lately (I've taken on some
other projects), and haven't been as responsive lately as I'd like, so
I approached Bjorn asking if he'd like to manage things. He's going
to give it a try, and I'm confident he'll do at least as well as I
have in keeping the tree managed, patches flowing, and keeping things
stable."
Fix up some fairly trivial conflicts due to other cleanups (mips device
resource fixup cleanups clashing with list handling cleanup, ppc iseries
removal clashing with pci_probe_only cleanup etc)
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits)
PCI: Bjorn gets PCI hotplug too
PCI: hand PCI maintenance over to Bjorn Helgaas
unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h
sparc/PCI: convert devtree and arch-probed bus addresses to resource
powerpc/PCI: allow reallocation on PA Semi
powerpc/PCI: convert devtree bus addresses to resource
powerpc/PCI: compute I/O space bus-to-resource offset consistently
arm/PCI: don't export pci_flags
PCI: fix bridge I/O window bus-to-resource conversion
x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()'
PCI / PCIe: Introduce command line option to disable ARI
PCI: make acpihp use __pci_remove_bus_device instead
PCI: export __pci_remove_bus_device
PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge
PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device
PCI: print out PCI device info along with duration
PCI: Move "pci reassigndev resource alignment" out of quirks.c
PCI: Use class for quirk for usb host controller fixup
PCI: Use class for quirk for ti816x class fixup
PCI: Use class for quirk for intel e100 interrupt fixup
Pull x86/asm changes from Ingo Molnar
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Include probe_roms.h in probe_roms.c
x86/32: Print control and debug registers for kerenel context
x86: Tighten dependencies of CPU_SUP_*_32
x86/numa: Improve internode cache alignment
x86: Fix the NMI nesting comments
x86-64: Improve insn scheduling in SAVE_ARGS_IRQ
x86-64: Fix CFI annotations for NMI nesting code
bitops: Add missing parentheses to new get_order macro
bitops: Optimise get_order()
bitops: Adjust the comment on get_order() to describe the size==0 case
x86/spinlocks: Eliminate TICKET_MASK
x86-64: Handle byte-wise tail copying in memcpy() without a loop
x86-64: Fix memcpy() to support sizes of 4Gb and above
x86-64: Fix memset() to support sizes of 4Gb and above
x86-64: Slightly shorten copy_page()
In some cases it may happen that pmd_none_or_clear_bad() is called with
the mmap_sem hold in read mode. In those cases the huge page faults can
allocate hugepmds under pmd_none_or_clear_bad() and that can trigger a
false positive from pmd_bad() that will not like to see a pmd
materializing as trans huge.
It's not khugepaged causing the problem, khugepaged holds the mmap_sem
in write mode (and all those sites must hold the mmap_sem in read mode
to prevent pagetables to go away from under them, during code review it
seems vm86 mode on 32bit kernels requires that too unless it's
restricted to 1 thread per process or UP builds). The race is only with
the huge pagefaults that can convert a pmd_none() into a
pmd_trans_huge().
Effectively all these pmd_none_or_clear_bad() sites running with
mmap_sem in read mode are somewhat speculative with the page faults, and
the result is always undefined when they run simultaneously. This is
probably why it wasn't common to run into this. For example if the
madvise(MADV_DONTNEED) runs zap_page_range() shortly before the page
fault, the hugepage will not be zapped, if the page fault runs first it
will be zapped.
Altering pmd_bad() not to error out if it finds hugepmds won't be enough
to fix this, because zap_pmd_range would then proceed to call
zap_pte_range (which would be incorrect if the pmd become a
pmd_trans_huge()).
The simplest way to fix this is to read the pmd in the local stack
(regardless of what we read, no need of actual CPU barriers, only
compiler barrier needed), and be sure it is not changing under the code
that computes its value. Even if the real pmd is changing under the
value we hold on the stack, we don't care. If we actually end up in
zap_pte_range it means the pmd was not none already and it was not huge,
and it can't become huge from under us (khugepaged locking explained
above).
All we need is to enforce that there is no way anymore that in a code
path like below, pmd_trans_huge can be false, but pmd_none_or_clear_bad
can run into a hugepmd. The overhead of a barrier() is just a compiler
tweak and should not be measurable (I only added it for THP builds). I
don't exclude different compiler versions may have prevented the race
too by caching the value of *pmd on the stack (that hasn't been
verified, but it wouldn't be impossible considering
pmd_none_or_clear_bad, pmd_bad, pmd_trans_huge, pmd_none are all inlines
and there's no external function called in between pmd_trans_huge and
pmd_none_or_clear_bad).
if (pmd_trans_huge(*pmd)) {
if (next-addr != HPAGE_PMD_SIZE) {
VM_BUG_ON(!rwsem_is_locked(&tlb->mm->mmap_sem));
split_huge_page_pmd(vma->vm_mm, pmd);
} else if (zap_huge_pmd(tlb, vma, pmd, addr))
continue;
/* fall through */
if (pmd_none_or_clear_bad(pmd))
Because this race condition could be exercised without special
privileges this was reported in CVE-2012-1179.
The race was identified and fully explained by Ulrich who debugged it.
I'm quoting his accurate explanation below, for reference.
====== start quote =======
mapcount 0 page_mapcount 1
kernel BUG at mm/huge_memory.c:1384!
At some point prior to the panic, a "bad pmd ..." message similar to the
following is logged on the console:
mm/memory.c:145: bad pmd ffff8800376e1f98(80000000314000e7).
The "bad pmd ..." message is logged by pmd_clear_bad() before it clears
the page's PMD table entry.
143 void pmd_clear_bad(pmd_t *pmd)
144 {
-> 145 pmd_ERROR(*pmd);
146 pmd_clear(pmd);
147 }
After the PMD table entry has been cleared, there is an inconsistency
between the actual number of PMD table entries that are mapping the page
and the page's map count (_mapcount field in struct page). When the page
is subsequently reclaimed, __split_huge_page() detects this inconsistency.
1381 if (mapcount != page_mapcount(page))
1382 printk(KERN_ERR "mapcount %d page_mapcount %d\n",
1383 mapcount, page_mapcount(page));
-> 1384 BUG_ON(mapcount != page_mapcount(page));
The root cause of the problem is a race of two threads in a multithreaded
process. Thread B incurs a page fault on a virtual address that has never
been accessed (PMD entry is zero) while Thread A is executing an madvise()
system call on a virtual address within the same 2 MB (huge page) range.
virtual address space
| | |<-- B(fault)
2 MB | |/////////////////////|-.
huge < |/////////////////////| > A(range)
page | |/////////////////////|-'
- Thread A is executing an madvise(..., MADV_DONTNEED) system call
on the virtual address range "A(range)" shown in the picture.
sys_madvise
// Acquire the semaphore in shared mode.
down_read(¤t->mm->mmap_sem)
madvise_vma
switch (behavior)
case MADV_DONTNEED:
madvise_dontneed
zap_page_range
unmap_vmas
unmap_page_range
zap_pud_range
zap_pmd_range
// Assume that this huge page has never been accessed.
// I.e. content of the PMD entry is zero (not mapped).
// We don't get here due to the above assumption.
// Assume that Thread B incurred a page fault and
.---------> // sneaks in here as shown below.
| if (unlikely(pmd_bad(*pmd)))
| pmd_clear_bad
| pmd_ERROR
| // Log "bad pmd ..." message here.
| pmd_clear
| // Clear the page's PMD entry.
| // Thread B incremented the map count
| // in page_add_new_anon_rmap(), but
| // now the page is no longer mapped
| // by a PMD entry (-> inconsistency).
v
- Thread B is handling a page fault on virtual address "B(fault)" shown
in the picture.
do_page_fault
__do_page_fault
down_read_trylock(&mm->mmap_sem)
handle_mm_fault
if (pmd_none(*pmd) && transparent_hugepage_enabled(vma))
// We get here due to the above assumption (PMD entry is zero).
do_huge_pmd_anonymous_page
alloc_hugepage_vma
// Allocate a new transparent huge page here.
__do_huge_pmd_anonymous_page
spin_lock(&mm->page_table_lock)
// Here we increment the page's map count (starts at -1).
atomic_set(&page->_mapcount, 0)
set_pmd_at
// Here we set the page's PMD entry which will be cleared
// when Thread A calls pmd_clear_bad().
spin_unlock(&mm->page_table_lock)
The mmap_sem does not prevent the race because both threads are acquiring
it in shared mode (down_read). Thread B holds the page_table_lock while
the page's map count and PMD table entry are updated. However, Thread A
does not synchronize on that lock.
====== end quote =======
[akpm@linux-foundation.org: checkpatch fixes]
Cc: Dave Jones <davej@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
Cc: <stable@vger.kernel.org> [2.6.38+]
Cc: Mark Salter <msalter@redhat.com>
Linux 3.3-rc7. Merged into the gpio branch to pick up gpio bugfixes already
in mainline before queueing up move v3.4 patches
drivers/net/vmxnet3/vmxnet3_drv.c
Small vmxnet3 conflict with header size bug fix in 'net'.
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
Sync up the latest NMI fixes.
functions conditional
The problem in
commit fea80311a939a746533a6d7e7c3183729d6a3faf
Author: Randy Dunlap <rdunlap@xenotime.net>
Date: Sun Jul 24 11:39:14 2011 -0700
iomap: make IOPORT/PCI mapping functions conditional
is that if your architecture supplies pci_iomap/pci_iounmap, it expects
always to supply them. Adding empty body defitions in the !CONFIG_PCI
case, which is what this patch does, breaks the parisc compile because
the functions become doubly defined. It took us a while to spot this,
because we don't actually build !CONFIG_PCI very often (only if someone
is brave enough to test the snake/asp machines).
Since the note in the commit log says this is to fix a
CONFIG_GENERIC_IOMAP issue (which it does because CONFIG_GENERIC_IOMAP
supplies pci_iounmap only if CONFIG_PCI is set), there should actually
have been a condition upon this. This should make sure no other
architecture's !CONFIG_PCI compile breaks in the same way as parisc.
The fix had to be updated to take account of the GENERIC_PCI_IOMAP
separation.
Reported-by: Rolf Eike Beer <eike@sf-mail.de>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
drivers/net/ethernet/sfc/rx.c
Overlapping changes in drivers/net/ethernet/sfc/rx.c, one to change
the rx_buf->is_page boolean into a set of u16 flags, and another to
adjust how ->ip_summed is initialized.
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
Reported-by: Maxime Bizon <mbizon@freebox.fr>
The new get_order macro introcuded in commit
d66acc39c7cee323733c8503b9de1821a56dff7e
does not use parentheses around all uses of the parameter n.
This causes new compile warnings, for example in the
amd_iommu_init.c function:
drivers/iommu/amd_iommu_init.c:561:6: warning: suggest parentheses around comparison in operand of ‘&’ [-Wparentheses]
Fix those warnings by adding the missing parentheses.
Reported-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Link: http://lkml.kernel.org/r/1330088295-28732-1-git-send-email-joerg.roedel@amd.com
This is useful for testing RX handling of frames with bad
CRCs.
Requires driver support to actually put the packet on the
wire properly.
Signed-off-by: Ben Greear <greearb@candelatech.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
Everybody uses the generic pcibios_resource_to_bus() supplied by the core
now, so remove the ARCH_HAS_GENERIC_PCI_OFFSETS used during conversion.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
This replaces the generic versions of pcibios_resource_to_bus() and
pcibios_bus_to_resource() in asm-generic/pci.h with versions that use
pci_resource_to_bus() and pci_bus_to_resource().
The replacements are equivalent except that they can apply host
bridge window offsets when the arch has supplied them by using
pci_add_resource_offset().
Each arch can convert to using pci_add_resource_offset() individually by
removing its device resource fixups from pcibios_fixup_bus() and supplying
ARCH_HAS_GENERIC_PCI_OFFSETS. ARCH_HAS_GENERIC_PCI_OFFSETS can be removed
after all have converted.
Add a pci_clear_flags() for cases when we statically initialize
pci_flags, then decide to clear things out later.
This provides unified readq()/writeq() helper functions for 32-bit
drivers.
For some cases, readq/writeq without atomicity is harmful, and order of
io access has to be specified explicitly. So in this patch, new two
header files which contain non-atomic readq/writeq are added.
- <asm-generic/io-64-nonatomic-lo-hi.h> provides non-atomic readq/
writeq with the order of lower address -> higher address
- <asm-generic/io-64-nonatomic-hi-lo.h> provides non-atomic readq/
writeq with reversed order
This allows us to remove some readq()s that were added drivers when the
default non-atomic ones were removed in commit dbee8a0affd5 ("x86:
remove 32-bit versions of readq()/writeq()")
The drivers which need readq/writeq but can do with the non-atomic ones
must add the line:
#include <asm-generic/io-64-nonatomic-lo-hi.h> /* or hi-lo.h */
But this will be nop in 64-bit environments, and no other #ifdefs are
required. So I believe that this patch can solve the problem of
1. driver-specific readq/writeq
2. atomicity and order of io access
This patch is tested with building allyesconfig and allmodconfig as
ARCH=x86 and ARCH=i386 on top of tip/master.
Cc: Kashyap Desai <Kashyap.Desai@lsi.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Ravi Anand <ravi.anand@qlogic.com>
Cc: Vikas Chaudhary <vikas.chaudhary@qlogic.com>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Jason Uhlenkott <juhlenko@akamai.com>
Cc: James Bottomley <James.Bottomley@parallels.com>
Cc: Roland Dreier <roland@purestorage.com>
Cc: James Bottomley <jbottomley@parallels.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Signed-off-by: Hitoshi Mitake <h.mitake@gmail.com>
This one specifies where to start MSG_PEEK-ing queue data from. When
set to negative value means that MSG_PEEK works as ususally -- peeks
from the head of the queue always.
When some bytes are peeked from queue and the peeking offset is non
negative it is moved forward so that the next peek will return next
portion of data.
When non-peeking recvmsg occurs and the peeking offset is non negative
is is moved backward so that the next peek will still peek the proper
data (i.e. the one that would have been picked if there were no non
peeking recv in between).
The offset is set using per-proto opteration to let the protocol handle
the locking issues and to check whether the peeking offset feature is
supported by the protocol the socket belongs to.
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Optimise get_order() to use bit scanning instructions if such exist rather than
a loop. Also, make it possible to use get_order() in static initialisations
too by building it on top of ilog2() in the constant parameter case.
This has been tested for i386 and x86_64 using the following userspace program,
and for FRV by making appropriate substitutions for fls() and fls64(). It will
abort if the case for get_order() deviates from the original except for the
order of 0, for which get_order() produces an undefined result. This program
tests both dynamic and static parameters.
#include <stdlib.h>
#include <stdio.h>
#ifdef __x86_64__
#define BITS_PER_LONG 64
#else
#define BITS_PER_LONG 32
#endif
#define PAGE_SHIFT 12
typedef unsigned long long __u64, u64;
typedef unsigned int __u32, u32;
#define noinline __attribute__((noinline))
static inline int fls(int x)
int bitpos = -1;
asm("bsrl %1,%0"
: "+r" (bitpos)
: "rm" (x));
return bitpos + 1;
static __always_inline int fls64(__u64 x)
#if BITS_PER_LONG == 64
long bitpos = -1;
asm("bsrq %1,%0"
: "+r" (bitpos)
: "rm" (x));
return bitpos + 1;
#else
__u32 h = x >> 32, l = x;
int bitpos = -1;
asm("bsrl %1,%0 \n"
"subl %2,%0 \n"
"bsrl %3,%0 \n"
: "+r" (bitpos)
: "rm" (l), "i"(32), "rm" (h));
return bitpos + 33;
#endif
static inline __attribute__((const))
int __ilog2_u32(u32 n)
return fls(n) - 1;
int __ilog2_u64(u64 n)
return fls64(n) - 1;
extern __attribute__((const, noreturn))
int ____ilog2_NaN(void);
#define ilog2(n) \
__builtin_constant_p(n) ? ( \
(n) < 1 ? ____ilog2_NaN() : \
(n) & (1ULL << 63) ? 63 : \
(n) & (1ULL << 62) ? 62 : \
(n) & (1ULL << 61) ? 61 : \
(n) & (1ULL << 60) ? 60 : \
(n) & (1ULL << 59) ? 59 : \
(n) & (1ULL << 58) ? 58 : \
(n) & (1ULL << 57) ? 57 : \
(n) & (1ULL << 56) ? 56 : \
(n) & (1ULL << 55) ? 55 : \
(n) & (1ULL << 54) ? 54 : \
(n) & (1ULL << 53) ? 53 : \
(n) & (1ULL << 52) ? 52 : \
(n) & (1ULL << 51) ? 51 : \
(n) & (1ULL << 50) ? 50 : \
(n) & (1ULL << 49) ? 49 : \
(n) & (1ULL << 48) ? 48 : \
(n) & (1ULL << 47) ? 47 : \
(n) & (1ULL << 46) ? 46 : \
(n) & (1ULL << 45) ? 45 : \
(n) & (1ULL << 44) ? 44 : \
(n) & (1ULL << 43) ? 43 : \
(n) & (1ULL << 42) ? 42 : \
(n) & (1ULL << 41) ? 41 : \
(n) & (1ULL << 40) ? 40 : \
(n) & (1ULL << 39) ? 39 : \
(n) & (1ULL << 38) ? 38 : \
(n) & (1ULL << 37) ? 37 : \
(n) & (1ULL << 36) ? 36 : \
(n) & (1ULL << 35) ? 35 : \
(n) & (1ULL << 34) ? 34 : \
(n) & (1ULL << 33) ? 33 : \
(n) & (1ULL << 32) ? 32 : \
(n) & (1ULL << 31) ? 31 : \
(n) & (1ULL << 30) ? 30 : \
(n) & (1ULL << 29) ? 29 : \
(n) & (1ULL << 28) ? 28 : \
(n) & (1ULL << 27) ? 27 : \
(n) & (1ULL << 26) ? 26 : \
(n) & (1ULL << 25) ? 25 : \
(n) & (1ULL << 24) ? 24 : \
(n) & (1ULL << 23) ? 23 : \
(n) & (1ULL << 22) ? 22 : \
(n) & (1ULL << 21) ? 21 : \
(n) & (1ULL << 20) ? 20 : \
(n) & (1ULL << 19) ? 19 : \
(n) & (1ULL << 18) ? 18 : \
(n) & (1ULL << 17) ? 17 : \
(n) & (1ULL << 16) ? 16 : \
(n) & (1ULL << 15) ? 15 : \
(n) & (1ULL << 14) ? 14 : \
(n) & (1ULL << 13) ? 13 : \
(n) & (1ULL << 12) ? 12 : \
(n) & (1ULL << 11) ? 11 : \
(n) & (1ULL << 10) ? 10 : \
(n) & (1ULL << 9) ? 9 : \
(n) & (1ULL << 8) ? 8 : \
(n) & (1ULL << 7) ? 7 : \
(n) & (1ULL << 6) ? 6 : \
(n) & (1ULL << 5) ? 5 : \
(n) & (1ULL << 4) ? 4 : \
(n) & (1ULL << 3) ? 3 : \
(n) & (1ULL << 2) ? 2 : \
(n) & (1ULL << 1) ? 1 : \
(n) & (1ULL << 0) ? 0 : \
____ilog2_NaN() \
(sizeof(n) <= 4) ? \
__ilog2_u32(n) : \
__ilog2_u64(n) \
static noinline __attribute__((const))
int old_get_order(unsigned long size)
int order;
size = (size - 1) >> (PAGE_SHIFT - 1);
order = -1;
do {
size >>= 1;
order++;
} while (size);
return order;
int __get_order(unsigned long size)
int order;
size--;
size >>= PAGE_SHIFT;
#if BITS_PER_LONG == 32
order = fls(size);
#else
order = fls64(size);
#endif
return order;
#define get_order(n) \
(n == 0UL) ? BITS_PER_LONG - PAGE_SHIFT : \
((n < (1UL << PAGE_SHIFT)) ? 0 : \
ilog2((n) - 1) - PAGE_SHIFT + 1) \
__get_order(n) \
#define order(N) \
{ (1UL << N) - 1, get_order((1UL << N) - 1) }, \
{ (1UL << N), get_order((1UL << N)) }, \
{ (1UL << N) + 1, get_order((1UL << N) + 1) }
struct order {
unsigned long n, order;
static const struct order order_table[] = {
order(0),
order(1),
order(2),
order(3),
order(4),
order(5),
order(6),
order(7),
order(8),
order(9),
order(10),
order(11),
order(12),
order(13),
order(14),
order(15),
order(16),
order(17),
order(18),
order(19),
order(20),
order(21),
order(22),
order(23),
order(24),
order(25),
order(26),
order(27),
order(28),
order(29),
order(30),
order(31),
order(32),
order(33),
order(34),
order(35),
#endif
{ 0x2929 }
void check(int loop, unsigned long n)
unsigned long old, new;
printf("[%2d]: %09lx | ", loop, n);
old = old_get_order(n);
new = get_order(n);
printf("%3ld, %3ld\n", old, new);
if (n != 0 && old != new)
abort();
int main(int argc, char **argv)
const struct order *p;
unsigned long n;
int loop;
for (loop = 0; loop <= BITS_PER_LONG - 1; loop++) {
n = 1UL << loop;
check(loop, n - 1);
check(loop, n);
check(loop, n + 1);
for (p = order_table; p->n != 0x2929; p++) {
old = old_get_order(p->n);
new = p->order;
printf("%09lx\t%3ld, %3ld\n", p->n, old, new);
if (p->n != 0 && old != new)
abort();
return 0;
Disassembling the x86_64 version of the above code shows:
0000000000400510 <old_get_order>:
400510: 48 83 ef 01 sub $0x1,%rdi
400514: b8 ff ff ff ff mov $0xffffffff,%eax
400519: 48 c1 ef 0b shr $0xb,%rdi
40051d: 0f 1f 00 nopl (%rax)
400520: 83 c0 01 add $0x1,%eax
400523: 48 d1 ef shr %rdi
400526: 75 f8 jne 400520 <old_get_order+0x10>
400528: f3 c3 repz retq
40052a: 66 0f 1f 44 00 00 nopw 0x0(%rax,%rax,1)
0000000000400530 <__get_order>:
400530: 48 83 ef 01 sub $0x1,%rdi
400534: 48 c7 c0 ff ff ff ff mov $0xffffffffffffffff,%rax
40053b: 48 c1 ef 0c shr $0xc,%rdi
40053f: 48 0f bd c7 bsr %rdi,%rax
400543: 83 c0 01 add $0x1,%eax
400546: c3 retq
400547: 66 0f 1f 84 00 00 00 nopw 0x0(%rax,%rax,1)
40054e: 00 00
As can be seen, the new __get_order() function is simpler than the
old_get_order() function.
Link: http://lkml.kernel.org/r/20120220223928.16199.29548.stgit@warthog.procyon.org.uk
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Adjust the comment on get_order() to note that the result of passing a size of
0 results in an undefined value.
Link: http://lkml.kernel.org/r/20120220223917.16199.9416.stgit@warthog.procyon.org.uk
Introduce __kernel_[u]long_t, which allows an ABI to override all
defaults of type [unsigned] long.
This enables x32 and potentially other 32-bit userspace on 64-bit
kernel ABIs.
<asm/posix_types.h> includes a set of macros that operate on file
descriptors. Way long ago those were exported to user space, but
nowadays they are #ifdef __KERNEL__.
However, they are nothing but standard (nonatomic) bit operations, and
we already have optimized versions of bit operations in the kernel.
We can't include <linux/bitops.h> in <asm/posix_types.h> but we can
move the definitions to <linux/time.h> and define them there in terms
of standard kernel bitops.
[ v2: folds the following fixes in:
a) Stray space in __FD_SET(), reported by Andrew Morton
b) #include <linux/string.h> needed for memset(), reported by Tony Luck ]
Link: http://lkml.kernel.org/r/1328677745-20121-22-git-send-email-hpa@zytor.com
