path: root/include/asm-frv/socket.h
2007-04-25[NET]: Adding SO_TIMESTAMPNS / SCM_TIMESTAMPNS supportEric Dumazet
Now that network timestamps use ktime_t infrastructure, we can add a new SOL_SOCKET sockopt SO_TIMESTAMPNS. This command is similar to SO_TIMESTAMP, but permits transmission of a 'timespec struct' instead of a 'timeval struct' control message. (nanosecond resolution instead of microsecond) Control message is labelled SCM_TIMESTAMPNS instead of SCM_TIMESTAMP A socket cannot mix SO_TIMESTAMP and SO_TIMESTAMPNS : the two modes are mutually exclusive. sock_recv_timestamp() became too big to be fully inlined so I added a __sock_recv_timestamp() helper function. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: linux-arch@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[AF_UNIX]: Datagram getpeersecCatherine Zhang
This patch implements an API whereby an application can determine the label of its peer's Unix datagram sockets via the auxiliary data mechanism of recvmsg. Patch purpose: This patch enables a security-aware application to retrieve the security context of the peer of a Unix datagram socket. The application can then use this security context to determine the security context for processing on behalf of the peer who sent the packet. Patch design and implementation: The design and implementation is very similar to the UDP case for INET sockets. Basically we build upon the existing Unix domain socket API for retrieving user credentials. Linux offers the API for obtaining user credentials via ancillary messages (i.e., out of band/control messages that are bundled together with a normal message). To retrieve the security context, the application first indicates to the kernel such desire by setting the SO_PASSSEC option via getsockopt. Then the application retrieves the security context using the auxiliary data mechanism. An example server application for Unix datagram socket should look like this: toggle = 1; toggle_len = sizeof(toggle); setsockopt(sockfd, SOL_SOCKET, SO_PASSSEC, &toggle, &toggle_len); recvmsg(sockfd, &msg_hdr, 0); if (msg_hdr.msg_controllen > sizeof(struct cmsghdr)) { cmsg_hdr = CMSG_FIRSTHDR(&msg_hdr); if (cmsg_hdr->cmsg_len <= CMSG_LEN(sizeof(scontext)) && cmsg_hdr->cmsg_level == SOL_SOCKET && cmsg_hdr->cmsg_type == SCM_SECURITY) { memcpy(&scontext, CMSG_DATA(cmsg_hdr), sizeof(scontext)); } } sock_setsockopt is enhanced with a new socket option SOCK_PASSSEC to allow a server socket to receive security context of the peer. Testing: We have tested the patch by setting up Unix datagram client and server applications. We verified that the server can retrieve the security context using the auxiliary data mechanism of recvmsg. Signed-off-by: Catherine Zhang <cxzhang@watson.ibm.com> Acked-by: Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Introduce SO_{SND,RCV}BUFFORCE socket optionsPatrick McHardy
Allows overriding of sysctl_{wmem,rmrm}_max Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
