path: root/include/asm-frv/pci.h
2007-07-11PCI: remove pci_dac_dma_... APIsJan Beulich
Based on replies to a respective query, remove the pci_dac_dma_...() APIs (except for pci_dac_dma_supported() on Alpha, where this function is used in non-DAC PCI DMA code). Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <ak@suse.de> Cc: Jesse Barnes <jesse.barnes@intel.com> Cc: Christoph Hellwig <hch@infradead.org> Acked-by: David Miller <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: Use a weak symbol for the empty version of pcibios_add_platform_entries()Michael Ellerman
I'm not sure if this is going to fly, weak symbols work on the compilers I'm using, but whether they work for all of the affected architectures I can't say. I've cc'ed as many arch maintainers/lists as I could find. But assuming they do, we can use a weak empty definition of pcibios_add_platform_entries() to avoid having an empty definition on every arch. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-08[PATCH] frv: miscellaneous changesDavid Howells
Fix a number of miscellanous items: (1) Declare lock sections in the linker script. (2) Recurse in the correct manner in the arch makefile. (3) asm/bug.h requires asm/linkage.h to be included first. One C file puts asm/bug.h first. (4) Add an empty RTC header file to avoid missing header file errors. (5) sg_dma_address() should use the dma_address member of a scatter list. (6) Add trivial pci_unmap support. (7) Add pgprot_noncached() (8) Discard u_quad_t. (9) Use ~0UL rather than ULONG_MAX in unistd.h in case the latter isn't declared. (10) Add an empty VGA header file to avoid missing header file errors. (11) Add an XOR header file to use the generic XOR stuff. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: dma-mapping (frv)Al Viro
2005-06-27[PATCH] PCI: fix up errors after dma bursting patch and CONFIG_PCI=nAndrew Morton
With CONFIG_PCI=n: In file included from include/linux/pci.h:917, from lib/iomap.c:6: include/asm/pci.h:104: warning: `enum pci_dma_burst_strategy' declared inside parameter list include/asm/pci.h:104: warning: its scope is only this definition or declaration, which is probably not what you want. include/asm/pci.h: In function `pci_dma_burst_advice': include/asm/pci.h:106: dereferencing pointer to incomplete type include/asm/pci.h:106: `PCI_DMA_BURST_INFINITY' undeclared (first use in this function) include/asm/pci.h:106: (Each undeclared identifier is reported only once include/asm/pci.h:106: for each function it appears in.) make[1]: *** [lib/iomap.o] Error 1 Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] PCI: DMA bursting adviceDavid S. Miller
After seeing, at best, "guesses" as to the following kind of information in several drivers, I decided that we really need a way for platforms to specifically give advice in this area for what works best with their PCI controller implementation. Basically, this new interface gives DMA bursting advice on PCI. There are three forms of the advice: 1) Burst as much as possible, it is not necessary to end bursts on some particular boundary for best performance. 2) Burst on some byte count multiple. A DMA burst to some multiple of number of bytes may be done, but it is important to end the burst on an exact multiple for best performance. The best example of this I am aware of are the PPC64 PCI controllers, where if you end a burst mid-cacheline then chip has to refetch the data and the IOMMU translations which hurts performance a lot. 3) Burst on a single byte count multiple. Bursts shall end exactly on the next multiple boundary for best performance. Sparc64 and Alpha's PCI controllers operate this way. They disconnect any device which tries to burst across a cacheline boundary. Actually, newer sparc64 PCI controllers do not have this behavior. That is why the "pdev" is passed into the interface, so I can add code later to check which PCI controller the system is using and give advice accordingly. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
