path: root/include/asm-blackfin
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (58 commits) ide: remove ide_init_default_irq() macro ide: move default IDE ports setup to ide_generic host driver ide: remove obsoleted "idex=noprobe" kernel parameter (take 2) ide: remove needless hwif->irq check from ide_hwif_configure() ide: init hwif->{io_ports,irq} explicitly in legacy VLB host drivers ide: limit legacy VLB host drivers to alpha, x86 and mips cmd640: init hwif->{io_ports,irq} explicitly cmd640: cleanup setup_device_ptrs() ide: add ide-4drives host driver (take 3) ide: remove ppc ifdef from init_ide_data() ide: remove ide_default_io_ctl() macro ide: remove CONFIG_IDE_ARCH_OBSOLETE_INIT ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2) ppc/pmac: remove no longer needed IDE quirk ppc: don't include <linux/ide.h> ppc: remove ppc_ide_md ppc/pplus: remove ppc_ide_md.ide_init_hwif hook ppc/sandpoint: remove ppc_ide_md hooks ppc/lopec: remove ppc_ide_md hooks ppc/mpc8xx: remove ppc_ide_md hooks ...
2008-04-18ide: remove ide_default_io_ctl() macroBartlomiej Zolnierkiewicz
It is always == '((base) + 0x206)' if CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=y and it is not needed otherwise (arm, blackfin, parisc, ppc64, sh, sparc[64]). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-05[Blackfin] arch: current_l1_stack_save is a pointer, so use NULL rather than 0Mike Frysinger
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-03-06[Blackfin] arch: to kill syscalls missing warning by adding new timerfd syscallsBryan Wu
2008-02-02[Blackfin] serial driver: Add flow control support to bf54xSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-02-02[Blackfin] serial driver: Fix bug Poll RTS/CTS status in DMA mode as wellSonic Zhang
https://blackfin.uclinux.org/gf/project/uclinux-dist/tracker/?action=TrackerItemEdit&tracker_item_id=3858 Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-12-24[Blackfin] serial driver: rework break flood anomaly handling to be more ↵Mike Frysinger
robust/realistic about what we can actually work around Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-12-24[Blackfin] serial driver: fix bug - cache the bits of the LSR on systems ↵Mike Frysinger
where the LSR is read-to-clear Cache the bits of the LSR on systems where the LSR is read-to-clear so that we can safely read the LSR in random places. this fixes older parts where break/framing/parity/overflow was not being detected at all in PIO mode, and this fixes newer parts where break/framing/parity/overflow was being reported all the time without being cleared. Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-02-25[Blackfin] arch: add bfin_clear_PPIx_STATUS() helper funcs like we have for ↵Mike Frysinger
other parts Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-02-25[Blackfin] arch: make sure we have proper description/copyright/license linesMike Frysinger
2008-02-25[Blackfin] arch: Fix CONFIG_PM support for BF561Michael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-02-25[Blackfin] arch: Cleanup abd Simplify:Michael Hennerich
- Simplify init_arch_irq - Make code more readable - Remove useless SSYNCs - Fix comments Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-02-09Add pgtable_t to remaining nommu architecturesMartin Schwidefsky
The pte_fn_t in include/linux/mm.h make it necessary for all architectures to define a pgtable_t type, even those that do not have an mmu. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09[Blackfin] arch: import defines for BF547 -- it is just like the BF548, but ↵Mike Frysinger
no CAN Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-02-09[Blackfin] arch: Encourage users to use the spidev character driver: Provide ↵Michael Hennerich
platform support - Enable kernel generic spidev driver for blackfin SPI ADC - spi_adc driver, document and test sample not synced Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-02-02[Blackfin] arch: Enable UART2 and UART3 for bf548Sonic Zhang
2008-02-02[Blackfin] arch: remove duplicated definitions of the line discipline ↵Tilman Schmidt
numbers N_* in asm-blackfin/termios.h The definitions of the line discipline numbers N_* have been moved from asm-*/termios.h to linux/tty.h, but the Blackfin architecture has somehow evaded that move. Bring it in line with the others. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-02-02[Blackfin] arch: change the trace buffer control start/stop logic in the ↵Mike Frysinger
exception handlers To save/restore the trace buffer control so that if we take an exception after turning off the trace buffer at a higher level we dont inadvertently turn the trace buffer back on Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-02-09[Blackfin] arch: hook up set_irq_wake in Blackfin's irq codeMichael Hennerich
- Add support for irq_wake on system and gpio interrupts - Remove outdated kernel options - Add option to select default PM mode - Fix various places where SIC_IWRx was only handled partially Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-02-09[Blackfin] arch: Merge BF561 support into ints-priorityMichael Hennerich
Merge single core ints-priority-sc.c and dual core ints-priority-dc.c into one common code ints-priority.c Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-02-02[Blackfin] arch: fix bug: redefinition warning when compile EZKIT548Bryan Wu
2008-02-08asm-*/posix_types.h: scrub __GLIBC__Mike Frysinger
Some arches (like alpha and ia64) already have a clean posix_types.h header. This brings all the others in line by removing all references to __GLIBC__ (and some undocumented __USE_ALL). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: move STACK_TOP[_MAX] to asm/processor.hDavid Howells
Move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Add cmpxchg_local to blackfin, replace __cmpxchg by generic cmpxchgMathieu Desnoyers
Use the new generic cmpxchg_local (disables interrupt). Also use the generic cmpxchg as fallback if SMP is not set since nobody seems to know why __cmpxchg has been implemented in assembly in the first place thather than in plain C. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Michael Frysinger <michael.frysinger@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Sanitize the type of struct user.u_ar0H. Peter Anvin
struct user.u_ar0 is defined to contain a pointer offset on all architectures in which it is defined (all architectures which define an a.out format except SPARC.) However, it has a pointer type in the headers, which is pointless -- <asm/user.h> is not exported to userspace, and it just makes the code messy. Redefine the field as "unsigned long" (which is the same size as a pointer on all Linux architectures) and change the setting code to user offsetof() instead of hand-coded arithmetic. Cc: Linux Arch Mailing List <linux-arch@vger.kernel.org> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Håvard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Cleanup asm/{elf,page,user}.h: #ifdef __KERNEL__ is no longer neededKirill A. Shutemov
asm/elf.h, asm/page.h and asm/user.h don't export to userspace now, so we can drop #ifdef __KERNEL__ for them. [k.shutemov@gmail.com: remove #ifdef __KERNEL_] Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06remove mm_{ptov,vtop}()Adrian Bunk
This patch removes the unused mm_{ptov,vtop}(). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Bryan Wu <bryan.wu@analog.com> Cc: Miles Bader <miles.bader@necel.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[NET]: Introducing socket mark socket option.Laszlo Attila Toth
A userspace program may wish to set the mark for each packets its send without using the netfilter MARK target. Changing the mark can be used for mark based routing without netfilter or for packet filtering. It requires CAP_NET_ADMIN capability. Signed-off-by: Laszlo Attila Toth <panther@balabit.hu> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-27[Blackfin] arch: remove old I2C BF54x porting.Bryan Wu
2008-01-27[Blackfin] arch: Add the semtimedop syscall. Upstream uClibc doesn't ↵Bernd Schmidt
compile without it. Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-01-22[Blackfin] arch: GPIO API cleanup and anomaly updateMichael Hennerich
- Add anomaly workaround for bfin_gpio_reset_spi0_ssel1 - Fix style - Update copyright - Remove BUG_ON checks for functions intended to be used only by arch support. GPIO users should only access using the generic GPIO API - Make all GPIO identifier unsigned int Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-01-22[Blackfin] arch: Fix BUG gpio_direction_output API is not compatitable with ↵Michael Hennerich
GENERIC_GPIO API interface signef-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-01-27[Blackfin] arch: Initial checkin of the memory protection support.Bernd Schmidt
Enable it with CONFIG_MPU. Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-01-22[Blackfin] arch: set_bfin_dma_config shouldnt set SYNC or RESTART by default ↵Michael Hennerich
- add argument or option Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-12-24[Blackfin] arch: update to latest anomaly sheetsMike Frysinger
2007-12-24[Blackfin] arch: Fix gpio label handlingMichael Hennerich
early serial init also utilizes the peripheral request api - however at this point bfin_gpio_init didn't allocate memory for the labels. So we always have two zombies (allocated pin functions without labels) This happens before the initcalls - We now allocate memory statically. Define MAX_RESOURCES individually for each cpu. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-12-24[Blackfin] arch: fix up coding style in uaccess.hBernd Schmidt
2008-01-27[Blackfin] arch: Fix bug to Enable bf548 to Re-program Clocks while Kernel ↵Sonic Zhang
boots. Reprogram DDR EBIU register properly for bf548. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-12-23[Blackfin] arch: Clean up dump_bfin_memRobin Getz
Clean up dump_bfin_mem so that it will display content from the kernel, as well as l1 instruction, when deferred HW errors happen, print out the last frame info if it makes sense. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-12-23[Blackfin] arch: Fix bug to Enable kernel to build for bf548 with PM.Sonic Zhang
On BF548-EZKIT, build kernel faills with power management, video and audio enabled. This patch fix this. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-12-21[Blackfin] arch: fix bug SDIO driver fails to build for BF542/BF548Cliff Cai
modified CMD_TIMEOUT and DAT_TIMEOUT to CMD_TIME_OUT and DAT_TIME_OUT Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-01-27[Blackfin] arch: fix bug - trap_tests fails to recover on some tests.Robin Getz
http://blackfin.uclinux.org/gf/project/uclinux-dist/tracker/?action=TrackerItemEdit&tracker_item_id=3719 When the CPLBs get a miss, we do: - find a victim in the HW table - remove the victim - find the replacement in the software table - put it into the HW table. If we can't find a replacement in the software table, we accidently leave a duplicate in the HW table. This patch ensures that duplicate is marked as not valid. What we should do is find the replacement in the software table, before we find a victim in the HW table - but its too late in the release cycle to do that much restructuring of this code. Rather that duplicate code, connect Hardware Errors (irq5) into trap_c, so user space processes get killed properly. The rest of irq_panic() can be moved into traps.c (later) There is still a small corner case that causes problems when a pheriperal interrupt goes off a single cycle before a user space hardware error. This causes a kernel panic, rather than the user space process being killed. But, this checkin makes things work in 99.9% of the cases, and is a vast improvement from what is there today (which fails 100% of the time). Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-12-05Blackfin SPI driver: move hard coded pin_req to board fileBryan Wu
Remove some sort of bloaty code, try to get these pin_req arrays built at compile-time - move this static things to the blackfin board file - add pin_req array to struct bfin5xx_spi_master - tested on BF537/BF548 with SPI flash Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05spi: spi_bfin: update handling of delay-after-deselectBryan Wu
Move cs_chg_udelay handling (specific to this driver) to cs_deactive(), fixing a bug when some SPI LCD driver needs delay after cs_deactive. Fix bug reported by Cameron Barfield <cbarfield@cyberdata.net> https://blackfin.uclinux.org/gf/project/uclinux-dist/forum/?action=ForumBrowse&forum_id=39&_forum_action=ForumMessageBrowse&thread_id=23630&feedback=Message%20replied. Cc: Cameron Barfield <cbarfield@cyberdata.net> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05spi: bfin spi uses portmux callsMichael Hennerich
Use new Blackfin portmux interface, add error handling. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05spi: initial BF54x SPI supportBryan Wu
Initial BF54x SPI support - support BF54x SPI0 - clean up some code (whitespace etc) - will support multiports in the future - start using portmux calls Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-21Blackfin arch: split apart dump_bfin_regs and merge/remove show_regs from ↵Mike Frysinger
process.c, which was largely duplicated Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-11-21Blackfin arch: Ensure we printk out strings with the proper loglevelRobin Getz
