Some arches (like alpha and ia64) already have a clean posix_types.h header.
This brings all the others in line by removing all references to __GLIBC__
(and some undocumented __USE_ALL).
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: Roland McGrath <roland@redhat.com>
Cc: <linux-arch@vger.kernel.org>
Move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're
required whether or not A.OUT format is available.
Use the new generic cmpxchg_local (disables interrupt). Also use the generic
cmpxchg as fallback if SMP is not set since nobody seems to know why __cmpxchg
has been implemented in assembly in the first place thather than in plain C.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Bryan Wu <bryan.wu@analog.com>
Cc: Michael Frysinger <michael.frysinger@analog.com>
struct user.u_ar0 is defined to contain a pointer offset on all
architectures in which it is defined (all architectures which define an
a.out format except SPARC.) However, it has a pointer type in the headers,
which is pointless -- <asm/user.h> is not exported to userspace, and it
just makes the code messy.
Redefine the field as "unsigned long" (which is the same size as a pointer
on all Linux architectures) and change the setting code to user offsetof()
instead of hand-coded arithmetic.
Cc: Linux Arch Mailing List <linux-arch@vger.kernel.org>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Håvard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
asm/elf.h, asm/page.h and asm/user.h don't export to userspace now, so we can
drop #ifdef __KERNEL__ for them.
[k.shutemov@gmail.com: remove #ifdef __KERNEL_]
Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com>
Reviewed-by: David Woodhouse <dwmw2@infradead.org>
This patch removes the unused mm_{ptov,vtop}().
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Greg Ungerer <gerg@uclinux.org>
Acked-by: Bryan Wu <bryan.wu@analog.com>
Cc: Miles Bader <miles.bader@necel.com>
A userspace program may wish to set the mark for each packets its send
without using the netfilter MARK target. Changing the mark can be used
for mark based routing without netfilter or for packet filtering.
It requires CAP_NET_ADMIN capability.
Signed-off-by: Laszlo Attila Toth <panther@balabit.hu>
Acked-by: Patrick McHardy <kaber@trash.net>
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
compile without it.
Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com>
- Add anomaly workaround for bfin_gpio_reset_spi0_ssel1
- Fix style
- Update copyright
- Remove BUG_ON checks for functions intended to be used only by arch
support. GPIO users should only access using the generic GPIO API
- Make all GPIO identifier unsigned int
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
GENERIC_GPIO API interface
signef-off-by: Michael Hennerich <michael.hennerich@analog.com>
Enable it with CONFIG_MPU.
- add argument or option
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com>
early serial init also utilizes the peripheral request api - however
at this point bfin_gpio_init didn't allocate memory for the labels.
So we always have two zombies (allocated pin functions without labels)
This happens before the initcalls - We now allocate memory statically.
Define MAX_RESOURCES individually for each cpu.
boots.
Reprogram DDR EBIU register properly for bf548.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Clean up dump_bfin_mem so that it will display
content from the kernel, as well as l1 instruction, when deferred
HW errors happen, print out the last frame info if it makes sense.
Signed-off-by: Robin Getz <robin.getz@analog.com>
On BF548-EZKIT, build kernel faills with power management, video and audio enabled.
This patch fix this.
modified CMD_TIMEOUT and DAT_TIMEOUT to CMD_TIME_OUT and DAT_TIME_OUT
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
http://blackfin.uclinux.org/gf/project/uclinux-dist/tracker/?action=TrackerItemEdit&tracker_item_id=3719
When the CPLBs get a miss, we do:
- find a victim in the HW table
- remove the victim
- find the replacement in the software table
- put it into the HW table.
If we can't find a replacement in the software table, we accidently
leave a duplicate in the HW table. This patch ensures that duplicate
is marked as not valid.
What we should do is find the replacement in the software table, before
we find a victim in the HW table - but its too late in the release cycle
to do that much restructuring of this code.
Rather that duplicate code, connect Hardware Errors (irq5) into trap_c,
so user space processes get killed properly.
The rest of irq_panic() can be moved into traps.c (later)
There is still a small corner case that causes problems when a
pheriperal interrupt goes off a single cycle before a user space
hardware error. This causes a kernel panic, rather than the user
space process being killed.
But, this checkin makes things work in 99.9% of the cases, and is a vast
improvement from what is there today (which fails 100% of the time).
Remove some sort of bloaty code, try to get these pin_req arrays built at compile-time
- move this static things to the blackfin board file
- add pin_req array to struct bfin5xx_spi_master
- tested on BF537/BF548 with SPI flash
Cc: David Brownell <david-b@pacbell.net>
Move cs_chg_udelay handling (specific to this driver) to cs_deactive(), fixing
a bug when some SPI LCD driver needs delay after cs_deactive.
Fix bug reported by Cameron Barfield <cbarfield@cyberdata.net>
https://blackfin.uclinux.org/gf/project/uclinux-dist/forum/?action=ForumBrowse&forum_id=39&_forum_action=ForumMessageBrowse&thread_id=23630&feedback=Message%20replied.
Cc: Cameron Barfield <cbarfield@cyberdata.net>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Use new Blackfin portmux interface, add error handling.
Initial BF54x SPI support
- support BF54x SPI0
- clean up some code (whitespace etc)
- will support multiports in the future
- start using portmux calls
process.c, which was largely duplicated
common sound code otherwise
Should not need separate cplb entry though as we cover L1 with a 4 meg page
- remove duplicated defines for the BF561
- generalize L2 support (so that it works for BF54x) and mark it executable
- add support for reading/executing the Boot ROM sections
(since it has data/functions we may need at runtime)
- and fixup names for each map
- no need to declare their sizes in the common header
- no need to tack on the section attribute as only the definition matters, not references
L1_SCRATCH defines
Anomaly 05000312 - Errors When SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted:
DESCRIPTION:
When instruction cache is enabled, erroneous behavior may occur when any of the following instructions are interrupted:
. CSYNC
• SSYNC
• LCx =
• LTx = (only when LCx is non-zero)
• LBx = (only when LCx is non-zero)
When this problem occurs, a variety of incorrect things could happen, including an illegal instruction exception. Additional errors could
show up as an exception, a hardware error, or an instruction that is valid but different than the one that was expected.
WORKAROUND:
Place a cli before all SSYNC, CSYNC, "LCx =", "LTx =", and "LBx =" instructions to disable interrupts, and place an sti after each of these
instructions to re-enable interrupts. When these instructions are executed in code that is already non-interruptible, the problem will not
occur.
and export it
defined
assembly.
Signed-off-by: Jie Zhang <jie.zhang@analog.com>
* CPUs often take a performance hit when accessing unaligned memory
* locations. The actual performance hit varies, it can be small if the
* hardware handles it or large if we have to take an exception and fix
* it
* in software.
* Since an ethernet header is 14 bytes network drivers often end up
* with
* the IP header at an unaligned offset. The IP header can be aligned by
* shifting the start of the packet by 2 bytes. Drivers should do this
* with:
* skb_reserve(NET_IP_ALIGN);
* The downside to this alignment of the IP header is that the DMA is
* now
* unaligned. On some architectures the cost of an unaligned DMA is high
* and this cost outweighs the gains made by aligning the IP header.
* Since this trade off varies between architectures, we allow
* NET_IP_ALIGN
* to be overridden.
This new function insl_16 allows to read form 32-bit IO and writes to
16-bit aligned memory. This is useful in above described scenario -
In particular with the AXIS AX88180 Gigabit Ethernet MAC.
Once the device is in 32-bit mode, reads from the RX FIFO always
decrements 4bytes.
While on the other side the destination address in SDRAM is always
16-bit aligned.
If we use skb_reserve(0) the receive buffer is 32-bit aligned but later
we hit a unaligned exception in the IP code.
The only user is the a.out support.
It was therefore removed prior to the blackfin merge from all
architectures not supporting a.out.
Currently, Blackfin doesn't suppport a.out.
VDSP has double fault on core a/b inverted for BF561 -- bit 11 is core a while bit 12 is core b
since we have this always turned on now and dont want it off (and hasnt been an option in a while)
double faults in either core
to do bad things.
Fix/change formatting of a few more things.
Timer API
