path: root/include/asm-avr32/kdebug.h
2007-05-13[AVR32] optimize pagefault pathChristoph Hellwig
Avoid the costly notifier list in the pagefault path and call the kprobes code directly. The same change went into the 2.6.22 cycle for powerpc, 2s390 and sparc64 already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] avr32 architectureHaavard Skinnemoen
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000 CPU and the AT32STK1000 development board. AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption and high code density. The AVR32 architecture is not binary compatible with earlier 8-bit AVR architectures. The AVR32 architecture, including the instruction set, is described by the AVR32 Architecture Manual, available from http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It features a 7-stage pipeline, 16KB instruction and data caches and a full Memory Management Unit. It also comes with a large set of integrated peripherals, many of which are shared with the AT91 ARM-based controllers from Atmel. Full data sheet is available from http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf while the CPU core implementation including caches and MMU is documented by the AVR32 AP Technical Reference, available from http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf Information about the AT32STK1000 development board can be found at http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918 including a BSP CD image with an earlier version of this patch, development tools (binaries and source/patches) and a root filesystem image suitable for booting from SD card. Alternatively, there's a preliminary "getting started" guide available at http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links to the sources and patches you will need in order to set up a cross-compiling environment for avr32-linux. This patch, as well as the other patches included with the BSP and the toolchain patches, is actively supported by Atmel Corporation. [dmccr@us.ibm.com: Fix more pxx_page macro locations] [bunk@stusta.de: fix `make defconfig'] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
