path: root/include/asm-avr32/atomic.h
2008-08-05avr32: Move include/asm-avr32 to arch/avr32/include/asmHaavard Skinnemoen
Leaving include/asm/arch alone for now. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2007-07-18[AVR32] Fix atomic_add_unless() and atomic_sub_unless()Haavard Skinnemoen
These functions depend on "result" being initalized to 0, but "result" is not included as an input constraint to the inline assembly block following its initialization, only as an output constraint. Thus gcc thinks it doesn't need to initialize it, so result ends up undefined if the "unless" condition is true. This fixes an oops in sunrpc where the faulty atomics caused rpciod_up() to not start the workqueue as it should. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-27avr32: remove unneeded cast in atomic.hMathieu Desnoyers
This int cast is superfluous since system.h cmpxchg already casts it in (typeof(*(ptr))). Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-25[PATCH] AVR32: Fix oversize immediates in atomic.hHaavard Skinnemoen
When calling e.g. atomic_sub_return with a large constant, the compiler may output an immediate that is too large for the sub instruction in the middle of the loop. Fix this by explicitly specifying the number of bits allowed in the constraint. Also stop atomic_add_return() and friends from falling back to their respective "sub" variants if the constant is too large to fit in an immediate. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] avr32 architectureHaavard Skinnemoen
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000 CPU and the AT32STK1000 development board. AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption and high code density. The AVR32 architecture is not binary compatible with earlier 8-bit AVR architectures. The AVR32 architecture, including the instruction set, is described by the AVR32 Architecture Manual, available from http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It features a 7-stage pipeline, 16KB instruction and data caches and a full Memory Management Unit. It also comes with a large set of integrated peripherals, many of which are shared with the AT91 ARM-based controllers from Atmel. Full data sheet is available from http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf while the CPU core implementation including caches and MMU is documented by the AVR32 AP Technical Reference, available from http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf Information about the AT32STK1000 development board can be found at http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918 including a BSP CD image with an earlier version of this patch, development tools (binaries and source/patches) and a root filesystem image suitable for booting from SD card. Alternatively, there's a preliminary "getting started" guide available at http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links to the sources and patches you will need in order to set up a cross-compiling environment for avr32-linux. This patch, as well as the other patches included with the BSP and the toolchain patches, is actively supported by Atmel Corporation. [dmccr@us.ibm.com: Fix more pxx_page macro locations] [bunk@stusta.de: fix `make defconfig'] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
