path: root/include/asm-arm
2008-05-23[ARM] fix OMAP include loopsRussell King
OMAP has two include loops in its header files: asm-arm/hardware.h <- asm-arm/arch-omap/io.h <- asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h asm-arm/arch-omap/board-palmte.h <- asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h <- asm-arm/arch-omap/gpio.h <- asm-arm/arch-omap/board-palmte.h Circular include dependencies are dangerous since they can result in inconsistent definitions being provided to other code, especially if '#ifndef' constructs are used. Solve these by removing the offending includes, and add additional includes where necessary. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-23[ARM] 5053/1: define before use of processor_idGreg Ungerer
For the simple read_cpuid() macro case the variable processor_id has no definition on use of the macro. Add an extern for it. Move all the processor ID macros into the #ifndef __ASSEMBLEY__ block. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-23[ARM] 5051/1: define pgtable_t for the !CONFIG_MMU case tooGreg Ungerer
The non-MMU case also needs the type definition of pgtable_t. So move it out of a CONFIG_MMU conditional section. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-22[ARM] omap: fix omap clk support build errorsRussell King
arch/arm/plat-omap/clock.c:397: warning: "struct cpufreq_frequency_table" declared inside parameter list arch/arm/plat-omap/clock.c:397: warning: its scope is only this definition or declaration, which is probably not what you want arch/arm/plat-omap/clock.c: In function `clk_init_cpufreq_table': arch/arm/plat-omap/clock.c:402: error: structure has no member named `clk_init_cpufreq_table' arch/arm/plat-omap/clock.c:403: error: structure has no member named `clk_init_cpufreq_table' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-22[ARM] 5025/2: fix collie cpu initialisationThomas Kunze
collie.h: * add some meaningfull names to some gpios collie.c: * initialize cpu registers correctly Signed-off-by: Thomas Kunze <thommycheck@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-17Merge branch 'omap-fixes' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
2008-05-17Merge branch 'sa1100'Russell King
2008-05-17[ARM] fix parenthesis in include/asm-arm/arch-omap/control.hMariusz Kozlowski
Parenthesis fix in include/asm-arm/arch-omap/control.h Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-17[ARM] 5026/1: locomo: add .settype for gpio and several small fixesThomas Kunze
irqs.h: * rename IRQ_LOCOMO_SPI_OVRN to IRQ_LOCOMO_SPI_REND locomo.h: * add some definition for locomo spi controller * correct some errors locomo.c: * correct some errors * add set_type for locomo gpio irq chip Signed-off-by: Thomas Kunze <thommycheck@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-09ARM: OMAP: Add calls to omap2_set_globals_*()Paul Walmsley
Add the omap2_set_globals_{242x,243x,343x}() functions. These functions are called early upon boot in the map_io() functions in the board-specific init files. This patch was accidentally left out of the earlier series. This fixes omap2 booting as noted by Kyungmin Park <kmpark@infradead.org>. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-05-09ARM: OMAP: Update MMC header to fix compileTony Lindgren
Update MMC header from linux-omap tree to match the recent MMC driver updates. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-05-08[ARM] pxa: Fix RCSR handlingRussell King
Related to d3930614e68bdf83a120d904c039a64e9f75dba1. RCSR is only present on PXA2xx CPUs, not on PXA3xx CPUs. Therefore, we should not be unconditionally writing to RCSR from generic code. Since we now clear the RCSR status from the SoC specific PXA PM code and before reset in the arch_reset() function, the duplication in the corgi, poodle, spitz and tosa code can be removed. Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-04[ARM] 5027/1: Fixed random memory corruption on pxa suspend cycle.Robert Jarzmik
Each time a pxa type cpu went in suspend, a portion of kmalloc memory was corrupted. The issue was an incorrect length allocation introduced by the commit 711be5ccfe9a02ba560aa918a008c31ea4760163 for the save registers array (=> overflow). Signed-off-by: Robert Jarzmik <rjarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-02arm: types: use <asm-generic/int-*.h> for the arm architectureH. Peter Anvin
This modifies <asm-arm/types.h> to use the <asm-generic/int-*.h> generic include files. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Ben Dooks <ben-linux@fluff.org>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30pxafb: preliminary smart panel interface supportEric Miao
Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30pxafb: introduce register independent LCD connection type for pxafberic miao
Reasons: 1. straight forward: the name "LCD_COLOR_DSTN_16BPP" is much better than "LCCR0_Pas | LCCR0_Color | LCCR0_Dual" 2. by defining LCD connection types as constants, it allows only valid possibilities 3. by removing the dependency of register bits definitions, those can be later moved into the body of pxafb.c, instead of having a regs-lcd.h around Currently, only lubbock, mainstone, zylonite and littleton have been modified to support these types (see coming patches after this). Other platforms are encouraged to change their way describing the LCD controller connections. Signed-off-by: eric miao <eric.miao@marvell.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30pxafb: convert fb driver to use ioremap() and __raw_{readl, writel}eric miao
This is part of the effort moving peripheral registers outside of pxa-regs.h, and using ioremap() make it possible the same IP can be re-used on different processors with different registers space As a result, the fixed mapping in pxa_map_io() is removed. The regs-lcd.h can actually moved to where closer to pxafb.c but some of its bit definitions are directly used by various platform code, though this is not a good style. Signed-off-by: eric miao <eric.miao@marvell.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (26 commits) [ARM] pxa: fix 1c104e0e4f6ab396960c058e95e18bdedcac945b [ARM] serial: s3c2410: platform_get_irq() may return signed unnoticed [ARM] am79c961a: platform_get_irq() may return signed unnoticed [ARM] Feroceon: Feroceon-specific WA-cache compatible {copy,clear}_user_page() [ARM] Feroceon: fix function alignment in proc-feroceon.S [ARM] Orion: catch a couple more alternative spellings of PCIe [ARM] Orion: fix orion-ehci platform resource end addresses [ARM] Orion: fix ->map_irq() PCIe bus number check [ARM] Orion: fix ioremap() optimization [ARM] feroceon: remove CONFIG_CPU_CACHE_ROUND_ROBIN check [ARM] feroceon: remove CONFIG_CPU_DCACHE_WRITETHROUGH check kprobes/arm: fix decoding of arithmetic immediate instructions kprobes/arm: fix cache flush address for instruction stub [ARM] 5022/1: Race in ARM MMCI PL18x driver, V2 [ARM] 5021/1: at91: buildfix for sam9263 + PM [ARM] 5018/1: RealView: Fix the ARM11MPCore Oprofile compilation [ARM] 5016/1: AT91: typo in mci configuration for at91cap at91sam9263 [ARM] 5017/1: pxa3xx: Report unsupported wakeup sources in pxa3xx_set_wake() [ARM] 5020/1: magician: remove __devinit marker from pasic3_leds_info [ARM] 5014/1: Cleanup reset state before entering suspend or resetting. ...
2008-04-29Merge branch 'orion-fixes2'Russell King
2008-04-29Merge branches 'pxa' and 'orion-fixes1'Russell King
2008-04-29kernel: Move arches to use common unaligned accessHarvey Harrison
Unaligned access is ok for the following arches: cris, m68k, mn10300, powerpc, s390, x86 Arches that use the memmove implementation for native endian, and the byteshifting for the opposite endianness. h8300, m32r, xtensa Packed struct for native endian, byteshifting for other endian: alpha, blackfin, ia64, parisc, sparc, sparc64, mips, sh m86knommu is generic_be for Coldfire, otherwise unaligned access is ok. frv, arm chooses endianness based on compiler settings, uses the byteshifting versions. Remove the unaligned trap handler from frv as it is now unused. v850 is le, uses the byteshifting versions for both be and le. Remove the now unused asm-generic implementation. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28[ARM] Feroceon: Feroceon-specific WA-cache compatible {copy,clear}_user_page()Lennert Buytenhek
This patch implements a set of Feroceon-specific {copy,clear}_user_page() routines that perform more optimally than the generic implementations. This also deals with write-allocate caches (Feroceon can run L1 D in WA mode) which otherwise prevents Linux from booting. [nico: optimized the code even further] Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Sylver Bruneau <sylver.bruneau@googlemail.com> Tested-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-04-28[ARM] Orion: fix ioremap() optimizationNicolas Pitre
The ioremap() optimization used for internal register didn't cope with the fact that paddr + size can wrap to zero if the area extends to the end of the physical address space. Issue isolated by Sylver Bruneau <sylver.bruneau@googlemail.com>. Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27ide: add struct ide_io_ports (take 3)Bartlomiej Zolnierkiewicz
* Add struct ide_io_ports and use it instead of `unsigned long io_ports[]` in ide_hwif_t. * Rename io_ports[] in hw_regs_t to io_ports_array[]. * Use un-named union for 'unsigned long io_ports_array[]' and 'struct ide_io_ports io_ports' in hw_regs_t. * Remove IDE_*_OFFSET defines. v2: * scc_pata.c build fix from Stephen Rothwell. v3: * Fix ctl_adrr typo in Sparc-specific part of ns87415.c. (Noticed by Andrew Morton) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-24[ARM] 5014/1: Cleanup reset state before entering suspend or resetting.Dmitry Baryshkov
The kernel should clean stale bits from reset status, so that they won't confuse the bootloader. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-24[ARM] 5013/1: Change ITE8152 interrupt numbersMike Rapoport
The patch kills the use of IRQ_GPIO() and adds #if NR_IRQS < (IT8152_LAST_IRQ+1) statement. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-22[MTD] [NAND] S3C2410 Allow ECC disable to be specified by the boardBen Dooks
Add support to disable ECC checking for a given chip when passed by the board via the platform data. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] [NAND] S3C2410 Allow ECC layout to be passed through platform dataBen Dooks
Add support for the ECC layout to be passed via the platform data specified by the board. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] [NAND] S3C2410 Allow unset ecc to be ignored for ecc correctionBen Dooks
If a block's ecc field is all 0xff, then ignore the ECC correction. This is for systems where some of the blocks, such as the initial cramfs are written without ECC and need to be loaded on start. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] [NAND] support for pxa3xxeric miao
This is preliminary since: 1. It supports only _one_ chip select at the moment. As there is no existing platforms available using two chip selects of the NAND controller, it shall really not include code for supporting the 2nd chip select for now, as such code cannot be verified. 2. It resorts to the default and simpliest memory based badblock table 3. Only limited types of nand flash are currently supported. Most PXA3xx processors come with on-chip NAND flash dies, so there isn't much flexibility for other types of NAND. 4. The NAND controller should be configured to detect the device's ID, thus making it difficult to use nand_scan_ident() to assist the detection process (though it's not impossible) TODO: fix all the above limitations of cuz :-) Signed-off-by: eric miao <eric.miao@marvell.com> Cc: Sergey Podstavin <spodstavin@ru.mvista.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (26 commits) mmc: sdio_ops.c should #include "sdio_ops.h" mmc: proper prototypes for mmc_attach_*() mmc: make __mmc_release_bus() static sdhci: improve no card, no reset quirk MMC: OMAP: Do not busy wait for end of command for ever MMC: OMAP: Start new commands from work queue instead of irq MMC: OMAP: Lazy clock shutdown MMC: OMAP: Move failing command abortion to workqueue MMC: OMAP: Use tasklet instead of workqueue for cover switch notification MMC: OMAP: Check the get_cover_state function pointer if not set MMC: OMAP: Using setup_timer instead of init_timer MMC: OMAP: Abort stuck commands MMC: OMAP: General cleanup for MMC multislot support MMC: OMAP: Power functions modified to MMC multislot support MMC: OMAP: Fix timeout calculation for MMC multislot support MMC: OMAP: New release dma and abort xfer functions MMC: OMAP: Add back cover switch support MMC: OMAP: Introduce new multislot structure and change driver to use it MMC: OMAP: Remove cover switch handling to allow adding multislot support MMC: OMAP: Fix the BYTEBLOCK capability removal ...
git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial: (24 commits) DOC: A couple corrections and clarifications in USB doc. Generate a slightly more informative error msg for bad HZ fix typo "is" -> "if" in Makefile ext*: spelling fix prefered -> preferred DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs. KEYS: Fix the comment to match the file name in rxrpc-type.h. RAID: remove trailing space from printk line DMA engine: typo fixes Remove unused MAX_NODES_SHIFT MAINTAINERS: Clarify access to OCFS2 development mailing list. V4L: Storage class should be before const qualifier (sn9c102) V4L: Storage class should be before const qualifier sonypi: Storage class should be before const qualifier intel_menlow: Storage class should be before const qualifier DVB: Storage class should be before const qualifier arm: Storage class should be before const qualifier ALSA: Storage class should be before const qualifier acpi: Storage class should be before const qualifier firmware_sample_driver.c: fix coding style MAINTAINERS: Add ati_remote2 driver ... Fixed up trivial conflicts in firmware_sample_driver.c
2008-04-21arm: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-04-21[ARM] 5009/1: magician: remove to-be-deprecated defines for pxa_gpio_modePhilipp Zabel
Alternate function and direction setting is now handled by the MFP config code or the generic GPIO API. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19Merge branch 'merge-fixes' into develRussell King
2008-04-19Merge branch 'omap2-upstream' into develRussell King
2008-04-19Merge branches 'arm', 'at91', 'ep93xx', 'iop', 'ks8695', 'misc', 'mxc', ↵Russell King
'ns9x', 'orion', 'pxa', 'sa1100', 's3c' and 'sparsemem' into devel
2008-04-19[ARM] pxa: V4L2 soc_camera driver for PXA270Guennadi Liakhovetski
This patch adds a driver for the Quick Capture Interface on the PXA270. It is based on the original driver from Intel, but has been re-worked multiple times since then, now it also supports the V4L2 API. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4988/1: Add GPIO lib support to the EP93xxRyan Mallon
Adds support for the generic GPIO lib to the EP93xx family. The gpio handling code has been moved from core.c to a new file called gpio.c. The GPIO based IRQ code has not been changed. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] Add initial sparsemem supportRussell King
2008-04-19[ARM] 5002/1: tosa: add two more ledsDmitry Baryshkov
This adds support for two more leds: the wlan one (found in SL-6000W and SL-6000L) and the blutooth one (found in SL-6000W). Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 5004/1: Tosa: make several unreferenced structures static.Dmitry Baryshkov
Now that scoop gpio's are converted to generic_gpio, tosascoop_device and tosascoop_jc_device don't have to be exported. Also make tosa_gpio_* static Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4976/1: zylonite: Configure GPIO for WM9713 IRQ lineMark Brown
Set up the IRQ line for the WM9713 device on the Zylonite. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4973/1: Tosa: use leds-gpio driver.Dmitry Baryshkov
Now as the scoop pins are covered by the generic gpio API, we can use leds-gpio driver instead of special leds-tosa. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4972/1: Tosa: convert scoop GPIOs usage to generic gpio codeDmitry Baryshkov
Convert set/reset_scoop_gpio to generic gpio calls. This patch depends on the pxaficp_ir hooks patch. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4971/1: pxaficp_ir: provide startup and shutdown hooksDmitry Baryshkov
Let platform do some specific initialisation and cleanup things during pxaficp_ir probing and removing. E.g. this can be usefull to request/free gpios used by the platform to control the transceiver. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4959/1: PXA: Fix misprint in CICR1_RGBT_CONVMike Rapoport
This patch fixes misprint in definition of CICR1_RGBT_CONV in include/asm-arm/arch-pxa/pxa-regs.h Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4952/1: magician: add LCD detection, LCD power switching, update pxafb ↵Philipp Zabel
settings All magician devices I've encountered so far have featured the Toppoly TD028STEB1 display, so the Samsung LTP280QV support is untested. The power-on sequence is not correct because pxafb doesn't yet support enabling the LCD controller in the middle of the it. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
