path: root/include/asm-arm26/system.h
2006-07-14[PATCH] remove set_wmb - arch removalSteven Rostedt
set_wmb should not be used in the kernel because it just confuses the code more and has no benefit. Since it is not currently used in the kernel this patch removes it so that new code does not include it. All archs define set_wmb(var, value) to do { var = value; wmb(); } while(0) except ia64 and sparc which use a mb() instead. But this is still moot since it is not used anyway. Hasn't been tested on any archs but x86 and x86_64 (and only compiled tested) Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-02-01[PATCH] arm26: drop first arg of prepare_arch_switch, finish_arch_switchAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] arm26: drop local task_running copyAlexey Dobriyan
2006-01-12[PATCH] arm26: task_thread_info()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] sched: add cacheflush() asmIngo Molnar
Add per-arch sched_cacheflush() which is a write-back cacheflush used by the migration-cost calibration code at bootup time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
