This modifies <asm-arm/types.h> to use the <asm-generic/int-*.h>
generic include files.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on
32bit targets.
GCC can be made to warn about usage of long long types with ISO C90
(-ansi), but only with -pedantic. You can write this in a way that even
then it doesn't cause warnings, namely by:
#ifdef __GNUC__
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
#endif
The __extension__ keyword in front of this switches off any pedantic
warnings for this expression.
Signed-off-by: Olaf Hering <olh@suse.de>
Cc: <linux-arch@vger.kernel.org>
This is used only in slab.c and each architecture gets to define whcih
underlying type is to be used.
Seems a bit silly - move it to slab.c and use the same type for all
architectures: unsigned int.
infrastructure for it.
Let it rip!
