path: root/include/asm-arm/semaphore.h
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2007-10-17kill DECLARE_MUTEX_LOCKEDChristoph Hellwig
DECLARE_MUTEX_LOCKED was used for semaphores used as completions and we've got rid of them. Well, except for one in libusual that the maintainer explicitly wants to keep as semaphore. So convert that useage to an explicit sema_init and kill of DECLARE_MUTEX_LOCKED so that new code is reminded to use a completion. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: "Satyam Sharma" <satyam.sharma@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-12-01[ARM] sema_count() removalArthur Othieno
sema_count() defined only for ARM but not used anywhere. Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-30[PATCH] semaphore: Remove __MUTEX_INITIALIZER()Arthur Othieno
__MUTEX_INITIALIZER() has no users, and equates to the more commonly used DECLARE_MUTEX(), thus making it pretty much redundant. Remove it for good. Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
