path: root/include/asm-arm/arch-l7200/hardware.h
2006-04-07[ARM] Move FLUSH_BASE macros to asm/arch/memory.hRussell King
FLUSH_BASE must be visible to arch/arm/mm/init.c in order for the memory region to be setup. Move these definitions from asm-arm/arch-*/hardware.h into asm-arm/arch-*/memory.h where mm stuff can see them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
