path: root/include/asm-arm/arch-iop33x
2006-09-25[ARM] 3832/1: iop3xx: coding style cleanupLennert Buytenhek
Since the iop32x code isn't iop321-specific, and the iop33x code isn't iop331-specfic, do a s/iop321/iop32x/ and s/iop331/iop33x/, and tidy up the code to conform to the coding style guidelines somewhat better. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3831/1: iop3xx: factor out common register definesLennert Buytenhek
Factor out the register defines for a number of other peripherals common to the iop32x and iop33x. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3830/1: iop3xx: board support file cleanupLennert Buytenhek
Revamp the iop3xx board support: move the support code for each iop board type into its own file, start using platform serial and platform physmap flash devices, switch to a per-board time tick rate, and get rid of the ARCH_EP80219 and STEPD config options by doing the relevant checks at run time. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3829/1: iop3xx: optimise irq entry macrosLennert Buytenhek
Squeeze three instructions out of the iop32x irq demuxer, and nine out of the iop33x irq demuxer by using the hardware vector generator. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3827/1: iop3xx: add common gpio moduleLennert Buytenhek
Implement the gpio_line_{config,get,set} API for iop3xx. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3826/1: iop3xx: remove IOP3??_IRQ_OFS irq offsetLennert Buytenhek
Get rid of the unused IOP3??_IRQ_OFS irq offset define, start IRQ numbering from zero. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3825/1: iop3xx: use cp6 enable/disable macrosLennert Buytenhek
Add CP6 enable/disable sequences to the timekeeping code and the IRQ code. As a result, we can't depend on CP6 access being enabled when we enter get_irqnr_and_base anymore, so switch the latter over to using memory-mapped accesses for now. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3823/1: iop3xx: switch iop32x/iop33x over to shared time codeLennert Buytenhek
Switch the iop32x and iop33x code over to the common time implementation, and remove the (nearly identical) iop32x and iop33x time implementations. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3822/1: iop3xx: rewrite time handlingLennert Buytenhek
Merge and rewrite the iop32x/iop33x time code to do lost jiffy tracking properly, and put the result in plat-iop/time.c. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3821/1: iop3xx: switch iop32x/iop33x over to shared pci codeLennert Buytenhek
Switch the iop32x and iop33x code over to the common PCI implementation, and remove the (nearly identical) iop32x and iop33x PCI implementations. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3819/1: iop3xx: factor out shared i2c codeLennert Buytenhek
Move the i2c bits shared between iop32x and iop33x to plat-iop/i2c.c and include/asm-arm/hardware/iop3xx.h. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3818/1: iop3xx: introduce arch/arm/plat-iop for shared iop32x/iop33x codeLennert Buytenhek
Introduce the arch/arm/plat-iop directory, for code shared between the iop32x and iop33x, and move the common memory map setup bits there. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3817/1: iop3xx: split the iop3xx mach into iop32x and iop33xLennert Buytenhek
Split the iop3xx mach type into iop32x and iop33x -- split the config symbols, and move the code in the mach-iop3xx directory to the mach-iop32x and mach-iop33x directories. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
